Post by jdc on Nov 4, 2018 12:40:18 GMT -6
thinking about making the switch to the UAD ecosystem for mixing at home. i know a bunch of you have been using their plugs for years, what are the ones you still use every day? if you had to go back and pick only ten what would you go with?
Post by ragan on Nov 4, 2018 12:52:39 GMT -6
I can tell you which ones I miss the most since ditching UAD, maybe that says something.
EMT140 EMT250 Studer Shadow Hills Mastering Comp Pultec MKII Dimension D EP34
Post by Johnkenn on Nov 4, 2018 13:34:42 GMT -6
1176 LA2A 140 250 Vari Mu SSL G Bus Eden/B15 RE201 (although I just got the Audiothing Outer Space and think I like it better) BX20 Spring
Post by Guitar on Nov 4, 2018 14:18:45 GMT -6
I usually reach for the tape sims. They are a big reason I stick with UAD.
SSL channels (legacy and MK II) and compressor
Neve 1073
1176 compressors and sometimes LA2A
BX20 reverb is a new go-to
I love all the elysia stuff but I sometimes use native Plugin Alliance versions. Mpressor, Alpha compressor, MusEQ
API EQ collection - fantastic general shaper
Ampeg bass amps (in the mix, not Unison since I have no apollo)
bx Digital V3 that one also is available native
kind of wish I had the Oxford Inflator
Post by sean on Nov 4, 2018 14:27:01 GMT -6
I use the 1176, LA-2A, and Pultec collection almost always. API 550/560 regularly. RE-201, EMT-140, and Dimension D often. Ocean Way Room and EMT 250 occasionally. Valley People Dynamite when I need an easy to use expander or gate.
Post by mjheck on Nov 4, 2018 17:38:35 GMT -6
1) New 1073 with EQ engaged and driven about +5 or +10 when mixing through it 2) Transient Designer 3) EP-34 Tape Echo 4) Manley Vari Mu 5) Dimension D
I have high regard for the BX20 and the Ocean Way, but have been using Nebula reverbs these days. If I am tracking DI electric guitar, I find I use the 1176 (Blackface) and That simple little tape plug for color.
MJH
Post by stratboy on Nov 4, 2018 21:44:46 GMT -6
Both EMTs LA2A, 1176, Fairchild and Pultec collections Cooper Time Cube Brainworx EQ Harrison EQ dbx 160
Post by javamad on Nov 5, 2018 0:35:32 GMT -6
API Vision and Neve 88 channel strips (I track through them with Unison) Neve 1081 Chandler Curve Bender EMT 140 Lexicon 224 LA2A -classic 1176 SSL Bus compressor
Fairchild
Post by lcr on Nov 5, 2018 2:54:43 GMT -6
Ragan & John,
May I ask, how are you (were you) using the 250? I have this one and never really gel’ed with it. Could you suggest any particular uses, settings or presets? Thanks in advance.
Post by Guitar on Nov 5, 2018 7:08:19 GMT -6
Oh yeah... I forgot to mention Chandler Curve Bender.
I don't own that one yet but I love that thing.
Post by joseph on Nov 5, 2018 8:06:40 GMT -6
API 500 series collection SSL strip MKII (crazy good emulation) SSL GBUS MKII (same) LA2A MKII (the gray one) Curve Bender 88RS strip MKII (I tend to use SSL more but I'd say this is equal quality and better for acoustic material) New 1073 (the mids sound much sweeter and less pointy than any other 1073 emulation I've heard (the old emulation is shit in comparison), dimension/phase pretty close to my BAEs) Pultec MKII 1176 MKII API 2500 Distressor
I like their effects but I tend to gravitate more to the Relab and Exponential reverbs and Soundtoys and Eventide delays. Prob would choose BX20 to keep one.
Post by bram on Nov 5, 2018 9:16:33 GMT -6
Distressor BX20 OWS Ampex EP-34 LA2A EMT140 SPL Transient Designer 88RS New Helios Oxford inflator
Post by jdc on Nov 5, 2018 10:10:55 GMT -6
It seems that all of the mkii versions of their plugins are better, is everything listed in the store mkii?
