Post by lcr on Jan 2, 2019 7:32:30 GMT -6
The single pedal I added to my Kemper setup was a gateway pedal, I have to stop.
Post by Johnkenn on Jan 2, 2019 10:18:24 GMT -6
I mentioned this somewhere...I think I’ve too often tweaked the amp/EQ to the sound I like thereby really making every amp sound similar. I’ve been trying to match smaller amps like a small Tweed or Supros to be on the opposite side to give some differentiation. Amps that I wouldn’t initially think sound good solo’d.
Post by donr on Jan 2, 2019 15:02:14 GMT -6
I think each modeler / company tends to have a sound. Ive bought some I like, a few I don’t. Im gonna mention what I tend to like in no particular order. Tone Junkie, Big Hairy Profiles and Britt. For me, these 3 different profile makers give me a nice range. Looking forward to double tracking / panning TJ brown eyed girl with BHP friedman Les Paul chunka chunka rock. TJ always has way over the top FX going on, which I find interesting and well done for over the top, makes great fun noodling in cans but always turned off when tracking. I think the Tone Junkie profiles have effects programmed so you can step on them with a controller. I wouldn't think they were trying to sell the effected sound as a preset. It's kind of a pain to turn them off listening to each profile. I'll track with a little 'verb and delay, Kemper or not, if it's something I don't mind printing.
Post by Johnkenn on Jan 2, 2019 17:14:28 GMT -6
Yeah you can turn everything off. Actually found the TJ effects to be some of the more tasteful. With some of the Fender amps/more traditional, I've been using the newest Spring preset (knob on the right, past the delays and trems I think). I usually use it in mono just to give it a little sound like you might hear from a real amp in the room...then I'll pan parts left and right and then maybe add in stereo delay/trem/rotary or whatever stereo effect on a stereo channel... I've had my Kemper patched in to my patchbay from the TRS because I'm too cheap to buy another expensive Mogami lol. Noticed that it doesn't give near the output. Switched back and forth (using a temp XLR) and felt like the 1/4th didn't have quite the upper bandwidth which I kind of liked...so I'm keeping it that way. It totally could have been confirmation bias.
Post by cowboycoalminer on Jan 2, 2019 18:32:48 GMT -6
Do you guys record mostly in stereo or mono? I've done both but lean toward mono for most stuff.
Post by cowboycoalminer on Jan 2, 2019 18:36:45 GMT -6
The delays are really pretty good. And the new Spring is awesome too. I’ve never really played with pedals in front...might try that. I use them sometimes. Works just like a real amp.
Post by the other mark williams on Jan 2, 2019 19:23:28 GMT -6
I don't have mine yet, but my plan is to record in mono most of the time (same as I do with real amps). HOWEVER, I have a couple of pedals with stereo outputs, so I could see myself inserting them in the FX loop and recording stereo for special purposes.
Post by the other mark williams on Jan 2, 2019 21:06:48 GMT -6
Yeah you can turn everything off. Actually found the TJ effects to be some of the more tasteful. With some of the Fender amps/more traditional, I've been using the newest Spring preset (knob on the right, past the delays and trems I think). I usually use it in mono just to give it a little sound like you might hear from a real amp in the room...then I'll pan parts left and right and then maybe add in stereo delay/trem/rotary or whatever stereo effect on a stereo channel... I've had my Kemper patched in to my patchbay from the TRS because I'm too cheap to buy another expensive Mogami lol. Noticed that it doesn't give near the output. Switched back and forth (using a temp XLR) and felt like the 1/4th didn't have quite the upper bandwidth which I kind of liked...so I'm keeping it that way. It totally could have been confirmation bias. John, were you patching it in with TRS cables? Or just TS?
Post by Johnkenn on Jan 2, 2019 21:08:33 GMT -6
Yeah you can turn everything off. Actually found the TJ effects to be some of the more tasteful. With some of the Fender amps/more traditional, I've been using the newest Spring preset (knob on the right, past the delays and trems I think). I usually use it in mono just to give it a little sound like you might hear from a real amp in the room...then I'll pan parts left and right and then maybe add in stereo delay/trem/rotary or whatever stereo effect on a stereo channel... I've had my Kemper patched in to my patchbay from the TRS because I'm too cheap to buy another expensive Mogami lol. Noticed that it doesn't give near the output. Switched back and forth (using a temp XLR) and felt like the 1/4th didn't have quite the upper bandwidth which I kind of liked...so I'm keeping it that way. It totally could have been confirmation bias. John, were you patching it in with TRS cables? Or just TS? Sorry TS I get that stuff confused. They’re mogami cables.
Post by the other mark williams on Jan 2, 2019 21:09:25 GMT -6
John, were you patching it in with TRS cables? Or just TS? Sorry TS I get that stuff confused. They’re mogami cables. Well that would account for the signal loss.
Post by lcr on Jan 3, 2019 1:38:30 GMT -6
Mono here Cowboy.
Post by donr on Jan 7, 2019 11:19:14 GMT -6
Checking out the Tone Junkies profiles, the free sample pack is great. The Twin Reverb profiles are stellar, and remind me why I like push-pull 6L6 amps so much. Other goodness too. They know how to profile an amp.
Post by the other mark williams on Jan 7, 2019 13:55:30 GMT -6
Man, I'm looking forward to getting mine. Looks like it's going to be early next week. The black tabletop unit was backordered.
Post by guitfiddler on Jan 12, 2019 23:32:44 GMT -6
Just got the Tone Junkies Super Reverb. Really great. Maybe I was gone for TWO many days...lol. Did you buy another Kemper John Kennedy?
Post by ragan on May 23, 2019 12:21:41 GMT -6
Welp, I ordered another one. #3 for me. Found a good deal on the white/Storm Trooper/toaster version that I like. I'm skeptical I'll keep it but I need to evaluate it again.
Post by kcatthedog on May 23, 2019 13:14:12 GMT -6
Hmmm, if I start calling you johnk2 , is that ok ?
Post by wiz on May 23, 2019 15:49:09 GMT -6
I see Mark Knopfler is using one on his latest tour
Cheers
Post by ragan on May 23, 2019 15:55:36 GMT -6
I see Mark Knopfler is using one on his latest tour Cheers Wiz Wow. A hero of mine. That's interesting.
Post by Johnkenn on May 23, 2019 16:46:40 GMT -6
It’s the Indian not the arrow. Lol
Post by wiz on May 23, 2019 17:43:12 GMT -6
I see Mark Knopfler is using one on his latest tour Cheers Wiz Wow. A hero of mine. That's interesting. It was said that Glen Saggers (knopflers guitar tech) worked for 6 MONTHS!! getting the sounds done... Imagine if they release it as a for sale item... it would sell through the roof! Cheers Wiz
Post by Johnkenn on May 23, 2019 18:02:01 GMT -6
Wow. A hero of mine. That's interesting. It was said that Glen Saggers (knopflers guitar tech) worked for 6 MONTHS!! getting the sounds done... Imagine if they release it as a for sale item... it would sell through the roof! Cheers Wiz I want Robin Ford’s rigsss
