Post by seawell on Dec 31, 2023 18:16:28 GMT -6
Doesn't the ping change though when you use different sample rates? Do you have to save delay calculations for every sample rate? Josh, I always work at 48KHz so I'm not sure if it would need re pinging? Even if it did, Cubase can save that as another set of recallable parameters but it wouldn't be automatic. HDX is far more sophisticated in that respect. Ok, thanks! Unfortunately for me I get mixes and masters at every sample rate and bit depth you can imagine 😂
Post by seawell on Dec 31, 2023 18:23:51 GMT -6
Aren't most plugin devs only making AAX native versions? (No HDX DSP versions?) So, for zero latency tracking, you're stuck with a very limited selection of plugs? You’re correct, there are way less AAX DSP versions than there used to be TDM versions. If you want to track through plugins you probably would be happier with UA or Antelope. I don’t track through plugins much but when I do on HDX, I like that you can use the DSP versions to shape the sound for tracking without committing it to “tape.” The main latency benefit for me though is that the baseline tracking latency is the lowest whether using plugins or not. I work with some musicians that are extremely sensitive to latency…it’s wild. For most people, especially home studios, HDX/Pro Tools is probably overkill at this point but I do enjoy it.
Post by thehightenor on Dec 31, 2023 19:26:28 GMT -6
Aren't most plugin devs only making AAX native versions? (No HDX DSP versions?) So, for zero latency tracking, you're stuck with a very limited selection of plugs? You’re correct, there are way less AAX DSP versions than there used to be TDM versions. If you want to track through plugins you probably would be happier with UA or Antelope. I don’t track through plugins much but when I do on HDX, I like that you can use the DSP versions to shape the sound for tracking without committing it to “tape.” The main latency benefit for me though is that the baseline tracking latency is the lowest whether using plugins or not. I work with some musicians that are extremely sensitive to latency…it’s wild. For most people, especially home studios, HDX/Pro Tools is probably overkill at this point but I do enjoy it. I can’t stand any latency - it kills the groove and messes with pitching. So I use a separate analog monitor mixer and bypass any DAW latency and simply remove it from the equation.
