Post by Johnkenn on Aug 11, 2021 11:31:53 GMT -6
Heard that Heritage and BL went in together and are doing a reissue of the bespoke/custom Mike McLean creations for Motown...Apparently Michael Brauer had a pair that they backward engineered and people have been raving about it...They had to custom make all the inductors, capacitors, switches and transformers.
Post by Johnkenn on Aug 11, 2021 11:32:41 GMT -6
[0]=AZWfnyng232GM2ydd0J73CrSS6kwT4KHSmLVlH0LEkEqOefy5Wan0Jseoc0X9bHc1NYPydYZMAcYcYRRoqCpGJKm0oGFMSEhJbtGi4iA9JtnTVMnjhaaspphSxowiIQhdY3MXP9stM-vzOi398S0AxJ7&__tn__=%2CO%2CP-R
Post by jcoutu1 on Aug 11, 2021 11:53:32 GMT -6
Post by raddistribution on Aug 11, 2021 12:11:25 GMT -6
I have no idea what you’re talking about… nothing to see here… All I can say is that the last 16 months of our lives were consumed by this project and we are beyond excited to finally talk about this literal once in a lifetime opportunity as designers. I’ll answer any question anyone has… as soon as I’m allowed.
Post by Guitar on Aug 11, 2021 12:15:02 GMT -6
I'm getting my popcorn ready! :-D
Post by Quint on Aug 11, 2021 12:16:46 GMT -6
Watching
Post by jcoutu1 on Aug 11, 2021 12:44:49 GMT -6
Post by tasteliketape on Aug 17, 2021 5:49:36 GMT -6
1999map price .
Post by raddistribution on Aug 17, 2021 6:59:30 GMT -6
Heritage Audio “MOTORCITY EQualizer” Occasionally, something so special arrives, it turns the music industry Upside down (and inside out). That is why Heritage Audio is incredibly pleased to offer the world’s first reproduction (and a dead on one at that) of the “Holy Grail” of classic EQ’s . The “MOTORCITY EQualizer” Recreated from Motown units owned by Eight time Grammy winning producer, mixdown artist, and innovative engineering genius Michael Brauer, Heritage Audio has left no stone unturned, recreating the unmistakably huge, punchy, and warm signature sound that makes this EQ as classic as the hits it helped create. From the 10 gauge hand brushed aluminum face plate, historically accurate control layout including custom molded bakelite knobs, the MOTORCITY Equalizer looks the part. More importantly, the unique passive equalization circuit is identical and fully faithful to the original design. The MOTORCITY EQualizer is so precise, it stands as the only EQ available that can rival, or even “best” the popular Pultec EQ.
It was no simple task to make a 100% accurate reincarnation. Peter Rodriguez and his team from Heritage Audio worked for weeks with their friends at Black Lion Audio. Seth Berman from Black Lion Audio’s NY facility took the lead in getting the info together for Heritage to work their magic.
Everything was complicated by the 2020 summer lockdowns in Europe and the US, but they got it done! The exceptionally tight mil spec 1960’S tone capacitors and inductors are simply no longer available. Replace with a alternate? Not on your life. Heritage Audio had custom recreations built from scratch. Each with exact materials, values, and tolerances: A perfect interchangeable clone of the very few originals remaining. Just add 60 years of dust, and you’ve got twins
The MOTORCITY EQualizer is a completely analog, passive EQ design with seven accessible frequency points across the tonal spectrum. Each frequency has a stepped rotary switch capable of a flat response, or up or down up 8db in 1dB increments. Frequency points graduate from 50hz, 130hz, 320hz and 800hz before jumping to 2000hz, 5000hz, peaking at 12,500hz. The front panel also features a simple in/out/off toggle switch with top hat knob and jewel light power indicator. All rotary switches have easy to read from a distance “General Radio” bakelite style knobs recreated to look exactly like the originals (remember, this is not a slider style graphic EQ). Finally, it features a master gain control (8db/+8db) , again in 1dB increments. The incredibly simple 1960’s accurate back panel features a power supply jack, and an XLR input and output. The sound itself is exactly what you’d expect. It packs a punch without sounding harsh or distorted. While something as simple as an analog seven band EQ might sound more like hype than hyper goodness, hearing is believing. Why has Heritage audio gone through the seemingly impossible task of bringing them back to life?
Michael Brauer will tell you this: It simply got that sound! The Heritage audio MOTORCITY EQ is not a digital equivalent, not a respectfully close replica and not a more compatible modernized “improvement.” The MOTORCITY EQualizer is nothing more or less than the genuine article finally made available for the general public.. For the very first time in history, you can integrate this true spec to spec carbon copy of both form and function into your own studio.
