Post by wiz on Mar 26, 2023 19:40:24 GMT -6
F$&@ckn waves. 8)
I use vocal rider and bass rider on every mix.
Own a lot over the years but they are the only ones installed.
It’s a very good chance for someone to come out with a replacement for those two and some others and grab market share
Cheers
Post by drumsound on Mar 26, 2023 19:47:22 GMT -6
Isn't there something called WaveRider that is the same type of thing (and possibly what Waved ripped off)?
Post by drumsound on Mar 26, 2023 19:48:57 GMT -6
Waves' Twitter is fun at the moment, with disgruntled customers scaling the castle walls, and Waves' new "CLA Comment Deleter v1.0" plugin whirring away at breakneck speed. ![](https://media3.giphy.com/media/srg19CG0cKMuI/200.gif?cid=b92a3d886fv0dopmw2ysqk46g9sm4rbw2agv2s07tfrhzqq3&rid=200.gif&ct=g)
Post by junior on Mar 26, 2023 20:52:27 GMT -6
Any vocal rider alternatives? I remember Melda had something called MAutoVolume that did something similar. Maybe worth a look.
Post by copperx on Mar 26, 2023 21:01:12 GMT -6
I mainly use L1 to manage peaks in vocals, like CLA does. I've tried to move away from it to the stuff that Dan recommends (TDR limiter, etc) and DMG TrackLimit, but nothing sounds quite like it.
I'm pretty sure it's a simple algorithm full of aliasing, but it does make a vocal cut better l and stay present without artifacts, when set appropriately.
Has anyone found something like L1?
Post by wiz on Mar 26, 2023 21:04:34 GMT -6
I just demo'd waverider TG and it will do the job of bass rider and vocal rider from waves.....its 139USD .. .I imagine there are sales... so there is an alternative for those
Post by sirthought on Mar 26, 2023 21:32:05 GMT -6
So what does it mean for peeps like me that use like 4-5 waves plugs? I just won’t be able to update them unless I pay for the sub? Maybe I can finally wean off of L2. Also use vocal rider occasionally. Any vocal rider alternatives? I love this developer from Germany. No sales. No subscriptions. Once you buy at his very reasonable price he gives you free updates forever. And he actually listens to suggestions and often incorporates them into the product, or explains why it doesn't work for him. www.tbproaudio.de/products/gainrider
Post by aremos on Mar 26, 2023 21:52:45 GMT -6
Is it that they're clocked (like a "trial version") inside the computer &, after a year, if you don't pay again they won't work? OR Can't one subscribe & use them for years until you actually choose (need) to upgrade (as one used to be able to do before & just not get the support after one year)?
Post by drbill on Mar 26, 2023 22:03:07 GMT -6
Hey Waves.......
Bye, bye. Hasta la Vista. Sayonara. Au Revoir. Shalom.
ADIOS GRINGOS!!!!!!!!!
Don't let the door hit ya on the way out!!!
Post by robo on Mar 26, 2023 22:27:57 GMT -6
Any vocal rider alternatives? I remember Melda had something called MAutoVolume that did something similar. Maybe worth a look. I don’t use it much but MAutoVolume works for me when needed. Back when I bought it I considered the Waves version, but the WUP thing had me sworn off them already.
Post by the other mark williams on Mar 26, 2023 22:45:56 GMT -6
Is it that they're clocked (like a "trial version") inside the computer &, after a year, if you don't pay again they won't work? OR Can't one subscribe & use them for years until you actually choose (need) to upgrade (as one used to be able to do before & just not get the support after one year)? If you "own" any Waves plugins now, you can keep using them as long as they continue to work with your OS and DAW of choice. But from here on out, it's a true rental system. The plugs will work as long as you have an active subscription. If you let your sub lapse, the plugins will not work. They will revert to demo status on your system, which means the plugins will introduce "periodic audio mutes."
Post by seawell on Mar 26, 2023 23:17:39 GMT -6
Is it that they're clocked (like a "trial version") inside the computer &, after a year, if you don't pay again they won't work? OR Can't one subscribe & use them for years until you actually choose (need) to upgrade (as one used to be able to do before & just not get the support after one year)? If you "own" any Waves plugins now, you can keep using them as long as they continue to work with your OS and DAW of choice. But from here on out, it's a true rental system. The plugs will work as long as you have an active subscription. If you let your sub lapse, the plugins will not work. They will revert to demo status on your system, which means the plugins will introduce "periodic audio mutes." Is WUP done for perpetual licenses? This is nuts. If so, they figured out how to make the worst policy in the business even more horrible…wow.
