Post by wiz on May 8, 2015 18:35:50 GMT -6
Hey wiz, here's my attempt... dl.dropboxusercontent.com/u/1579861/Wiz%20-%20Fool%20Me%20Once%20mix1.mp3I'm not positive about an exact RMS match, but it's probably pretty close Like I said, I mix and master metal 95% of the time, so this was a lot of fun to get to work on something totally different for me, and see what happens. The "pseudo-raw"/mix tracks sound fantastic! Great job Thanks for having a go, this is really fun to hear this stuff.. Again, I might leave it a week, to give those who want a chance to kick in, then I will post my thoughts and questions , cause there is a bunch of stuff I want to ask about, even though at this point there has only been two mixes. Hope its fun cheers Wiz
Post by mrholmes on May 8, 2015 18:44:41 GMT -6
Wiz would be great if we name all mixes with the depending user names. Than you level match them. And you reup them as 24/96 files.
That makes sure we all talk about the same.
BTW had a unwanted free slot for 3 h today and worked on it. I wanted to use the console but I also had on my list to do a real world demo with the Airwindows Console3 and Buss-Colors3.
Will do automation on sunday and post a download link for the 24/96 file..
Post by bluenoise on May 8, 2015 20:00:45 GMT -6
Even though I'm booked solid for the next few weeks (I won't complain!) I will try to give it a go. Sounds like an amazing learning (humbling) experience!
Post by svart on May 8, 2015 20:43:06 GMT -6
Ok here's my quick one. www.theopiumdenproductions.com/wiz/mixdown.mp3I had tonight free from all obligations besides beer, so I loaded everything up and took a shot! I was surprised at how low the levels on the tracks were. I had to boost each track up 15dB to get it to where I usually have tracks peaking.. And to get my outboard gear VUs to start moving. Anyway, here's what I did: Acoustic has some 2.2K boost, some 180 boost on it and was bussed to a stereo delay with one side at 0 and the other side at 10ms to get it to sound somewhat stereo, then sent to a bus with an 1178. Electrics were bussed to a pair of channels, a little top removed, a little bottom removed, then sent to the 1178 bus for compression. Each was panned a bit off center. Snare has some top boost, a cut around 5K, narrow boost around 180, with bluestripe 1176 on it, -6ish GR. This was sent to a bus with a 33609/2254 hybrid on it. 2:1, -6GR. Kick has some 7k boost, some 70 boost. Sent to the 33609 bus. Cymbals have some 5K cut, some 400 cut. Sent to the 33609 bus. Bass has some narrow 100 boost, some 800 cut, LA4A crushing at -15GR. Vocals have a little 500 cut, some cut around 2k. LA2A peaking at -8GR. Some uncompressed vocals brought up under, maybe -6dB down from the compressed ones. Background vocals are flat, sent to a delay with one side at 0 and the other at 10ms for widening. There is a little spring verb and a little room verb on everything in different amounts, just for some ambience. Master bus has a SSL bus compressor on it, 4:1, 2-4dB GR. That's all. I'm sure some automation would help the movement a bit, but I think it sounds pretty damn good as-is. Oh and it's all hardware you hear besides the delay.
Post by jeromemason on May 8, 2015 21:05:16 GMT -6
I'm gonna give it a try while I'm waiting for some keys/b3 to come in for a couple of tracks..... no telling how long his internet connection is "down" on this Friday night Havn't even heard it or anyone else's, sounds like fun and I've always wanted to get some mojo cooking on that vox of yours, should be fun.
Post by Deleted on May 8, 2015 22:09:54 GMT -6
Hahaha, i could pick watchtower's mix probably out of a hundred mixes blindly. It has his "Honorable Mention at Dynamic Range Day" most modern metal signature sound. :-)
Post by watchtower on May 8, 2015 22:38:49 GMT -6
Hahaha, i could pick watchtower's mix probably out of a hundred mixes blindly. It has his "Honorable Mention at Dynamic Range Day" most modern metal signature sound. :-) Hahaha, I made the kick sound like a triggered sample didn't I? Just a joke, but in all honesty, the kick was really difficult for me. I'm so used to mixing metal kicks I hardly knew what to do in this context.
Post by Deleted on May 8, 2015 22:45:20 GMT -6
Hahaha, yes DEEEPERRR! The deep kick esp. in this song is funny in your mix, identifies you. Also the complete dryness of your mix. It just STANDS IN THE ROOM WITH SOME AIRYNESS, IN FRONT OF A BLACK HOLE. This is absolutely your sound. I make a bit fun out of it but i actually like it because it's a completely different approach that still could be used on completely other genres. And still works. \m/
Post by jazznoise on May 8, 2015 23:50:34 GMT -6
Just DL'ing it. I'll try and have a go at it before work tomorrow evening!
