Post by drumrec on Dec 13, 2022 16:16:47 GMT -6
Now maybe I'll get basted by all you nice gears guro. Maybe a bit like swearing in church. Here we go...I did the same thing with my TT CL1B when it came to the UA platform. The plug sounded so great. So the small difference made me sell my hardware (now you can throw eggs and tomatoes at me 😂).
I exclusively use up to 90% UA plugs when mixing (just love them). What I wanted to say about the room. After having built such acoustics properly, the need for compressors has become less due to the even balance in the room. Hence I brought up that piece.
Post by plinker on Dec 13, 2022 18:02:41 GMT -6
It's time for someone to mention that the musician is the most important piece of gear... The point of the thread (or at least my it was my intention as the OP) was to focus on hardware one might use in a hybrid fashion and weigh its value against today's plugins. So Musicians, instrument quality, microphones, placement, treatment, pre-amps, etc. shouldn't really be part of the discussion, unless for instance the pre-amp is designated for re-amping or coloring applications. Put it this way, if you can buy it as a plugin, it's fair game. Yeah -- I was just being silly. The thread started going down the same rabbit hole we've seen before.
Post by christopher on Dec 13, 2022 20:32:16 GMT -6
For me.. the number one thing that makes a difference over plugins, tube stuff like audioscape, locomotive, and similar. It is incredible.
But am I buying it yet? I need more EQ first
I know that tube stuff gets the magic for when I’d want it- I don’t want it on every little thing.. Id want it for sub groups, master bus, vocals. And probably not always.
I almost always want EQ on every little thing though. Especially EQ that sounds like it’s part of the source, I can re-shape the mic or source with EQ. And while the plugin EQ get me to a 95%+ same place and work great, I just like being 100% there as a starting point. Maybe I don’t add any plugins.
Post by M57 on Dec 14, 2022 5:48:33 GMT -6
I almost always want EQ on every little thing though. Especially EQ that sounds like it’s part of the source, I can re-shape the mic or source with EQ. Obviously, putting a real EQ on every track is too expensive, so I assume you record through EQ hardware. The problem is that you have to commit. Do you ever find yourself printing already recorded tracks through EQ hardware?
Post by bikescene on Dec 14, 2022 7:11:15 GMT -6
I just started to integrate more hardware into my workflow recently. Bus compression via an Audioscape Buss Comp has been something that I stay OTB for. I might use an SSL-type plugin as a placeholder, but it is ultimately more satisfying to use the Buss Comp.
I do like to use my cheap outboard comps on bass guitar and snare, but I to stay ITB for other elements for convenience. I’ll probably add an 1176-type compressor in the future to see if my workflow changes.
Post by drbill on Dec 14, 2022 10:10:08 GMT -6
I almost always want EQ on every little thing though. Especially EQ that sounds like it’s part of the source, I can re-shape the mic or source with EQ. Obviously, putting a real EQ on every track is too expensive, so I assume you record through EQ hardware. The problem is that you have to commit. Do you ever find yourself printing already recorded tracks through EQ hardware? Can't answer for Christopher, but for me, sure. Why not?
Post by ragan on Dec 14, 2022 10:33:34 GMT -6
I almost always want EQ on every little thing though. Especially EQ that sounds like it’s part of the source, I can re-shape the mic or source with EQ. Obviously, putting a real EQ on every track is too expensive, so I assume you record through EQ hardware. The problem is that you have to commit. Do you ever find yourself printing already recorded tracks through EQ hardware? I do this constantly, for almost every track. I wear the musician hat while tracking, mostly. Then after things are tracked, I put on the audio engineer hat and print the tracks through my hardware, sculpting things in the context of all the other tracks. I love doing it that way.
