Post by phdamage on Apr 4, 2022 21:01:49 GMT -6
Have any of you swapped DAW platforms after many years on another?
I’ve been using Cubase for close to 15 years now and I’m very comfortable and efficient with it. I’m clumsy with ProTools and Reaper but do own both and have worked in them here and there.
I knew it was super customizable but having just watched a video showing web based remote control, my mind is kinda blown (would kill for that - my control room is two flights up!)
Never mind the easier processor hit and numerous features I wish other DAWs would use (wet/dry blend on all plugs, pitch control wheel like on my old tape machines, for ex), I’m thinking it might be worth the learning curve.
Post by junior on Apr 4, 2022 21:18:02 GMT -6
I was a Cubase user since it was on Atari (LOL) and jumped ship to Reaper a few years ago. Kenny Gioia has a nice series of tutorials available. Takes a bit of getting used to, but I think it's worth it in the end. Good luck!
Post by Deleted on Apr 4, 2022 21:19:24 GMT -6
Have any of you swapped DAW platforms after many years on another? I’ve been using Cubase for close to 15 years now and I’m very comfortable and efficient with it. I’m clumsy with ProTools and Reaper but do own both and have worked in them here and there. I knew it was super customizable but having just watched a video showing web based remote control, my mind is kinda blown (would kill for that - my control room is two flights up!) Never mind the easier processor hit and numerous features I wish other DAWs would use (wet/dry blend on all plugs, pitch control wheel like on my old tape machines, for ex), I’m thinking it might be worth the learning curve. If you're good with Cubase just use it dude. Cubase has caught up a lot in efficiency and has a more purposeful workflow in many ways. Reaper is good to get a grasp on because all the punk and metal guys use it because you can "evaluate" it forever. A lot of stuff like comping and midi in it just suck. Also most of the stock effects are very basic, easy to use utilitarian stuff or so bad, they're beyond normally bad to "glorified shit box" like ReaComp
I mix in Reaper because it was multiplatform when Cubase was best on Windows and Logic is only on Mac. The reaper community is pretty evangelist and rather toxic when other DAWs are simply more stable, have more fleshed out basic features, less half-assed ones, and are simply easier to use. Compared to the Logic Pro Help forums and Logic Pro Gem, Reaper community just sucks.
Kenny Goia is the man because you basically would never figure how to do some stuff in Reaper without him but he is left apologizing for a lot of the crap that comes with it.
Post by Deleted on Apr 4, 2022 21:38:52 GMT -6
I should add that Logic is stuck in Apple lala land and Cubase is stuck in Steinberg lala land. Reaper is just two guys, Justin and Schwa, but it gets updated fairly regularly and maintains back compatibility even with 32 bit sessions on windows now because it can open so many plugs.
Cubase 12 is VST3 only fyi
Post by teejay on Apr 4, 2022 22:04:51 GMT -6
I use Reaper. Works for me, but I'm no power user. We need svart to give you some insights.
Post by phdamage on Apr 4, 2022 22:11:21 GMT -6
I should add that Logic is stuck in Apple lala land and Cubase is stuck in Steinberg lala land. Reaper is just two guys, Justin and Schwa, but it gets updated fairly regularly and maintains back compatibility even with 32 bit sessions on windows now because it can open so many plugs. Cubase 12 is VST3 only fyi Yeah, I’ve heard bad things about 12. I’m still on 10. I’m honestly just kinda tired of throwing money at Strindberg for updates every few years. I appreciate the more egalitarian spirit of Reaper. I just set up a little monitoring/mixing setup at home and I ended up buying a second hand license of Cubase elements just so I wasn’t carting around the stupid e-licensed back and forth. Also, I probably could have held off buying the new studio comp quite a bit longer - I’m without my UAD octo and doing fine with mixing a 50 track project at the moment. I almost never use stock plugs anyway Fair point about midi. I am clumsy enough with that in Cubase. I have done a few entire projects with it. I might try again for my session this weekend.
Post by christopher on Apr 5, 2022 0:03:09 GMT -6
Reaper is great because it’s small, easy to install, update, compatible with everything, and has a way to accomplish almost anything I want from a DAW… like the remote thing, for example.
I think the reason it’s a pain, I guess you don’t really learn to use Reaper: you learn how screwed up the defaults are, and then learn how to change them so it works the way you want them to.
