Post by mrholmes on Nov 3, 2016 9:24:31 GMT -6
I always had on my shortlist to demo VCC2 - you know to be fair -
I did my test with something I am currently writing - a ballad. Drums / Guitar / Base / B3 Organ / Lead Vocal.
Its just a short test with one stile of music.
To make a long story short. I did hear a lot of things which I like. Depth. Dimension. Nice Base distribution.
The two G and E SSL simulations did it for me.
Now I think about to ditch my summing mixer.
Any opinion is welcome ....but this seems to me the first Slate plug in which makes sense.
Post by thehightenor on Nov 3, 2016 9:46:11 GMT -6
Being 53 I come from a tape machine/ large format console back ground in recording, and Slates VCC was the first plugin since I went digital many years ago to make me feel my mixes have the sound I really want from them.
I won't mix without VCC perosnally, for me it makes digital audio sound the way I want it for the style of recordings/production and music I make.
I still use a hardare mix bus compressor and some tape/tube FX in my HEDD 192 as I mix, but VCC has removed my own personal need for a summing mixer.
It's definately my favourite Slate plugin, I think they really got VCC right :-)
Post by deehope on Nov 3, 2016 9:48:17 GMT -6
I always had on my shortlist to demo VCC2 - you know to be fair - I did my test with something I am currently writing - a ballad. Drums / Guitar / Base / B3 Organ / Lead Vocal. Its just a short test with one stile of music. To make a long story short. I did hear a lot of things which I like. Depth. Dimension. Nice Base distribution. The two G and E SSL simulations did for me. Now I think about to ditch my summing mixer. Any opinion is welcome ....but this seems to me the first Slate plug in which makes sense. I have the every thing bundle and use pretty much everything except the consoles and tapes. Nebula/aqua r king there. Download the sand Trial from acustica audio. Unreal and not a big cpu hit either. I'm doing a direct comparison right now
Post by jeremygillespie on Nov 3, 2016 9:48:22 GMT -6
Which summing mixer are you using?
Post by ragan on Nov 3, 2016 10:18:58 GMT -6
I always had on my shortlist to demo VCC2 - you know to be fair - I did my test with something I am currently writing - a ballad. Drums / Guitar / Base / B3 Organ / Lead Vocal. Its just a short test with one stile of music. To make a long story short. I did hear a lot of things which I like. Depth. Dimension. Nice Base distribution. The two G and E SSL simulations did for me. Now I think about to ditch my summing mixer. Any opinion is welcome ....but this seems to me the first Slate plug in which makes sense. I have the every thing bundle and use pretty much everything except the consoles and tapes. Nebula/aqua r king there. Download the sand Trial from acustica audio. Unreal and not a big cpu hit either. I'm doing a direct comparison right now Does it work smoothly? Is it AAX? I've always been really curious about Nebula but last time I tried to navigate their site and demo something I felt like someone slipped me some LSD. Just mind bogglingly obtuse. I'd like to try that stuff out though.
Post by mrholmes on Nov 3, 2016 14:21:23 GMT -6
Which summing mixer are you using? I use an A+H small format console ZED 24 which sounds good too. I am in doubt, but VCC would make my workflow easier... I have to do some more AB ing.
Post by donr on Nov 3, 2016 14:31:35 GMT -6
One good thing about VCC 2 is grouping channels for drive and level is so much easier within the VMR format than it was for VCC 1.
Decent video on using the VCC came out today.
Post by Johnkenn on Nov 3, 2016 15:07:58 GMT -6
Yeah - love VCC. I use VCC and a summing mixer.
Post by wiz on Nov 3, 2016 15:12:12 GMT -6
I hadn't tried VCC 2... I just downloaded and installed it.. and threw it on a mix... sounded good, real good.
Will have to explore further, I really never got on with VCC 1... don't know if its different, or I am 8)
good tutorials too!
Post by ragan on Nov 3, 2016 15:29:39 GMT -6
I hadn't tried VCC 2... I just downloaded and installed it.. and threw it on a mix... sounded good, real good. Will have to explore further, I really never got on with VCC 1... don't know if its different, or I am 8) good tutorials too! cheers Wiz They definitely tweaked the algos on VCC 2. It does sound better.
