Post by svart on Feb 3, 2014 10:16:14 GMT -6
There have been lots of clones. Many sound really good on acoustic guitar because that's what the 84 is noted for but forget about vocals, strings, horns, drums, electric guitars, orchestras, etc. Any 84 or 87 that looks pretty new has probably had the housing replaced. My understanding is that the main difference between an 84 and a 184 is that the capsule isn't interchangeable, is a slightly different design and there is no transformer. The circuit is completely different. The KM184 has a number of transistors mounted to a ceramic amplifier card, whereas the KM84 had a single FET feeding the transformer.. My KM184's also have removable capsules, but I think they have the sound holes on the capsule so they won't work on a KM84. Honestly I think they sound more alike than anything else does. This probably shows that the capsule has a lot more to do with the sound than the amplifier/transformer does. Anyway, the KM184 is extremely cheaply made compared to the old KM84. the XLR is thin plastic and has a tendency to wiggle. The circuit board isn't mounted on anything but the XLR and they used foam to hold the board in place (sort of..). Huge difference in build quality.
Post by Deleted on Feb 3, 2014 11:00:28 GMT -6
TLM102 is where you begin, you can probably stop there too. I was a fan of the mic when I got it a couple years ago, I traded up to a TLM49 and then 6 months later bought another 102. The last few weeks I've used that mic on every vocal that's been through here and I can't sing it's praises enough. It's by no means harsh, if you're used to really colored mics this might not be the best choice but it's an extremely good vocal mic and at it's price point I'd recommend getting one as a first LDC on the basis that you will not outgrow it. I just need another one now for overheads.
Post by Johnkenn on Feb 3, 2014 11:08:20 GMT -6
I might have Shannon work on a capsule for the Miktek C5...
Post by geoff738 on Feb 3, 2014 11:13:39 GMT -6
So, don't get 184s then! (Actually leaning to the Beyer 930s in the SDC side of things or maybe another Joly modded Oktava as I already have one of those). I saw the Heil dynamics mentioned too and I'm curious about them as well.
Ok, I didn't start this to necessarily talk about my particular mic search, but what the heck. I have a decent collection of dynamics - could cover a full band of typical instrumentation and I have a lot of the usual suspects - 57s, SM7, 421 etc. One ribbon (AEA). SDCs I could use. For LDCs I have a Soudelux U195, and the Joly modded Oktava that drbill described as being U67ish. That's it. I also have a pair of AT 4033s and a pair of Kels that are both more what I'd call mid-sized DCs.
Now, given that I'm purely a weekend warrior, that I rarely (like twice a year) record full bands, that I generally record myself and so far have found the SM7 works better on my voice than anything else I've tried - I have more than enough mics already. But, I like gear and obsessing over gear and joining forums that talk about gear and sometimes even plugging in the gear I already have.
So, if I were to get another LDC, my thinking was get something as different as possible from what I already have. And that's where you guys could help. Let's pretend for now that my Joly is kinda 67ish as drbill has described. Where would you put the U195 in the flavor/ mic family. It certainly has a brighter top than the Joly. It has been described as a poor man's 87 - but I don't really know if that's accurate. I guess knowing what mics you think would be similar in character - and therefore I should bypass for now - would help.
My thinking for the moment is that I have neither a multipattern nor tube, so I'm leaning towards something having both those features. And given that I'm just a hobbyist, leaning toward the budget end of things. Does this make sense? Now, I also don't have the experience with the real deal to have a clue whether something in the 47ish camp would be better or C12 or 251 or whatever. I do know that I'm not looking for something bright/ modern.
Ok, that was more longwinded than I had intended. But it's what I do.
Thanks!
Cheers, Geoff
Post by watchtower on Feb 3, 2014 11:44:17 GMT -6
I might have Shannon work on a capsule for the Miktek C5... Could be interesting. I'm getting my matched pair repaired right now.
