Post by gouge on Feb 21, 2014 16:32:31 GMT -6
so looking for tips.
I did a drum session recently where I was very happy with all except one thing. (retrospectively speaking) the hats are full on. at the time of sound check I moved my top snare mic around to minimise the impact of the hats. mic was an atm450. it sounds sweet on snare, its card but the drummer seemed to be smashing the hats a little to much.
hats are 14" k custom.
so any tips to tame the hats?
keys in the hat, close the gap between top and bottom hat?
any tips?
Post by jazznoise on Feb 21, 2014 16:56:31 GMT -6
Some light de-essing/compresser sidechained to the hat on the overheads and rooms post is all I can suggest now. For songs without a lot of tom action, sometimes running the drum overheads into an expander keyed to the snare can make you less reliant on the OH sound in general.
Sort of on off topic: I've heard talk either way that bigger hats or smaller hats are louder. Has anyone any input on this?
Post by Ward on Feb 21, 2014 17:30:02 GMT -6
Have you tried flipping the phase on the hi hat mic?
Post by Ward on Feb 21, 2014 17:31:47 GMT -6
Sort of on off topic: I've heard talk either way that bigger hats or smaller hats are louder. Has anyone any input on this? 14" K series hats are louder than 13" K series hats/ I have both here in my studio. It is a rare day when the 14s win out over the 13s, in any situation. the 13" k series Zidjians are just THAT good.
Post by gouge on Feb 21, 2014 17:36:14 GMT -6
no hat mic this session. I've tracked this drummer before and not had the problem but for some reason this time.....
any techniques other than placement I can take forward next time.
sounds like smaller hats might be worth looking into. micing the hats so I can play with phase....
I might try some other mic choices next time as well.
Post by jazznoise on Feb 21, 2014 17:52:02 GMT -6
Sort of on off topic: I've heard talk either way that bigger hats or smaller hats are louder. Has anyone any input on this? 14" K series hats are louder than 13" K series hats/ I have both here in my studio. It is a rare day when the 14s win out over the 13s, in any situation. the 13" k series Zidjians are just THAT good. Then someone explain how Greg Saunier uses 2 rides for a hi hat and makes them and the kit balance sound freaking amazing!? Is it that they're bigger but also thicker? Different sticks make a difference too. He hasn't swapped to nylon tips, has he?
Post by drumrec on Feb 21, 2014 17:56:27 GMT -6
Meinl Byzance Vintage Series does not take over too much when recording, though you hit pretty hard. Then you can give the drummer thinner drumsticks in the right hand, usually work! Then I watched some producers put on electric collars that send electrical impulses if the drummer comes across a particular db. But those first two proposals is to recommend /H
Post by jcoutu1 on Feb 21, 2014 17:57:44 GMT -6
I have 13" K Mastersounds and they're killer. Sound nice and not too loud. I had a pair of 15" Z Custom Mastersounds for a short time. They were super loud and bright.
Post by gouge on Feb 21, 2014 18:19:23 GMT -6
it's interesting to hear the responses.
I'm starting mixdown next week so i'll give jazznoises desser a go. steve albini is also a big fan of this method.
on the actual cymbals. I must have it about face from what I'm reading. I had always been told that in a live situation the smaller hats were preferred because they tended to cut through more, bigger were a bit smoother.
has anyone tried keys in the hats?
Post by jcoutu1 on Feb 21, 2014 18:25:44 GMT -6
For me, it's more the material of the cymbal than the size though I think.
Post by svart on Feb 21, 2014 18:28:08 GMT -6
Usually hats have small range of peaks in the frequency range. Use a very narrow Q boost to sweep around and find the loudest one and cut it.
Post by drumrec on Feb 21, 2014 18:31:12 GMT -6
I had always been told that in a live situation the smaller hats were preferred because they tended to cut through more, bigger were a bit smoother. It's true! Live situations, I use a little more bright hihats and cymbals as they cut through the sound wall (of course depending what style of music). But in the studio recording I choose the other way around the dark cymbals so it will be more pleasant and easier to mix the drums.
