Post by rowmat on Dec 17, 2016 1:02:45 GMT -6
Bouncing offline is also an ITB resource issue. I tend to add plugins until I run out of CPU, even with large buffers. It was similar in the hardware era, we'd mix with every piece of outboard we could scrounge hooked up at studios like the NY Record Plant. We wouldn't print the 2trk until we ran out of gear. But offline bounces let the computer do the math without farting, and you can use the oversampling options offline where they'd choke the box realtime. Of course you have to check the mix. Especially to play on systems with hyped lows and highs. I love this.. .should be a T shirt. "how do you know when the mix is done?...... when you run out of outboard!" Don circa 2016 8) cheers Wiz "... do the math without farting."That wasn't too bad either!
