Post by OtisGreying on Feb 3, 2021 19:18:44 GMT -6
It’s using the exact same box but only 2 channels of it versus 8-32. It’s still outboard summing, just less of it. i dunno to me you aren't "summing" anything lol, I always thought summing is taking multiple tracks and summing it down to two. you're taking 2 channels and processing it through the sum bus to another two? 2 channels to 2 channels isn't summing anything? ... but nothing is being summed, that happens in the box before. Either way just semantics i guess, whateber works ... I went with 32 channels capi outboard summed and do not regret it haha. Best of luck with whatever direction you end up going! It's beside the point shakermaker, it's not the resistors in question, its moreso: do multiple busses of the same xformers and opamps treating the music in 8-32 seperate busses make a significant difference over just one stereo buss of the same xformers/opamps treating all the music? Past summing mixers have displayed not much difference in their 2 channel vs X channel test, but the CAPI is different in that the iron/analog circuitry attached to each channel is very extensive and perhaps leads to a different and easily audible result. Only way to know is to A/B compare.
Post by drbill on Feb 3, 2021 19:39:34 GMT -6
It’s using the exact same box but only 2 channels of it versus 8-32. It’s still outboard summing, just less of it. I always thought summing is taking multiple tracks and summing it down to two. This is exactly right. The Burl experiment I referenced was essentially - a.) 32 channels summed thru the Burl; b.) everything summed ITB then 2 channels "processed" thru the Burl with the same settings in the DAW and on the box; and c.) everything summed ITB then two channels processed thru the Silver Bullet. Spoiler Alert : FYI, the 32 channel wide version (a.) got the least amount of love. IMO - when summing OTB, the magic is not in the summing - it's in the associated circuitry that surrounds the summing - the channel electronics, the back end amplification, etc.. So unless workflow demands it, I'd prefer to sum ITB and add outboard as needed. Many disagree with me. That's fine. I've done my due diligence and formed my own opinions. I get FURTHER in the direction I want to go with ITB summing, 2 Buss processing, and a FREAKING TON of outboard inserted on almost all channels ITB via hardware inserts. Then, plugins picking up the slack. That's putting the specific mojo where it's needed, and custom tweaking to allow different OTB processing where I want it as opposed to a "console approach" of "everything gets the same flavor" - which can be interesting as well, but doesn't really suit my esthetic. Complicated stems mixes and routings can easily be recalled 100% in seconds vs. OTB routing.
Post by shakermaker on Feb 3, 2021 19:43:13 GMT -6
i dunno to me you aren't "summing" anything lol, I always thought summing is taking multiple tracks and summing it down to two. you're taking 2 channels and processing it through the sum bus to another two? 2 channels to 2 channels isn't summing anything? ... but nothing is being summed, that happens in the box before. Either way just semantics i guess, whateber works ... I went with 32 channels capi outboard summed and do not regret it haha. Best of luck with whatever direction you end up going! It's beside the point shakermaker, it's not the resistors in question, its moreso: do multiple busses of the same xformers and opamps treating the music in 8-32 seperate busses make a significant difference over just one stereo buss of the same xformers/opamps treating all the music? Past summing mixers have displayed not much difference in their 2 channel vs X channel test, but the CAPI is different in that the iron/analog circuitry attached to each channel is very extensive and perhaps leads to a different and easily audible result. Only way to know is to A/B compare. Yeah I get it, and it's channels not busses, the capi sum bus has two busses, A/B and channels up to 32. So my vote is yes, 32 channels sounds different summed analog than a digital summed mix processed through 2 channels of sumbus... Is that difference big enough to warrant you needing 30 more channels? I guess thats up to you to decide haha. If you get a two channel we can a/b it, but you would need to have the same sumbus configuration as me transformers and op amps. I put outboard gear between my outputs and the sumbus so 2 wouldn't work for me anyways... lots of people are happy with a only an outboard mix bus chain
Post by Bat Lanyard on Feb 3, 2021 19:51:32 GMT -6
I hope someone here doesn't mind doing a 2 channel sum vs more and posting for comparison at some point, it'd be really interesting. Man, I would no problem, but as my setup is wired up now with a fixed mixbus and monitoring flow (and none of that easy to get to - mastering style desk), it would take hours for me to satisfy the all-to-two-track request and then rewire it all back up. Were you not hearing the differences in the Burl example others pointed you to? Edit: and drbill's comment above is another perspective, so maybe just consider the broader question: do you think working through a console would be beneficial, or can/are you getting the sound you want now ITB? There is no right or wrong, as drbill said, that's his setup and it's exactly how he wants to work. I could easily ditch the SumBus and go ITB summing to my mixbus and try to make all that happen, but I'm getting our sounds with what I have and I like those sounds. Hybrid blend of outboard summing, hardware inserts and plug-ins. I've bought and sold a lot of gear over a decade+, because usually there's no demo unit, etc., and I just had to buy something I thought would get me closer.
