Post by ericn on Jan 25, 2021 13:57:49 GMT -6
Temptation...is...strong... Shocked, truely Shocked John😎
Post by Johnkenn on Feb 5, 2021 14:07:23 GMT -6
Still waiting...sigh
Post by Hudsonic on Feb 7, 2021 11:37:40 GMT -6
I had some of the Type 69 500 series modules from Arny. Bought from VK. They sounded trashy and distorted easily with little headroom. It was not engineered well with a proper output section. I sold them. Then, a few years later, Arny died and these modules have not been available for a few years. Their rarity is part of the myth. These new modules sounded good in the video demo. Big push happening from the Vintage King.
Post by Johnkenn on Feb 7, 2021 13:07:56 GMT -6
I had some of the Type 69 500 series modules from Arny. Bought from VK. They sounded trashy and distorted easily with little headroom. It was not engineered well with a proper output section. I sold them. Then, a few years later, Arny died and these modules have not been available for a few years. Their rarity is part of the myth. These new modules sounded good in the video demo. Big push happening from the Vintage King. Don’t know how much headroom the original ones had...I think part of the issue with the Arny ones was the choice to remain true to “pulling a unit out of the console.” They only had the output transformers further down the line in the console, so they didn’t put one in the reissue modules...so you had to make up output gain with a compressor. But I wonder how much of that headroom issue is just the sound of that lustraphone input transformer. That distortion - that sounds more like ugly clipping - was just how it sounded. The Arny ones were persnickety - but if you had the input correct and made up the volume with a compressor on the back end, it was really an open, natural sounding pre that didn’t sound like others. Little more pushed in the low mids, dipped in the 1-3khz and a beautiful top end. And the eq points are great in the midrange and top. Bottom leaves a bit to be desired. I’m hoping these new ones address some of those issues.
Post by matt@IAA on Feb 7, 2021 13:17:08 GMT -6
I don’t know which desk y’all are referring to, but the Musicland console doesn’t have any output transformers. I have been told none did, originally. The sum amp is basically the same as the mic pre, just with a little different compensation. They ran internally at low level, around 0 dBu. The distortion comes on so early because the first transistor in the amplifier is biased “wrong.” It’s actually extremely similar to the preamps in the early Trident desks - the A range. Those are “right” but they sound different.
Post by nobtwiddler on Feb 7, 2021 17:24:26 GMT -6
If used within their headroom limits, the Helios Type 69 modules sound GREAT~! And as John stated previously, if followed by another amplifier, like Capi's Missing Link, and or a Compressor / Limiter, which is the route I took for each of my 16 channels. They sound simply beautiful, and are wonderful.
I mean look, no...actually listen to their history.
Back then, it wasn't Neve that wrote the book on early 70's British Rock n Roll, it was Helios!
Post by roundbadge on Feb 7, 2021 19:05:20 GMT -6
All very intersting. Does anyone know the price of the Realios? I had 4 realios before I got 4 original Lutraphone 001 modules. the Realios were nice mic pres and had more output gain but kinda vanilla next to the real ones
Post by roundbadge on Feb 7, 2021 19:11:12 GMT -6
I don’t know which desk y’all are referring to, but the Musicland console doesn’t have any output transformers. I have been told none did, originally. The sum amp is basically the same as the mic pre, just with a little different compensation. They ran internally at low level, around 0 dBu. The distortion comes on so early because the first transistor in the amplifier is biased “wrong.” It’s actually extremely similar to the preamps in the early Trident desks - the A range. Those are “right” but they sound different. the originals definitely had headroom issues out of the console.you had to stage them accordingly. I felt the synergy between the eq and pre were kind of the ticket to that sound. I always cranked the 2.8 or 3.5k. esp on guitars. I found it interesting the waves version even mimic'd the low bump when the eq was engaged.I compared directly with the real thing. I'm glad the H2's have a proper output stage. I'm told end of month for delivery. looking forward to checking them out
Post by drumsound on Feb 8, 2021 8:47:05 GMT -6
All very intersting. Does anyone know the price of the Realios? I had 4 realios before I got 4 original Lutraphone 001 modules. the Realios were nice mic pres and had more output gain but kinda vanilla next to the real ones That's interesting. I do (jealously) remember you documenting the Helios quest a few years back.
