Post by indiehouse on Aug 8, 2018 7:32:03 GMT -6
Anyone ever use a Trinnov? Expensive as hell. Worth it?
Post by Johnkenn on Aug 8, 2018 8:23:21 GMT -6
littlesicily once told me it was one of the biggest improvements he has made.
Trinnov
Aug 8, 2018 8:59:28 GMT -6
via mobile
Post by littlesicily on Aug 8, 2018 8:59:28 GMT -6
littlesicily once told me it was one of the biggest improvements he has made. Exactly. With every penny.
Post by Johnkenn on Aug 8, 2018 10:04:36 GMT -6
Damnit
Post by littlesicily on Aug 8, 2018 10:10:18 GMT -6
If pressed, I'd sell a lot of things before ever letting this go. It influences EVERY decision I make tracking, programming, mixing. Totally cleared up the 110hz-400hz confusion. And this is in a Carl Tatz room w/ ATC 50's! Still made a massive difference.
Post by EmRR on Aug 8, 2018 10:27:53 GMT -6
Wow, what a horrible website they have.
You mean the Optimizer? They have a lot of products.
Trinnov
Aug 8, 2018 11:03:51 GMT -6
Post by drbill on Aug 8, 2018 11:03:51 GMT -6
This is for room tuning, right? Agreed on the website EmRR. If so, is it any better than say...JBL 708P's with their room correction software? I understand if your speakers do not have room correction software, but I've been eyeing the 708P's, and they've got it built in. Not sure if the Trinnov would be redundant, but I'm guessing yes...
Trinnov
Aug 8, 2018 11:10:06 GMT -6
via mobile
Post by indiehouse on Aug 8, 2018 11:10:06 GMT -6
I’m referring to the ST2 Pro
Trinnov
Aug 8, 2018 11:11:37 GMT -6
Post by Johnkenn on Aug 8, 2018 11:11:37 GMT -6
Do you have to buy the microphone too?
Trinnov
Aug 8, 2018 11:14:29 GMT -6
Post by EmRR on Aug 8, 2018 11:14:29 GMT -6
This is for room tuning, right? Agreed on the website EmRR. If so, is it any better than say...JBL 708P's with their room correction software? I understand if your speakers do not have room correction software, but I've been eyeing the 708P's, and they've got it built in. Not sure if the Trinnov would be redundant, but I'm guessing yes... The 708's have EQ, but not correction software built in. Maybe if you also buy the controller? I think you still have to run a 3rd party assessment program and then dial it in.
Trinnov
Aug 8, 2018 11:22:31 GMT -6
via mobile
Post by indiehouse on Aug 8, 2018 11:22:31 GMT -6
Do you have to buy the microphone too? Yeah, and it’s $700.
Trinnov
Aug 8, 2018 11:25:44 GMT -6
Post by Johnkenn on Aug 8, 2018 11:25:44 GMT -6
Awesome.
Trinnov
Aug 8, 2018 11:31:15 GMT -6
via mobile
Post by stormymondays on Aug 8, 2018 11:31:15 GMT -6
On the cheap side, Sonarworks did wonders for me in a professionally designed and treated room.
Trinnov
Aug 8, 2018 11:31:24 GMT -6
Post by matt on Aug 8, 2018 11:31:24 GMT -6
You'd also have to get the 8" external touch screen @ $350. I mean, why not?
Post by matt on Aug 8, 2018 12:02:41 GMT -6
I must be the only person in the world who found that Sonarworks didn't work for them. I tried the v4 demo using a calibrated mic for the full two week trial period. I ran calibration after calibration and the result was always the same: it "discovered" the slightly relaxed upper-midrange response of my PMC twotwo 8s and "flattened" the curve beautifully. But the result was a harshening of that same frequency range that no one liked. Strident and edgy would be good descriptors of the tonality with the calibration in; the response was relatively clean and articulate when bypassed. I tweaked the software endlessly to try to make it work, but no dice. I've come to the conclusion that the tone curve of the PMCs is by design, and Sonarworks negated it. Just a theory. Also, the way the software corrected the low frequencies was inconclusive- different, but not "oh wow" better. My ultimate conclusion is that my room might be so bad that Sonarworks is unable to correct for all the issues. I need to treat my room- the sub-low response is all over the place as you move around and I'm sure that I've got destructive reflections happening too. So I'm not bashing Sonarworks- it just didn't do what I expected; it didn't "fix" anything. My father used to say, "you can't make a silk purse out of a sow's ear". Words of wisdom. I need to heed them, I think.
Trinnov
Aug 8, 2018 13:05:15 GMT -6
via mobile
Post by stormymondays on Aug 8, 2018 13:05:15 GMT -6
Yes, I think a good enough room is mandatory for any EQ correction to work.
Post by indiehouse on Aug 8, 2018 13:20:34 GMT -6
I tried Dirac Live for a bit and I didn't get along with it.
Post by allbuttonmode on Aug 9, 2018 4:21:17 GMT -6
I have the ST-2 Pro. I can't live without it now. The biggest improvement I've found, is the phase and time delay. It can only do so much in correcting the frequency response of a room before you notice it. But the phase and time delay correction is amazing.
Obviously, the better the room before running a calibration, the better the result. As always; shit in, shit out.
Post by indiehouse on Aug 9, 2018 11:07:53 GMT -6
I have the ST-2 Pro. I can't live without it now. I'm finding that's been pretty much the consensus of anyone who's used one.
Trinnov
Aug 9, 2018 11:55:47 GMT -6
Post by drbill on Aug 9, 2018 11:55:47 GMT -6
Watched the VK video. Pretty insane. EQ, phase, speaker placement, time alignment, etc. all dialed. I'm wondering if it would replace my Grace m905. Obviously it does things the Grace doesn't. more investigation necessary. Thanks for the heads up.
Trinnov
Aug 9, 2018 13:38:34 GMT -6
Post by indiehouse on Aug 9, 2018 13:38:34 GMT -6
Watched the VK video. Pretty insane. EQ, phase, speaker placement, time alignment, etc. all dialed. I'm wondering if it would replace my Grace m905. Obviously it does things the Grace doesn't. more investigation necessary. Thanks for the heads up. Apparently there is a USB volume controller you can hook up to this.
Post by Johnkenn on Aug 9, 2018 16:53:06 GMT -6
Can I borrow some money?
Trinnov
Aug 9, 2018 18:06:22 GMT -6
Post by the other mark williams on Aug 9, 2018 18:06:22 GMT -6
My only real hope with a product like this is that within 5 to 10 years the technology may filter down into a more affordable product.
Post by indiehouse on Aug 9, 2018 18:27:20 GMT -6
My only real hope with a product like this is that within 5 to 10 years the technology may filter down into a more affordable product. Bricasti didn’t get that memo.
Post by the other mark williams on Aug 9, 2018 18:49:24 GMT -6
My only real hope with a product like this is that within 5 to 10 years the technology may filter down into a more affordable product. Bricasti didn’t get that memo. Yeah. Hence why I said "hope" and "may". Haha!
