Post by ragan on Aug 7, 2018 17:08:01 GMT -6
Got a preference between these?
https%3A//soundcloud.com/fir_out/acoustics-a
https%3A//soundcloud.com/fir_out/acoustics-b
Post by Johnkenn on Aug 7, 2018 17:11:24 GMT -6
I thiiiink I like B better.
Post by ragan on Aug 7, 2018 17:35:17 GMT -6
Post by Deleted on Aug 7, 2018 17:45:36 GMT -6
All I have to say to this thread is AHAHAHAHAHAHAHA..! *Cough, hmmm AHAHAHAHAHA..! **I'm not just insane, I asked Ragan what the mics are.!
Post by matt on Aug 7, 2018 18:05:50 GMT -6
OK, pray, do tell! What's what here? The A file sounds a bit better to me- although I'd probably EQ out a little of the low end in a full mix.
Post by ragan on Aug 7, 2018 18:09:53 GMT -6
Here are a couple more clips.
https%3A//soundcloud.com/fir_out/acoustics-c
https%3A//soundcloud.com/fir_out/acoustics-d
Post by ragan on Aug 7, 2018 18:17:19 GMT -6
Post by Vincent R. on Aug 7, 2018 18:22:27 GMT -6
I prefered B and C. They had more bottom end. Otherwise they both sound fine.
Post by Johnkenn on Aug 7, 2018 18:37:46 GMT -6
Not being critical because this sounds better than 95% of the acoustic tracks I get from studios - but there’s some washiness in the top...could be SoundCloud.
Post by ragan on Aug 7, 2018 18:48:34 GMT -6
Not being critical because this sounds better than 95% of the acoustic tracks I get from studios - but there’s some washiness in the top...could be SoundCloud. Yeah could be. The WAVs sound better, of course. I also usually work a little harder to get a good sound. I'd usually run through the Harrison EQs, do some very slight dip somewhere and a little HPF. For this test, I just wanted to hear the raw mics pointed right at the usual spot to see how they stacked up on raw capture, if that makes any sense.
Post by Deleted on Aug 7, 2018 20:29:49 GMT -6
I said on GS one has a bit more Kahuna's (A on the first test) and that it's an absolutley cracking recording. Although TBH for me there isn't a whole lotta difference in them, you could probably interchange one for the other with a bit of EQ or proximity.
How far we've come over the last decade, one of these mic's I'd of dismissed out of hand due to the price.
Post by Mister Chase on Aug 8, 2018 0:27:21 GMT -6
Sounds lovely, Ragan. Great sounds. A seems a little flatter and maybe more transparent to me. B seems to have more lows going on that help me hear the wood of the guitar nicely. The top and upper mids have kind of a silkyness to them as well. Depending on the mix I could use either. I prefer B though in solo.
I imagine a nice picked jazz bass or rick bass with some dry 70s drums going too. In that instance I might prefer A.
Post by Mister Chase on Aug 8, 2018 0:31:04 GMT -6
I feel like C is also B and A is D. I feel the same about them at least. Good ole night moves.
Post by jampa on Aug 8, 2018 3:24:34 GMT -6
I'm going all in and guess that A & D are an ISK Pearl and that B & C are a 3U CM100
Post by mike on Aug 8, 2018 6:11:40 GMT -6
Not being critical because this sounds better than 95% of the acoustic tracks I get from studios - but there’s some washiness in the top...could be SoundCloud. For this test, I just wanted to hear the raw mics pointed right at the usual spot to see how they stacked up on raw capture, if that makes any sense.
Sounds great, do you mind if I ask what mic's you used on the raw capture ?
SDC Clips
Aug 8, 2018 6:52:19 GMT -6
via mobile
Post by stormymondays on Aug 8, 2018 6:52:19 GMT -6
Regarding cheap mics, I wouldn’t be afraid of using my lowly Avantone CK-1 on acoustic guitar if my KM84 wasn’t available.
SDC Clips
Aug 8, 2018 7:02:29 GMT -6
via mobile
Post by Johnkenn on Aug 8, 2018 7:02:29 GMT -6
So what’s the twist?
Post by matt@IAA on Aug 8, 2018 7:07:05 GMT -6
Plot twist: no guitar, that’s ragan practicing for his a capella group.
Post by svart on Aug 8, 2018 7:11:50 GMT -6
I'm betting that one is some ridiculously low end mic like a MXL603 or something.. But in all honesty, I'm not hearing much difference between any of the tracks. It would be funny if they were the same mic over and over just to see if people would choose a "favorite" even though there are no differences..
Post by Johnkenn on Aug 8, 2018 8:24:50 GMT -6
When I first heard B after A I thought it was tremendously better. Went back and listened to A again and realized I wasn’t sure if there was any difference at all. Still think B is a little fuller.
SDC Clips
Aug 8, 2018 8:37:10 GMT -6
via mobile
Post by ragan on Aug 8, 2018 8:37:10 GMT -6
I can PM anyone who wants to know. It isn’t meant to be a “twist” or anything, just a comparison.
SDC Clips
Aug 8, 2018 8:37:34 GMT -6
via mobile
Post by ragan on Aug 8, 2018 8:37:34 GMT -6
When I first heard B after A I thought it was tremendously better. Went back and listened to A again and realized I wasn’t sure if there was any difference at all. Still think B is a little fuller. Which of C and D do you prefer?
Post by yotonic on Aug 8, 2018 8:39:15 GMT -6
B is better
C and D is closer than a convertor shootout
Post by ragan on Aug 8, 2018 8:42:36 GMT -6
B is better C and D is closer than a convertor shootout Interesting. Listening blind, I had a clearer preference between C and D then I did between A and B.
Post by EmRR on Aug 8, 2018 8:45:33 GMT -6
I didn't listen to C or D, but putting A and B into DAW made me wonder if it was the same thing with something like phase rotation applied.
