Post by Johnkenn on Nov 21, 2013 11:11:48 GMT -6
Just trying to see what everyone is doing. I guess it really just depends on where the acoustic sits in the mix - i.e., what's the point of a stereo acoustic if it's gonna be panned to the left...A lot of my songs are acoustically driven, so I'll end up doubling the part with a different inversion or something...But, I'd love to just get a huge stereo image. How are you guys miking? I've used Blumlein before - and it's cool - but sometimes it's off balance...more info to one way or the other. Sometimes when miking in stereo 3:1 technique, I find the tone on the neck is so much different than the body that it's kind of weird to spread them left and right. So - how do you get space and blend?
Post by Johnkenn on Nov 21, 2013 11:13:51 GMT -6
Also, what about distance? And gain? I've always just kept the mic about 8in to a foot/foot1/2 away...Never really pulled the mic(s) far away and cranked the gain...Of course, my room isn't particularly a performance room.
Post by tonycamphd on Nov 21, 2013 11:54:58 GMT -6
IME, Of course the room matters, but distance=depth and less chance to mess things up, the closer you get, the bigger small mic moves change the tone(movements by the player). The newest thing i've been messing with, and loving the results of, is mid/side recording, C12 in cardoid, and figure 8 ribbon, duplicate the ribbon track, invert phase on one channel, hard pan opposite each other respective of the 8 pickup.
the versatility is, you can collapse to mono certainly, and you can control the amount of spread with the split ribbon faders, essentially gives you mono and stereo tracks of the same take, and allows you to totally control the width of the stereo image....or not?
especially useful if your creating on the fly, with no end result in mind up front.
Post by matt on Nov 21, 2013 12:00:18 GMT -6
Interested in this as well. I end up falling back to one mic most of the time just to make things easy. And like JK, I like to double parts and throw in variation to add interest. I usually send all acoustic parts panned out to a stereo bus and add reverb/effects in parallel on another stereo bus. That desirable huge sound can be elusive though. I need to play well, or it just sounds like a loose mess. Also, I am working on controlling string noise, something I never notice when gigging.
Post by Johnkenn on Nov 21, 2013 12:18:39 GMT -6
IME, Of course the room matters, but distance=depth and less chance to mess things up, the closer you get, the bigger small mic moves change the tone(movements by the player). The newest thing i've been messing with, and loving the results of, is mid/side recording, C12 in cardoid, and figure 8 ribbon, duplicate the ribbon track, invert phase on one channel, hard pan opposite each other respective of the 8 pickup. Yeah - also called Blumlein...or at least I think...
Post by svart on Nov 21, 2013 12:20:52 GMT -6
2 mics, both Oktava MK012s. One right around the bridge, another about the 12th fret, both angled in slightly. Usually around 12" back, sometimes less or more depending on the loudness of the person playing. I'll pan these 3/4 to full left and right and let the distance of the mics from each other create the narrow stereo sound. I've not had a single complaint yet. In fact I get a lot of compliments.
These go into 312s for some mid thickness, and usually some compression, and then for EQ I usually boost 7K shelf, somewhere around 2K-3K for some articulation and cut narrow somewhere around 200-300 to get rid of the boom. I might boost 150 and below with a shelf for thickness. this usually sits very well with the vocals.
I might set up some LDCs in the room for some room tone, which can help thicken some bright acoustics. I'll just bus these together with the main mics and compress through a bus compressor.
Post by Johnkenn on Nov 21, 2013 12:21:45 GMT -6
The room definitely matters. Listening to tracks I have from Sound Emporium and I think it's basically a 184 and 87...and it sounds better. Of course having a real player helps too
Post by popmann on Nov 21, 2013 13:14:23 GMT -6
If you want the WIDEST stereo image that's still mono collapsable, you play the same part twice, but reverse the mic. So think of an X/Y, right? Only you use the mic in one of the positions for the first track...second in the second position.
Widest without compatibility, you can spread the mics some and use a continuous phase adjuster plug on the two mics to find the widest spread--but, since it doesn't collapse, it can't be holding down the arrangement, so it needs to be for the kind of "harmonic high hat" effect.
Post by watchtower on Nov 21, 2013 13:18:41 GMT -6
IME, Of course the room matters, but distance=depth and less chance to mess things up, the closer you get, the bigger small mic moves change the tone(movements by the player). The newest thing i've been messing with, and loving the results of, is mid/side recording, C12 in cardoid, and figure 8 ribbon, duplicate the ribbon track, invert phase on one channel, hard pan opposite each other respective of the 8 pickup. the versatility is, you can collapse to mono certainly, and you can control the amount of spread with the split ribbon faders, essentially gives you mono and stereo tracks of the same take, and allows you to totally control the width of the stereo image....or not? especially useful if your creating on the fly, with no end result in mind up front. I can't wait to try exactly this once I get my C12 built. C12 in cardioid for M, AEA R44CE for S. I have tried a spaced pair on acoustic before and found that movements caused too big of a image shift and tonal change. I typically just record mono and double a part if I feel like doing so. IME, Of course the room matters, but distance=depth and less chance to mess things up, the closer you get, the bigger small mic moves change the tone(movements by the player). The newest thing i've been messing with, and loving the results of, is mid/side recording, C12 in cardoid, and figure 8 ribbon, duplicate the ribbon track, invert phase on one channel, hard pan opposite each other respective of the 8 pickup. Yeah - also called Blumlein...or at least I think... Technically, Blumlein features two Figure 8 mics that are each 45 degrees off axis, whereas in M/S, the mid mic is on axis. Plus, M/S requires a "decade," whereas Blumelein doesn't - it's basically just XY, but with Figure 8s.
