Post by kcatthedog on Nov 14, 2021 17:34:38 GMT -6
I have always gotten along fine with ilok, until today, trying to get everything authorized for my new m1 mini: pita.
Post by javamad on Nov 15, 2021 2:28:26 GMT -6
I work in software (not in audio unfortunately) but with the amount of hacking that goes on I fully respect UADs decision to lock their software in with some third party security. Especially with all the resources they are putting to the LUNAverse (see what I did there? :-) ) which is free but requiring the use of their products.
Imagine that all you had to do was have an Apollo connected … someone could create a cracked version of LUNA that just skipped that check.
On the audio software 3rd party license validation market, iLok is a major player so it makes sense they would choose them. I have not had many issues at all with iLok except for Logic at startup asking me to activate old trial/demos … a real pain.
Post by Drew @ UA on Nov 15, 2021 6:58:12 GMT -6
Hi skav, Happy to answer any specific questions you might have. Quote this post with them. I've got a quick one.. I bought UAD to get away from the multi-authorisation pain so why do you need Ilok for Luna when you have a UA interface (which essentially does the same thing)?! Rather avoid Ilok and use Logic. Using Pace protects our IP and keeps users from "sharing" Extensions and Instruments.
Post by kcatthedog on Nov 15, 2021 8:38:55 GMT -6
Be very hard pressed not to buy Precision K now that it’s on sale: part of UA’s secret Sauce. It doesn’t get a lot of attention, which surprises me: even the default will expand your mixes soundstage: subtlety, but apparently in a good way.
Post by Drew @ UA on Nov 15, 2021 10:05:30 GMT -6
Be very hard pressed not to buy Precision K now that it’s on sale: part of UA’s secret Sauce. It doesn’t get a lot of attention, which surprises me: even the default will expand your mixes soundstage: subtlety, but apparently in a good way. Indeed, see here:
Post by Johnkenn on Nov 15, 2021 10:20:28 GMT -6
Always seem to prefer something like the Manley Vari Mu in M/S
Post by kcatthedog on Nov 15, 2021 10:40:05 GMT -6
Fair enuff, Manley is another fav comp, but VM does no ambience recovery: they are very different beasts.
Post by ShadowK on Nov 15, 2021 16:23:10 GMT -6
I've got a quick one.. I bought UAD to get away from the multi-authorisation pain so why do you need Ilok for Luna when you have a UA interface (which essentially does the same thing)?! Rather avoid Ilok and use Logic. Using Pace protects our IP and keeps users from "sharing" Extensions and Instruments. So does other methods, if someone has cracked AES256 encryption / lic gen / RSA key models etc. that are used in regulated secure industries we've got bigger issues than pro audio IP. I'm a developer and very much understand Ilok isn't necessary, although from a speculative side I'm sure there's some reason for it (cost, time, skillsets etc.?).. Anyway, after the debacle I had with Avid / Ilok stopping me from working for a month or so, the cloud version randomly skipping out and having a lot of issues when changing out a machine I'll probably give it a skip. Appreciate the reply Drew.
80hz
Junior Member
Post by 80hz on Nov 15, 2021 23:26:37 GMT -6
Re: Offline Rendering Session with UAD
Didn't see anyone clarify but essentially if you run UAD plugins and then offline render your session, the UAD plugins are not rendered by your computer's CPU. They are instead rendered through the SHARC chips. So your entire offline render is limited to the slowest point in the chain (in this case the sharc chips). I run UAD and swear by many of their plugins. I have gotten used to printing all mixes in real time. With Reaper though I can just put a marker at the end of the session that triggers stop playback. So I print mixes and get up and go make a coffee/stretch lol.
Post by viciousbliss on Nov 16, 2021 11:56:53 GMT -6
I'm debating what to get during Plug-in Month here.
Probably gonna get Sonnox Restore and Oxford Reverb.
Now I'm looking at UAD.
I own Capitol Chambers, Ocean Way, 1176, DFC, Helios, 610B, AMS RMX, 102, Avalon, 2500, Distressor, 224, 480, Voxbox, 175/176, then the stuff that came with.
Looking at: Massive Passive, Manley Vari-Mu, Softube Vocoder, AMS Delay, Cedar, Studer, SSL G Bus, BX20
I still use most all my UAD stuff at some point or other.
Cost-wise, it'd make the most sense just to get the Cedar and AMS. But I haven't had much time to see if I really have a need.
Acustica will have a sale coming up, so I have to ask whether I'd want a Massive Passive or something like Magenta, Pensado Eq2, or Scarlett when I have Azure, Purple3, and Erin.
I've got the new V2 Duende SSL Bus Comp, so I may be covered there.
