Post by watchtower on Feb 2, 2014 22:20:55 GMT -6
You can hear the C12 on vocals here, with very minimal EQ.
https%3A//soundcloud.com/damianherring/st-peters-hood-justin-vernon
Post by winetree on Feb 2, 2014 23:57:30 GMT -6
They're in the mail. Waiting for Poctop's 251 boards with floating Hi-Z section with the 3 switching relays. I already have all the new Mouser parts for mic and power supply. I'm going to convert over one of my DIY C-12s with the Tim Campbell capsule. Might sell Matador's C12 finished and tested Mic and power supply boards. If interested let me know.
Post by watchtower on Feb 5, 2014 21:02:58 GMT -6
Wintree, would you mind posting a clip of your C12? Do you have a U47 type to compare it to? Tony, do you have the ability to post an MK47 versus C12 clip yet? I just got some Russian PIO caps. Gonna install one in the C12 this weekend I think. I'll do a detailed comparison of before and after by using my U47 and Manley Ref Card as "controls."
Post by svart on Feb 6, 2014 8:43:04 GMT -6
Here's a rough mix of a band I'm recording using my C12 copy for vocals. EQ was a cut around 1.8k for a nasal note, cut around 300hz for clarity (both pre compressor). Post compressor EQ was wide boost around 7k for clarity, narrow cut around 200hz for a boomy note. Compressors were 1176, medium attack, fast release and an LA2A, around 4db reduction. Preamp was 1272. www.theopiumdenproductions.com/spacely/parkinglots.wav
Post by watchtower on Feb 6, 2014 22:14:51 GMT -6
Thanks for sharing svart! Is this your 460 that you modified? I just installed a green Russian K42y-2 PIO in my C12 in place of the modern, metalized polypropylene cap. The silver K40y was way too big unfortunately (and its outer shell is conductive, which had me a bit worried). The verdict? Well, the mic still sounds great . I'm sure there's SOME difference, but it is certainly not an obvious one if it's there.
Post by svart on Feb 7, 2014 8:38:10 GMT -6
Thanks for sharing svart! Is this your 460 that you modified? I just installed a green Russian K42y-2 PIO in my C12 in place of the modern, metalized polypropylene cap. The silver K40y was way too big unfortunately (and its outer shell is conductive, which had me a bit worried). The verdict? Well, the mic still sounds great . I'm sure there's SOME difference, but it is certainly not an obvious one if it's there. It is! It's just rewired to match the C12 circuit with an old 12AT7 I pulled out of a vintage Fender amp when I re-tubed it. The capsule is a C12 edge-terminated clone. I bought 2 capsules for cheap and selected which one I liked better, and then selected which side I liked better to use as the primary side. I used the other capsule to play around with tensioning. The bulk decoupling caps in the mic were paralleled for increased decoupling. The audio path caps were changed to 'styrene or polypro depending on the location and value, and the RFI caps were removed to get rid of that LC peaking of the transformer. I also cut apart the cheesy rubber capsule mount and fashioned an epoxy-putty mount that is conical in shape, just like my Gefell's have. This is supposed to reduce the reflections inside the headbasket, but who knows if it really does.. I also shortened the 7pin cable to 10ft. This artist I was recording came in right after I made the mic and he was always complaining that none of the studios he had been to could capture his voice quite right. He did have a very strange harmonic in his voice which would cause mics to "warble" at high levels. I still don't quite know what it was, but maybe some kind of sympathetic vibration of the capsule or something.. Anyway, we tried the C12 clone and he LOVED it, although it still "warbled" just a little bit. He loved it so much that he begged me to sell this mic to him. Instead, I offered to show him how to make his own. So he bought a 460 on ebay for 150$, and I did the same mods and installed my second capsule in his mic. To our amazement, the different tension on the second capsule didn't "warble" at all with his voice and the lower tension kind of lessened the upper harmonics in his voice too. Unfortunately he moved away and I don't get to record him, but to this day he still carries that mic to every studio he goes to to record and he's told me that none of them can find a mic to beat it on his voice.
