Post by popmann on Dec 10, 2013 9:12:34 GMT -6
You're listening in a control room, no?
I mix records recorded by musicians. Not engineers. They almost never HAVE a control room...let alone objective ears listening to said playback.
Post by henge on Dec 10, 2013 9:42:52 GMT -6
You guys got me thinking!Next vocal I'm going to track without compression.
Post by littlesicily on Dec 10, 2013 10:05:33 GMT -6
You're listening in a control room, no? I mix records recorded by musicians. Not engineers. They almost never HAVE a control room...let alone objective ears listening to said playback. Not sure if you're asking me... but I have a decently treated room with great monitoring... Bryston/Proacs/Avocet, yada
Post by Johnkenn on Dec 10, 2013 10:33:50 GMT -6
I think he's saying that you know what you're doing, but most of the stuff he gets, they don't...
Post by Johnkenn on Dec 10, 2013 11:17:04 GMT -6
So...
After my lengthy rant about no compression, I was browsing through Ebay and lo and behold, there in the shining mist is a Retro Instruments 176 for $2450. TWENTY FOUR FREAKING FIFTY. I couldn't pass it up. Thank you, Billmelater...
I've only used one briefly and didn't really have time to put it through the paces, but I remember pretty much loving what I heard. I figure if it doesn't work, or if times get tougher, it will be easy to get my money back if not a little more.
Damn you, G.A.S...
Post by noah shain on Dec 10, 2013 11:19:38 GMT -6
So... After my lengthy rant about no compression, I was browsing through Ebay and lo and behold, there in the shining mist is a Retro Instruments 176 for $2450. TWENTY FOUR FREAKING FIFTY. I couldn't pass it up. Thank you, Billmelater... I've only used one briefly and didn't really have time to put it through the paces, but I remember pretty much loving what I heard. I figure if it doesn't work, or if times get tougher, it will be easy to get my money back if not a little more. Damn you, G.A.S... BAM!!! You won't sell it. G.A.S. Will win.
Post by Johnkenn on Dec 10, 2013 11:22:22 GMT -6
Well, unless my 2014 is better than my 2013 (which it's looking like it will be ), I won't have a choice...
Post by littlesicily on Dec 10, 2013 11:51:48 GMT -6
I think he's saying that you know what you're doing, but most of the stuff he gets, they don't... Ahh. I see.
Post by tonycamphd on Dec 10, 2013 11:54:31 GMT -6
I think the point Mr Swedien was making, when you compress on the way in, you're permanently shrinking and removing transients and dynamics from the source, once those things are gone, you cant gettem back. Conversely, you can always add the compressor after tracking and achieve the the same and MORE results in the context of a final mix based on your artistic whim. This is a solid philosophy IMV, we spend $1,000's of dollars for gear that gives us lots of options, and subjective control over our sounds, permanently shrinking the size of your canvas on the way in doesn't make a lot of sense to me.
again YMMV, i've heard lots of great results by guys who track with compression, but i've also heard a ton of compression abuse... this video is a little off topic, but funny none the less.
Post by Martin John Butler on Dec 10, 2013 12:19:38 GMT -6
I think it comes down to, does the hardware compressor sound better than the software. If it does, it make sense to use it. If not, it would be silly to bother. I print a pinch of UAD's LA2 on vocal tracks, to save dsp power. If I need more later, so be it, I'll add more compression.
Post by popmann on Dec 10, 2013 12:52:10 GMT -6
I think he's saying that you know what you're doing, but most of the stuff he gets, they don't... I'm saying that AND...that he's not likely in the room with the singer with headphones on setting the compression. Or worse, BEING the singer with headphones on setting the levels. That's the disconnect. Here's the Tower of Babel here: musician reads how John's going to track Martina through the Fairchild...they neither have the objective view from the control room's live playback, John's engineering experience, OR a Fairchild. So, someone with the headphones on themselves patches in a ProVLA and set it so they get visible GR when they sing loudly, turn up the make up...and likely never really gain match compares...so, it's louder, therefore better. They don't hear how it's changing the envelope. They don't hear the color that may not be particularly as flattering as something I have access to...etc.
Post by littlesicily on Dec 11, 2013 8:54:29 GMT -6
Yeah,.... leave more decisions for the mix... (insert mild humorous sarcasm). If someone is compressing with a Behringer Composer on the way in, that's prob a mistake. I buy tools that make sounds I like. I choose those tools per part, per song. I'm not squashing things to oblivion (unless a part calls for it). I'm of the opinion that after producing 1000+ songs from start to finish and using over 50 compressors thru the years (not trying to sound arrogant, just providing context) that I can see the end from the beginning. This is called "experience". So, my experience tells me that I can make a "creative choice" to compress or not compress a vocal on the way in. Sometimes I'm just running thru the circuit of the UREI 1176 with no compression. I'm an american but I take the English approach to "get the sound to tape that you want".