Post by Guitar on Feb 3, 2014 12:54:58 GMT -6
I like my KM184 quite a bit, and would like to make a pair. Yeah I wish it were more industrial like a Shure, but mine is actually pretty sturdy, for what it is. No wiggles or anything. Very light weight. It's a special mic for its full and smooth midrange, and bass. Very different from any other SDC I have tried.
Post by tonycamphd on Feb 3, 2014 13:19:29 GMT -6
So then what would be the next best SDC in line after the km84? Inquiring minds want to know 8)
Post by svart on Feb 3, 2014 14:06:32 GMT -6
I like my KM184's a lot. I really don't get the hate out there for them. Seems like most of the haters are folks who want to drive up the KM84 prices. It's rather funny that I've seen a handful of shootouts with the km84 and km184 where folks pick the KM184 blindly as their favorite and then cry foul when it's revealed. Stuff like "you mixed up the files by accident" or "you must not have used the mics in the same position" typically fly around quickly afterwards.
Post by popmann on Feb 3, 2014 14:38:58 GMT -6
I've never had an issue with them. FWIW. Except they're big money for SDCs. Once you hit the level of "industrial" (ha...I like that)...451s, 81s, 4051s ($700-1k/pr)...you've hit the level of diminished returns for me. The rule of doubling starts to get significant.
That's actually the reason I make the rec I do for home studios. If an sm7 or an sm81 sounds bad? You've got another problem. Which doesn't mean there's not several levels of "better still"...but...it's not found with budget LDCs. Which I would point out are more like a Les Paul to Strat than a Squire versus Custom Shop strat. I'm not caught up up the nuance of sniffing of corks for audio woodiness...they're wholly different instruments that the LDCs of yesteryear. They're also, at ALL levels of modern manufacture--more consistent unit to unit than LDCs. I've used some really nice sounding less expensive LDCs thatI won't mention because the one RIGHT NEXT TO it...sounded like utter ass. And, that actually applies up the price chain with LDCs--but, not dynamics and SDCs, IME.
Just wanted to point out as we get into now rare and boutique level SDCs....which is fine...but, my rec is related to price ranges discussed. And SDCs hit that diminished return point for me at about $700-1k/pair...dynamics less than that...a pair of solid performing NEW LDCs? You could buy a small...kind of shitty car for the money it would cost. Which is why I make the recs I do.
I've got something to add to the wife analogy. When I the little studio I worked in closed and I started building my "serious" home set up (man, if you knew how funny I find those quotes)...I coulda bought a pair of 87is for $3k. I loved them on everything. Where I didn't love them-they were "fine". Of course, now a pair of 87is are more like $5-6k and 20 years older...but, when I think about ALL the mics that came through here...even if I'd just bought off my two faves from the studio--ONE 87i and the pair of old 451ebs....what the fuck would I have ever looked at another mic for? Other than the Royer which wasn't around...but, who knows if I'd even have tried one...looking back? It would've been wiser to have borrowed the money for those and paid it back over time than have bought, sold, rented over the years...ehh...hindsight, you know?
Post by svart on Feb 3, 2014 15:59:43 GMT -6
I have to agree 100% on this. If I hadn't bought mine for cheap, I probably wouldn't have ever bought them and would have been happy working with what I already have. However, now that I have them, I have to say that while they aren't "worth" their price in materials, they are definitely worth it in results.
Post by geoff738 on Feb 3, 2014 16:34:11 GMT -6
I think part of the thing with 184s is that they're like the new Coke. If they'd just kept the 84s and introduced the 184 as a more budget conscious version, I doubt there'd be nearly as many complaints. That and there are lots of bright SDCs to choose from already.
If Neumann could make 84s again priced competitively with the ones on the vintage market and still make a profit, I wonder why they wouldn't.
Cheers, Geoff
Post by Guitar on Feb 3, 2014 16:45:24 GMT -6
I have heard they have all the parts to make U67 as well?
