Post by m03 on Mar 22, 2017 17:38:43 GMT -6
I wish I could get rid of the click when making beats. I don't think you can disable the metronome in Tap2Find, but you could try turning down the metronome volume. I think it's in Settings -> Metronome Settings. Also make sure you've got it updated to the latest version, as they didn't make the Tap2Find metronome volume linked to the main metronome volume control until fairly recently.
Post by Johnkenn on Mar 22, 2017 19:02:29 GMT -6
why would you want to get rid of the click in Tap to Find?
Post by Martin John Butler on Mar 22, 2017 20:39:17 GMT -6
Because there's so much latency. I follow the click when creating a simple beat, but because of the delay, I hear it around 1/2 a beat late.
Post by kilroyrock on Mar 22, 2017 20:45:34 GMT -6
I don't have a delay, maybe ADC is handling it for me? PT 11, ezd2, top of the line ish PC
Post by m03 on Mar 22, 2017 20:51:55 GMT -6
Because there's so much latency. I follow the click when creating a simple beat, but because of the delay, I hear it around 1/2 a beat late. Is this latency when running as a VST, or as a standalone application?
Post by Johnkenn on Mar 22, 2017 21:21:05 GMT -6
just change your buffer to 128 and then change back after you find the groove.
Post by Martin John Butler on Mar 22, 2017 21:25:26 GMT -6
m03, I already had Superior Drummer. I simply downloaded EZ Drummer, installed, and there it was in my DAW. I use Logic X. It is weird though. They guy in the video obviously had no issues. I'll look into it further tomorrow. Because it just a simple beat making process, I can pretend I don't hear the delay, even though it's awkward, or maybe just turn down the volume and make the beat in my head. Still, it is odd.
I'll send a note to Toontracks tomorrow if the answer isn't obvious once I look around.
* I'll try that tomorrow John, maybe that's all it is, wrong buffer size.
Post by Johnkenn on Mar 23, 2017 9:00:04 GMT -6
It's just latency. If you put a plugin piano on and tried to play it, you'd have the same problem. Also, do you have any plugs on the master bus? The master bus usually isn't delay compensated, so you'll hear all that latency.
Post by Martin John Butler on Mar 24, 2017 20:49:43 GMT -6
Thanks John, I forgot to even look at the EZ Drummer today. I'll see if I can figure it out tomorrow..