Post by Johnkenn on Nov 21, 2013 15:39:11 GMT -6
You're right!
Post by Johnkenn on Nov 21, 2013 15:41:05 GMT -6
BTW - I went super cheap and bought a MXL R144 Ribbon. Gonna use it for side in the aforementioned mid/side config. Probably recording some stuff tonight - maybe I'll post results. Miktek C5 Mid, R144 Side...
Post by Johnkenn on Nov 21, 2013 20:32:41 GMT -6
Ooooo...I kinda like using the ribbon for the side...feels way more natural than other times I've used M/S with two condensers...
BTW - I opened the MXL box, screwed the shockmount to the stand, tried to tighten the nut on the shockmount and the cheap Chinese metal dissolved like butter. Nice. I jerry rigged the mic up and used it.
Post by Martin John Butler on Nov 21, 2013 21:47:31 GMT -6
I use one mic, usually one track for recording my acoustic these days. If I want wide, I record the same basic part again on a different track, then pan to taste. I also add stereo reverb to my single guitar tracks, which brings a little of it to the other speaker when it's panned toward one side, and does help the acoustic to feel bigger. I tried two mics, and didn't like the tone difference between the neck and the bridge mic. All the neck mic ended up being was an EQ, as I brought the volume up or down the tonal mix shifted. See if this works. It was my first recording with my Blackspade U17, and I miked it too close. It's an old rough mix of a New Mantra track from a project I'm working on with my wife. It is a nice example of the size I get with one acoustic and the UAD EMT 140 though. soundcloud.com/martin-john-butler/naam-music-project-guru-ram
Post by Ward on Nov 21, 2013 21:56:12 GMT -6
For stereo recordings, there are two techniques that are awful hard to beat: 1. Blumlein, 2 figure of 8s in XY stereo about 18" to 24" back from a center point aimed at the 17th fret in parallel alignment to the plane of the floor. LDCs excel here. 2. One SDC aimed at a slight angle downward at the neck body joint about 12-18"back, another SDC or an LDC looking over the shoulder of the player aimed at the bridge, "looking" at it, at a 10º to 15º angle.
The Blumlein is an incredible sound because it's a real stereo technique that collapses well but when collapsed to mono, retains all the information. The balance of direct and reflected signal can really give you a brilliant sense of space. It can be a really big sound and fill up a lot of the sonic real estate in a beautiful way. The problem with MS is that it isn't really a true stereo technique but a simulated one... now stay with me here. The sides are captured with ONE Figure 8 microphone that is feeding the signal to both sides in positive and negative phase. This is a psycho-acoustic pseudo-stereo effect. When summed to mono, the sides are obviously canceled out. Thus leaving only the mono single point source and then that becomes critical that it is pointed at the neck/body joint and provides the basis for most of what you wish to hear. But just think about it... true stereo is two coincident sources. MS is not two coincident sources, it is ONE source with the phase flipped on one side. Now, it can be argued that it sounds good, and certainly it can. But it isn't actual stereo.
Post by Ward on Nov 21, 2013 22:01:40 GMT -6
I should add, your two figure-of-8 microphones for Blumlein are supposed to be positioned at a 90º< to each other, but you can vary this between 80º and 110º to get various different stereo size placement effects. You'd be amazed at how the tone can change as you do this!
Post by Deleted on Nov 21, 2013 22:06:28 GMT -6
LDC pointed at the body about a foot away, SDC at the 12th fret as close as I can get it.
TLM 49 sucks major ass here to my ears.
Post by Martin John Butler on Nov 21, 2013 22:07:09 GMT -6
Great explanation, thanks Ward.