Post by christopher on Dec 14, 2022 11:05:56 GMT -6
Yeah me too! During mix, it’s pretty fast even going one track at a time. I’m mostly looking for character from the EQ circuit, ..to pretend it was mixed through a 36 channel Neve for example.. some quick dialing in, maybe 30 seconds to a minute, and print. Some tracks I find a few different settings, mild/aggressive etc, and print back a couple versions as alternates. It’s way faster than tracking, you can just print only where the item is, not the whole song. So for example instead of a 5 min print, vocals might be done in under 2 minutes if there’s not many words in the song. So printing alternate vocal EQ settings is very fast, just jump around the timeline and punch in where the words are. when I know the mic and I know the EQ settings that seem to work well, I love tracking with EQ so much, makes me have a great starting point. If I don’t have it perfect, I haven’t been upset with using plugins to adjust. Similar to any mic on anything.. Not trying to promote anyone , but I do look at the Silver Bullet as a smart device which gets most of what I do in hardware in a nice unit. That, some EQ, and a tube thing.. would probably satisfy me.. I think about it sometimes
Post by robo on Dec 14, 2022 11:37:38 GMT -6
Obviously, putting a real EQ on every track is too expensive, so I assume you record through EQ hardware. The problem is that you have to commit. Do you ever find yourself printing already recorded tracks through EQ hardware? I do this constantly, for almost every track. I wear the musician hat while tracking, mostly. Then after things are tracked, I put on the audio engineer hat and print the tracks through my hardware, sculpting things in the context of all the other tracks. I love doing it that way. After many years of doing a half-assed job when recording myself, this is now my approach too. It’s sooo much better than trying to split your brain and attention. I still do some processing on the way in, but not like I do when recording clients.
Post by plinker on Dec 14, 2022 11:51:05 GMT -6
I've often thought that, if I started using hardware EQ, that I would first use software EQ to get estimates of the changes, then print them with hardware EQ. That way, I'd know that the EQ moves are copacetic across the mix before printing each track.
Does anyone work that way?
Note: I suck at mixing anything but small projects, so this is just a thought experiment for me.
Post by ironinthepath on Dec 14, 2022 12:10:43 GMT -6
I think good mic - good preamp - GOOD CONVERSION are the first priorities for a really nice/pristine pro-sounding recording at home (assuming content and room sound are worthwhile). I'd be curious what audio interface M57 is using, as I've noticed a lot more clarity when using a high-end pre (like the Great River, although I have no experience with the 500 series unit) directly into a proper data-path than otherwise.
For example, there was a time (thanks to an out-of-state move during COVID) that I had access to a couple reasonably nice preamps (Vintech X73i and Focusite ISA 220) but only a Scarlett 2i2, at first, for conversion (and Sony MDR7506 for monitoring). The problem with Scarlett is that, as far as I could figure, there's no way to fully avoid the built-in mic-pre related circuitry in the datapath (just set so near 0dB but still "there"). Making music was fun enough but I eventually got annoyed and bought a MOTU M4 for my temporary setup - I could finally hear the benefits of nicer preamps again (but not in same league as Aurora (n)).
The COVID induced gear separation stretched out (my wife didn't want me to fly back to finish the move) and I picked up some Warm Audio gear used. I liked the WA-2a and, to a lessor degree, their version of the Pultec EQ - but, to my ears, it was immediately apparent that at least with stock tubes (I have never tried anything else with the Warm stuff) the pristine signal quality from the nicer pres alone was diminished (like the mildly blurry camera lens analogy). I don't think this was anywhere near as audible going through the Scarlett compared to the M4.