Post by drumrec on Feb 21, 2014 18:43:12 GMT -6
Usually hats have small range of peaks in the frequency range. Use a very narrow Q boost to sweep around and find the loudest one and cut it. Absolutely, but I still think it destroys 2 much of the sound of the snare drum if you cut out too much hihat frequency. So there are no shortcuts, play more gently on hihat
Post by cenafria on Feb 23, 2014 1:39:17 GMT -6
it's interesting to hear the responses. I'm starting mixdown next week so i'll give jazznoises desser a go. steve albini is also a big fan of this method. on the actual cymbals. I must have it about face from what I'm reading. I had always been told that in a live situation the smaller hats were preferred because they tended to cut through more, bigger were a bit smoother. has anyone tried keys in the hats? I do the keys in the hat thing a lot. It's better to do it with coins though. Once a drummer left his home keys in the hi hat and i had to go back to the studio after a long session. I keep a bunch of coins around in the live room. Doesn't work that well for open hat. Darker hats help. It is really hats that are too bright that eat up guitars, vocals, etc and might end up as the "loudest thing" in the mix. Room mics help. If the hat is too loud, at least you can place guitars "in front" of it. Keep your guitars or any instruments that should be more prominent in the mix, as dry as possible. If you didn't record room mics for the drums, fake it with a chamber or a reverb. Roomier drums and drier "melodic" instruments might not have been you initial idea, but it will help when rerecording is out of the question. Hats that you can bend with your hand will be less of a problem. Larger diameter hat will sound darker usually. I have a set of 15" Turkish classic hats that are fairly dark and "grainy" sounding. I also have a 14" Turkish classic crash that can function as the top hat. It is thin and dark. It works well but if it is hit too hard, it will bend out of shape and ruin the take. If the drummer is ok with moving the hat a little, raising it usually helps. He cant hit it as hard or were it sounds the nastiest. Avoid nylon tipped drum sticks. They make the cymbals sound much more present. Sometimes using an "end fire" mic for the snare instead of a "side address" mic can help. You can get a little more separation with your mic positioning. Perhaps the snare wont sound as natural as you would like, though. You can find quite a lot of hi hat spill in the rack tom mic as well as in the snare mic. Changing the mic placement here might also reduce some spill. Talking to the drummer and explaining the situation is important. He or she should be aware of how his playing "translates" into the control room. However, there are many drummers that cant really change their playing style in the middle of a session. Use a louder snare. Avoid snare muffling as it doesn't just change the sound (shorter, drier) it also reduces the volume. More snare in the snare mic will help. These are the things I can think of from the top of my head.
Post by gouge on Feb 23, 2014 4:49:47 GMT -6
hat height was an issue Javier,
this drummer likes to set his hats very low. so low it had me buying new snare mics for his sessions. I picked up the atm450 just for him and found I liked it on snare.
I've always shied away from getting him to move his hats. but will have a chat next session.
room mics I ran were an MS setup in front and a hallway mic and there does seem to be some hope there if I mix it well. tom mics I think were not picking up much hat spill but will need to double check.
so what does the coins in the hat do. does it reduce the sustain?
Post by cenafria on Feb 23, 2014 6:25:52 GMT -6
Coins/keys in the hat trick reduces volume without changing the sound like using duct tape. Drummers don't find it objectionable. I first read about it on a post by Steve Albini in the old PSW forum a while back.
Post by gouge on Feb 23, 2014 6:35:35 GMT -6
excellent, thanks. :-)
Post by cenafria on Feb 23, 2014 6:57:14 GMT -6
Thanks. I found a link to the Albini PSW post through a post in the EA forum. I hope it's ok to post links to other forums : ) (You have to scroll up to the post. Uhm, ninth from the top I think)
Post by gouge on Feb 23, 2014 7:21:47 GMT -6
great stuff. I am such an albini fan. it's his drum sound I most try and emulate currently. I love it. big thunderous and real!
Post by tonycamphd on Feb 23, 2014 10:13:22 GMT -6
Some light de-essing/compresser sidechained to the hat on the overheads and rooms post is all I can suggest now. For songs without a lot of tom action, sometimes running the drum overheads into an expander keyed to the snare can make you less reliant on the OH sound in general. Sort of on off topic: I've heard talk either way that bigger hats or smaller hats are louder. Has anyone any input on this? bigger, thinner hats are tame in comparison to the opposite IME
Post by tonycamphd on Feb 23, 2014 10:20:26 GMT -6
Then I watched some producers put on electric collars that send electrical impulses if the drummer comes across a particular db. treating us drummers like the barking Dawgs we most certainly are!!
Post by tonycamphd on Feb 23, 2014 10:29:04 GMT -6
any tips? I totally agree that certain condenser mics sound GREAT on snare, I know this is already a done deal tracking wise, but when i use a condenser, i try to get it as close as possible and still sound good, so there is a larger db range between the desired snare signal and bleed for gating and expanding downward if necessary. that said, great drummers mix themselves IMO
Post by drumrec on Feb 23, 2014 13:11:05 GMT -6
Then I watched some producers put on electric collars that send electrical impulses if the drummer comes across a particular db. treating us drummers like the barking Dawgs we most certainly are!! We have to put up with a lot in our profession, haha
Post by cenafria on Feb 24, 2014 1:52:10 GMT -6
great stuff. I am such an albini fan. it's his drum sound I most try and emulate currently. I love it. big thunderous and real! He makes incredibly good sounding recordings imo. They stand out on a good system. The delayed omnis on the flor technique also helps with the hat. Hat and cymbals are the furthest away from the mics. It's a technique you can use in smaller rooms as you get no reflected sound from any surface. You can use a lot of the room signal and still have definition in your drum sound.
Post by jimwilliams on Feb 24, 2014 10:35:26 GMT -6
You need to tame the drummer.