Post by tonycamphd on Nov 22, 2013 1:35:18 GMT -6
Ooooo...I kinda like using the ribbon for the side...feels way more natural than other times I've used M/S with two condensers... i dig the ribbon there also, gives the pseudo stereo image a deepness because the roll off on the hi's make the S sound farther away, especially with a C12 mid. It's indeed a versatile technique, fader set just right, it definitely strikes me as natural sounding as well 8)
Post by cenafria on Nov 22, 2013 2:27:55 GMT -6
IME, Of course the room matters, but distance=depth and less chance to mess things up, the closer you get, the bigger small mic moves change the tone(movements by the player). The newest thing i've been messing with, and loving the results of, is mid/side recording, C12 in cardoid, and figure 8 ribbon, duplicate the ribbon track, invert phase on one channel, hard pan opposite each other respective of the 8 pickup. Yeah - also called Blumlein...or at least I think... psst... Blumlein and MS arent the same ; ) Both are coincident pair techniques and can provide excellent results, but... Blumlein consists of two matched fig 8 mics placed 90º from each other. The centre of the source would be 45º from this crossed pair. No decoding necessary. The signal from each mic is panned to either side of the stereo "picture". With MS you can have any kind of mic with any kind of polar pattern "looking" straight at the source (source of the Mid signal) and a figure of eight placed 90º from the first mic with the positive lobe pointing towards the left from audience perspective (source of the S signals). The signal from this mic is split into two channels, each panned 100% to either side. You need to invert the polarity of one of these signals. Usually it is panned right to maintain "audience perspective". It is crucial to keep equal gain for S and -S during playback. You adjust these levels to make the perceived stereo field wider or narrower. Wes Dooley has a geat article on MS on his AEA web page.
Post by cenafria on Nov 22, 2013 2:35:11 GMT -6
I see the Blumlein/MS thing had already been cleared up... : )
I have had great results placing a ribbon and a condenser together and mixing both signals to get a good balance of air and detail and "physicality" and girth.
I usually like to record acoustics in the room with the liveliest acoustic response and add a couple of room mics. The delayed omnis on the floor technique usually works well.
Post by cenafria on Nov 22, 2013 3:48:24 GMT -6
For stereo recordings, there are two techniques that are awful hard to beat: 1. Blumlein, 2 figure of 8s in XY stereo about 18" to 24" back from a center point aimed at the 17th fret in parallel alignment to the plane of the floor. LDCs excel here. 2. One SDC aimed at a slight angle downward at the neck body joint about 12-18"back, another SDC or an LDC looking over the shoulder of the player aimed at the bridge, "looking" at it, at a 10º to 15º angle. The Blumlein is an incredible sound because it's a real stereo technique that collapses well but when collapsed to mono, retains all the information. The balance of direct and reflected signal can really give you a brilliant sense of space. It can be a really big sound and fill up a lot of the sonic real estate in a beautiful way. The problem with MS is that it isn't really a true stereo technique but a simulated one... now stay with me here. The sides are captured with ONE Figure 8 microphone that is feeding the signal to both sides in positive and negative phase. This is a psycho-acoustic pseudo-stereo effect. When summed to mono, the sides are obviously canceled out. Thus leaving only the mono single point source and then that becomes critical that it is pointed at the neck/body joint and provides the basis for most of what you wish to hear. But just think about it... true stereo is two coincident sources. MS is not two coincident sources, it is ONE source with the phase flipped on one side. Now, it can be argued that it sounds good, and certainly it can. But it isn't actual stereo. Hmm... Scratching my head a little Ward. I understand where you're coming from, but I believe similar points could be argued against all stereo microphone techniques. Having said that, I feel like I completely derailed the conversation. Sorry guys!
Post by watchtower on Nov 22, 2013 10:40:05 GMT -6
In my previous post I typed "decade" and meant "decode." Ridiculous.
Post by tonycamphd on Nov 22, 2013 11:08:50 GMT -6
^ damn spell checker lol, I do love the blumlein pair, spaced pair, ortf are all great of course, the thing i'm loving about M/S is, the only thing i'm doing(musically) right now, besides building this friggin studio, is working on my tunes. I like to come up with, and record my ideas, i don't know where i'm going ultimately, the M/S gives such control over the stereo image, that i'm just loving the versatility.
If i was to use any of the other techniques, i'd have to have an end result in mind, M/S has turned out to be very liberating in regard to creating on the fly, and it sounds really nice and much more realistic than a plugin stereo image on a mono track after the fact IMV
Post by watchtower on Nov 22, 2013 11:09:26 GMT -6
ward, I would argue that your assessment is not entirely accurate. M/S IS two coincident sources. You place the mics as close together as possible, just like Blumlein or XY. It's a coincident mic technique. You're not "just" flipping the phase on one side, either. There's a matrix that sums or subtracts with the Mid mic. It's not the same as taking a random cardioid mic in the room and putting it + on the Left and - on the Right. That would also cancel out when you sum to mono like M/S, and it would have an "out-of-speaker" wideness sea-sickness thing going on. A bi-directional mic will actually pickup the room sound differently on the left and right. It's true stereo. Yes, it fully cancels the S mic when you sum to mono, but that doesn't mean there aren't volume and timing differences between the two sides of the figure 8, which is the basis for stereo mic techniques.
Post by Martin John Butler on Nov 22, 2013 11:40:23 GMT -6
OK, can you guys post some examples of some of these different mic techniques? Even a song by an artist you like, with some mic info would be cool.