Post by tonycamphd on Feb 7, 2014 22:00:29 GMT -6
Wintree, would you mind posting a clip of your C12? Do you hnave a U47 type to compare it to? Tony, do you have the ability to post an MK47 versus C12 clip yet? I just got some Russian PIO caps. Gonna install one in the C12 this weekend I think. I'll do a detailed comparison of before and after by using my U47 and Manley Ref Card as "controls." Sorry, Not yet mang, im in the NYC area working for a bit, won't be home till March, then I'll try to get that and a bunch more done...I hope!
Post by tonycamphd on Feb 7, 2014 22:08:46 GMT -6
svart, can u show a pic of the guts of ur modded 460? I'd love to see what u did, also, how did u mess with capsule tensioning? That seems like quite a trick! Thanx
Post by hazmatstrat on Feb 8, 2014 14:48:02 GMT -6
Wintree, would you mind posting a clip of your C12? Do you have a U47 type to compare it to? Tony, do you have the ability to post an MK47 versus C12 clip yet? I just got some Russian PIO caps. Gonna install one in the C12 this weekend I think. I'll do a detailed comparison of before and after by using my U47 and Manley Ref Card as "controls." I love the green PIO capacitors I use them a lot in custom builds. Very smooth sound. I also use the RFT, Seimens and ERO MP box capacitors. All sound good. I saw Dave Bock using one on a high end custom build. Jim Jacobsen JJ Audio Attachments:
Post by watchtower on Feb 8, 2014 15:09:46 GMT -6
Wintree, would you mind posting a clip of your C12? Do you have a U47 type to compare it to? Tony, do you have the ability to post an MK47 versus C12 clip yet? I just got some Russian PIO caps. Gonna install one in the C12 this weekend I think. I'll do a detailed comparison of before and after by using my U47 and Manley Ref Card as "controls." I love the green PIO capacitors I use them a lot in custom builds. Very smooth sound. I also use the RFT, Seimens and ERO MP box capacitors. All sound good. I saw Dave Bock using one on a high end custom build. Jim Jacobsen JJ Audio Looks great, Jim! I'd love to hear more about that Seimen's MP. Might be the perfect fit for a C12 or U47.
Post by hazmatstrat on Feb 8, 2014 15:47:56 GMT -6
Attachment Deleted Attachment Deleted Attachment Deleted Attachment DeletedThis RFT cap is in my 47 build it is a dual .5uf capacitor. It looks the same as the Seimens. The other 4 capacitors are ERO, and Russian mil spec box capacitors. All of them are MP capacitors like the original Bosch / Seimen capacitors. In fact Siemens makes a dual .5uf capacitor that looks the same as the RFT including the schematic on the back. The box capacitor in the last pic was mounted in the mic by cutting the bottom tab off of the capacitor, soldering a bent piece of brass, on the capacitor and drilling and tapping the brass to fit on the existing rail holes. Jim Jacobsen JJ Audio
Post by watchtower on Feb 8, 2014 16:34:29 GMT -6
Awesome! Does MP in this context stand for Metal Paper, or something German? I have always wondered if the original AKG C12 output cap was metal paper or PIO Siemens. I think all of those would be too big for my U47 and C12, unfortunately
Post by svart on Feb 8, 2014 21:27:57 GMT -6
svart, can u show a pic of the guts of ur modded 460? I'd love to see what u did, also, how did u mess with capsule tensioning? That seems like quite a trick! Thanx yeah, I'll get some tomorrow. Using the mic tonight! Not sure that there is much to see, there are quite a few wires and it just took moving a couple. The tensioning was sort of a happy accident. I loosened the screws around the outer ring and the mylar started to wrinkle just a little, so I tightened it back until the wrinkle was gone. It sounded a little different, but I can't say what the actual tension was or that other capsules would do the same thing. I had to break the "loc-tite" that was on the screws (the red glue looking stuff) to get them to move. I think of capsule tension as the same as that of a drum head. It needs to be tense enough to move with the audio but not so tight that it rings.
Post by svart on Feb 9, 2014 14:19:45 GMT -6
Here's the pics. not much to see. There is a styrene cap on the back of the board. One of the coupling caps was changed with a polypro (large reddish cap), a couple of the resistors were changed to different values, the RF caps removed, etc. All these parts I put in because I had them already and needed to change them to make it more C12 like, not really due to tone or anything like that. I figure that if the circuit is functioning correctly, the difference in how the singer sings into the mic from take to take is greater than the difference a cap could ever possibly make.