Post by gouge on May 8, 2015 23:52:51 GMT -6
I'm purposefully not listening to anyone's mix so I am not influenced. but i listened to smallbutfines mix because curiosity got to me. it is excellent! the song is excellent!
Mothers day and wifeys bday this weekend, session Monday Tuesday and Wednesday, mixing my own stuff Fri/Sat and i gota fit in my day job somewhere, so I'm tied up all next week. For me it's the week after but I've booked the slot in.
Post by odyssey76 on May 9, 2015 4:35:46 GMT -6
I'm purposefully not listening to anyone's mix so I am not influenced. but i listened to smallbutfines mix because curiosity got to me. it is excellent! the song is excellent! Mothers day and wifeys bday this weekend, session Monday Tuesday and Wednesday, mixing my own stuff Fri/Sat and i gota fit in my day job somewhere, so I'm tied up all next week. For me it's the week after but I've booked the slot in. Same here - not listening to other's mixes yet. Going to start mixing tonight but no way I'll finish anything up until next week. I'm slow
Post by odyssey76 on May 9, 2015 4:37:22 GMT -6
I'm gonna give it a try while I'm waiting for some keys/b3 to come in for a couple of tracks..... no telling how long his internet connection is "down" on this Friday night Havn't even heard it or anyone else's, sounds like fun and I've always wanted to get some mojo cooking on that vox of yours, should be fun. Nice! I've been wanting to hear your mixing style for awhile now.
Post by odyssey76 on May 9, 2015 4:45:53 GMT -6
WIZ listened to it and what should I say - it deserves to be mixed on the console with the outboard. It makes fun to listen to it, you sing waht you mean WOW- I am blown away. BTW is there a CD I can buy.... I like your vocal work much.... Is JJ Cale one of your influences??? mrholmes - I bought Wiz' 4th Time Lucky CD when it came out and it still gets play every week. When I'm sick and tired of listening to fluffed up, inflated, musical cosmetic surgery, I'll throw Wiz' CD on to remind me that there are actually still talented musicians and songwriters in the world. Check out Wiz' video that @smallbutfine mentioned to look into your JJ Cale question! BTW - If you want to stalk Wiz, you have to get in line behind tonycamphd and myself lol!
Post by Deleted on May 9, 2015 12:03:36 GMT -6
Welcome to the international wiz fan club. Yesterday a friend of mine listened to my mix on soundcloud and she is all into quiet music, singer/songwriter stuff etc. and she said it is not often that this style of song catches her and makes her even want to *dance* to it! And wiz has this unique voice every singer wants to have, you hear it and it has a very high recognition value. He does not have to do much with it, not much variation, his lyrics become believable instantly.
Post by odyssey76 on May 9, 2015 13:34:36 GMT -6
Welcome to the international wiz fan club. Yesterday a friend of mine listened to my mix on soundcloud and she is all into quiet music, singer/songwriter stuff etc. and she said it is not often that this style of song catches her and makes her even want to *dance* to it! And wiz has this unique voice every singer wants to have, you hear it and it has a very high recognition value. He does not have to do much with it, not much variation, his lyrics become believable instantly. Yup, agreed. By *dance* does she mean f***? Because that sure is some serious baby makin' music!
Post by mrholmes on May 9, 2015 14:21:52 GMT -6
Wiz. It was a pleasure to mix it because the lyrics did not let me go. I can identify myself with the story. Thanks for the nice song. First class songwriters very seldom knock on the door, you are one of those. Cheers. Holmes On the mix. Its all ITB Logic 9 just bounced to disk. I used the Airwindows (Audio Units only) mix-buss-replacement Console3 in conjunction with BussColors. Its Chris Johnson’s take on simulating the "saturation" part of a console. I mixed with the Rock setting which claims to simulate an SSL sound. To me the setting was the one that sounded the most open, for this song. It gave me the best depth and dimension. The verbs are all UAD-Real-Verb-Pro together with some delays. Except the drum room is an impulse response of a brick-drum-ISO at SARM Studios UK made by Altiverb. A very small breeze of dimension is used on the acoustic guitar with logics Ensemble plug in. The file is the pure mix, no limiter, no bullshit, no loudening. I listened AB to professional mixes with the Magic-AB plug in. JJ Cale was the reference - Album REWIND. I am not totally satisfied. To my taste the low end is not where it should be. I hope someone likes it. You can download as 24/96 file 140 MB www.dropbox.com/s/snku3b3ctfwrtqo/fool_me_once_wiz.aif?dl=0
Post by Deleted on May 9, 2015 15:05:30 GMT -6
Ehm, odyssey76, no, this was not meant as a metaphore, LOL. I was just a bit surprised because i personally would not dance to this genre of music, it is more about listening for me...hahaha.