Post by shakermaker on Feb 3, 2021 19:53:02 GMT -6
I always thought summing is taking multiple tracks and summing it down to two. This is exactly right. The Burl experiment I referenced was essentially - a.) 32 channels summed thru the Burl; b.) everything summed ITB then 2 channels "processed" thru the Burl with the same settings in the DAW and on the box; and c.) everything summed ITB then two channels processed thru the Silver Bullet. Spoiler Alert : FYI, the 32 channel wide version (a.) got the least amount of love. IMO - when summing OTB, the magic is not in the summing - it's in the associated circuitry that surrounds the summing - the channel electronics, the back end amplification, etc.. So unless workflow demands it, I'd prefer to sum ITB and add outboard as needed. Many disagree with me. That's fine. I've done my due diligence and formed my own opinions. I get FURTHER in the direction I want to go with ITB summing, 2 Buss processing, and a FREAKING TON of outboard inserted on almost all channels ITB via hardware inserts. Then, plugins picking up the slack. That's putting the specific mojo where it's needed, and custom tweaking to allow different OTB processing where I want it as opposed to a "console approach" of "everything gets the same flavor" - which can be interesting as well, but doesn't really suit my esthetic. Complicated stems mixes and routings can easily be recalled 100% in seconds vs. OTB routing. Ah yeah gotcha, that's cool sounds like you got it dialed in just to suit your needs and the best of both worlds while making sure workflow is maximized. I dig it ... I think the burl32 can't be compared to the sumbus, Maybe I will try the test with my sumbus (32 chan analog summed vs itb summed 2 channel) but it was such a huge difference using all 32 channels right away I can't see how it's not doing something with all those High nickle 2503 + SL-1731 combos slammin into each other haha, and that was before I added a silver bullet and some other things... but yeah it really gets into taste and work flow decisions at this level. when I was 21 i got to record at the tragically hips studio and they had a vintage API there, I've been chasing that sound ever since so maybe thats why I'm so happy with it hahaha
Post by drbill on Feb 3, 2021 20:22:17 GMT -6
Clarifying further (my opinion only) :
For those considering summing - figure out what you're looking for so that you can test appropriately (ala Otis's search) : the bottom line for me based on my listening tests..... Unless your summer has discrete class A electronics, tubes, transformers, etc. in some form or another on every channel, then the benefits are going to get exponentially smaller. A simple summing resistor network with uber clean makeup gain is not going to net you what Jeff's box or a Silver Bullet does.
Then....to be fully informed, you should try to compare that OTB summed sound, a quality 2 Buss solution, and ITB and see which you like better esthetically. I know for me, adding 32 channels of summing (and honestly, I'd need 48+ to really get going) and it would cost me several thousand dollars in cabling and patch bays (bays currently full, and long cable runs), cost me the flexibility that I have with an ITB sum (complicated stems / bussing / etc.), and for me, there's no net gain in the workflow. That's ME!
To achieve the CAPI sound, I'd rather add more VC528's or more vp28's and insert them where needed. Or a host of other super cool outboard like the AudioScape stuff which oozes tube / class a goodness.