Reaper is highly customizable, so you imagine how you want it to work.. then google YouTube “how to do X in Reaper.. “
It’s been good, but I don’t need as many features anymore, I’m thinking of trying other stuff. It’s hard to though with Reaper’s support so nice
Post by christophert on Apr 5, 2022 0:59:19 GMT -6
Reaper is awesome. If you like working with playlists, or track grouping for automation - then forget it. It's a shit fight in a session where you have multiple players, or even a vocal session and you need playlists. The work arounds are a nightmare. (Google "Reaper Playlists")
If you just do stuff at home, and you don't have clients in front of you, then it is a great tool, the customization is second to none.
Post by thehightenor on Apr 5, 2022 3:08:26 GMT -6
Reaper is the Sudoku of the DAW world.
I tried it and found it to cause me cognitive overload - probably my age!
What I like about Cubase is, I can get at most of its features without even reading the manual as it’s very intuitive in its operation.
My main schtick is composing/writing and VI’s/MIDI are handled so well in Cubase.
The cost of the updates spread throughout a year is without doubt the cheapest part of maintaining my studio so no complaints there from me.
Personally, I’d stick with Cubase.
Post by nick8801 on Apr 5, 2022 4:19:55 GMT -6
I’m probably biased because I learned on Reaper, but I really love it. I’ve recorded full bands, and never had an issue with takes, but maybe I don’t know what I’m missing. For me, the big difference between say a logic or Cubase is the built in instruments/loops etc. Reaper is a total blank slate, so if you rely on on some of that stuff and you really want to switch, prepare to spend some time building up a library of plugins and sounds. As far as the built in effects, I think they are great. Even reacomp lol. They’re not the prettiest looking fx, but if you never wanted to buy a plug-in, the stock reaper stuff would work just fine. I think it’s more about what kind of music/production style you are into. I teach music tech at a high school and we use BandLab. For working with loops/samples and general quick creativity it’s really fantastic. I couldn’t imagine the extra steps I would have to take if I was using reaper! If you want options on everything and the ability to do almost anything, I think reaper is a no brainer. And yes, I pay for it.
Post by svart on Apr 5, 2022 7:57:32 GMT -6
Did someone say Reaper??
I dunno. Reaper can do anything any other DAW can do and a whole lot more save for some very specific things. You've already mentioned a few reasons to use it over others, but it's also constantly being updated, and bugs are fixed immediately. You can even reskin it to look like cubase if you wanted.
Now I totally disagree with the community being "toxic".
The problem is that Reaper draws a large number of those starting out in recording due to it's "no-cost" fully featured trial.
This creates a TON of "I downloaded Reaper and hit record and I don't hear anything! Everybody stop and tell me what is wrong!!" types of threads.
Let's face it, new users are not compelled to go search for answers anymore. They create a new thread and get inundated with "go search" replies or links to tutorials.
This usually elicits a response where the OP thinks people are being condescending or unhelpful while those who reply are simply tired of the same questions over and over and you see a lot of bickering about it. I've personally tried to help folks in some of those threads and they get MAD that you aren't replying fast enough or not fixing their problem to their expectations as if you were some kind of free tech support. If anything, the toxicity is the entitlement of the younger generations, but I digress.
But once you get past those things, there is a ton of information out there and there is ALWAYS a way to do something in Reaper, even if it's a workaround. Eventually the developers will add new features as the users require but they work on priority, so some things get put aside for a long time. My guess is that something like Playlists is fairly low priority. Regions in Reaper work similarly and you can download SWS scripts that add Playlist functionality if you desire. There's always a way in Reaper. Try adding scripts and extensions for PT or Cubase to add functionality..
I've worked on PT, Logic and Cubase over the years and ended up using Reaper for the majority of my personal work. Sometimes when I go to other places to do something I have to use PT or Cubase or Logic or something and I can usually find my way around them enough to keep working, or I can download Reaper and have it set up in minutes, or take it on a USB stick with my templates ready to go. I don't find it really easier or harder than any other DAW to use in the same way that I find my Netflix app different to my HBOMax app. They do the same things, just laid out differently.
I also disagree on stability. I've never had Reaper crash without it being due to a plugin causing it. I also update just about every release now and have never had a problem.
I also own the corporate license even though I don't really need to. I just figured spending the 200$ was worth the years of updates you get.
Post by mcirish on Apr 5, 2022 8:52:27 GMT -6
I use Nuendo. I've been using it for a couple decades. Once every year, I try Reaper again. I get utterly confused on how to do basic functions and after a while, I give up. There is so much I just take for granted in Nuendo that it surprises me when I can't do similar things in Reaper as quickly. I do want to like it and use it, but it just isn't intuitive. I end up having to watch a lot of videos to understand the mindset of the developers.
