Post by jsteiger on Jul 24, 2015 14:50:46 GMT -6
Crap. That's like my 2nd one in a week. I better be careful 'round hereya It's pretty clear he believes the Litz wire has an audible effect and PW mentions an 80khz peak that extends in to the audio spectrum. You think he means it's such a broad curve that it affects the audio all the way down to where we can hear it? No I don't think it would be that wide but more harmonics/undertones.
Post by tonycamphd on Jul 24, 2015 14:55:07 GMT -6
yes, those harmonics head up and down.
On a side note, after you live with these for a bit, you can really hear the diffs between opamps if you're paying attention IME, the diffs aren't huge, but they are definitely there, i'm curious about the Litzwire now of course, i'm also a firm believer that this is a game of inches.
Post by jsteiger on Jul 24, 2015 14:57:56 GMT -6
yes, those harmonics head up and down. On a side note, after you live with these for a bit, you can really hear the diffs between opamps if you're paying attention IME, the diffs aren't huge, but they are definitely there, i'm curious about the Litzwire now of course, i'm also a firm believer that this is a game of inches. T, you may be the only guy I know that can hear 80kHz. Seriously, I am very curious to see what you think of the Litz trafo's. You really have great ears and seem to hear at a different level than most folks.
Post by noah shain on Jul 24, 2015 15:04:42 GMT -6
yes, those harmonics head up and down. On a side note, after you live with these for a bit, you can really hear the diffs between opamps if you're paying attention IME, the diffs aren't huge, but they are definitely there, i'm curious about the Litzwire now of course, i'm also a firm believer that this is a game of inches. Yeah I'm excited to get some samples up for you to hear.
Post by tonycamphd on Jul 24, 2015 16:09:26 GMT -6
well..... haha, but even in jest, i really appreciate the vote of confidence JS 8) I seriously need to round out the drum capturing pre's in here, so a pair of VP25's with some big ole 2503 Litz's are around the corner, and another pair of Vp28's are on my short list, i will def opt for the litzwires on those as well, and do comparisons to my other Vp28 pre's once i getem going.
Post by Guitar on Jul 24, 2015 19:23:09 GMT -6
That's interesting to me that it's a winding scheme, not just a type of wire, as I had initially assumed. Maybe that makes a little more sense than the audiophile kind of "better cable" thing.
I'd like to get a few of these on hand... approved by the American Dental Association. I want to taste them myself darn it.
Nobody knows but I've got plans to fill out this 10 space lunchbox before I die.
Post by jsteiger on Jul 24, 2015 19:32:20 GMT -6
Yes its very interesting.
Part science. Part voodoo.
Post by guitfiddler on Jul 24, 2015 20:16:14 GMT -6
Damn you Jeff, forcing me to buy your products. Is that another infraction John? I'm sure that 251 will pair good with a vp28! I can't wait! Lol
Post by tonycamphd on Jul 24, 2015 20:23:54 GMT -6
Funny u say that, the more I creep toward understanding a bit about audio electronics, the more tubes and transformers seem like voodoo with their rather significant impact on sound, spooky!
Post by noah shain on Aug 7, 2015 18:46:06 GMT -6
I got the modded channels back from Jeff today and put them straight to work.
I'm uploading files to a server now. I'll post the link here when they're up.
This is a hybrid mix running out a JCF Audio Latte to 2 channels of the console using the channel inserts, aca groups, 2bus insert and a big helping of outboard gear. A few transformers in line and back in to the JCF. It's not my production, just my mix. It's a self financed, independent band. Low budget work. I doubt they'd mind me posting. We'll keep it just between us;) This is a decidedly un-scientific test and you may need to do some level matching. I did. Happy to answer any questions.
Post by noah shain on Aug 7, 2015 18:56:03 GMT -6
Post by noah shain on Aug 7, 2015 19:09:17 GMT -6
BTW it's not quite a final mix! Don't judge me!
Post by jsteiger on Aug 7, 2015 19:35:12 GMT -6
Thanks Noah! This will be great to get some opinions from folks. So everyone knows (if you give a rats ass!), here is what I did. 1. Replaced the mic input transformer with a EA2622. The stock one was label as a BT-115K-E. Not sure who makes it. I was told CineMag makes their inputs these days but the can was not marked as such. No manufacturer tag was present. Had to parallel the primaries since the stock trafo was paralleled internally. 2. Removed the 162k R from after the input and replaced it with a 220pF -> 10k series R which is the recommended zobel for a EA2622. There is a 162k load R just before the preamp opamp so the rest of the mic circuit is pretty similar to its vintage counterpart. 3. Physically lowered the .1µF local power rail decoupling caps for both 2520 positions. They use the z leads. The 2520's have gigantic extra long pins so the caps needed to be lowered for the more common shorter pins that Scott and Gary use. 4. Removed/lowered the 68pF feedback cap for the output opamp. 5. Removed the 56pF feedback cap for the preamp stage and replaced with a 82pF. A little less bandwidth and more on track with my vintage board. Some may disagree but we were tying to get closer to the vintage console. 6. Removed all 4 of the 330µF Panasonic bipolar coupling caps from the 2520 outputs. These were bypassed with .1µF film caps which I also removed. Replaced the 330µF's with BC/Vishay 470µF's. The nice expensive ones that most folks use when recapping old Neve's or API's. These are the same AML 138's that I use in most of my kits. The small bypass caps were left out. They were never used in the vintage boards. We are after vintage not hifi. 7. Removed the 100Ω that was in parallel with the 2nd stage output coupling cap. This is used in many API circuits but not in the vintage console channels so ixnay. 8. Replaced both stock 2520's with SL-2520 red dot's from the man, Scott Liebers. sll9. Replaced both stock output trafo's with the Litz 2623-1's. And that was it.