Features:
Dead nuts replica of Michael Brauer ́s units designed at Motown’s“ Hitsville” studio for private use. First time publicly available. Motown’s Chief technical engineer and miracle worker Mike McLean ́s take on the smart graphic eq designed for the film industry and made by Cinema Engineering, Langevin and Altec.. Shockingly clever passive design uses no less than 21 inductors and 21 tone capacitors ( 3 each per band) exclusively made for Heritage Audio, matching Brauer ́s values to 1% tolerances.Heavy duty stepped rotary switches used for all 7 eq bands and gain control. . UTC replica input transformer transformer with modified turns ratio for better integration into modern studios. Exclusively made for Heritage Audio. . Carnhill driven output line amp substitutes the original ́s Achilles heel Opamplabs output. . In/Out/Off Lever switch allows you to A/B the effect of EQ settings. *Motown, Cinema Engineering, Langevin, Pultec and Altec may be trademarks of their respective owners and HA is in no way affiliated with any of them. Mike McLean is cited for historically purposes only and HA is in no way affiliated with him
Post by nick8801 on Aug 17, 2021 7:47:43 GMT -6
Post by gouge on Aug 17, 2021 8:18:06 GMT -6
Why advertise something as 100% accurate then go on to say the circuit was changed. It may sound amazing but how dumb do companies think the punters are these days.
How can something be both a replica and modified...
Its a replica with a different input and output... lol who wrote that..
So its not a modernised improvement. But wait. It has modernised improvements... ha.
Post by superwack on Aug 17, 2021 9:34:01 GMT -6
Why advertise something as 100% accurate then go on to say the circuit was changed. It may sound amazing but how dumb do companies think the punters are these days. How can something be both a replica and modified... Its a repluca with a different input and output... lol who wrote that.. So its not a modernised improvement. But wait. It has modernised improvements... ha. This sadly seems to be very prevalent. You get guys who do a shoot out and say “there’s no processing on the track… other than some bus compression, EQ, and a little bit of reverb” 🙄 or plug-ins manufacturers claiming a 1:1 exact copy… other than the plug-in emulates an transformer (that the hardware doesn’t have) oh and it has an extra band 🙄 I’d love to know if Bob Olhsson has any thoughts about the original and/or reissuing it.
Post by christopher on Aug 17, 2021 10:01:00 GMT -6
It’s really cool they went custom for so much stuff, shows they were willing spend a little extra. Also cool to see their enthusiasm. I think we are all jaded from the plugin promises and “super duper recreations” over past 20 years lol. I prefer transformer out since my grounding situation is often crap. Maybe can mod a opamp labs in there?
Post by seawell on Aug 17, 2021 10:13:13 GMT -6
Hmmm...I wonder what a pair of these would be like on the 2 buss?
Post by Vincent R. on Aug 17, 2021 11:13:39 GMT -6
Cool.
Post by teejay on Aug 17, 2021 14:47:58 GMT -6
Why advertise something as 100% accurate then go on to say the circuit was changed. It may sound amazing but how dumb do companies think the punters are these days. How can something be both a replica and modified... Its a repluca with a different input and output... lol who wrote that.. So its not a modernised improvement. But wait. It has modernised improvements... ha. This is going to sound worse than I mean it, but my first thought was: "Hi, I'm Michael Brauer. I'm helping sell this great piece of new hardware that is almost exactly like a piece of vintage hardware I used to use, but which I don't use or even own anymore because I do everything ITB now. (BTW, keep an eye open for my soon-to-be-released Michael Brauer edition Motor City EQ plugin that is modeled from the vintage hardware I used to use.)"
Post by Guitar on Aug 17, 2021 15:06:28 GMT -6
Todd, I was thinking the same thing! That would be really cool if they go for a plugin with Brainworx or something.
Post by notneeson on Aug 17, 2021 15:34:33 GMT -6
Todd, I was thinking the same thing! That would be really cool if they go for a plugin with Brainworx or something. I think URS made a plugin version back in the day. Not that that helps anyone now.
Post by gouge on Aug 17, 2021 15:35:33 GMT -6
URSplugins have a plug.
Post by jeremygillespie on Aug 17, 2021 16:37:04 GMT -6
Todd, I was thinking the same thing! That would be really cool if they go for a plugin with Brainworx or something. I think URS made a plugin version back in the day. Not that that helps anyone now. I used to love those on our HD3 system and pt7
Post by jamiesego on Aug 17, 2021 16:37:57 GMT -6
I’ve always wanted one of these. I’m very curious to hear some clips.
Post by superwack on Aug 17, 2021 16:48:14 GMT -6
Post by yotonic on Aug 17, 2021 19:29:12 GMT -6
I’m glad someone is aggressive enough to develop new products in a down market. Back in the day companies had everything from German Broadcast to a robust recording industry to drive innovation. I’ll live with the hype and gladly support anyone who is building best in class audio production hardware. Lately I feel like I’m living in a world with no guardrails and dictated by big box stores and corporate monopolies. Sucks compared to 1972.
Post by jampa on Aug 17, 2021 19:52:40 GMT -6
I know how much I like my klark teknik DN22 inductor eq with sowter in/out transformers
This looks great
Post by Quint on Aug 17, 2021 19:57:55 GMT -6
I know how much I like my klark teknik DN22 inductor eq with sowter in/out transformers This looks great Is the Klark supposed to be a knockoff of the Motown eq?