When considering whether to sum / mix OTB, ITB, or move Hybrid - I think the workflow should be what should be of primary concern vs. the sonics. You can achieve the sonics with a hybrid approach. You CANNOT achieve the workflow of a console or SumBus style summer workflow with an ITB approach. Different strokes..... <thumbsup>
Post by OtisGreying on Feb 3, 2021 22:29:15 GMT -6
I hope someone here doesn't mind doing a 2 channel sum vs more and posting for comparison at some point, it'd be really interesting. Man, I would no problem, but as my setup is wired up now with a fixed mixbus and monitoring flow (and none of that easy to get to - mastering style desk), it would take hours for me to satisfy the all-to-two-track request and then rewire it all back up. Were you not hearing the differences in the Burl example others pointed you to? Edit: and drbill 's comment above is another perspective, so maybe just consider the broader question: do you think working through a console would be beneficial, or can/are you getting the sound you want now ITB? There is no right or wrong, as drbill said, that's his setup and it's exactly how he wants to work. I could easily ditch the SumBus and go ITB summing to my mixbus and try to make all that happen, but I'm getting our sounds with what I have and I like those sounds. Hybrid blend of outboard summing, hardware inserts and plug-ins. I've bought and sold a lot of gear over a decade+, because usually there's no demo unit, etc., and I just had to buy something I thought would get me closer. To be honest, the only difference I could tell between even the Burl 32 and the ITB reference was a ever so slighty tighter bass-end in the Burl - and that took my like A/Bing for a good few minutes to pick out. Burl 2 channel vs 32 channel was basically indistinguishable. The Silver Bullet was more obvious- it had a slight sub-bass boost from what I could tell.
I'm currently not getting the sound I want ITB, the SB has gotten me extremely close with reamping my tracks and then having it sitting on mix buss. But this is a pain to reamp things, and I want to find the best solution to having the color already initiated and already there on busses so I can monitor through the color from the start and not have to reamp so much. Having a mini API console would be awesome, I'm just wondering if considering how I can't pick out any audible difference between SSL Sigma 2 channel vs 16/32 or Burl 2 channels vs 16/32, how much of a difference really is the iron being on each channel individually going to make in the CAPI's case, and that will factor into my decision between getting a SumBus and perhaps just two pairs of VP28's for stationary line amp saturation on some busses as hardware inserts. I am not bias in any direction here. I don't have any CAPI products, and no bone to pick with summing. If I can tell the SumBus sounds better when expanded, I will get it. If not I'll probably just get 2-4 VP28's.
As far as workflow goes like drBill pointed out, It seems the workflow would be pretty similar using VP28's on busses as inserts versus the SumBus just already being on. Just set a template with the proper routing.
Post by Bat Lanyard on Feb 3, 2021 23:46:45 GMT -6
Totally get what you're saying and where you're at with this. And, for sure zero problem that the Burl test wasn't something drastic. I was only asking as a reference. I haven't heard the files myself. So, as an attempt to be helpful, I ran into the same kinda decision you seem to be up against years ago. And there is no right or wrong answer. And keep in mind, our music is guitar/keys driven, some live drums, some TR-707 and samples. It's rock sometimes, it's modern sometimes. Just depends on the vibe. I am not talented enough to get an ITB mix to sound like a record. So I journeyed to where I am now with a hybrid setup. I guess the point that might help is that maybe think about where you get your best sounds. A SumBus is NOT going to take you lightyears into the future. It is going to be special and do some amazing things sonically. That doesn't mean you can't achieve them ITB or via other hardware, that's just where my journey led me and Jeff's presentation of what he was building for the rest of us resonated with me. And, delivered, helping me get the sounds out of my head and into the computer. Shit. I'm not sure much of that is helpful, LOL.