Post by the other mark williams on Mar 26, 2023 23:20:31 GMT -6
If you "own" any Waves plugins now, you can keep using them as long as they continue to work with your OS and DAW of choice. But from here on out, it's a true rental system. The plugs will work as long as you have an active subscription. If you let your sub lapse, the plugins will not work. They will revert to demo status on your system, which means the plugins will introduce "periodic audio mutes." Is WUP done for perpetual licenses? This is nuts. If so, they figured out how to make the worst policy in the business even more horrible…wow. Yep, WUP is no more. I didn't think it was possible to replace it with something worse. Looks like I was wrong!
Post by thehightenor on Mar 27, 2023 0:14:39 GMT -6
I totally get why a lot of people are very pi**ed about this.
But I just checked and it’s a rolling sub. Cancel anytime. So …. this might actually suits my workflow.
I no longer take on any client based recording and mixing, I only put out my own music. I work on a writing, arranging, recording, mixing cycle.
So for the two months I’m mixing a new album I can spend $50 and get access to the entire Waves catalog (which previously I couldn’t afford) then when I’m writing, arranging and out performing I’m not paying for something I’m not using.
I archive my files both with and without processing so I’m ok on that front - I’m sat here thinking this new approach is actually going to suit me nicely.
Though looks like I might end up being their only customer LOL !!
Post by Blackdawg on Mar 27, 2023 0:49:21 GMT -6
Fuggin pissed about this. Would have been mostly ok with it if they had given more than 4 days notice. And really they switched over a day earlier than they said so just screwed all around.
I need an LA3a plugin now and La2a plugin. And SSL EQ.
Unfreaking believable how they went about this.
Post by copperx on Mar 27, 2023 1:07:18 GMT -6
I totally get why a lot of people are very pi**ed about this. But I just checked and it’s a rolling sub. Cancel anytime. So …. this might actually suits my workflow. I no longer take on any client based recording and mixing, I only put out my own music. I work on a writing, arranging, recording, mixing cycle. So for the two months I’m mixing a new album I can spend $50 and get access to the entire Waves catalog (which previously I couldn’t afford) then when I’m writing, arranging and out performing I’m not paying for something I’m not using. I archive my files both with and without processing so I’m ok on that front - I’m sat here thinking this new approach is actually going to suit me nicely. Though looks like I might end up being their only customer LOL !! Yeah, that's what I like about subscriptions for those of us who are not doing this every single day. However, it sucks if your situation changes and your work rythm changes.
Post by thehightenor on Mar 27, 2023 1:38:45 GMT -6
I totally get why a lot of people are very pi**ed about this. But I just checked and it’s a rolling sub. Cancel anytime. So …. this might actually suits my workflow. I no longer take on any client based recording and mixing, I only put out my own music. I work on a writing, arranging, recording, mixing cycle. So for the two months I’m mixing a new album I can spend $50 and get access to the entire Waves catalog (which previously I couldn’t afford) then when I’m writing, arranging and out performing I’m not paying for something I’m not using. I archive my files both with and without processing so I’m ok on that front - I’m sat here thinking this new approach is actually going to suit me nicely. Though looks like I might end up being their only customer LOL !! Yeah, that's what I like about subscriptions for those of us who are not doing this every single day. However, it sucks if your situation changes and your work rythm changes. When I was taking client work (I might go back to that when I semi retire from being a full time musician) then $25 a month is irrelevant as the clients are paying for it. I don’t think successful studios and full time music producers are going to flinch at $25 per month - it’s 0.83 cents per day. In my part of the world a sandwich and a coffee is $15! I know I’m going upset people saying this, but Waves have without doubt thought this through and I honestly think their business will grow. It’s attractive to beginners starting out who have no software. It’s an irrelevant cost to successful professionals (it just gets written off as expenses) People like me who write and mix in cycles can turn the switch on and off. That leaves those not falling into those three categories who I do honestly feel for and I fully understand why they are very p***ed off …. I know I would be in their situation.
Post by kcatthedog on Mar 27, 2023 3:27:41 GMT -6
I totally get why a lot of people are very pi**ed about this. But I just checked and it’s a rolling sub. Cancel anytime. So …. this might actually suits my workflow. I no longer take on any client based recording and mixing, I only put out my own music. I work on a writing, arranging, recording, mixing cycle. So for the two months I’m mixing a new album I can spend $50 and get access to the entire Waves catalog (which previously I couldn’t afford) then when I’m writing, arranging and out performing I’m not paying for something I’m not using. I archive my files both with and without processing so I’m ok on that front - I’m sat here thinking this new approach is actually going to suit me nicely. Though looks like I might end up being their only customer LOL !! Subs are great for the least invested client and completely fuck over the well invested client, who asks why did I bother buying into the previous model. The company is really saying we care about certain customers, not others: hey thx for your business now we are going to give you the business!