Post by jcoutu1 on Dec 11, 2013 9:07:53 GMT -6
I'm not squashing things to oblivion (unless a part calls for it). I'm an american but I take the English approach to "get the sound to tape that you want". I'm a big fan of both of these things. Let's try to get it right when laying it down rather than fixing it later.
Post by svart on Dec 11, 2013 15:22:27 GMT -6
I've never tracked with compression, probably never will. I made up my mind not to do such things way before I ever read others going for or against it. For vocals I use two channel EQ and two compressors. First channel EQ does all the hard cuts on problem frequencies then sends to the compressors, an 1176 and a LA2A (both real hardware) and then out to the second channel EQ for the surgical cuts. Once I found this, there isn't anything I can't make sound good, as long as the majority of the sound is there in the track. Neither compressor is working more than a few (3-5) dB, the 1176 is medium-fast attack and medium slow release to catch the transients. The LA2A is mainly for the large volume changes.
If the singer is more dynamic than this can handle, something is wrong with the way they are singing or the way it was tracked. In this case I'll do volume evolutions in the DAW to keep the levels hitting the channels more even.
Post by jcoutu1 on Dec 11, 2013 16:02:34 GMT -6
I've never tracked with compression, probably never will. I made up my mind not to do such things way before I ever read others going for or against it. For vocals I use two channel EQ and two compressors. First channel EQ does all the hard cuts on problem frequencies then sends to the compressors, an 1176 and a LA2A (both real hardware) and then out to the second channel EQ for the surgical cuts. Once I found this, there isn't anything I can't make sound good, as long as the majority of the sound is there in the track. Neither compressor is working more than a few (3-5) dB, the 1176 is medium-fast attack and medium slow release to catch the transients. The LA2A is mainly for the large volume changes. If the singer is more dynamic than this can handle, something is wrong with the way they are singing or the way it was tracked. In this case I'll do volume evolutions in the DAW to keep the levels hitting the channels more even. What are you using for EQ's?
Post by svart on Dec 11, 2013 16:05:24 GMT -6
the channel EQs in my mixer.
Post by popmann on Dec 11, 2013 16:17:15 GMT -6
This comes down to why you're using a compressor. I use compression simply for mix context. Not for some cool vibey distortion circuit (though sometimes that's an added bonus). I actually hate running VOCALS through an 1176 with no GR...for that very reason. There's nothing wrong with you doing that. THAT...is an artistic choice. Compression really rarely is. I'm not suggesting people don't make decisions until mix time...AL ALL...but, I DO advise they not make MIX context decisions until mix time. If there's a frequency that needs gone, get it gone on the way in. That's not context. If you creatively want to here the sound of the 1176 transformer, that's not contextual--that's a sound you want...you print it.
I think maybe I'm being misunderstood.
If the compression is part of "a sound"...it's part of a sound...print it. But, you don't print it out of technical "need". There' no noise floor concern. There's no ADC overload concerns-turn the preamp down--OR turn it UP and attenuate so the tube or transformer present clips musically and not the ADC. There's no analog compression is better than digital concerns--because that being what it is, you can use either during mixing with any system I'd mix on.
That's ALL I'm saying. I print through EQ all day. I'll print certain guitar pedal FX. I'll saturate preamps on the way in. If we have an IBP around, I'll manipulate the phase. Submix tom mics. I actually HAVE patched the La3a in with no GR on some egtr tracks before for it's euphonic transformer*. I will limit where it's got an intended side effect on the envelope. Anyway--you will NOT find me recommending carte blanche to "leave decisions until the mix" anywhere. And certainly not when they're working at a facility with a great collection of gear and a solid engineer with the objective view of the live playback in the control room.
*BTW...didn't they make a preamp out of those? 2108 or something? I see those pop up now and again and always consider...
Post by littlesicily on Dec 11, 2013 17:16:47 GMT -6
Popmann, sorry I misunderstood you and responded based upon my misunderstanding.
Post by littlesicily on Dec 11, 2013 19:16:52 GMT -6
@johnkenn, when do you get that 176?
Post by Johnkenn on Dec 11, 2013 19:29:50 GMT -6
Might be Monday.
Post by jsteiger on Dec 11, 2013 19:35:39 GMT -6
Oh lord, what have you done now!!
Post by Johnkenn on Dec 11, 2013 19:52:10 GMT -6
Ha! I figure if I need to, I can flip it for at least what I paid for it.
Post by jsteiger on Dec 11, 2013 19:55:17 GMT -6
Gear slut!!!
Post by Johnkenn on Dec 11, 2013 21:08:11 GMT -6
Jeff, why don't you just make a 500 series Fairchild clone and I'll call it a day...
Post by popmann on Dec 11, 2013 21:19:15 GMT -6
Sure...no problem...thirty tubes on a 500 series rail should be no problem.
