Post by illacov on Nov 30, 2016 18:10:12 GMT -6
So for us little guys, could I achieve a similar tape compression sound by using the tape compression stuff in say, mcDSP's analog channel? Cause I really like what it does to my bus. I recorded to tape since I was 15. I don't recall any "slamming" of the tape, although no one worried if it hit the red a little now and then. I paid more attention to playing then, so it might have escaped me. I also had my own private small studio for doing music for radio and TV for a decade, and I must have completed 200 local spots there, before selling all my gear. My point is, my ears know tape when I hear it and the only plug that actually reminds me of tape is the new UAD Oxide. I've tried a dozen others, many were mushy, and in truth, they're basically EQ's. Click on a preset and it shifts the overall tone. So if you can use the UAD platform, go for Oxide, and you're in the right direction. Martin at some point I'd love to get you to send me a mix to run through Zulu. Regarding the slamming of the deck in reference to your meters, that all depended on how your deck was calibrated. Do you recall how you had your deck(s) set up? Thanks -L.
Post by jjinvegas on Nov 30, 2016 21:03:17 GMT -6
I have found that Roughrider, a pretty well-known freeware color compressor, when used lightly, in combination with a 6 db/octave HPF set at 50hz does a pretty fair job of emulating the sound of oxide compression. But a significant portion of the drum sound we are discussing has to do with playing style and tuning. The big G symbol will take you to a song cut here at home with significantly less legendary gear, bur it isn't the gear, it is what you do with it. Although I was initially channeling Dee and Nigel while I played the drums and bass, once I picked up the guitar the song (especially starting about 2 minutes in) wandered into the pink. A bit of Iowa Piano from Bit Cat audio and AZR by Rumpelrausch, two excellent freeware instruments, and at least from an instrumental standpoint the period is evoked. It is also a song about the big gig in the sky, a very early production client had to leave for that gig far too early, I found out several years after it happened but the song wrote itself in a very few minutes on the piano. Channeling? Or just a bit of grief, I don't listen to the song very often, but it has a mood..... https://plus.google.com/108160675808711007132/posts/JSg4iBcRFtr
Post by Martin John Butler on Dec 1, 2016 16:51:15 GMT -6
"Martin at some point I'd love to get you to send me a mix to run through Zulu. Regarding the slamming of the deck in reference to your meters, that all depended on how your deck was calibrated. Do you recall how you had your deck(s) set up?
Thanks -L.
It's been a long, long time, but I think I had everything +4 db.
Post by illacov on Dec 1, 2016 17:37:26 GMT -6
"Martin at some point I'd love to get you to send me a mix to run through Zulu. Regarding the slamming of the deck in reference to your meters, that all depended on how your deck was calibrated. Do you recall how you had your deck(s) set up? Thanks -L. It's been a long, long time, but I think I had everything +4 db. So when your needle was at -4 you were really at 0db? Or?? Thanks -L.
Post by Martin John Butler on Dec 1, 2016 17:59:18 GMT -6
Yes, if memory serves, but it's been a long time. I forget exactly how it read, but settings were either -10db or +4 db. The +4 was balanced. I used +4. Although it's supposed to make no difference, +4 setup always sounded louder. More headroom I think.
Post by illacov on Dec 1, 2016 22:34:31 GMT -6
Yes, if memory serves, but it's been a long time. I forget exactly how it read, but settings were either -10db or +4 db. The +4 was balanced. I used +4. Although it's supposed to make no difference, +4 setup always sounded louder. More headroom I think. Oh! I'm not referring to consumer vs professional level. I'm referring to how your internal levels were setup when the deck was calibrated. See on decks when you set these levels up, the 0 on the VU meter is normally going to indicate a level over what we actually call 0db. For instance our Studer A810, when you hit -9 on the VU, that's actually 0db. When you go to 0 you're actually at +12db. This typically applies to all tape decks, they have their internal configurations and calibrations that are aside from the consumer vs professional aspect. This is why I was curious about your post where you said that you never pegged your meters, thus you claimed that you weren't hitting your deck that hot. On average if you were approaching 0db on the needles or even in the neighborhood, you could be anywhere (depending on the formula you calibrated for, EQ curve and tape speed) from +3db to +9db over 0 once you got to the actual 0 on your meter. So when people are talking about pegging their meters, they are speaking typically of recording very very hot to tape, whereas your machine even though your needles weren't dimed you were still hitting the deck hot, definitely hotter than you'd hit digital converters. BTW the offer is still out there to do a pass of something of yours through Zulu while we wait for the initial run to spawn. I've watched a bunch of your videos on youtube, must say I dig the material. Thanks -L.