Later on, with all my stuff available again, I overall advocate for the nice mic - nice pre - nice EQ (not extreme, but remove unwanted low-end) - nice compression (not so much, but some) into nice converters (see previous posts by christopher & robo). If I'm lucky, I feel very little need for plugins other than maybe delay/reverb and corrective EQ (where plugins excel). Just an opinion to not leave A/D conversion as a complete after thought. -Chris
Post by robo on Dec 14, 2022 13:20:10 GMT -6
I've often thought that, if I started using hardware EQ, that I would first use software EQ to get estimates of the changes, then print them with hardware EQ. That way, I'd know that the EQ moves are copacetic across the mix before printing each track. Does anyone work that way? Note: I suck at mixing anything but small projects, so this is just a thought experiment for me. This is how I integrate all my hardware. I get things in the ballpark with emulations and then I have a starting point when it is time to commit. I work without a patchbay, so it’s nice to do the trial and error part ITB. Then I just process the most important tracks first. Not all my outboard is emulated 1:1 in plugins, but I can get close enough to know what will work. Corrective eq is the thing that is generally better done with plugins and left on. I love analog sweetening eq, but that stuff is usually pretty subtle IME and can be done fine with plugins if prioritizing like the OP.
Post by M57 on Dec 14, 2022 13:30:45 GMT -6
I'd be curious what audio interface M57 is using, as I've noticed a lot more clarity when using a high-end pre (like the Great River, although I have no experience with the 500 series unit) directly into a proper data-path than otherwise. I'm pretty happy with my chains. Vocal BSA UM4X --> Great River NP-500NV --> Warm WA-2A --> MOTU 828 ES Piano AKG C-451Bs --> A designs P-1s -- MOTU I have other mics and pre-amps but these are my go-to's. Once in the box it stays there except when I throw an AudioScape Buss Compressor on the mix buss. My initial thoughts were to get another compressor/color box for the Mix Buss, which I could also use for printing, but this thread has made me reconsider my options. It started out compression, compression, compression, but there are clearly other options that I should seriously research/consider. I'd have to get a bigger lunchbox if I decided to get an EQ or two (for recording) ..but then at that point, I figure that might force my hand and I'd be temped to fill the extra slots with a nice stereo compressor, like an API 529. But I've been considering 19" gear, with things like the Silver Bullet, Black Box, Manley Var-Mu, etc. That's the point of this thread. Given the quality of plugins these days, I want to make sure I'm putting up the big bucks for the equipment that will make the most impact. Maybe I should save a lot and I just focus on gear like EQs that I use before things get to the box (though I could use any of the gear I've mentioned for that too).
Post by ironinthepath on Dec 14, 2022 14:35:56 GMT -6
I'm a big fan of MOTU, used their (now ancient) 1224 for well over a decade. When upgrading I was looking at the Motu 16A but ultimately decided to go with Lynx. Overall through, Motu is really really nice conversion considering the cost and channel count and both 828ES and 16A offer input paths that are direct - no internal pre to bypass when using your nice pres.
I have noticed though, in two different cases (not the GR, haven't tried 500 series version), where I greatly preferred the 19 inch version of a preamp (from same company) to the 500 series version - I opened them up and found the transformers were (likely) the key difference - physical size was different (people often talk about the +/- 16V supply limitation too, but that's easier to work around in my opinion). That being said, lots of good stuff in 500 series format and I would never hesitate about API, Avedis, Buzz Audio, etc.
Is there a place near you where you can rent gear? If so, that might be a great way to try hardware and see if it's worthwhile. Plugins have come a long way and it's definitely law of diminishing returns with hardware. I just love using hardware though, often find it easier/quicker to get a sound I like, it's more inspiring to me, and maybe it's just the psychology of it all: I like physical controls, bright lights, and fancy meters :-)
I would try renting an RND Shelford Channel if one was available (a place near me has them) - see if worth all the fuss (and the cash). -Chris
Post by eyebytwomuchgeer on Dec 14, 2022 14:43:44 GMT -6
I've been learning this way to a certain extent. I will set up my drums and mics and make sure everything is phased correctly, then I will track something straight in, no EQ, no compression, etc. Then I use something like a clean EQ plugin to make some general moves. I make a note of the dB cuts or boosts, then I've been going back, patching in my hardware to make similar moves at like 30-50% of that initial plugin value. So if I'm cutting 8dB at 350Hz on a floor tom with the plugin, I'm going to go back and patch in my hardware EQ at like 3-4dB of a cut. Then, I will start to track my drums 'for real' haha with that hardware added into the chain. Then I usually just move forward and try to mix like that, with the hardware and the plugins. I keep a journal handy to make notes, like, "you can really cut that floor tom 350Hz 6dB going in and you'll be ok for this and that..." It has been helping me inch closer to what I think are better sounds.