Post by svart on Apr 5, 2022 9:09:32 GMT -6
I use Nuendo. I've been using it for a couple decades. Once every year, I try Reaper again. I get utterly confused on how to do basic functions and after a while, I give up. There is so much I just take for granted in Nuendo that it surprises me when I can't do similar things in Reaper as quickly. I do want to like it and use it, but it just isn't intuitive. I end up having to watch a lot of videos to understand the mindset of the developers. Like what for instance? Not trying to fight or anything, I just don't understand how folks get confused by reaper. It seems about the same difficulty as any other DAW to me.
Post by Deleted on Apr 5, 2022 9:35:38 GMT -6
Did someone say Reaper?? I dunno. Reaper can do anything any other DAW can do and a whole lot more save for some very specific things. You've already mentioned a few reasons to use it over others, but it's also constantly being updated, and bugs are fixed immediately. You can even reskin it to look like cubase if you wanted. Now I totally disagree with the community being "toxic". The problem is that Reaper draws a large number of those starting out in recording due to it's "no-cost" fully featured trial. This creates a TON of "I downloaded Reaper and hit record and I don't hear anything! Everybody stop and tell me what is wrong!!" types of threads. Let's face it, new users are not compelled to go search for answers anymore. They create a new thread and get inundated with "go search" replies or links to tutorials. This usually elicits a response where the OP thinks people are being condescending or unhelpful while those who reply are simply tired of the same questions over and over and you see a lot of bickering about it. I've personally tried to help folks in some of those threads and they get MAD that you aren't replying fast enough or not fixing their problem to their expectations as if you were some kind of free tech support. If anything, the toxicity is the entitlement of the younger generations, but I digress. But once you get past those things, there is a ton of information out there and there is ALWAYS a way to do something in Reaper, even if it's a workaround. Eventually the developers will add new features as the users require but they work on priority, so some things get put aside for a long time. My guess is that something like Playlists is fairly low priority. Regions in Reaper work similarly and you can download SWS scripts that add Playlist functionality if you desire. There's always a way in Reaper. Try adding scripts and extensions for PT or Cubase to add functionality.. I've worked on PT, Logic and Cubase over the years and ended up using Reaper for the majority of my personal work. Sometimes when I go to other places to do something I have to use PT or Cubase or Logic or something and I can usually find my way around them enough to keep working, or I can download Reaper and have it set up in minutes, or take it on a USB stick with my templates ready to go. I don't find it really easier or harder than any other DAW to use in the same way that I find my Netflix app different to my HBOMax app. They do the same things, just laid out differently. I also disagree on stability. I've never had Reaper crash without it being due to a plugin causing it. I also update just about every release now and have never had a problem. I also own the corporate license even though I don't really need to. I just figured spending the 200$ was worth the years of updates you get. The community makes reaper usable and it is so flexible it can be set up make very efficient, E.g. This is how I record drums now in it However the community is full of apologists who have never used it to make records. They’re not beginners, they just voraciously defend the inefficiencies of the software because they never encounter them. In contrast to the Cockos forum, Logic Pro help has a more sympathetic attitude. Reaper used to be super unstable until version 6.0. A lot of popular plugins could crash it upon loading the session. Now it’s better but I still get an occasional crash when mixing.