If there were some $25 coupons, I could just grab something cheap. Seems silly to waste a Custom Bundle spot on something like BX20 or Cooper Time Cube.
In comparing the UAD Massive Passive with Azure2, SPL Passeq, and Claro, it's still unique even with me having had minimal time to learn it. Last time I tried Magenta, I preferred Scarlett. But I preferred Erin and Purple to either of those two. Pensado Eq2 looks exciting though.
But I also know plug-ins have learning curves and can be useful years after I've last touched them due to the fact that I learn more as time goes on. Or maybe someone on a forum brings up some information as to how to make best use of something and then I start using it again. So I often approach buying plug-ins with the mindset of "Is this a quality product that will be useful at some point?".
I'm sure there's an Overloud sale coming up too.
There's a lot of releases these companies are holding back on too, I bet. Seems like with covid we don't get anywhere near as many releases as we used to.
A lot of UAD stuff does not have native equivalents for how I use them. Though I haven't tried IK Sunset reverb or that Acustica Silver or whatever it's called to see if they work like Ocean Way. Probably not.
Relab 480 is not as good or versatile as UAD's, I've tried to find a native equivalent of the 480 Effects algorithm. I don't see another 224 or RMX out there. Capitol Chambers stands alone. Really, everything I've got from UAD has a unique purpose.
Precision Channel Strip and Delay are very underrated.
I know there's going to be some other UAD coupons popping up according to their social media.
I'll have to try using the UAD Studer in place of Satin or Tapedesk on tracks. Last time I thought it could be better at times.
Any suggestions are appreciated.
Post by gravesnumber9 on Nov 16, 2021 12:18:04 GMT -6
I'm debating what to get during Plug-in Month here. Probably gonna get Sonnox Restore and Oxford Reverb. Now I'm looking at UAD. I own Capitol Chambers, Ocean Way, 1176, DFC, Helios, 610B, AMS RMX, 102, Avalon, 2500, Distressor, 224, 480, Voxbox, 175/176, then the stuff that came with. Looking at: Massive Passive, Manley Vari-Mu, Softube Vocoder, AMS Delay, Cedar, Studer, SSL G Bus, BX20 I still use most all my UAD stuff at some point or other. Cost-wise, it'd make the most sense just to get the Cedar and AMS. But I haven't had much time to see if I really have a need. Acustica will have a sale coming up, so I have to ask whether I'd want a Massive Passive or something like Magenta, Pensado Eq2, or Scarlett when I have Azure, Purple3, and Erin. I've got the new V2 Duende SSL Bus Comp, so I may be covered there. If there were some $25 coupons, I could just grab something cheap. Seems silly to waste a Custom Bundle spot on something like BX20 or Cooper Time Cube. In comparing the UAD Massive Passive with Azure2, SPL Passeq, and Claro, it's still unique even with me having had minimal time to learn it. Last time I tried Magenta, I preferred Scarlett. But I preferred Erin and Purple to either of those two. Pensado Eq2 looks exciting though. But I also know plug-ins have learning curves and can be useful years after I've last touched them due to the fact that I learn more as time goes on. Or maybe someone on a forum brings up some information as to how to make best use of something and then I start using it again. So I often approach buying plug-ins with the mindset of "Is this a quality product that will be useful at some point?". I'm sure there's an Overloud sale coming up too. There's a lot of releases these companies are holding back on too, I bet. Seems like with covid we don't get anywhere near as many releases as we used to. A lot of UAD stuff does not have native equivalents for how I use them. Though I haven't tried IK Sunset reverb or that Acustica Silver or whatever it's called to see if they work like Ocean Way. Probably not. Relab 480 is not as good or versatile as UAD's, I've tried to find a native equivalent of the 480 Effects algorithm. I don't see another 224 or RMX out there. Capitol Chambers stands alone. Really, everything I've got from UAD has a unique purpose. Precision Channel Strip and Delay are very underrated. I know there's going to be some other UAD coupons popping up according to their social media. I'll have to try using the UAD Studer in place of Satin or Tapedesk on tracks. Last time I thought it could be better at times. Any suggestions are appreciated. I nearly pulled the trigger on Massive Passive a year ago but at the time I didn't have enough DSP to make great use of it. Instead I ended up with Softube's Curve Bender which I use all the time in native mode. Not that much cheaper actually (if at all), but depends on your DSP availability. Massive Passive is a big boy if I recall.
Post by Guitar on Nov 16, 2021 15:09:00 GMT -6
Pulsar is having a sale. I like the Echorec a lot, I think it's $29 right now.
EDIT: whoops, wrong thread.