Post by rocinante on Dec 1, 2016 23:56:10 GMT -6
It was a series of songs that Vig broke down and I cant find it on YouTube anywhere. He actually sits at the Neve console they used (I think) and replays a bunch of the songs and breaks down recording the instruments and hardware used as well as techniques. Lots of stories like convincing Kurt to layer vocals, using three to four different guitar amps and cabinets and layering them as well. Drum recording etc... I searched for awhile to no avail but it actually had an impact on how I mixed after watching it. Yeah its kind of a tease. Like that pbs special on recording which almost showed producers doing stuff. Id buy clips of footage from DSOTM too. A good one though is Butch Vig discussing Nirvana's Nevermind. He actually gets into the details. Hey could you post that , I'd like to read it .
Post by Quint on Dec 2, 2016 0:22:22 GMT -6
It was a series of songs that Vig broke down and I cant find it on YouTube anywhere. He actually sits at the Neve console they used (I think) and replays a bunch of the songs and breaks down recording the instruments and hardware used as well as techniques. Lots of stories like convincing Kurt to layer vocals, using three to four different guitar amps and cabinets and layering them as well. Drum recording etc... I searched for awhile to no avail but it actually had an impact on how I mixed after watching it. Hey could you post that , I'd like to read it . This is an excerpt from the video you're talking about. In it, Vig talks about the vocal doubling.
Post by scumbum on Dec 2, 2016 0:22:40 GMT -6
I'M STILL REALLY MAD WE DIDN'T GET TO HEAR THE TRACKS IN THE VIDEO I'll contact the guys that made the video and see if they have more audio or videos of this session .
Post by ragan on Dec 2, 2016 0:25:06 GMT -6
I'M STILL REALLY MAD WE DIDN'T GET TO HEAR THE TRACKS IN THE VIDEO I'll contact the guys that made the video and see if they have more audio or videos of this session . Uhh...yes please.
Post by scumbum on Dec 2, 2016 0:25:19 GMT -6
It was a series of songs that Vig broke down and I cant find it on YouTube anywhere. He actually sits at the Neve console they used (I think) and replays a bunch of the songs and breaks down recording the instruments and hardware used as well as techniques. Lots of stories like convincing Kurt to layer vocals, using three to four different guitar amps and cabinets and layering them as well. Drum recording etc... I searched for awhile to no avail but it actually had an impact on how I mixed after watching it. This is an excerpt from the video you're talking about. In it, Vig talks about the vocal doubling. I got this video on DVD . Its good but not too detailed .
Post by rocinante on Dec 2, 2016 4:05:50 GMT -6
Wow hijacked the thread; oops. Yeah thats gotta be the video. Its been awhile. I think what I got most from it was (and this applies to DOTTM too) there are no real rules in rock or pop or whatever genre. I think at the time I believed everything had to sound like the band did; i really like it when a band can produce that album sound live (and vice versa) but in all actuality an album can be an entirely different beast. I guess at one time or another I was a haphazard purist. Nowadays im a professional hobbyist. Ha!