Post by vvvooojjj on Mar 27, 2023 3:31:42 GMT -6
I mainly use L1 to manage peaks in vocals, like CLA does. I've tried to move away from it to the stuff that Dan recommends (TDR limiter, etc) and DMG TrackLimit, but nothing sounds quite like it. I'm pretty sure it's a simple algorithm full of aliasing, but it does make a vocal cut better l and stay present without artifacts, when set appropriately. Has anyone found something like L1? Same here. Haven't found anything that sounds like L1 for pushing vocals. Also RDeEsser is lovely for vocals in addition to Weiss Deesser. This subscription really sucks I got to say. I use SSL. EV2, L1 and 1176, RDeEsser in almost every mix/production. I also use RVox and RComp from time to time. On some sources I like Waves 76 than the UA ones.
Post by levon on Mar 27, 2023 4:15:10 GMT -6
So what does it mean for peeps like me that use like 4-5 waves plugs? I just won’t be able to update them unless I pay for the sub? Maybe I can finally wean off of L2. Also use vocal rider occasionally. Any vocal rider alternatives? Same here. Two of my steadies. Voice Rider alternate? Your hands and ears???
Post by thehightenor on Mar 27, 2023 4:20:52 GMT -6
I totally get why a lot of people are very pi**ed about this. But I just checked and it’s a rolling sub. Cancel anytime. So …. this might actually suits my workflow. I no longer take on any client based recording and mixing, I only put out my own music. I work on a writing, arranging, recording, mixing cycle. So for the two months I’m mixing a new album I can spend $50 and get access to the entire Waves catalog (which previously I couldn’t afford) then when I’m writing, arranging and out performing I’m not paying for something I’m not using. I archive my files both with and without processing so I’m ok on that front - I’m sat here thinking this new approach is actually going to suit me nicely. Though looks like I might end up being their only customer LOL !! Subs are great for the least invested client and completely fuck over the well invested client, who asks why did I bother buying into the previous model. The company is really saying we care about certain customers, not others: hey thx for your business now we are going to give you the business! Yes, Emagic did it too me. TC electronics did it to me. There are others. I try to be philosophical about it, it’s the nature of licensed software, you never own it anyway. It’s why I started to build up my hardware racks …. until you need new tubes or a repair then it costs of course! I’ll end up buying 3 months of sub when I mix the album I’m currently working on, if I go back to taking clients I’ll no doubt subscribe monthly as I still value their plug-ins.
Post by kcatthedog on Mar 27, 2023 4:48:47 GMT -6
Not a Waves user.
i recently sold all my ua stuff blah blah: find I use fewer and fewer plugs mixing, when i track with ob and am currently much more interested in, when I can afford them, a few quality ob pieces for tracking and mix buss or nothing.
Post by stratboy on Mar 27, 2023 6:00:55 GMT -6
Same here. Two of my steadies. Voice Rider alternate? Your hands and ears??? Thanks for the helpful comment. VR is useful to me maybe 30% of the time. When I’m in a hurry and need some leveling that’s more dynamic than a limiter, I give it a try. The fact that no one’s suggesting a substitute tells me it’s somewhat unique. Nectar 3 may do something similar, but the leveling function is not explicitly broken out among all the things that Nectar does. I guess I’ll take a look at the subscription terms. I can do just fine without Waves. I do still have hands and ears. But sometimes you find that one tool that does that one thing that comes in handy every once in a while.
Post by Deleted on Mar 27, 2023 6:33:31 GMT -6
Maybe I can finally wean off of L2. Also use vocal rider occasionally. Any vocal rider alternatives? Something like a Presonus faderport can be pretty handy for writing automation and it's not just for vocals either. Also the transport controls are pretty cool, its been on my to buy list since forever.
Post by svart on Mar 27, 2023 7:03:30 GMT -6
Fuck’em. I can live without MaxxBass and the 3 other waves plugins I use. I bet if we took a poll there’s only a dozen or so waves plugs that anyone on this forum uses. And how many of those are indispensable? Zero…that’s how many. Check out Black Salt Audio - Low Control. I've moved to that instead of Rbass or Maxxbass.