Post by wiz on May 9, 2015 17:25:34 GMT -6
You guys are making me blush... 8)
I am having a blast listening to all the mixes... thanks for jumping in on the spirit of the idea... Its been really cool and super worthwhile for me...
each mix so far has made me think about the tune in a slightly different light.
Its also really really interesting to hear what each person identifies with in the sonics of the tune...
I think I won't comment directly on each tune for a bit.. there are a few people who want to mix, and have time constraints so I think for the moment, will leave it going, and then after at least those who have said they want to put there mix in , do...
Great stuff and lots of fun
thanks fellas...
Post by svart on May 9, 2015 18:51:35 GMT -6
Man, i really wanted some feedback on my mix!
I really like these types of things. They're fun and educational.
Post by mrholmes on May 9, 2015 19:26:44 GMT -6
Man, i really wanted some feedback on my mix! I really like these types of things. They're fun and educational. true some comments would be cool....feedback is what we all need to get better...
Post by wiz on May 9, 2015 19:41:06 GMT -6
Man, i really wanted some feedback on my mix! I really like these types of things. They're fun and educational. true some comments would be cool....feedback is what we all need to get better... I agree... I just wanna give everyone a chance... 8) I promise I will give detailed feedback on everyone who posts.. that is the very least I can do. cheers Wiz
Post by Deleted on May 9, 2015 20:02:49 GMT -6
mrholmes: what immediately hit my ears in your mix is the snare sound, you chose. It sounds very open and sticks out very much. I like it, if the snare is very good hearable in a mix, but i personally decided against a too open snare sound because i thought it leads away a bit from the intimate athmosphere of the song. This said, i needed a second attempt because i was not completely happy with my first snare sound, so, all these are options and matters of personal taste... I just found it to be very characteristic for your mix.
Post by mrholmes on May 9, 2015 20:16:37 GMT -6
mrholmes: what immediately hit my ears in your mix is the snare sound, you chose. It sounds very open and sticks out very much. I like it, if the snare is very good hearable in a mix, but i personally decided against a too open snare sound because i thought it leads away a bit from the intimate athmosphere of the song. This said, i needed a second attempt because i was not completely happy with my first snare sound, so, all these are options and matters of personal taste... I just found it to be very characteristic for your mix. In the second you wrote this I decided to replace the snare tomorrow with one of XLNs. To me the HW pre mix by WIz took out too much dynamics in the snare. I tried to compensate with some harmonics, to make it more ringing, but this results in a too straining sound for the ear. thx for the hint.... btw check the LV verb in yours, to mee its too much for the near dry rest of the song. BTW what do you think about the low end......?
Post by Deleted on May 9, 2015 20:20:37 GMT -6
svart: I found it very interesting that you featured the rhythm guitar and not the tremolo guitar in the mix! Since this is a decision that could be made freely, it's a matter of personal taste, and i was quite surprised, because most mixes did it the other way round. Neither sounds bad. I just didn't come to this idea, in the opposite, i even made it thinner, robbed it some body so it sounded higher and more fragile, while you gave it fullness. That was very interesting for me. And i thought i found your mix quite punchy and warm but missed some characteristics from kick and bass outside of the bass freqencies, like the kick attack click, they are all there, but it wasn't so obvious. From your previous mixes i heard, i know this may be quite your style to do it. Personally, i always fear it doesn't translate as good or has too little character, if i don't have both clearly hearable in the mix also in the mids and sometimes even in the high-end. Like for bass lacking radios. What i often do is making the monitors quieter and go to the other room. Bass disappears mostly then, and i hope to hear everything still. Many of my early mixes sound lousy if i do this, because i spent too little attention to this or was simply not aware that this is a problem.... Just my 0.02 cent. (yes, not 2 cent ;-) )
Post by Deleted on May 9, 2015 20:42:57 GMT -6
mrholmes: I wanted to give wiz a bit wide room so he sounds a bit like playing live in a larger room, something like that. I thought quite a bit about it. There is really very little verb used in the rest and these are all "studio A" Room like presets with a very tiny amount and a plate on the snare, also very little. As i revisited the mix i thought his voice *can* have more of it. I feature the voice really in my mix and i wanted it to fly a bit above everything else, give it more openness, as i was not quite ok with it in more intimate verb rooms. This was not by accident, but a creative decision, as i did not want to create a real room. I was hesitating first, but listened a few times and found it makes wiz voices more huge without beeing obviously wrong or irritating. So really there is some tension between intimate instrument room and a voice that breaks out of this, not naturally at all...and i liked it. It is the GVerb+ that can be bought from harrison as plugin, which i did. So the whole mix was Mixbus and the only external plugin i used was the Tischmeyer Loudness Meter, LOL.