I tried to match my plugin purchases to my hardware purchases. So I have CAPI stuff, and I match that with API plugins. Some BAE and I match with Neve style plugins. Gotta have a few Distressors, so theres those too. That's how I've been moving forward, or, at least moving in a direction.
Post by gravesnumber9 on Dec 14, 2022 15:05:59 GMT -6
I'd be curious what audio interface M57 is using, as I've noticed a lot more clarity when using a high-end pre (like the Great River, although I have no experience with the 500 series unit) directly into a proper data-path than otherwise. I'm pretty happy with my chains. Vocal BSA UM4X --> Great River NP-500NV --> Warm WA-2A --> MOTU 828 ES Piano AKG C-451Bs --> A designs P-1s -- MOTU I have other mics and pre-amps but these are my go-to's. Once in the box it stays there except when I throw an AudioScape Buss Compressor on the mix buss. My initial thoughts were to get another compressor/color box for the Mix Buss, which I could also use for printing, but this thread has made me reconsider my options. It started out compression, compression, compression, but there are clearly other options that I should seriously research/consider. I'd have to get a bigger lunchbox if I decided to get an EQ or two (for recording) ..but then at that point, I figure that might force my hand and I'd be temped to fill the extra slots with a nice stereo compressor, like an API 529. But I've been considering 19" gear, with things like the Silver Bullet, Black Box, Manley Var-Mu, etc. That's the point of this thread. Given the quality of plugins these days, I want to make sure I'm putting up the big bucks for the equipment that will make the most impact. Maybe I should save a lot and I just focus on gear like EQs that I use before things get to the box (though I could use any of the gear I've mentioned for that too). I'd recommend the Silver Bullet in that case. You can use it in so many different ways. As a stereo pre-amp it's great, obviously as a bus (or mix bus) sweetener/color, and the bax EQ is awesome in my opinion. It's really tuned perfectly so you can "twist it 'till it's good". I've said this before, but I would be an instant buyer (even pre-sale) if LTL released a standalone Bax EQ. Mark me down for two drbill.
Post by Deleted on Dec 14, 2022 15:19:59 GMT -6
You won’t get paid more for having hardware now so it’s about if the hardware let’s you mix faster or getting it mostly done on the way in. Molot GE cured my compressor gas. Part of the problem is you can only really flex the very distorted stuff that sounds super cool but the artist might not want it on their sound!
Post by Quint on Dec 14, 2022 17:43:45 GMT -6
This discussion about using plugins to sort of predetermine what eq moves you might want to make in hardware is why I was keen to make the move to Luna. With the API console plugin/extension that they have now (there will be others), you can seamlessly track within Luna and hear those eq moves realtime during tracking and then again on playback, all while not having to commit to any eq moves or worry about latency or buffers.
It's not that you can't do this with two separate plugins, one in DSP and one natively in the DAW, or even all natively if you are able and willing to really crank your buffer down, but I didn't want to have to mess with all of that or worry about buffers or latency or plugin settings in two different locations. Luna just takes care of all of that in the background.
I have quite a few hardware comps and use them a lot during tracking, but I don't print hardware eq as much during tracking and that's part of the reason I don't have as many hardware EQs. So my line of reasoning is to commit hardware comps during tracking, let Luna/API plugin handle non-committal eq moves during tracking so you can hear what you're aiming for, and then do whatever I see fit during the mix stage (print more hardware using inserts or use plugins).
