Post by Johnkenn on Jan 19, 2014 8:53:28 GMT -6
Speaking of playing with the Kemper...I sat down and spent about 3 hours yesterday with it...Started fresh with profiles. And holy shit. The clips I posted in the first post pale in comparison...
Here's what I posted on the Kemper Forum...
I have a ton of TAF and Soundside amps...but I really got into the parameters. I started by zeroing everything out - EQ and all amp parameters. Then adding in a tiny bit of verb - ambience/low mix %/Time at around 1.4/Damping high...Then slowly turning the definition up until it sounds the best to my ears for the particular model. Then setting the EQ. Alot of the TAF plugs tend to have two EQ's set...I tended to take the stereo one off and tweak the parametric to take out offending tones - seems like I tended to dial out 10kHz in pretty much everything. Then tweak the Amp EQ to taste.
I'm telling you - I have the baddest ass Fender Super Reverb, AC30 and EC Tremolux (with treble booster) I've heard. Holy shit. I'm gonna follow this process on all of my patches.
OH - another parameter that really, really seems to bring the crunchy, tweeds and blackfaces alive is the "Power Sag"...man, crank that up and you still hear that clean tone behind it...fantastic.
I'm gonna have to post just short 4 sec clips of each of the amps I've done this way. That Tremolux and the AC30 are unbelievable...
I just don't think I can sell this thing...and I've got a guy that's ready to buy.
Post by Martin John Butler on Jan 19, 2014 10:02:32 GMT -6
Forgive me, but I' a little behind the curve here, "The Kemper" is a $2,000 profiling amp?
Post by jazznoise on Jan 19, 2014 10:15:49 GMT -6
To talk in purist terms - any situation in which the electric guitar is not acoustically coupled to the amplifier is not true to how the instrument is played live. The feedback between the guitar and amplifier is a big part of the electric guitars sound.
But that doesn't mean that having that feedback makes the guitar do what you need, it's just an abstract fact.
Post by Johnkenn on Jan 19, 2014 10:45:03 GMT -6
I'm gonna post a few of those files here...see if I can make believers out of you snobs...
Yes, Popmann, I know you will hate it. It's a badge of honor...
Post by matt on Jan 19, 2014 10:59:11 GMT -6
I'm gonna post a few of those files here...see if I can make believers out of you snobs... Yes, Popmann, I know you will hate it. It's a badge of honor... Very interested in this, JK. Post away!
Post by Ward on Jan 19, 2014 12:45:16 GMT -6
That might be a good idea once the forum gets a little bigger. I don't know if I love separating everything out so much though. Agree completely! This often happens and you get lost trying to find information.
Post by Johnkenn on Jan 19, 2014 12:51:01 GMT -6
Totally agree, Ward...Gearslutz has - what - 30 sub forums? It's an absolute mess. Although, when you have 200,000 members, I guess you have to spread it out so threads don't roll off 10 minutes after you post them.
Post by Deleted on Jan 19, 2014 13:03:43 GMT -6
To talk in purist terms - any situation in which the electric guitar is not acoustically coupled to the amplifier is not true to how the instrument is played live. The feedback between the guitar and amplifier is a big part of the electric guitars sound. But that doesn't mean that having that feedback makes the guitar do what you need, it's just an abstract fact. Completely true. To some degree you can emulate it with internal feedback inside of the virtual amp. Not too realistic, but does the trick on quite some occasions, e.g. some good high gain amp emulations work with that. But i have seen enough situations, where real amps have been acoustically decoupled as well, and also, you are always able to use a digitally modelled guitar amp thru a clean amp and real cab and play with the feedback as well, if needed.....
Post by LesC on Jan 19, 2014 13:10:20 GMT -6
Alright already,..., for the love of god,...sonically, the kemper has NO advantage on a real amp....ever, .... Period, end of story! This place is called REAL GEAR, not VIRTUAL GEAR for crying out loud lol 8) Kemper is a sophisticated piece of hardware that uses digital processing, is that virtual gear? Other examples would be units from Bricasti, Eventide, Lexicon, TC Electronics, UAD, etc. Are you suggesting we shouldn't be discussing this type of equipment, or computers used for music, or plugins? You could make the case that this is all virtual gear and has no place in a real gear forum, but I think the forum would become less interesting for many of us. Similarly, I don't see any advantage of segregating this information into a digital subforum. As for the point about Kemper having no advantage on a real amp, I believe one advantage it does have is that I can get close to the sound of a real amp that I otherwise would have no way to do. You're right that if you have the real amp and the Kemper modeling that identical amp, then of course the Kemper has no advantage, assuming you have a great cab, a good room, good microphones, and know how to set them up properly.
