Post by robo on Sept 8, 2024 16:02:59 GMT -6
Looking for suggestions for a fet LDC to leave hanging over my house kit indefinitely to use for demos or any session where I need to dial up a drum sound quick. I’d like something that will capture the toms decently without a close mics.
For many projects I’ll put up stereo mics, or a tube/ribbon mic for a specific vibe. I guess I’m looking for something in the “boring but works” category. The closest thing I have is a Serrano 87, but I think I’d prefer something with more of a mellow midrange in that spot.
This might be a long winded way to ask what the best modern 414-style mic is, but I’m also curious about the Chandler Type L, Vanguard V4, and anything else folks have had success with over a kit. Thanks for any advice!
Post by timcampbell on Sept 8, 2024 17:07:39 GMT -6
Why not try to find a used AKG 414EB P48 or ULS? They are usually pretty cheap or buy any of the decent chinese mics and drop a good aftermarket capsule in it? I have made plenty of recordings with a single overhead mic that sounded brilliant.
Post by doubledog on Sept 8, 2024 17:19:07 GMT -6
if you want cheap, an AKG 214 ($200-250 used) will be much cheaper new or used (even if it doesn't really sound like a 414) and you probably only need cardioid? or the WA14 (also $200-250 used)?
Post by doubledog on Sept 8, 2024 17:20:19 GMT -6
I think the Lauten Audio LA220v2 is pretty good sounding over the drums too (I have a pair of them) and fairly inexpensive (they also have b-stock -- $289 -- on their website or at some dealers)
Post by ragan on Sept 8, 2024 17:25:06 GMT -6
I like the ADK Cremona for OH. I keep a pair over my kit, but they work just as well for mono. Regularly go on sale for ~$500-600. I get better results with them than I did with the pair of 414b-ULS I used on OH for years.
Post by Tbone81 on Sept 8, 2024 17:47:22 GMT -6
The Heiserman type 19 is worth checking out. I don’t have any direct experience with them but I’ve been wanting a pair since they came out.
Post by drumsound on Sept 8, 2024 18:07:58 GMT -6
What are you wanting to spend? $750 for the Beesneez C12a solid state would be super cool. A used 4050 would do a good job. The Lauten Mike mentioned, an sE T2 or 4400 would probably be great. An inexpensive ribbon, maybe sE X1r is a cool OH.
Post by robo on Sept 8, 2024 19:19:38 GMT -6
What are you wanting to spend? $750 for the Beesneez C12a solid state would be super cool. A used 4050 would do a good job. The Lauten Mike mentioned, an sE T2 or 4400 would probably be great. An inexpensive ribbon, maybe sE X1r is a cool OH. I have a BU67 that I love so I’m curious about the C12a. I wish I could find some audio as I understand it is quite a bit brighter than the tube version (which sounds great). The Austrian Audio OC18 is probably in a similar ballpark. That ADK Cremona likely too. I haven’t used a 4050 but will look into that and the Lauten/SE recommendations. Thanks, fellas.
Post by eyebytwomuchgeer on Sept 8, 2024 20:48:31 GMT -6
I’ve had far better success with a cheap condenser and well-balanced playing than with any “decent” mic and average playing. That mono OH position really benefits from solid playing. For a house kit, that’s not always the reality since you’re looking at a lot of potential players.
That being said, I like the stereo Vanguard mic OH, so, I’d think a V4 would be quite nice.
But yea, for an up-all-the-time mic, I’d just use a cheap but dependable mic. Even a 57 in that mono OH position can be really cool. Aaron Sterling was running a 57 there for a while and he always got great tones (at least to my ear)
Post by the other mark williams on Sept 8, 2024 23:33:55 GMT -6
I fully realize they're not mono, and hence exactly what you're NOT asking for in this thread, but I personally like blumlein ribbons over a kit - they can often collapse to mono very well, but can also be spread out just a bit to get a liiiiiiiiiiiittle more width if needed. Totally a taste thing, obviously. And sorry for mentioning something outside the scope of what you were asking.
Post by jacobamerritt on Sept 8, 2024 23:53:17 GMT -6
You could do much worse than a Vanguard V4... I have a pair, and it's a lovely mic. It doesn't sound 'larger than life' to me- but sounds really nice! I've had good luck with my Warbler Mk Vs on drum OH as well.
Post by niklas1073 on Sept 9, 2024 0:10:41 GMT -6
I fully realize they're not mono, and hence exactly what you're NOT asking for in this thread, but I personally like blumlein ribbons over a kit - they can often collapse to mono very well, but can also be spread out just a bit to get a liiiiiiiiiiiittle more width if needed. Totally a taste thing, obviously. And sorry for mentioning something outside the scope of what you were asking. I agree here fully. Mono overhead is great and can be just the way to go many times. But a ribbon blumlein already serves as a pretty standard setup. Quick and dirty. That and a kick and you are way beyond demo drums. But I understand if the main purpose was to get a quick demo drum setup the a blumlein ribbon will set you back a little more.
Post by ragan on Sept 9, 2024 1:19:08 GMT -6
I think I’m in the minority on the Beezneez C12a but I found it way too bright for me (this was on vocals and acoustic guitar). And I’ve heard the clips that suggest the FET version is even brighter still. I dunno, I didn’t love the mic when I had it. Noise floor was higher than I was used to and it was just too bright for me. Which is a bummer because I like what Ben is doing in general. That’s ok though. Not every mic is meant for every person/aesthetic.