Post by scumbum on Dec 2, 2016 11:38:40 GMT -6
Post by Martin John Butler on Dec 2, 2016 14:27:45 GMT -6
Yes, if memory serves, but it's been a long time. I forget exactly how it read, but settings were either -10db or +4 db. The +4 was balanced. I used +4. Although it's supposed to make no difference, +4 setup always sounded louder. More headroom I think. Oh! I'm not referring to consumer vs professional level. I'm referring to how your internal levels were setup when the deck was calibrated. See on decks when you set these levels up, the 0 on the VU meter is normally going to indicate a level over what we actually call 0db. For instance our Studer A810, when you hit -9 on the VU, that's actually 0db. When you go to 0 you're actually at +12db. This typically applies to all tape decks, they have their internal configurations and calibrations that are aside from the consumer vs professional aspect. This is why I was curious about your post where you said that you never pegged your meters, thus you claimed that you weren't hitting your deck that hot. On average if you were approaching 0db on the needles or even in the neighborhood, you could be anywhere (depending on the formula you calibrated for, EQ curve and tape speed) from +3db to +9db over 0 once you got to the actual 0 on your meter. So when people are talking about pegging their meters, they are speaking typically of recording very very hot to tape, whereas your machine even though your needles weren't dimed you were still hitting the deck hot, definitely hotter than you'd hit digital converters. BTW the offer is still out there to do a pass of something of yours through Zulu while we wait for the initial run to spawn. I've watched a bunch of your videos on youtube, must say I dig the material. Thanks -L. Thinking on it a little, I think zero on my meter was + 4db, but again, it's been a while.
Post by scumbum on Dec 3, 2016 11:46:44 GMT -6
Post by ericn on Dec 3, 2016 14:17:57 GMT -6
It was a series of songs that Vig broke down and I cant find it on YouTube anywhere. He actually sits at the Neve console they used (I think) and replays a bunch of the songs and breaks down recording the instruments and hardware used as well as techniques. Lots of stories like convincing Kurt to layer vocals, using three to four different guitar amps and cabinets and layering them as well. Drum recording etc... I searched for awhile to no avail but it actually had an impact on how I mixed after watching it. This is an excerpt from the video you're talking about. In it, Vig talks about the vocal doubling. All I can think of while watching this is Lonya / AKA Russki who kept the gear running at SMART going " Lennin? Lennin? why would anyone want to sound like Lennin?" 😄
Post by Bob Olhsson on Dec 3, 2016 15:02:29 GMT -6
FWIW nobody used separate snare tracks until the '70s or even separate snare mikes prior to the late '60s. Splitting drums among multiple analog tracks castrates the drum sound due to gap scatter.
I think our biggest sources of distortion were the U67s. Back then they were sold with an output pad to make them compatible with RCA-style tube preamps. As a result there was a big loss of presence when you engaged the input pad so everybody avoided doing that like the plague.
Post by scumbum on Dec 3, 2016 22:04:41 GMT -6
FWIW nobody used separate snare tracks until the '70s or even separate snare mikes prior to the late '60s. Splitting drums among multiple analog tracks castrates the drum sound due to gap scatter. I think our biggest sources of distortion were the U67s. Back then they were sold with an output pad to make them compatible with RCA-style tube preamps. As a result there was a big loss of presence when you engaged the input pad so everybody avoided doing that like the plague. Did you , or other engineers back then slam tape to get a compressed sound ? When would you say engineers started to slam tape as an alternative to using a hardware compressor ?
Post by Bob Olhsson on Dec 3, 2016 22:08:41 GMT -6
I tried it once and ruined a session!
Most control rooms only had three or four compressors.
The only reason to slam tape was to reduce hiss.
Post by Martin John Butler on Dec 3, 2016 22:21:01 GMT -6
Yep. I said I don't recall anyone ever slamming tape. A little red now and then was tolerated, but that's it.
Post by illacov on Dec 3, 2016 22:36:07 GMT -6
What do/did you consider slamming tape? At 0 on the VU? Over? Pegged?
Add in lower headroom tape and all bets are off.
Im extremely curious how these decks ya'll used were calibrated? +3, +6, +9? Bob O? Anyone else?
Thanks -L.