Post by LesC on Jan 19, 2014 13:22:59 GMT -6
Forgive me, but I' a little behind the curve here, "The Kemper" is a $2,000 profiling amp? Yes. It's similar in concept to a high-end Fractal Audio unit or a Line 6 modeler, except it also allows you to profile your own amps and get a sound nearly identical, as long as you don't stray too far from the amp settings that were modeled. So to model an amp as accurately as possible, you need to model the amp at several different settings. The model includes the entire signal path, effects, preamp, amp, mics, mic preamp, console eq and compression, etc. Some effects, such as fuzz, are not modeled accurately, so it's better to use such effects separately from the Kemper. Here's a link: www.kemper-amps.com/homeMore importantly, to me, if someone creates a great model of an amp, then anybody with a Kemper can use that same model and get the same sound. This is what companies such as the Amp Factory do, create very good profiles of very good amps, and sell the profiles. Here's a link: www.theampfactory.com
Post by tonycamphd on Jan 19, 2014 14:37:03 GMT -6
Alright already,..., for the love of god,...sonically, the kemper has NO advantage on a real amp....ever, .... Period, end of story! This place is called REAL GEAR, not VIRTUAL GEAR for crying out loud lol 8) Kemper is a sophisticated piece of hardware that uses digital processing, is that virtual gear? Other examples would be units from Bricasti, Eventide, Lexicon, TC Electronics, UAD, etc. Are you suggesting we shouldn't be discussing this type of equipment, or computers used for music, or plugins? You could make the case that this is all virtual gear and has no place in a real gear forum, but I think the forum would become less interesting for many of us. Similarly, I don't see any advantage of segregating this information into a digital subforum. As for the point about Kemper having no advantage on a real amp, I believe one advantage it does have is that I can get close to the sound of a real amp that I otherwise would have no way to do. You're right that if you have the real amp and the Kemper modeling that identical amp, then of course the Kemper has no advantage, assuming you have a great cab, a good room, good microphones, and know how to set them up properly. Keeping feet on the ground? I said that because the group selling and apparent confirmation bias was abound imv, the day a kemper is better than a real rig, is the day I sell my stuff and get one, currently it's not even close. Anything in the digital domain is considered "virtual", the more u use in the " virtual" sense, the more synthetic and video game like your final product will sound. As great as they are, a Bricasti plate reverb doesn't touch a real plate reverb to just about anyone whose used a real plate... Of course this is my experience...so ymmv If you look at my first post on this thread, I said B was a Kemper, there was no mention that a kemper was even used?, and just because I said A was better, doesn't mean it was great. By all means please talk about anything you want, but I'm Just being honest to my thoughts and keeping it real my brother
Post by popmann on Jan 19, 2014 14:41:23 GMT -6
I'm gonna post a few of those files here...see if I can make believers out of you snobs... Yes, Popmann, I know you will hate it. It's a badge of honor... Um...didn't the "snob" like the $149 software pod better than the $2000 Pod? Didn't the majority of voters? How did the majority get called snobs for picking the less expensive piece of kit**. **which really is only less expensive by way of you already owning the hardware to run it. I mean, add a MacMini, audio interface, whatever DI you used...point is--what you're paying for with the Kemper is a nice portable computer with some specific function knobs so you don't have to do screens.
Post by popmann on Jan 19, 2014 14:42:56 GMT -6
Oh...and I had looked at the percentages....not actually votes...there were only 14 cast....so...ok--that's not exactly the landslide the percentages implied.
Post by Johnkenn on Jan 19, 2014 14:50:44 GMT -6
This thread has devolved into shit. Can it just be done?