Post by plinker on Dec 14, 2022 23:24:21 GMT -6
Thanks, Quint. Yeah -- I hadn't really considered that Luna-dvantage. Cool approach. I'm OK with compression while tracking, but EQ moves...hmm...yeah, Luna seems pretty cool in that respect.
Post by Quint on Dec 15, 2022 4:41:59 GMT -6
Thanks, Quint. Yeah -- I hadn't really considered that Luna-dvantage. Cool approach. I'm OK with compression while tracking, but EQ moves...hmm...yeah, Luna seems pretty cool in that respect. Pro Tools offers similar DSP/CPU shuffling capabilities with the caveat that it's more expensive than a Luna/Apollo setup. Also, you can't use UAD extensions within PT in this way, as only Luna allows this with UAD extensions. I realize that comes down to a personal preference thing, and you could do this with "other" plugins within PT, but I do like UAD plugins/extensions. The other nice workflow thing about that API extension is that it's integrated (if you choose so) into Luna right there on the screen for each channel. There is no plugin window to open. It's just always there, which provides for a more console-like experience. This is what UA was aiming for and it's what attracted me to giving Luna a shot. It's pretty cool to just be able to pull up Luna with the API console emulation on every channel and just get to it. Even if you ultimately end up not sticking with the eq (or comp) settings on the API, it makes for a pretty easy to use, great sounding, non-committal placeholder until you get to the mix stage, and all while allowing you to not have to worry about buffers or latency or anything when you're tracking and trying to stay focused on the artistic/music side of the equation.
Post by Deleted on Dec 18, 2022 18:58:25 GMT -6
Its never been one of the other for me and never could be. The SSL Big Six or Shelford channel for example sounds nothing like anything else I've heard, it's not always subtle either and imparts its own flavour. When it comes to EQ's I'd rather go ITB, there is an element of practicality, accuracy and besides the RND or Pultec style EQ's (which I have a HW 2-bus Pultec style EQ) Tokyo Dawn or certain UA plugs for example tend to sound better anyway. In terms of comp's some of mine haven't even been modelled and on top of that are generally far more flexible, they don't seem give out or damage a track so easily.
Verbs, delay's and mastering limiters have come along way, whilst I use a HW ML it's more for effect than anything else. Its M/S functions are awesome, I still use Ozone in front of it though.
There's also technical advantages to this hybrid setup, I don't concern myself with ADC, loopback plugs or any sort of time correctors. Everything stays as it should, I can get a scratch mix up and know roughly how it'll sound towards the end even after the recording. I could bang on about this for a while but in short I'd just demo stuff and see what offers a tangible gain, if it doesn't send the HW back and bask in the amount of $$$'s you've saved.
Post by Bat Lanyard on Dec 18, 2022 21:49:07 GMT -6
Obviously, putting a real EQ on every track is too expensive, so I assume you record through EQ hardware. The problem is that you have to commit. Do you ever find yourself printing already recorded tracks through EQ hardware? I do this constantly, for almost every track. I wear the musician hat while tracking, mostly. Then after things are tracked, I put on the audio engineer hat and print the tracks through my hardware, sculpting things in the context of all the other tracks. I love doing it that way. And your stuff sounds killer, so there's that as well.