I'm not sure why they refuse to go backwards, with so much obvious market for originals like that, with the clone armies and whatnot. Maybe they just have pride in their new designs or something, want to keep moving forwards. Maybe they're really into specifications and test results that the old mics don't compete in vs. the new ones, regarding noise, distortion, etc. Could a company like that put out an old noisy design like the KM84? Or do they take pride in "advancements"? I wish I knew more about the insides of pro audio equipment companies. I do get the idea that engineers like to "innovate" and use their skills. Just look at Rupert Neve and the original API guys, not making their old circuits, but taking them steps further. They seem to evolve.
Post by watchtower on Feb 3, 2014 17:30:07 GMT -6
I highly doubt there's enough NOS EF86 for a production run, let alone NOS BV12 transformers.
Post by popmann on Feb 3, 2014 18:01:26 GMT -6
Yeah, I think the ones they made in the 90s were rid themselves of whatever was left....other than whatever calculated for repair work. Re:67s parts.
....BUT....you know...the 87AI is a 67 cap, and they are so inconsistent, IME, I think the reason these old mics are better has retired or died. And why I find it odd when people offer the really expensive Neumann caps as "upgrades" in part mics...I don't necessarily think a NEW Neumann cap is necessarily any better than a good clone.
That said, and I've said this before--AMI makes the transformer...no one does 67 clones (except Wunder, whose sounds patently brighter) for a very specific reason--the new market engineers wouldn't buy them. They're "dull". They're "honky"...there is simply nothing sexy about 67s. Well, there is--but, it's a mature sexy--not a push'em up and put'em in your face while Motley Crue plays over a PA sexy.
Post by Deleted on Feb 3, 2014 20:43:27 GMT -6
but, it's a mature sexy--not a push'em up and put'em in your face while Motley Crue plays over a PA sexy. but the women who did that in those motley crue videos would be considered 'mature sexy' now lolol :-P
Post by popmann on Feb 3, 2014 20:59:04 GMT -6
Post by Bob Olhsson on Feb 3, 2014 21:38:00 GMT -6
My biggest issue with the 184 is the tendency to pick up radio stations.
I think the main reason only label studios bought lots of 84s and 86s is because they were too easy for people to walk off with in their pockets.
Post by Johnkenn on Feb 3, 2014 22:27:36 GMT -6
As long as it's not Country stations...who wants to hear the same song in constant rotation...but I digress.
Post by svart on Feb 3, 2014 23:05:07 GMT -6
One of my 184's has another blank PCB with only a ground plane soldered to the back of the original PCB. I assume it's used as a cheap RF shield. Both of mine also have ceramic substrate amplifiers mounted off the main PCB with stand-offs. Earlier versions had all the components mounted directly on the PCB. I suppose there are a few improved versions over the years.
Post by Shannon on Feb 4, 2014 1:40:50 GMT -6
Pretty kewl thread and lots of good info that has been collected over the years. I quickly skimmed through it, and everyone seems to be right in some way. Hey just kinda throwing it out there, would anyone be interested in some small diagphiam NICKEL capsules for the miktek C5 or others hit me up here or at Shannon@micrehab.com. Im curious how many people would be interested. One of the biggest motivators for me is (* Excluding the CLASSICS * ) So many of the affordable Mics that are mentioned in this and many other threads, and the Talent, gifted, blessed, Gear Junkies, tweakers, the one that can use and appreciated them are forced to get due to cost, budget, day job, WIFE, KID, food, electric...... really are very similar built and sounding. Its hard to find one in that area the has the thing that we all love and got us hear today. THAT classic vintage sound, and traits. Although Described different by many, yet all the same at the end of the day..... That group of mic are hyped and seem to be very close sounding. Im pretty sure that all us could tell a U47 out of a crowd, REmove that mic from the rest and it would harder to identify whats left in that price range Not that they dont sound good. What really makes me smile at the end of the day, is after 3 seconds rule. Meaning after hearing a mic i worked on, to see that person that could