Post by Ward on Jan 19, 2014 18:04:46 GMT -6
Forgive me, but I' a little behind the curve here, "The Kemper" is a $2,000 profiling amp? Yes. It's similar in concept to a high-end Fractal Audio unit or a Line 6 modeler, except it also allows you to profile your own amps and get a sound nearly identical, as long as you don't stray too far from the amp settings that were modeled. So to model an amp as accurately as possible, you need to model the amp at several different settings. The model includes the entire signal path, effects, preamp, amp, mics, mic preamp, console eq and compression, etc. Some effects, such as fuzz, are not modeled accurately, so it's better to use such effects separately from the Kemper. Here's a link: www.kemper-amps.com/homeMore importantly, to me, if someone creates a great model of an amp, then anybody with a Kemper can use that same model and get the same sound. This is what companies such as the Amp Factory do, create very good profiles of very good amps, and sell the profiles. Here's a link: www.theampfactory.comPardon me, but your last two posts are a little dark and contain a sweeping accusation of "ludditism" to those of us who don't really fancy modeling amps. Modeling amps are still in their infancy and haven't really got it right... the Kemper is very good but at best it sounds like a recording of a real amp. And when you use it in tracking, often times it sounds like a recording of a recording. Do you remember the Alesis D4 drum module? Widely used in the early-mid 90s and sure, it sounded ok for demo purposes but in an album production as a sample trigger it sounded very 2 dimensional. Ken Tamplin's 1992 album "TAMPLIN" and Dream Theater's albums "Images and Words" and "Awake" relied heavily on its triggered sounds and certainly sounded like it at the time, and now sound even worse because of it. This is what many of us hear in the Kemper. It's close, but there is something missing. It's an excellent tool but it doesn't quite replace the real amps, at least not yet. The same can't be said for digital reverb nor digital recording. These were like that at first but have since overcome so much and have gained in quality to the point where they are widely accepted. This will happen in time with amplifier modeling, but it just isn't quite there yet. Close but not quite there yet. Best regards!
Post by Johnkenn on Jan 19, 2014 18:53:10 GMT -6
I believe that recording an amp is absolutely the optimal choice...but Ward, I think you are being a little dismissive. Why in the world do you consider his posts "dark"...? Honestly, I think that with a lot of these profiles, they probably sound better than me trying to mic an amp up with a 57 myself. Seriously. A number of session guitarists here are buying them - because they sound good. They're not going to replace cartage on most sessions, but they're bringing them to ones with smaller budgets. When guys like Bob Britt, Rob McNelley and Michael Wagener are using these things, they aren't doing it for their health.
Post by Ward on Jan 19, 2014 19:10:16 GMT -6
You do make two good points JK, and I do respect Michael on so many levels and his ways... but sometimes ease of use trumps all other factors too. If you can plug n play and get 90% of the way there in 5 minutes, it can beat the heck out of 4 hours of experimentation with amp settings and microphone placement/choice and preamps and EQs and Comps etc. Sometimes economy is the best utility.
Post by Johnkenn on Jan 19, 2014 19:44:10 GMT -6
Post by LesC on Jan 19, 2014 19:53:21 GMT -6
Ward, I apologize if somehow I offended you. I've re-read my posts, and I can't understand how they can be taken as dark. In the second one, I was explaining to Martin what the Kemper is, what is dark about that? I am a college professor, so my writing often has a lecture-ish style, maybe that's what you're misinterpreting. In the first one, I was taking issue with Tony seeming to suggest that we shouldn't be discussing something that isn't "real gear" by his definition. I'm sorry if I offended anybody.
I never said modeling was perfect, but for some of us home-recordists it's a god-send. I'm not crazy about people who are fortunate enough to work in "real" studios dismissing it out of hand. I certainly wouldn't suggest ludditism, maybe a bit of elitism.
Post by tonycamphd on Jan 19, 2014 20:04:22 GMT -6
Ward, I apologize if somehow I offended you. I've re-read my posts, and I can't understand how they can be taken as dark. In the second one, I was explaining to Martin what the Kemper is, what is dark about that? I am a college professor, so my writing often has a lecture-ish style, maybe that's what you're misinterpreting. In the first one, I was taking issue with Tony seeming to suggest that we shouldn't be discussing something that isn't "real gear" by his definition. I'm sorry if I offended anybody. I never said modeling was perfect, but for some of us home-recordists it's a god-send. I'm not crazy about people who are fortunate enough to work in "real" studios dismissing it out of hand. I certainly wouldn't suggest ludditism, maybe a bit of elitism. Come on bro, I said "lol 8)" at the end, there are guys saying it's better than the real thing, I was and am saying IMO no way. I use modelers to write btw Let's lighten up some fellas 8)
Post by LesC on Jan 19, 2014 20:11:56 GMT -6
I think we're actually in agreement. There's lots of people on Gearslutz who seem to think that modeling is better than the real thing, but I doubt if anybody here thinks that. It's just a convenience that gets some of us closer to good sound than we could otherwise get. If modeling ever gets better than the real thing, maybe at that point we can model the modelers and make quantum leaps in guitar technology
Post by Martin John Butler on Jan 19, 2014 20:29:57 GMT -6
Cool, thanks Les.
Post by Ward on Jan 19, 2014 22:20:26 GMT -6
Yes, we are in agreement!
Post by jimwilliams on Jan 23, 2014 11:52:58 GMT -6
I like my 1966 Fender Deluxe Reverb a bit more.
Post by Johnkenn on Jan 23, 2014 15:41:47 GMT -6
I like my 1966 Fender Deluxe Reverb a bit more. Rub it in...