Post by Bat Lanyard on Dec 18, 2022 21:58:00 GMT -6
I'm pretty happy with my chains. Vocal BSA UM4X --> Great River NP-500NV --> Warm WA-2A --> MOTU 828 ES Piano AKG C-451Bs --> A designs P-1s -- MOTU I have other mics and pre-amps but these are my go-to's. Once in the box it stays there except when I throw an AudioScape Buss Compressor on the mix buss. My initial thoughts were to get another compressor/color box for the Mix Buss, which I could also use for printing, but this thread has made me reconsider my options. It started out compression, compression, compression, but there are clearly other options that I should seriously research/consider. I'd have to get a bigger lunchbox if I decided to get an EQ or two (for recording) ..but then at that point, I figure that might force my hand and I'd be temped to fill the extra slots with a nice stereo compressor, like an API 529. But I've been considering 19" gear, with things like the Silver Bullet, Black Box, Manley Var-Mu, etc. That's the point of this thread. Given the quality of plugins these days, I want to make sure I'm putting up the big bucks for the equipment that will make the most impact. Maybe I should save a lot and I just focus on gear like EQs that I use before things get to the box (though I could use any of the gear I've mentioned for that too). I'd recommend the Silver Bullet in that case. You can use it in so many different ways. As a stereo pre-amp it's great, obviously as a bus (or mix bus) sweetener/color, and the bax EQ is awesome in my opinion. It's really tuned perfectly so you can "twist it 'till it's good". I've said this before, but I would be an instant buyer (even pre-sale) if LTL released a standalone Bax EQ. Mark me down for two drbill . I wasn't that overwhelmed with the eq on the unit I had (used #0008). I found after years of using it only on mix that it was 10 and 2 A -> N and a touch of EQ here and there. Preamps were cool, but a setup like I use now (mainly on keys) the RNDI stereo into CAPI Heiders into CAPI audio bacon things is glorious. YMMV. There are so many options and the SB is an excellent choice for sure.
Post by jmoose on Dec 19, 2022 18:24:49 GMT -6
Obviously, putting a real EQ on every track is too expensive, so I assume you record through EQ hardware. The problem is that you have to commit. Do you ever find yourself printing already recorded tracks through EQ hardware? This seems like as good a jump spot as any other... and overall this didn't go the direction I thought it would from the title. Value? Hardware easily wins. In terms of value & return on investment? If I spent $2500 on an analog box 10 years ago its still worth something today. 10 year old digital gear..? Not the point I guess! So what's wrong with commitment?? If your making an album at some point your going to have to start making decisions and committing to various parts of the process. Takes & edits... sounds... musical arrangements... hopefully none of its too paralyzing and then we can move on to picking some questionable reverb! Mastering? Song order? Album artwork? So many things to commit to. Overall with EQ? Hitting things twice... while recording and again at mix? And a 3rd time again at mastering? Just part of the process & happens on almost every record. If anything it was more frequent in the full on analog dinosaur days. Tracking to tape off a console? You'd have to EQ and shape sounds on the capture side to maximize headroom & bandwidth vs noise. I've never been fearless about carving things up on the tracking side... EQ, compress, mangle at will. I'll even print FX like reverbs & delays. No fear of commitment! The EQ doesn't even have to be extensive, sometimes a little tweak at top or bottom goes a long way and is all you need. No source is truly perfect. Rarely. Recording an album is artwork. An exaggeration of life and so sometimes? That acoustic with dead strings your too lazy or inspired to change? Slap a little 10kHz on there. If you know your going to make a move then don't put it off... get lazy & use a plug. Record it the way you want it. Overall its interesting to read everyone's responses & see what they consider invaluable to the process. From a gear expansion standpoint one thing I always consider before everything else is actual needs. Lots of stuff I'd love to have, but what could I add tomorrow that would actual expand my capabilities? What wall have I hit that needs addressing? Like hypothetically? If someone handed you $5000 tomorrow to invest in the studio/album... what makes the most sense? Would you spend $5k on a manley vari mu for "mastering" or is it more likely you'd hire someone to master for $500 and drop the rest on a big pile of microphones? I know what I'd do!
Post by M57 on Dec 19, 2022 18:34:07 GMT -6
Like hypothetically? If someone handed you $5000 tomorrow to invest in the studio/album... what makes the most sense? Would you spend $5k on a manley vari mu for "mastering" or is it more likely you'd hire someone to master for $500 and drop the rest on a big pile of microphones? I know what I'd do! ..and that is??? Damn. Are you reading my mind? It's not hypothetical. This is almost exactly the situation I'm in, and the Manley vari-mu is on my list.