Post by Johnkenn on Feb 8, 2021 12:56:00 GMT -6
I don’t know which desk y’all are referring to, but the Musicland console doesn’t have any output transformers. I have been told none did, originally. The sum amp is basically the same as the mic pre, just with a little different compensation. They ran internally at low level, around 0 dBu. The distortion comes on so early because the first transistor in the amplifier is biased “wrong.” It’s actually extremely similar to the preamps in the early Trident desks - the A range. Those are “right” but they sound different. the originals definitely had headroom issues out of the console.you had to stage them accordingly. I felt the synergy between the eq and pre were kind of the ticket to that sound. I always cranked the 2.8 or 3.5k. esp on guitars. I found it interesting the waves version even mimic'd the low bump when the eq was engaged.I compared directly with the real thing. I'm glad the H2's have a proper output stage. I'm told end of month for delivery. looking forward to checking them out Tim said they were working on getting them out the door early this week. Hope that’s true.
Post by roundbadge on Feb 8, 2021 20:42:33 GMT -6
I had 4 realios before I got 4 original Lutraphone 001 modules. the Realios were nice mic pres and had more output gain but kinda vanilla next to the real ones That's interesting. I do (jealously) remember you documenting the Helios quest a few years back. oh sorry price wise I bought the 4 modules from Dave Cobb I think for 600 ea?
Post by Johnkenn on Feb 8, 2021 22:46:46 GMT -6
That's interesting. I do (jealously) remember you documenting the Helios quest a few years back. oh sorry price wise I bought the 4 modules from Dave Cobb I think for 600 ea? Oh good Lord
Post by roundbadge on Feb 9, 2021 0:48:01 GMT -6
oh sorry price wise I bought the 4 modules from Dave Cobb I think for 600 ea? Oh good Lord haha the Anamod realios 500's. not the the real helios.
Post by Ward on Feb 9, 2021 9:20:37 GMT -6
haha the Anamod realios 500's. not the the real helios. For a moment, I thought we had a reference point and was about to ask Chris to send Charlie to visit you!
Post by Johnkenn on Feb 9, 2021 10:59:13 GMT -6
haha the Anamod realios 500's. not the the real helios. Oh...ok...now I feel better. You had the real ones though too, right?
Post by roundbadge on Feb 10, 2021 13:27:44 GMT -6
haha the Anamod realios 500's. not the the real helios. Oh...ok...now I feel better. You had the real ones though too, right? the real ones were around 4k each not racked. I saw one on reverb for 5.thats VK level prices.
Post by kcatthedog on Feb 11, 2021 9:57:10 GMT -6
Eddie analyzing the Watchtower intro guitar part and eventually talking Helios! He talks mikes later too.
Post by Johnkenn on Feb 11, 2021 10:38:27 GMT -6
Hoping my 2128 (mic pre) is coming in today.
Post by audioscape on Feb 11, 2021 14:06:29 GMT -6
haha the Anamod realios 500's. not the the real helios. For a moment, I thought we had a reference point and was about to ask Chris to send Charlie to visit you! ON GUARD!!!! 😂😂😂
Post by audioscape on Feb 11, 2021 14:06:45 GMT -6
Hoping my 2128 (mic pre) is coming in today. Excellent! Can’t wait to hear your thoughts John!
Post by Johnkenn on Feb 11, 2021 14:47:47 GMT -6
Hoping my 2128 (mic pre) is coming in today. Excellent! Can’t wait to hear your thoughts John! I'd much prefer a cheaper version lol.
Post by Ward on Feb 11, 2021 15:05:32 GMT -6
It's an option everyone should have. Love how EK describes it too!!
Post by audioscape on Feb 11, 2021 18:50:36 GMT -6
Excellent! Can’t wait to hear your thoughts John! I'd much prefer a cheaper version lol. 😂😂 ahhhh man y'all are killing us! hahahahaha
Post by roundbadge on Feb 12, 2021 2:35:52 GMT -6
Post by roundbadge on Feb 12, 2021 15:16:35 GMT -6
I ordered the full size modules and rack