Post by nick8801 on Sept 9, 2024 3:53:51 GMT -6
I have a drummer friend who used the Audio Technica 4030 as a mono overhead. It’s a great mic. Medium diaphragm so similar to the ksm32 which I have and use over drums pretty often.
Post by jaba on Sept 9, 2024 6:55:39 GMT -6
Not a LCD, but the Sennheiser MKH40 is a fantastic OH mic and definitely works well as a single. Slightly softening and toms sound big. I'll often choose these over 414EBs if I'm really leaning on the OH(s) for the overall drum sound.
Post by kbsmoove on Sept 9, 2024 8:33:12 GMT -6
if i wanted something more neutral i'd get a sony c38b. something with more color heiserman type 19.
Post by robo on Sept 9, 2024 8:38:02 GMT -6
I fully realize they're not mono, and hence exactly what you're NOT asking for in this thread, but I personally like blumlein ribbons over a kit - they can often collapse to mono very well, but can also be spread out just a bit to get a liiiiiiiiiiiittle more width if needed. Totally a taste thing, obviously. And sorry for mentioning something outside the scope of what you were asking. I agree here fully. Mono overhead is great and can be just the way to go many times. But a ribbon blumlein already serves as a pretty standard setup. Quick and dirty. That and a kick and you are way beyond demo drums. But I understand if the main purpose was to get a quick demo drum setup the a blumlein ribbon will set you back a little more. I have a decent stereo ribbon, and an R84 which I like over the kit. I’m not leaving a ribbon hanging sideways on a stand indefinitely, and this is a room where I want a cardioid mic. Thanks though!
Post by mcirish on Sept 9, 2024 8:38:28 GMT -6
Lately, what I have used for a mono overhead is an Alder Audio H44 ribbon. It's fairly small, fairly light, and sounds really great. At $500, I haven't found anything I liked better for mono overhead. For stereo overheads, I have a pair of AT4050. They are nice sounding and pretty nuetral. I actually prefer the Alder ribbon.
Also not a ribbon, but a Beyerdynamic MC930 is very nice on overheads as well.
Post by robo on Sept 9, 2024 8:46:40 GMT -6
The Heiserman type 19 is worth checking out. I don’t have any direct experience with them but I’ve been wanting a pair since they came out. I forgot about that mic. I like my Pearlman 47 over the kit, so if it is roughly in the same ballpark it might work. My other fet47 style mic (ADK tfet Berlin) is a bit dark and honky in that spot. I’ll add it to the list to investigate. A bit more spendy than others, but if it lives up to the hype…
Post by phdamage on Sept 9, 2024 8:53:21 GMT -6
As a drummer who usually sticks 15 mics on a kit for a proper session, Glyn Johns method works pretty damn well for me. For a quick practice recording, I usually just stick my usual tom mics (Oktava 012s) up top and leave my kick mic in there and I'm good to go. I get a lot of detail out of it.
Post by robo on Sept 9, 2024 8:53:41 GMT -6
Lately, what I have used for a mono overhead is an Alder Audio H44 ribbon. It's fairly small, fairly light, and sounds really great. At $500, I haven't found anything I liked better for mono overhead. For stereo overheads, I have a pair of AT4050. They are nice sounding and pretty nuetral. I actually prefer the Alder ribbon. Also not a ribbon, but a Beyerdynamic MC930 is very nice on overheads as well. The MC930 has been what I’ve used in the past, and once it passes through my RND 542 it is workable. I find my pair too useful doing other things to leave there, and my other SDC’s don’t pick up enough toms. I’m pretty sure I want a single LDC. The AT is on my list, thanks!
Post by phdamage on Sept 9, 2024 8:57:02 GMT -6
low end on 4050s was always really lacking for me. by contrast, the 414ULS have a ton of low end. I did sell my ULS pair and all 3 of my 4050s, though. still have a pair of Serrano 87s
Post by theshea on Sept 9, 2024 9:38:07 GMT -6
violet design amethyst vintage can be had for 5-600€ as it seems to be always on sale (its called jz microphones now). sounds in the 67 ballpark. very nice mic.
Post by ericn on Sept 9, 2024 17:47:08 GMT -6
It’s not mono, it’s not an LDC but as far as just putting up one mic for OH, there are a lot who love the Shure Vp88!
Post by the other mark williams on Sept 9, 2024 21:56:55 GMT -6
I agree here fully. Mono overhead is great and can be just the way to go many times. But a ribbon blumlein already serves as a pretty standard setup. Quick and dirty. That and a kick and you are way beyond demo drums. But I understand if the main purpose was to get a quick demo drum setup the a blumlein ribbon will set you back a little more. I have a decent stereo ribbon, and an R84 which I like over the kit. I’m not leaving a ribbon hanging sideways on a stand indefinitely, and this is a room where I want a cardioid mic. Thanks though! Totally understood! 👍 The Soyuz 023 could be an interesting candidate up there. I have a 019FET, which is a bit too spendy of a mic for me personally to leave up all the time, but the 023 could be super interesting in that spot. And the Chandler Type L also comes to mind, of course.