Post by OtisGreying on Feb 4, 2021 0:04:43 GMT -6
Totally get what you're saying and where you're at with this. And, for sure zero problem that the Burl test wasn't something drastic. I was only asking as a reference. I haven't heard the files myself. So, as an attempt to be helpful, I ran into the same kinda decision you seem to be up against years ago. And there is no right or wrong answer. And keep in mind, our music is guitar/keys driven, some live drums, some TR-707 and samples. It's rock sometimes, it's modern sometimes. Just depends on the vibe. I am not talented enough to get an ITB mix to sound like a record. So I journeyed to where I am now with a hybrid setup. I guess the point that might help is that maybe think about where you get your best sounds. A SumBus is NOT going to take you lightyears into the future. It is going to be special and do some amazing things sonically. That doesn't mean you can't achieve them ITB or via other hardware, that's just where my journey led me and Jeff's presentation of what he was building for the rest of us resonated with me. And, delivered, helping me get the sounds out of my head and into the computer. Shit. I'm not sure much of that is helpful, LOL. I am not talented enough to do it either Bat, and so here we are haha. I do appreciate the insight Bat, and yeah, it seems like the only really helpful thing at the moment would be to hear the A/B comparison for myself and judge. I'm sure both options will yield great sonic results as you said, in the meantime I'll be torn and waiting for my knight in shining armor to come to my rescue with A & B clips in hand.. Or maybe just go with VP28's if its too much hassle. I understand that getting a SumBus usually binds you into a pretty complicated routing setup that would be annoying to mess with. I'm hoping an early adopter who isn't in too deep can give it a go.
Post by Quint on Feb 4, 2021 18:36:08 GMT -6
Were I using a simple passive summing mixer or doing the large scale hardware insert thing like DrBill, my solution would be to use a preamp (with a line in option like the VP28), in addition to whatever other comps and eqs you might use, on each channel.
That way you get all of those extra transformers and opamps in the signal path of each individual channel. That essentially recreates the same thing as mixing through a bunch of channels on a console. If you have a bunch of the same type of preamp, even better.
Post by OtisGreying on Feb 4, 2021 23:17:27 GMT -6
Were I using a simple passive summing mixer or doing the large scale hardware insert thing like DrBill, my solution would be to use a preamp (with a line in option like the VP28), in addition to whatever other comps and eqs you might use, on each channel. That way you get all of those extra transformers and opamps in the signal path of each individual channel. That essentially recreates the same thing as mixing through a bunch of channels on a console. If you have a bunch of the same type of preamp, even better. Well thats the idea with the SumBus. The iron in a pre is basically on every channel, like a console. I just wonder how the same exact iron on 32 seperate channels differs versus just 2 channels of this iron. As all the music is passing through the same exact color once in both instances.
Post by Blackdawg on Feb 4, 2021 23:21:37 GMT -6
well..go listen to something from the 70s or 80s..or 90s...or 2000s.. Major label stuff was all done with tape and a console. was 4-120ch of the same thing. Seemed to work pretty damn good! I realize this reply is a bit stupid but just had to say it haha
Post by christopher on Feb 4, 2021 23:32:09 GMT -6
I personally wish the sumbus had direct outputs so that I could add those line stages and analog goodness on all my channels when tracking. I know the VP28s in line mode or the Missing Links do a similar thing, but cost a bunch more dough too. The whole idea of the SumBus is super cool even though direct out could be sort of nice esp for chaining channels in series. There’s still some fun to experiment with though: if you have all the DA outputs patched anyway, can also try stuff like a super parallel 2 bus? ..where each leg of L/R is feeding half the channels? And you could EQ and drive each channel a little different, maybe its plugins so it’s 100% recall? I think the CAPi idea is you have your pres and EQs feeding it like a console, and a patchbay would then allow typical console techniques? Kind of build as you go toward an API desk.. really awesome CAPI came up with it
Post by jcoutu1 on Feb 5, 2021 1:22:13 GMT -6
Taking 32 tracks and adding a slight bottom boost, top shelf, and a soft low pass filter will be significantly different than doing that same treatment to the stereo mix. I imagine the sum bus is like this (but to a much smaller degree). Does that make sense?