Post by tonycamphd on Aug 7, 2015 19:36:40 GMT -6
so everything's exactly the same except you ran it into a pair of litzwire channel strips?
edit; posted this 1 sec after Jeff's post 8)
first thing i noticed was the sweet compression i here in the old school api stuff, friggin awesome Jeff, the unmodded track is slightly hotter in level, I want to listen a bit more now....
Post by tonycamphd on Aug 7, 2015 20:16:30 GMT -6
I imported the files and level matched them in a PT session of the same rate, both tracks don't even come close to nulling each other out, there are pretty substantial differences to my ears...,
So the modded track has that sweet compression i mentioned earlier, the depth is pretty equal, but by a smidge the modern API has more low end extension and more width than the modded. But so what, the modded has balls and in your face image detail and presence that the other isn't even flirting with, and that's exactly what makes me love the vintage api stuff, it sounds like a record already on Jeff's modded version, while the modern API sounds a bit carved out, unfocused and hollow by comparison to my ears. Anyone hearing the same thing?
I need to listen again and focus in on the top a little more now haha.
Post by Johnkenn on Aug 7, 2015 20:36:59 GMT -6
Gonna download in a bit...
Post by Johnkenn on Aug 7, 2015 21:47:27 GMT -6
Man...I thought the modded channel version had more separation between instruments. More definition. And I thought the modded version had a good bit more depth. Here's the best way I can explain what I hear. In the beginning with the vocals...in the modded file it sounds like the center is hitting me with and then washing out over me. This sounds silly, but a wider center and you can hear the snare hit and then it move out to the sides with the verb...In comparison, the un-modded file sounds a little flat.
Post by Johnkenn on Aug 7, 2015 21:47:45 GMT -6
No I feel like I want to go watch "The Breakfast Club" for some weird reason...
Post by jeromemason on Aug 7, 2015 22:59:29 GMT -6
Leaving thoughts as I'm toggling between them at the same places in the song.....
The modded is most definitely smoother on the top end, I'd say in the 5k-7k area.
Most definitely has some natural compression happening that is extremely smooth
Sounds like some distortion has been removed on the modded channels as well
I almost want to say that I feel as though the cross talk between the modded channels has improved, I feel like I can sense the vocal's area better on the modded version
The lowend on the modded channels is much more settled, not nearly as pumpy to me.
There is just a slight improvement in the transient response, splitting hairs with that one, but the modded channels handle the transients in a more finished way,
I don't know if I can say that I hear anything extended in the lowend.... it's just handled better. We are talking about a stereo mix going through 2 channels, if this were spread out the benefits that I'm hearing would have a very large improvement over the entire mix. I would imagine there would be much more depth because like I said there seems to be more separation between the channels and a more defined center. If that were spread across the whole console I would imagine Noah mixing would be easier with less eq to carve out some of the build up in the middle. Overall like I said, this is two channels so I'd say all these changes are slight, but if it were over 16 channels I think there would be a very very nice and enhanced depth and staging. I bet your verbs and delays would have a much more defined tail, your drums would be much more open and you'd be grabbing the upper mid/high eq knob much less.
Great job Jeff, I can hear the vintage element you were going for, it's subtle over two channels but if I were Noah I would have this done to all my channels asap.
Just my .02
Post by jsteiger on Aug 8, 2015 8:16:44 GMT -6
Correct me if I am wrong noah shain, but you were running into the 'line input" for test captures? I would imagine there will be a much more noticeable difference once the mic input trafo's come into play. Track something for us!
Post by tonycamphd on Aug 8, 2015 10:23:23 GMT -6
Upon further listening, the difference in the solidity and density of the images is most striking! jsteiger can you explain the diffs you heard from stock to mod? I imagine having the before and afts in your own mad scientist dungeon would be extremely revealing? I never really though about getting a newer 1608 and having it modded by you? It's a bit out of my league really, it's kinda like buying a Mustang and giving it to Carroll Shelby for mods haha. same Q to noah shain
Post by jsteiger on Aug 8, 2015 10:47:45 GMT -6
Well, I had no way to power and test the modules since the pinout would be nearly impossible to figure out without a schemo. I told Noah I was a bit worried about carrying out the mod's without being able to test them. I just went with grandma's recipe. It has never failed me yet!
Too bad one can't order a stripped down input module from them.
Post by jeromemason on Aug 8, 2015 10:59:41 GMT -6
Correct me if I am wrong noah shain, but you were running into the 'line input" for test captures? I would imagine there will be a much more noticeable difference once the mic input trafo's come into play. Track something for us! What if he pulled the signal way down on the way in or used the pads and ran the mix through the mic section?
Post by jsteiger on Aug 8, 2015 11:12:23 GMT -6
Correct me if I am wrong noah shain, but you were running into the 'line input" for test captures? I would imagine there will be a much more noticeable difference once the mic input trafo's come into play. Track something for us! What if he pulled the signal way down on the way in or used the pads and ran the mix through the mic section? That was a mod I wanted to look at but the relay and signal routing is a little tough without a schemo. There are a plethora of 10mil tracks running around like mad. The mic pad won't be great since the input Z will be low. The best way is a u-pad before the mic in of the desk.
Post by jeromemason on Aug 8, 2015 11:54:11 GMT -6
Sure are a lot of relays that's for sure.... I don't see how you'd trace all that w/o a skim....So you were talking about putting a mod in so he could potentially route the line inputs through the input trafo?
That would had been a cool little feature for sure.