Post by svart on Apr 5, 2022 9:44:36 GMT -6
Did someone say Reaper?? I dunno. Reaper can do anything any other DAW can do and a whole lot more save for some very specific things. You've already mentioned a few reasons to use it over others, but it's also constantly being updated, and bugs are fixed immediately. You can even reskin it to look like cubase if you wanted. Now I totally disagree with the community being "toxic". The problem is that Reaper draws a large number of those starting out in recording due to it's "no-cost" fully featured trial. This creates a TON of "I downloaded Reaper and hit record and I don't hear anything! Everybody stop and tell me what is wrong!!" types of threads. Let's face it, new users are not compelled to go search for answers anymore. They create a new thread and get inundated with "go search" replies or links to tutorials. This usually elicits a response where the OP thinks people are being condescending or unhelpful while those who reply are simply tired of the same questions over and over and you see a lot of bickering about it. I've personally tried to help folks in some of those threads and they get MAD that you aren't replying fast enough or not fixing their problem to their expectations as if you were some kind of free tech support. If anything, the toxicity is the entitlement of the younger generations, but I digress. But once you get past those things, there is a ton of information out there and there is ALWAYS a way to do something in Reaper, even if it's a workaround. Eventually the developers will add new features as the users require but they work on priority, so some things get put aside for a long time. My guess is that something like Playlists is fairly low priority. Regions in Reaper work similarly and you can download SWS scripts that add Playlist functionality if you desire. There's always a way in Reaper. Try adding scripts and extensions for PT or Cubase to add functionality.. I've worked on PT, Logic and Cubase over the years and ended up using Reaper for the majority of my personal work. Sometimes when I go to other places to do something I have to use PT or Cubase or Logic or something and I can usually find my way around them enough to keep working, or I can download Reaper and have it set up in minutes, or take it on a USB stick with my templates ready to go. I don't find it really easier or harder than any other DAW to use in the same way that I find my Netflix app different to my HBOMax app. They do the same things, just laid out differently. I also disagree on stability. I've never had Reaper crash without it being due to a plugin causing it. I also update just about every release now and have never had a problem. I also own the corporate license even though I don't really need to. I just figured spending the 200$ was worth the years of updates you get. The community makes reaper usable and it is so flexible it can be set up make very efficient, E.g. This is how I record drums now in it However the community is full of apologists who have never used it to make records. They’re not beginners, they just voraciously defend the inefficiencies of the software because they never encounter them. In contrast to the Cockos forum, Logic Pro help has a more sympathetic attitude. Reaper used to be super unstable until version 6.0. A lot of popular plugins could crash it upon loading the session. Now it’s better but I still get an occasional crash when mixing. I just have a "Drum bus" folder with sub folders for each drum, like "Snare bus" which in turn have their own sub folders for original mic track, edited mic track, sample, etc. I slaved the record buttons so that all I have to do is hit one of them and they all arm or disarm at the same time. I can then do overarching plugs like EQ to the bus track but I can still edit each sub track as needed. I've used Reaper since the original beta release in 2005. I find that the after version 6 actually hates one of my plugs more than prior to version 6. Back then I only updated once per major update such as going from 4 to 5 or 5 to 6. Either way, I've never really noticed stability being a problem. I've seen tons of spinning wheels of death in studios using Logic and PT though..
Post by Chad on Apr 5, 2022 9:57:01 GMT -6
I've never used it, but I feel compelled to say... "Don't Fear the Reaper" donr
Post by Guitar on Apr 5, 2022 9:58:38 GMT -6
I should add that Logic is stuck in Apple lala land and Cubase is stuck in Steinberg lala land. Reaper is just two guys, Justin and Schwa, but it gets updated fairly regularly and maintains back compatibility even with 32 bit sessions on windows now because it can open so many plugs. Cubase 12 is VST3 only fyi Cubase 12 runs VST2 and VST3. I just got it yesterday. Haven't read the whole thread yet but Cubase seems a bit more "powerful" with some features, and Reaper seems a bit more stable, has never really crashed on me unlike Cubase. I like them both but mostly use Cubase. I think a lot of the Live Recording people use Reaper because it's stable and simple / customizable. That will likely be the gist of my division, Cubase for "producing" and Reaper for live tracking maybe. I doubt it will be so black and white, I'm glad to have both of them. I pretty much only use Reaper on my laptop, and Cubase at home. Cubase is now "dongle free" so I just installed it on my laptop yesterday... we'll see where the chips fall now that there's two competing DAWs there.
Post by chessparov on Apr 5, 2022 10:27:04 GMT -6
For those with friends like me... That are Geico Caveman.
Audacity/Bandlab/Bremmers Multitrackstudio, are among the easiest DAW's.
For mostly fun, I did get the newest N-Track. Reaper was a little too involved for me. Chris
Post by mcirish on Apr 5, 2022 10:37:43 GMT -6
I use Nuendo. I've been using it for a couple decades. Once every year, I try Reaper again. I get utterly confused on how to do basic functions and after a while, I give up. There is so much I just take for granted in Nuendo that it surprises me when I can't do similar things in Reaper as quickly. I do want to like it and use it, but it just isn't intuitive. I end up having to watch a lot of videos to understand the mindset of the developers. Like what for instance? Not trying to fight or anything, I just don't understand how folks get confused by reaper. It seems about the same difficulty as any other DAW to me. I'm just about at my yearly "time to try Reaper" session. I don't remember last week, much less last year when I tried it out again. I'm not sure if it was a midi issue or automation. There was something that got me stumped. I will give it another shot and report back.