Not sure which UAD to recommend, but I will say Sunset Sound Studio Reverb from IK is definitely "up there" with similar products, I love it.
Post by viciousbliss on Nov 16, 2021 15:41:58 GMT -6
I rarely have DSP usage issues anymore since I started using Comp76 and then Molot GE instead of 1176 and 176 in most instances. Using Oxford Reverb further frees up DSP. One has to selectively place their UAD stuff if they don't want to invest in a pile of Octos. One issue I'm having now is the Precision Channel Strip deactivating instances and saying there's a problem with the device even if I have 75% dsp left.
Looks like there's a very good possibility I could pick up Magenta for something like $15-$20 if they put it at 75% off again. Could get Scarlett and some others cheap too in about ten days. Since I only use one mastering EQ, I can get away with using these. I'll have to try the Pensado2 even though it's a little more.
Post by rockinrobin on Nov 17, 2021 14:40:05 GMT -6
Still liking the Ocean Way Reverb? When I first heard it I was like "wow sounds like a record". I'd be tempted to get into UAD just for this one, and maybe Capitol Chambers. Do they have equivalents, maybe in Acustica land?
Post by Guitar on Nov 17, 2021 16:11:01 GMT -6
Still liking the Ocean Way Reverb? When I first heard it I was like "wow sounds like a record". I'd be tempted to get into UAD just for this one, and maybe Capitol Chambers. Do they have equivalents, maybe in Acustica land? IK has the Sunset Sound, which I LOVE, and they just came out with a Fame Studios (Muscle Shoals) one that I haven't tried but am excited about. I'm sure I'll buy Ocean Way and Capitol Chambers...eventually.
Post by viciousbliss on Nov 17, 2021 16:39:50 GMT -6
I've not tried Sunset or Acustica's Silver. I'd be highly surprised if they were Ocean Way equivalents.
Having UAD stuff gives you something that says you're at least willing to make a serious investment and that you're not a fly-by-night hack.
Plus, UAD's marketing could be helpful in enticing clients.
Post by rockinrobin on Nov 19, 2021 8:58:26 GMT -6
Still liking the Ocean Way Reverb? When I first heard it I was like "wow sounds like a record". I'd be tempted to get into UAD just for this one, and maybe Capitol Chambers. Do they have equivalents, maybe in Acustica land? IK has the Sunset Sound, which I LOVE, and they just came out with a Fame Studios (Muscle Shoals) one that I haven't tried but am excited about. I'm sure I'll buy Ocean Way and Capitol Chambers...eventually. Oooh I didn't know about that Fame Studio, sounds exciting !! Gonna check that out asap
Post by skav on Nov 19, 2021 11:24:32 GMT -6
I've used UAD plugins for a couple of months now and can state that the reverbs are absolutely great and I now feel stupid for lacking the foresight to see I might be impressed by them.
Post by kcatthedog on Nov 19, 2021 15:27:43 GMT -6
Live and lUArn !
Post by viciousbliss on Nov 24, 2022 21:07:46 GMT -6
Since this post I got Studer, Fairchild, AMS Delay, SSL Bus, Neve Dynamics, API Vision, Massive Passive, and I think that’s everything. I kept this mix or maybe you could even call it a master I did about four years ago where I recorded vocals to mix with the Peace Sells Rock Band tracks. It was the one thing I did then that sounded very good on headphones and speakers. So, I reopened the session and saw what I used.
Ocean Way was a big part of the vocal sound. Leaving it in remic mode. I had stopped using it a lot sometime after. The Aurora N monitoring with K701 headphones is much easier to work with than K701 in an ID14. Since then I also replaced PA SSL E with Oxford Eq on tracks and auxes. Four years ago I was using Satin with the 102 preset on a pre-master aux and then Punish, DFC, and DS-1 on the master fader.
What I did now was replace the Oxford Eq with API Vision or UAD SSL E on busses. That was instantly a big jump out of sterile land. Put Ocean Way back instead of Capitol Chambers. Used Hitsville, 224, 480, or BX20 for main reverbs. Put the UAD 2A on the vocal busses. I’ve largely kept Molot GE in insane mode on vocal tracks or put the UAD blue 1176 back like I did four years ago.
I don’t do a lot of pre-master aux or master fader processing. The Hitsville Mastering Eq can do a ton of work though if you set it right. Four years ago I was also working at 96k with Phoenix on all tracks instead of Satin. All vocals had Dopamine after Phoenix. Nowadays I put Satin and Dopamine on any tracks that don’t have a lot of analog sound to them.
Still waiting on MCDSP to restore my NR800 license, as I used that on some busses and it definitely had a real positive impact on the sound. But, if I set it correctly back then, it was more luck than anything.