Post by craigmorris74 on Feb 5, 2021 16:19:15 GMT -6
Running through one instance of an amp is like adding one drop of dressing to a salad. Going through a console (same input amp on each channel) is like putting the right amount of dressing in your salad. You can add more or less if you want it, depending on how hard you push things. I'm terms of summing boxes, I'm not aware of any other device whose circuitry more accurately recreates a console than SumBus. The idea of running things through different colors is a modern Gear***** era construct invented by guys selling preamps. All my favorite records were mixed on consoles with the same input circuitry on every channel.
Post by OtisGreying on Feb 5, 2021 21:20:19 GMT -6
I personally wish the sumbus had direct outputs so that I could add those line stages and analog goodness on all my channels when tracking. I know the VP28s in line mode or the Missing Links do a similar thing, but cost a bunch more dough too. What kind of outputs are on the SumBus? Can't you route some of the channels outputs through another converter back into the DAW?
Post by Blackdawg on Feb 5, 2021 23:38:22 GMT -6
I personally wish the sumbus had direct outputs so that I could add those line stages and analog goodness on all my channels when tracking. I know the VP28s in line mode or the Missing Links do a similar thing, but cost a bunch more dough too. What kind of outputs are on the SumBus? Can't you route some of the channels outputs through another converter back into the DAW? there are only 2 stereo outputs, an A bus and a B bus. The B bus is an add on. It sums just the same as the A bus but you can have a different transformer and op amp on the makeup stage side. So you could say us 8-12ch for drums on the B bus and then loop that back into the Sumbus with everything else +the stereo drum mix down on the A bus. He was saying he wished each channel had it's own dedicated output.
Post by OtisGreying on Feb 5, 2021 23:45:55 GMT -6
What kind of outputs are on the SumBus? Can't you route some of the channels outputs through another converter back into the DAW? there are only 2 stereo outputs, an A bus and a B bus. The B bus is an add on. It sums just the same as the A bus but you can have a different transformer and op amp on the makeup stage side. So you could say us 8-12ch for drums on the B bus and then loop that back into the Sumbus with everything else +the stereo drum mix down on the A bus. He was saying he wished each channel had it's own dedicated output. I see so you can't split the outputs through a snake cable of some sort? Or is that only DB25
Post by Blackdawg on Feb 6, 2021 0:34:33 GMT -6
there are only 2 stereo outputs, an A bus and a B bus. The B bus is an add on. It sums just the same as the A bus but you can have a different transformer and op amp on the makeup stage side. So you could say us 8-12ch for drums on the B bus and then loop that back into the Sumbus with everything else +the stereo drum mix down on the A bus. He was saying he wished each channel had it's own dedicated output. I see so you can't split the outputs through a snake cable of some sort? Or is that only DB25 you could split the stereo outputs sure I guess. I'm not really sure how that would be useful unless you are wanting to do some odd parallel processing thing. But you can't have a direct output of every channel.
Post by thehightenor on Feb 6, 2021 6:35:04 GMT -6
One thing I never got with summing mixers is people saying they have greater separation.
To my mind (and ears) nothing can be more separate than the DATA streams of a DAW as there is zero cross talk. Sure you might like the corss talk of a desk - but it's not greater separation it's less.
I've done a fair bit of testing and to my ears greater separation with a summing mixing is something I simply cannot hear in a double blind ABX.
Personally, I don't find it anymore "3D" than mixing ITB with hardware EQ and compression on the stereo mix bus.
Post by OtisGreying on Feb 6, 2021 6:35:50 GMT -6
Are there any samples/clips/tests of 8 channel SumBus vs 16-32 channels out there that anyone has done?
Or at least with the SumBus and without?
Post by craigmorris74 on Feb 6, 2021 8:53:04 GMT -6
Are there any samples/clips/tests of 8 channel SumBus vs 16-32 channels out there that anyone has done? Or at least with the SumBus and without? If you have a pair of preamps, you can simulate what you're looking for. For one trial send the whole mix through these preamps. For the next trial run 4 busses through these preamps one at a time. Sum ITB, and you could run the mid through the preamp again to simulate the master bus circuitry. Repeat, but use 8 buses, etc. You'll be able to hear a difference, but whether or not it's significant enough will be up to you. I'm guessing the test will resemble the SumBus if your preamps are CAPI.