Post by christopher on Apr 5, 2022 11:27:00 GMT -6
This is what I do everytime I install it:
- open project settings, adjust them and SAVE as Default, which includes:
- pan laws. Default there isn’t any, and pan laws sound way better. You can experiment with lots of values, I use 4.5, Just know that stereo tracks panned center will be -4.5dB, and that also means track folders and busses will lose 4.5dB. A folder feeding a bus suddenly you lost 9dB. Simple to fix, right click on the stereo track’s pan knob to override and enter the pan law.. stereo tracks/auxes/busses/folders I like 0.0dB
- Timebase for items/envelopes/etc Default is BEATS. This screws everything up for working with audio. If you record a wav, and later tap on the bpm to change the tempo for a delay sync, it will time-stretch your audio. BAD. …>>>change it to TIME, then your timeline is independent of your grid. Now you can tap the tempo meter so delays can match.
- Similarly newer versions have shipped with Embedded Tempo in the wavs. I searched google to turn that off, after I had sent wavs to a buddy and he loaded in his DAW, which slowed them down and composed a whole song to them at half speed!!!
- the MIX window defaults to arranges rows of tracks on top of each other to save space.. terribly confusing. Right click at top of window and deselect the checkbox it to get back to a normal mix window.
- always Install SWS,
Right click a blank area by the Toolbar (the strip with the lock and magnet icons) and CUSTOMIZE TOOLBAR… this is the most useful thing they bring, can make a button or shortcut for anything here.
For the TOOLBAR
- make shortcut buttons for “Create Snapshot” and “Open Snapshots”. This is for when you kind of like your mix, but want to try some stuff. You can save and recall mix snapshots here, without making a bunch of different file versions.
- make a shortcut button “solo all” and “unsolo all”
- make a shortcut button “unmute all”
It takes a few minutes to do all this stuff, but it’s soooo much friendlier to use
***By Default the timeline snaps everything to the grid. Click on the magnet icon to move anywhere.. “ALT +S” toggles between snap and unsnap. Learning that shortcut helps a lot.
….. There’s a routing matrix you can use to assign ins and outs if you like. That can be a time saver.
Post by Omicron9 on Apr 5, 2022 13:04:25 GMT -6
I left Logic for Reaper. Never looked back. Now food tastes better. Birds are singing. Flowers are blooming. I love it.
Full disclosure: I'm only using it for tracking, but never a single issue with it.
-09
Post by Deleted on Apr 5, 2022 13:10:20 GMT -6
This is what I do everytime I install it: - open project settings, adjust them and SAVE as Default, which includes: - pan laws. Default there isn’t any, and pan laws sound way better. You can experiment with lots of values, I use 4.5, Just know that stereo tracks panned center will be -4.5dB, and that also means track folders and busses will lose 4.5dB. A folder feeding a bus suddenly you lost 9dB. Simple to fix, right click on the stereo track’s pan knob to override and enter the pan law.. stereo tracks/auxes/busses/folders I like 0.0dB - Timebase for items/envelopes/etc Default is BEATS. This screws everything up for working with audio. If you record a wav, and later tap on the bpm to change the tempo for a delay sync, it will time-stretch your audio. BAD. …>>>change it to TIME, then your timeline is independent of your grid. Now you can tap the tempo meter so delays can match. - Similarly newer versions have shipped with Embedded Tempo in the wavs. I searched google to turn that off, after I had sent wavs to a buddy and he loaded in his DAW, which slowed them down and composed a whole song to them at half speed!!! - the MIX window defaults to arranges rows of tracks on top of each other to save space.. terribly confusing. Right click at top of window and deselect the checkbox it to get back to a normal mix window. - always Install SWS, Right click a blank area by the Toolbar (the strip with the lock and magnet icons) and CUSTOMIZE TOOLBAR… this is the most useful thing they bring, can make a button or shortcut for anything here. For the TOOLBAR - make shortcut buttons for “Create Snapshot” and “Open Snapshots”. This is for when you kind of like your mix, but want to try some stuff. You can save and recall mix snapshots here, without making a bunch of different file versions. - make a shortcut button “solo all” and “unsolo all” - make a shortcut button “unmute all” It takes a few minutes to do all this stuff, but it’s soooo much friendlier to use … ***By Default the timeline snaps everything to the grid. Click on the magnet icon to move anywhere.. “ALT +S” toggles between snap and unsnap. Learning that shortcut helps a lot. ….. There’s a routing matrix you can use to assign ins and outs if you like. That can be a time saver. These are all necessary fixes. is embedded tempo in the .wav files in the alt+enter menu? Also. Always hit alt-enter. set playback and render SRC to Voxengo R8brain Free. It's very good. R8brain Pro is a little better but hey Aleksey didn't give that away. Set Freeze format to 32-bit float or 64-bit float. I also like to record in float too. Set the mixer to 64-bit float.