Post by svart on Feb 9, 2014 14:22:58 GMT -6
Awesome! Does MP in this context stand for Metal Paper, or something German? I have always wondered if the original AKG C12 output cap was metal paper or PIO Siemens. I think all of those would be too big for my U47 and C12, unfortunately MP is metallized paper.
Post by Deleted on Feb 9, 2014 16:33:36 GMT -6
Yes, or in german: Metallpapierkondensator.
Post by watchtower on Feb 9, 2014 21:28:51 GMT -6
Thanks guys. So now I'm curious... I read the original C12 used PIO and styrene caps, but I've also read it used a Seimens MP cap. So if it used MP for the coupling cap, which others were PIO and which were styrene? I think there's 3 other caps in the circuit.
This is just for fun. I don't think I have room in my mic for any different components from what are in it now. PIO would be a lot bigger than my current styrene. I'd have to rebuild the entire mic point to point I think. Could be fun, but not really on my "to-do" list.
I have some other russian caps that are "paper and aluminum foil." Some have called these "paper and wax," but I was wondering if you might also call them metallized paper, or if that would be an improper term.
Post by Deleted on Feb 10, 2014 2:03:30 GMT -6
MP "Metallpapier" capacitors have paper as dielectric. Therefore Paper-In-Oil caps are MP capacitors as well. The paper is soaked or impregnated with oil or wax. Pre 1980 PIO caps can be highly toxic in case of fire, because they release PCB polychloric biphenyle. I do not know of any caps that use paper as dielectric, that were not using oil or wax. All of them are called "MP".
They are picked for their exceptional hysteresis properties due to paper as a dielectric and in this regard they shine. Followed by polystyrene and poöypropylene as dielectrics (KS and PP). Obviously the physical dimensions limit the use of MP caps. You want to take them for output cap, where they shine. The cap connected to the capsule, you definitely want to be styroflex (polystyrene?)... I don't have the schem or BOM of the C12 at hand so i don't know what they used for other caps in the C12, but the above can be taken as critical choices that have proven to sound good in these positions(generally). Also in other mics.
Best regards, Martin
EDIT: PS: I do not know if i am right calling styroflex polystyrene caps, the material in the styroflex caps is called "Polystyrol" in german. Both are trivial product names, not chemical names, which is in fact "Styrol-Butadien-Block-Copolymer" (SBC), a synthetic resin.
Post by svart on Feb 10, 2014 11:59:08 GMT -6
Styroflex is a name of a model/product name of polystyrene cap, so yes, you are correct.
Post by Deleted on Feb 10, 2014 17:08:41 GMT -6
Another thing i forgot about MP and Styroflex capacitors that are good to know when experimenting with them for audio use, that is not regarded as much as it should... Capacitors are susceptible to microphonics to different degrees. E.g. Styroflex are quite microphonic, therefore you have to watch out where and how you pick and mount them. Sometimes it is better to mount them off the PCB, point to point. The huge MP caps on the other hand are very insensitive in this regard.
Post by ben on Dec 10, 2014 0:22:06 GMT -6
Does the voltage rating of the c12 output cap matter all that much? I've seen 250v-650v. Does the voltage effect the sound as much as the uf?
Post by jeromemason on Dec 10, 2014 1:19:47 GMT -6
250v is fine. The voltage is usually around 120v-150v unless it's stated otherwise somewhere. I believe the voltage across that Cap is halved as well, but I suppose it would depend on which circuit you're using, in mine I have 70vdc on the plate.
Post by ben on Dec 10, 2014 10:32:48 GMT -6
Cool thanks.
Post by ben on Jan 19, 2015 23:33:37 GMT -6
Do the polystyrene caps have to be polystyrene? What's the sonic benefit? As far as voltage, I assume that anything from 120v on up would be ok on a 120v circuit? (Maybe a bit more for good measure).
Post by tonycamphd on Jan 26, 2015 22:06:42 GMT -6
Do the polystyrene caps have to be polystyrene? What's the sonic benefit? As far as voltage, I assume that anything from 120v on up would be ok on a 120v circuit? (Maybe a bit more for good measure). polystyrene are known to be the most transparent of caps...so?