Post by christopher on Feb 6, 2021 15:13:42 GMT -6
One thing I never got with summing mixers is people saying they have greater separation. To my mind (and ears) nothing can be more separate than the DATA streams of a DAW as there is zero cross talk. Sure you might like the corss talk of a desk - but it's not greater separation it's less. I've done a fair bit of testing and to my ears greater separation with a summing mixing is something I simply cannot hear in a double blind ABX. Personally, I don't find it anymore "3D" than mixing ITB with hardware EQ and compression on the stereo mix bus. I went and looked up the burl summing silver bullet tests. Silver bullet and 2 channel summing clearly won the quick AB test.. they provided glue that track needed. If you listen to the ITB, it was very separated like you say. What was surprising to everyone is that you would assume the 2 channel processing would retain that ITB separation more than multi summing- But that was not the case! The outboard summing was closer to ITB in that example, so I guessed that to be LR>Burl, I was wrong. I listened a little longer to them and really paid attention, the 2channel on both are more “one blended sound” with harmonics that really help! However the full summing version did give the ‘ITB separation’ a unique good sounding space for each element, really I don’t notice it until I try to listen to the track while not listening for stuff, just enjoyment. In that aspect it beats the ITB as it gives a more interesting thing to each element, but stays similar to the ITB. It makes me wonder which track would master the best? Also, if the summing channels were pushed harder into more harmonics, what is that like? Either case, Silver Bullet is a killer deal and likely simplest, flexible way to get a nice finished outcome.
Post by Bat Lanyard on Feb 6, 2021 21:02:36 GMT -6
I went and looked up the burl summing silver bullet tests. Silver bullet and 2 channel summing clearly won the quick AB test.. they provided glue that track needed. If you listen to the ITB, it was very separated like you say. What was surprising to everyone is that you would assume the 2 channel processing would retain that ITB separation more than multi summing- But that was not the case! The outboard summing was closer to ITB in that example, so I guessed that to be LR>Burl, I was wrong. I listened a little longer to them and really paid attention, the 2channel on both are more “one blended sound” with harmonics that really help! However the full summing version did give the ‘ITB separation’ a unique good sounding space for each element, really I don’t notice it until I try to listen to the track while not listening for stuff, just enjoyment. In that aspect it beats the ITB as it gives a more interesting thing to each element, but stays similar to the ITB. It makes me wonder which track would master the best? Also, if the summing channels were pushed harder into more harmonics, what is that like? Either case, Silver Bullet is a killer deal and likely simplest, flexible way to get a nice finished outcome. I would second the Silver Bullet vote. #0008 popped up on the interwebs used and I grabbed it in 2014 (I think?). Lots of changes since, but now I still think of it in drbill 's angle where you "use it like a console". So, the SumBus driving that unit gives a lot of options. The SB has been on N for a couple of years now that I've had the SumBus. Drive the SumBus, let that drive the SB, faders in the middle of the exchange... working well for where I try to get stuff. YMMV.
Post by OtisGreying on Feb 7, 2021 3:32:32 GMT -6
New video on summing. Really interesting. First time I've heard that significant of a difference in a summing comparison.
The thing is though, I'm listening to many ITB mixes that have way more depth and separation than the ITB version of his mix in which he is comparing to his analog summing mix. ITB mixes without any hardware units either used on the mix nor the summing, that I would say have more depth and width than even his analog mix. These ITB mixes were of course tracked with top notch equipment. I think what I'm realizing is I just need to arrange better and/or improve my front end. But then again if that were so easy to snap my fingers and become a better arranger or improve my already very nice front end I wouldn't be reading all day about summing mixers... Lol! Tough cookie.
That being said, in his tests, the analog summing sounds much better and would be nice to have.