Post by jcoutu1 on Nov 3, 2016 15:45:27 GMT -6
I hadn't tried VCC 2... I just downloaded and installed it.. and threw it on a mix... sounded good, real good. Will have to explore further, I really never got on with VCC 1... don't know if its different, or I am 8) good tutorials too! cheers Wiz I also never really got down with VCC either. I actually used it on my mix of your tune though wiz, because I was looking to give it another crack.
Post by mrholmes on Nov 3, 2016 15:50:05 GMT -6
I stop working now but it sounds not bad. Maybe the console is a bit more smooth in the HF range and provides a more 3D base range, but its not a big deal. I guess I could solve this with some HW on the mix bus.
Post by wiz on Nov 3, 2016 16:15:19 GMT -6
Here is the mix I am on atm... Two mixes one with VCC 2 and one without. The non VCC 2 Mix No VCC
The VCC 2 Mix (channels are RC Tube, each channel at 0VU peaking, Mix Buss is 4KE at +3VU peaking) VCC RcTube Channels 4KE Mix Buss
So what do you think? I like it... but I need to come back after a break and double check... but my initial reaction is very positive... Certainly way better than I remember it. I tried the other models on the channels, and the RC tube was pretty much the stand out on this. CPU usage was very low. The interface is easier than last time, IIRC. cheers Wiz
Post by mrholmes on Nov 3, 2016 16:53:56 GMT -6
So what do you think? I like it... but I need to come back after a break and double check... but my initial reaction is very positive... Certainly way better than I remember it. I tried the other models on the channels, and the RC tube was pretty much the stand out on this. CPU usage was very low. The interface is easier than last time, IIRC. cheers Wiz Jupp with the VCC it sounds more like a record more depth more dimension more like a band in a room.... its the same with a real console. I am just searching for something bad or the hook but yet there is nothing bad I can say.
Post by deehope on Nov 3, 2016 18:06:34 GMT -6
So what do you think? I like it... but I need to come back after a break and double check... but my initial reaction is very positive... Certainly way better than I remember it. I tried the other models on the channels, and the RC tube was pretty much the stand out on this. CPU usage was very low. The interface is easier than last time, IIRC. cheers Wiz is their anyway you can do the same thing with the sand Trial? I'm willing to do it just to hear something as well recorded as your stuff run through it.
Post by wiz on Nov 3, 2016 18:37:59 GMT -6
What is sand?
link me.. and I will see what I can do...
Post by deehope on Nov 3, 2016 19:00:23 GMT -6
Post by wiz on Nov 3, 2016 19:05:59 GMT -6
Sorry to ask a dumb questions.. does it require nebula... or is it a plug in I can demo in Logic Pro X? cheers Wiz
Post by jcoutu1 on Nov 3, 2016 19:24:43 GMT -6
This "looks" awesome. I'd love to have a pair of these hardware units in real life. Haha
Post by deehope on Nov 3, 2016 19:58:39 GMT -6
No such things as dumb questions man. These r completely independent of nebula. And yes I believe their au as well. I just demoed pink 2416 (api 2500) yikes... I'm gonna stop demoing... I'm already broke lol Sorry to ask a dumb questions.. does it require nebula... or is it a plug in I can demo in Logic Pro X? cheers Wiz
Post by ragan on Nov 3, 2016 20:17:38 GMT -6
Yeah Wiz I'd love to hear your stuff through the Acqua stuff too if you get a chance.
Post by Johnkenn on Nov 3, 2016 20:49:30 GMT -6
I hardly ever make it off the Neve emu...can't really hear much happening with the SSLs.
Post by mrholmes on Nov 3, 2016 20:53:45 GMT -6
I hardly ever make it off the Neve emu...can't really hear much happening with the SSLs. Push the mix bus with the SSLs into, or near the red and things start to happen. I am surprised that it works as advertised.
Post by cowboycoalminer on Nov 3, 2016 23:32:24 GMT -6
One good thing about VCC 2 is grouping channels for drive and level is so much easier within the VMR format than it was for VCC 1. Decent video on using the VCC came out today. That is Steven singing on that tune, Buck. He's pretty damn good if ask me!
Post by cowboycoalminer on Nov 3, 2016 23:35:23 GMT -6
So what do you think? I like it... but I need to come back after a break and double check... but my initial reaction is very positive... Certainly way better than I remember it. I tried the other models on the channels, and the RC tube was pretty much the stand out on this. CPU usage was very low. The interface is easier than last time, IIRC. cheers Wiz It really adds a nice touch. Pulls me into the song more. Great song and performance as always, Pete.
