Post by gouge on Jan 17, 2017 20:14:01 GMT -6
finished off the mix last night. I removed a lot of plugs. go figure.....:-)
https%3A//soundcloud.com/studiogestalt/lay-down-with-me-1
Post by wiz on Jan 18, 2017 15:10:03 GMT -6
https%3A//soundcloud.com/studiogestalt/lay-down-with-me-1cool stuff bud cheers Wiz
Post by bradd on Jan 19, 2017 20:54:29 GMT -6
Good work, Gouge!
Post by jampa on Jan 21, 2017 16:49:43 GMT -6
Hey
I started with what other people were doing and then did something else.
If I was going further with it, I'd probably do a few things. I'd put something in the solo section and overall add automation.
I'd also do the Roger Nichols thing - take one track, turn it up 1dB, listen, turn down 1dB (from starting point), listen, choose the best of the three levels (starting point, +1, -1), repeat for every track to finalise levels.
There's EQ on the mix bus (lift) but no mastering.
Thanks for the opportunity Wiz!
__https%3A//soundcloud.com/user-497267101-565507130/wiz-lay-down-with-me
Post by wiz on Jan 21, 2017 17:19:39 GMT -6
Hey I started with what other people were doing and then did something else. If I was going further with it, I'd probably do a few things. I'd put something in the solo section and overall add automation. I'd also do the Roger Nichols thing - take one track, turn it up 1dB, listen, turn down 1dB (from starting point), listen, choose the best of the three levels (starting point, +1, -1), repeat for every track to finalise levels. There's EQ on the mix bus (lift) but no mastering. Thanks for the opportunity Wiz! __ https%3A//soundcloud.com/user-497267101-565507130/wiz-lay-down-with-meHi jampathanks for sharing. Glad you had fun with it! Very cool.... and... welcome to the forum cheers Wiz