Then on the final insert on your master bus or monitoring fx if you use them, always add a 24-bit TDPF dither. I prefer Goodhertz Good Dither in 24-bit, dither HIGH, autoblanking on, no noiseshaping. PSP X-Dither is good too but adds 1 sample of latency while Good dither has none and is more recently updated. There's also a JS: Bit-Reduction / Dither plug in Reaper but while that's better than what comes stock in some other DAWs like Logic, has more ways to go wrong.
This trades noise for truncation. The signal path is: 1. Reaper 64-bit float master out. 2. ASIO drivers can sometimes take 64-bit float but most of the time are 24-bit fixed. CoreAudio is 32-bit float. So there is a rounding in Master out -> CoreAudio and a Truncation in most Reaper master out -> ASIO drivers. 3. The ASIO or CoreAudio driver truncates to hand it off to the audio interface. Many of the volume controls in drivers are truncated too. RME TotalMix is truncated so if using it, add more dither or another instance, MOTU AVB is 32-bit float Lynx N Control has dither. Unsure about Apogee but Apogee usually uses digitally controlled analog vs pure digital volume control.
Post by tkaitkai on Apr 5, 2022 13:41:55 GMT -6
Been using Reaper for over 10 years at this point, and it's definitely a love/hate thing. In addition to christopher 's excellent suggestions, here are a bunch of things I find EXTREMELY useful: - By default, scrolling vertically with your mouse will zoom in/out of the timeline. I absolutely HATED this. Luckily, you can change mousewheel behavior to scroll around the timeline as you would in any other DAW. - On a related note, scrolling horizontally is set backwards by default, which I also hated, and can also be changed. - Install ReaMenus. God, this one is a lifesaver. Reaper desperately needs a complete overhaul of their menus, but at this point, I think they're in too deep to do anything about it. You can also add your own custom menu items. - SWS Marker Utilities. Another lifesaver. This allows you to copy & paste marker sets between various Reaper projects. - Christopher already pointed this out, but it's worth repeating — go into the mix window and disable "show maximum rows when size permits." This is easily one of the most infuriating default "features" in Reaper. You will thank us later. - Create custom buttons for grid divisions. If you want to change your grid from 1/4 to 1/16 or whatever, the default is you have to right click on the grid button and select your grid division from a menu. How annoying. I added buttons (whole note, half note, quarter note, etc.) that change the grid with one click. - Similarly, create custom buttons for any action you find yourself using frequently. I have a single custom toolbar with buttons for grid divisions, adding tempo markers, changing track colors, quantizing items, freezing/unfreezing tracks, normalizing items, adding blank MIDI items, reversing items, swapping between L/R channels in stereo items (and also doing a mono downmix), and much more. - DISABLE THE TAKES SYSTEM. Good god I hate takes. To do this, go into actions and search for "new recording trims existing items behind new recording (tape mode)." This gives you destructive recording as you would have in PT. - In preferences, disable "loop item source," especially for MIDI items. Highly irritating when working with MIDI. - SWS track list. This lets you hide/unhide tracks in a very similar fashion to PT. There's no way that I know of to truly "hide and make inactive," but you can mimic it by muting the track, alt/option-clicking on the track routing (disables routing to the master), and then using SWS to hide the track. There are probably a million other things I could think of, but that's it for now. I love Reaper now that I've sorted out most of the issues mentioned above, although I still think it kind of sucks for editing (I much prefer Pro Tools for that). But it's still a great DAW once you wrap your head around it.
Post by jacobamerritt on Apr 5, 2022 13:44:01 GMT -6
Id say try it out for a couple months- using a DAW consistently for a handful of projects is the only way to get past a learning curve. Sounds like you have a few features in mind that you are interested in, which would be the biggest reason to switch from any DAW to another. I use Reaper and have for like 7 years. Its never been unstable or closed unexpectedly etc. Currently using on an M1 Mac with no problems.
Post by christopher on Apr 5, 2022 13:49:57 GMT -6
Good stuff..
Re: embedded tempo.. I can’t remember why it did that, probably render menu that was defaulted to enabled? Or export window?
I sent my friend some loops in 4/4 to work with in Reason, he sent me the song back time stretched and slowed waaaay down, which Reason turned into 6/8. He had no idea what the original loop was. Ironically the song kicked ass that way