Post by Guitar on Nov 5, 2018 10:15:36 GMT -6
It seems that all of the mkii versions of their plugins are better, is everything listed in the store mkii? Yes, generally when a MK II comes out... they lump the MK I "legacy" plugins with it as a bundle if you need to save SHARC power, or run old projects, etc I use MK I plugs on my individual drum channels since there are so many and I only have a Quad DSP.
Post by matt on Nov 5, 2018 10:30:20 GMT -6
On every session: Shadow Hills Mastering Comp WT800 B15 VoG LA2A Gray Summit TLA-100 EMT-140 and 250 Ocean Way Studio (on acoustic instruments and recorded percussion) Fairchild 660 and 670 API Channel strip
Occasionally: Curvebender 1176 collection BX-20 EP-3 VSC-2 Type 69
Own but don't use much SSL 4000E ATR-102 and Studer A800 SVT collection Lex 224 Massive Passive SPL Transient Designer Oxford Envolution Oxford Limiter 33609 Fatso IBP Pultec Collection (I'm using the recently updated Softube release)
I went through a serious acquisition phase early in my UAD ownership, and as you can see, I have quite a few plugins that just sit on the sidelines. Part of it is due to my evolving approach of "less is more" these days. Also, I think I am less likely seduced by a pretty face. Slightly.
If I were to change my purchasing approach, I'd demo everything for the full two week period whenever possible. I used to just tell myself "I need that!" and jump. No more.
EDIT: I'd use UAD comps more if the compression amount showed on the Pro Tools channel strip. Yeah I know I should listen and not look, but it's a nice visual cue to have. I'm not sure it's possible with UAD since it's been talked about for a long time.
Post by jdc on Nov 5, 2018 15:32:19 GMT -6
Drew @ UA will there ever be an LA3A mkii plugin release?
Post by swurveman on Nov 5, 2018 15:39:12 GMT -6
EMT 250 1176LN
Post by Mister Chase on Nov 5, 2018 16:40:49 GMT -6
1) 1176 A and E
2) Ampex ATR 102
3) Fairchild collection
4) Studer A800
5) SSL 4k Strip
Post by nudwig on Nov 5, 2018 20:31:23 GMT -6
I love the 1081 and LA3A, even though they could both probably use a MK2 treatment. Especially if the jump is like the others that have a MK2.
Post by Mister Chase on Nov 5, 2018 21:21:50 GMT -6
I love the 1081 and LA3A, even though they could both probably use a MK2 treatment. Especially if the jump is like the others that have a MK2. I don't quite love the 1081. I bet a mkii would bring the tone. The new Helios is amazing. I would LOVE a mkii Harrison channel strip. You have to believe they are working on one. The 88rs is good but doesn't knock me out. Though it's fine for more transparent stuff. The api vision is ok I suppose. I like the 550 and 560 better though so the strip isn't worth as much to me just for the dynamics and saturation.
Post by Drew @ UA on Nov 6, 2018 10:31:49 GMT -6
Drew @ UA will there ever be an LA3A mkii plugin release? jdc, Sorry, but as a company rule we don't ever discuss future products. I can tell you that we are slowly replacing the GUIs of many plugins, making them "retina" compatible, and the LA3 and DBX are on that list.
Post by Vincent R. on Nov 6, 2018 15:07:55 GMT -6
SSL E Channel Neve 88RS Neve 1073 Studer 800 Pultec Collection LA2A Collection Summit TLA-100
Post by Johnkenn on Nov 6, 2018 20:13:43 GMT -6
Ragan & John, May I ask, how are you (were you) using the 250? I have this one and never really gel’ed with it. Could you suggest any particular uses, settings or presets? Thanks in advance. I use it for snare reverb all the time. Percussion - shakers and Tambo. I like how you can easily control the top and bottom and it gets really great results quickly.
Post by Johnkenn on Nov 6, 2018 20:15:58 GMT -6
Forgot to mention, I use the Chandler Zener for parallel crush drums on just about every mix.
Post by Mister Chase on Nov 6, 2018 20:17:05 GMT -6
Forgot to mention, I use the Chandler Zener for parallel crush drums on just about every mix. Dude. Yes. I've been doing that on rock lately. Joe Chic preset and mix to taste. Killer.