shine like the sun on a u47 or 251 or..... , Now almost someone has lit a fire under them, and confidence as well sing better than they did when they walked in. and has that smart ass grin, of HELL YEA, bring it.... No shit i sound like that, Thanx dude. Which now brings me to the point that i was getting at. The majority of mics in that range are honestly built closely. I hope i dont cuz a PANTIES IN A BUNCH party when i say that most of your sound 70%-80% comes from the capsules. Those capsule are taken off the shelf and installed. end of story. The reason i like the Miktek ( not just cuz i worked on them ) a couple things but mainly was thier capsule choice. It was, and is built out of the circle and well., I believe the BEEZKNEES capsules are very good example to Im sure there are some that srry if i didnt mention. But with so many similiar yet very good, but not that $8,000-$15,000 sound that we want for a "G" the OG stuff is and will always be the bomb. Like Bob O mentioned a simple thing that is always or easily overlooked is the mic placement. That sweet spot isnt the same on every women, nor the distance and setup of mics, like both if done right its the bomb, and yes both can be easily overlooked, and the difference between making it or not. You know what im gonna quit while im ahead. Also i can mod not just the miktek but almost any. depending how much dna of each mic you want. There is alot of things to look forward to in that area very soon. drop me a line if you would be interest in the Nickel to give me a ideal of how big of a project it can be. Sinsay Sorry for the omits and typos keyboard works sometimes
Post by dandeurloo on Feb 4, 2014 9:42:25 GMT -6
The Joly modded SDC's are really great value as well. I have tracked drum OH's with them many times and some acoustics. They are a great value. If I was to buy some cheap SDC's those would be it. If I was to buy something not on the cheap that wasn't KM84's, KM54's I would look at the Gefell M300's. Those are really nice mics. They are probably the best of the mid ranged price current production SDC's.
Sinsay, you should look at fixing up some of the cheaper tube SDC's so they are more inline with the KM54 or older gefel tube mics. That was something I was thinking of doing but haven't had time to explore. That would probably be more interesting to a number of people.
Post by Shannon on Feb 4, 2014 9:55:28 GMT -6
The Joly modded SDC's are really great value as well. I have tracked drum OH's with them many times and some acoustics. They are a great value. If I was to buy some cheap SDC's those would be it. If I was to buy something not on the cheap that wasn't KM84's, KM54's I would look at the Gefell M300's. Those are really nice mics. They are probably the best of the mid ranged price current production SDC's. Sinsay, you should look at fixing up some of the cheaper tube SDC's so they are more inline with the KM54 or older gefel tube mics. That was something I was thinking of doing but haven't had time to explore. That would probably be more interesting to a number of people. Yea will do. The whole time thing is a problem for us all. Thats why wanted to see how many people interested in the half dime. Nickel. i have had alot of inquiries already before the mention of this. see how it goes Sinsay Shan
Post by Ward on Feb 5, 2014 9:59:35 GMT -6
So then what would be the next best SDC in line after the km84? Inquiring minds want to know 8) The AKG C460, IMHO. But I wouldn't go as far as "next best". I would suggest it is just as good, just slightly different. I truly LOVE all my C460s. Big and warm, neutral mids and a sparkly top end that can vary depending on which capsule you use: Omni, cardioid, hyper cardioid or even a ring adapter and use a CK1 capsule from the C451 for extra sparkle and/or cut.
Post by grummy on Feb 5, 2014 15:35:28 GMT -6
The AT5040 has my interest as of late. I happened to be in one of the local stores when a the AT rep popped in. The thing looks and feels great. Also had a chance in the store to hear a comparison between it and a u87ai. Personally I liked what I heard from the 5040 more.
Considering selling a couple of my mics and getting one. Anyone on here tried a 5040?
Post by Deleted on Feb 7, 2014 11:39:53 GMT -6
I'll be testing out a michael joly ribbon mic next week. might add a ribbon to use alongside the S.R.cv4