Post by jjinvegas on Dec 4, 2016 1:59:02 GMT -6
I think what constrained anything beyond +3 was the inability of the erase head to cope with anything hotter on a lot of machines still in service back then, even as Ampex 456 and AGFA 469 could handle the hotter signals. Not everybody could afford one-pass two inch tracking of basics. Or even 30 ips in lots of cases. I did have an Otari half track machine that was set up +6 for a bit, the first project that went to a duplicator convinced me that that it wasn't worth a bit of complaining on the other end about possible distortion. I hadn't forewarned them, and they called when they put up the test tones wondering what I was thinking. Funny thing, that tape ended up a national release, with those same masters. Really, there was no talk of oxide compression at all until the ADAT format became commonplace and engineers tried to figure out why things they had done a certain way for a decade suddenly sounded weak. I initially loved digital, I was an early user of the the Sony PCM F-1 with a Betamax for stereo capture, even using it to record two live-to-stereo LPs with the Coctails from Chicago. In keeping with their retro image we claimed that they were recorded on my Ampex 354 which made for a better photograph. When Akai introduced their 14 track digital multitrack that used videocassettes I did an analysis of tape costs and found that the machines ended up being basically free but I demurred out of caution. A few months later I saw a demo of the ADAT machine, looked at the MAP and decided that owning a music-oriented recording shack was likely to be a less exclusive enterprise and sold all the gear about six months before it became boat anchors in terms of value. Most of the ADAT-enabled studios ended up DAW victims, technology marches on, and you can adapt or perish. As someone who started at the dawn of the DIY recording era, I can certainly appreciate the democracy of the DAW, even as it has spelled disaster for entrepreneurial types who parlayed their knowledge of music and audio into some kind of enterprise. If the public doesn't understand that the number of people who are adept at multi-track recording hasn't really changed even as the number of people offering the service has exploded, well, the majority of recording has always been more about desire than actual need. Same as it ever was.....
Post by Martin John Butler on Dec 4, 2016 8:26:56 GMT -6
Great post JJ. Paragraphs next time please ;-)
Post by Bob Olhsson on Dec 4, 2016 8:47:12 GMT -6
Erasure only became a problem with the high output tapes like 456 of the '70s and '80s that tape machines from the '50 and '60s weren't designed for. We aligned for 185 until around 1970 and then 3 dB. higher with Scotch 206. We only pinned the needle for bass and lead vocal because our early 8 tracks had a hum problem on the two outside tracks. (Almost from the beginning we were doing 8 to 8 mix down transfers exactly like we had done 3 to 3s and the Beatles did 4 to 4s. I roll my eyes whenever people talk about recording to one 8 track because that wasn't how I ever saw it done.)
The only instrument that benefited from tape saturation for me was the piano and even then it was never pinned and recorded peaking to around -5. A very small percentage of people using tape today are recording at traditional levels and today's tape has pretty serious drop out problems if it isn't transferred right away.
Post by illacov on Dec 4, 2016 9:14:39 GMT -6
Erasure only became a problem with the high output tapes like 456 of the '70s and '80s that tape machines from the '50 and '60s weren't designed for. We aligned for 185 until around 1970 and then 3 dB. higher with Scotch 206. We only pinned the needle for bass and lead vocal because our early 8 tracks had a hum problem on the two outside tracks. (Almost from the beginning we were doing 8 to 8 mix down transfers exactly like we had done 3 to 3s and the Beatles did 4 to 4s. I roll my eyes whenever people talk about recording to one 8 track because that wasn't how I ever saw it done.) The only instrument that benefited from tape saturation for me was the piano and even then it was never pinned and recorded peaking to around -5. A very small percentage of people using tape today are recording at traditional levels and today's tape has pretty serious drop out problems if it isn't transferred right away. Ok so you did engage in this behavior but only on two tracks and out of necessity. Could you possibly see how this might influence recording aesthetic? Especially on popular material? The position that you were in, every decision that you or the bosses made, influenced us ALL. Even if they were never intended to be thought of as intentional motifs or sonic excellence. If we heard it and it had anything to do with gold standard classic pop or rock music, we admired it because it was that: popular. One thing of interest to share. In the Tom Dowd movie, there's discussion about how the USA had 8 track for 10 years before UK. In a world where these gaps in tech, technique and communication where far more common than they are now, how could anybody possibly know what everybody else was doing? Now they can but at the time? I personally grew up listening to my mentors and their friends talk about pegging sounds to tape, maybe not the whole production but they did it and it wasn't described as if they agonized over doing it but rather they delighted in it. I can listen to the DSOTM album and hear the tape compression, the splat, the soft cymbals with tasty sustain. Does this mean they pegged every needle on every track? Maybe none at all, but if you grow up listening to and working with analog tape, then you know why things sound tapey:) Thanks -L.