With the right combinations on the busses, other plugins will sound a lot better. Phoenix didn’t sound like a downgrade from Satin, for example. The UAD SSL definitely has more of a real hardware sound than the PA though, using Fusion as a reference for what a piece of hardware should have. Same with the LA2A. The PA SSL E just sounds kinda sterile and dull by comparison. Like a lot of plugins do.
Right now I’m trying to come up with 6 and am deciding on two between Harrison Eq, Culture, 1073, SSL E, the Cedars, Autotune RT Advanced, 1084, Pultec, and Vari Mu. I’ve already basically decided to get the two Hitsville, BX20, and LA2A.
The BX20 is still really good and unique. It has a wetter sound than the Chambers and will give the vocals more of a sense of being in an open space. Hitsville is definitely better than Capitol when I’ve replaced an instance of CC with it.
Love the UAD-X, I have the majority of those released on that platform. Allows me to do more with the DSP.
Post by kcatthedog on Nov 24, 2022 21:13:15 GMT -6
As long as you are happy with your results!
Post by indiehouse on Nov 24, 2022 21:46:13 GMT -6
I stopped buying UAD. I have quite a few of their plugs and think they are great. There are a few more aid like to have, but Cut myself off from them because of their resell policy. Same with PA. They didn’t explicitly say it, but the way they restructured makes their plugs worthless on the second hand market.
I think UAD has great software though. And so do a lot of other companies these days.
Post by viciousbliss on Nov 24, 2022 22:32:14 GMT -6
It’s a tough choice between them all. I’ve always loved what the Harrison does and especially without using a lot of DSP. The 1073 and Pultec both have UAD-X, but maybe others will soon? I’ve seen someone get the UAD Pultec to sound basically the same as Acustica Purple, which I have. So, that one would mainly be for cpu reasons. The UAD SSL E would be cool to have even if I prefer the results I’m getting with the Vision at the moment. Not that I’ve had a ton of time to mess with either. The vocal preset on the Vision works really well as a starting point for any buss within my latest sessions.
Culture Vulture was good as well, but do I need it? Same could be said about Fatso. CV also uses a lot of DSP. I’ve read the Hitsville cpu as UAD-X versions is not bad. Tough call to say whether I prefer UAD Vari-Mu over Magenta. Paul Third did a video showing how Magenta was extremely close to the hardware. He must have been trying it through Mix Analog.
The Cedars both sounded like they compromised the integrity of the track some along with removing the noise. I’m not really a big fan of noise reduction stuff for music. When I used the NR800, I was using it for kinda the same reason I’d use a saturation plugin. Plus I spent on the Sonnox Restore stuff a few months ago. And funny enough, I did something that got rid of the buzz in this bass guitar track because when I went to try Cedar Axe on it, it wasn’t audible anymore. Then I was able to deactivate Oxford DeBuzz too.
I’m not sure if this real-time Autotune is a great idea. It’s basically like recording with Autotune Pro’s full automatic mode. Most of the videos I see with it focus on creating those robot voices. I’ve already got AT Pro. UAD is saying to place AT after eq, compressors, and all this stuff. When I first got Autotune 8 years ago, I had read that it was supposed to go first in the chain. First in the chain, after a compressor and before Satin, or after Satin and Dopamine, it can sound good in any of those scenarios.
I was using AT 5 classic mode on the 2018 Peace Sells I dug up and the vocal track sounded really good.
Hitsville is also probably better than Atlantis Dual too. It is definitely faster and easier to work with, that’s for sure. Atlantis has to be reopened for the GUI not to be black and it can be a little tough to dial in for rock and metal. But I haven’t tried it since incorporating the UAD LA2A on the vocal bus and the Vision. There’s no way I could easily run four instances of Atlantis easily. So, using Hitsville is a no brainer.
I may just have to randomly choose the last two plugins before the end of the offer tomorrow unless someone makes a good case or I figure something else out.
Post by tim on Nov 25, 2022 8:57:21 GMT -6
That Ultimate 11 package on sale right now is looking very compelling. Loads of plugs in that bundle. I’ve been trialing the spark stuff and they’ve been great. Wondering how much more will be added to spark. But I do have an octo card that is under utilized. I bought it years ago when the EMT 140 was released. I was comparing the API 2500 in both spark and dsp against my hardware and man it sounds identical to the point where I was like f*ck it I should just sell the hardware. Haven’t said that about any of my other hardware comps.
Post by kcatthedog on Nov 25, 2022 9:30:24 GMT -6
UA has committed to slowing building spark, so if you bought u11( a screaming deal), you will eventually benefit by also receiving uadx versions of whatever is ported to spark.
