Post by wiz on Nov 8, 2016 13:36:10 GMT -6
DRIP REDD 47 PCB and CASE
Post by Guitar on Nov 19, 2016 14:20:19 GMT -6
I decided to try my luck with some Joly-esque (or Shannon-esque?) MXL sdc mods. I started with a sub-$80 pair of 991 mics, added a paper in oil cap between the capsule and FET, and replaced two ceramic 220n caps with larger 680n film caps in the audio path. Then I disassembled the capsules, carved a shorter and more rounded shape in the capsule housing, then reassembled the capsules. I intend to make blog post about it for other people to follow. This is basically the same thing OktavaMod will do for you but they are asking $300 per mic, which in my mind, means skip the whole thing and buy a better mic, like a Beyer MC930 or something. Used KM184, etc. I love doing stuff like this though so I had to take a shot at it. Also I just sold my KM184 so I needed something roughly similar to replace it. They sort of remind me of the Oktava MK 012 I used to own once upon a time. Pleasantly rounded tone, perhaps lacking that super clear detail of the more expensive mics like the Neumanns. Just a tiny bit less resolution. They almost sound "vintage" in a way. Sort of a distinct midrange character. They won't replace my favorite acoustic guitar microphones, might be a good option for too bright guitars, or guitars that need to sit in a big mix. I got some great drum sounds in XY over my kit. Cymbals are very clear but not hyped at all, even in a pretty bright room. It's too early to pass a grand judgement on these. But I can say stock, I found them almost unacceptable for use. After the mods, they are doing some worthwhile stuff. The mods open up the low end a lot, and drastically improve clarity. I guess most of all, it was a really fun, and cheap project. I guess I still am also on the market for a high end SDC pair. It's hard to move from Neumann to MXL, even when tricked out.
Post by mikec on Nov 20, 2016 7:14:50 GMT -6
Just got a pair of consecutive serial numbered Avedis e27 EQs. Really nice top end without being harsh. These things are really built great. Can't believe how heavy these little things are.
Post by ericn on Nov 21, 2016 20:29:23 GMT -6
Just pulled the trigger on a used RADAR V with controller & meterbridge from Don Larking Great deal from across the pond!
Post by john on Nov 21, 2016 23:51:45 GMT -6
Post by Bender on Nov 22, 2016 0:47:20 GMT -6
Sweet lamp!
Post by jeremygillespie on Nov 22, 2016 8:18:13 GMT -6
How is it? Almost went further with some bids on it over the weekend but I've never used one and got cold feet haha.
Post by john on Nov 22, 2016 9:02:14 GMT -6
How is it? Almost went further with some bids on it over the weekend but I've never used one and got cold feet haha. ill let you know after the long weekend. first stops are snare and electric guitar. i stumbled on it local for a great price which NEVER happens to me.
Post by svart on Nov 22, 2016 9:21:24 GMT -6
1985 Peavey Butcher.
I immediately turned it into a 59 superlead JCM800. It's only about 6 resistors and a couple trace cuts, Which is why Marshall sued peavey over the Butcher back in the day.
Which is hilarious when you think about almost the whole PI and PA sections are identical to early Fender amps.
Post by Johnkenn on Nov 22, 2016 9:24:00 GMT -6
1985 Peavey Butcher. I immediately turned it into a 59 superlead JCM800. It's only about 6 resistors and a couple trace cuts, Which is why Marshall sued peavey over the Butcher back in the day. Which is hilarious when you think about almost the whole PI and PA sections are identical to early Fender amps. Interesting. Never heard of it. joelhamilton
Post by Johnkenn on Nov 22, 2016 9:25:17 GMT -6
Friedman UAD amps Stam SA4000 Samar VL37A
Post by ericn on Nov 22, 2016 10:13:50 GMT -6
It kind of reminds me of your avatars head!
Post by ChaseUTB on Nov 22, 2016 15:38:05 GMT -6
$49 I got The waves API 2500 64 bit! ( $300 normal and we complain about UAD right 😂 ) Now I don't have to go back and print 100 old mixes going to 64 bit:) When I was rich, I bought a big old waves Bundle. I could have got way more for the $ spent nowadays. I didn't/ don't use hardly any of the stuff in the bundle and when the wup came for 32-64 bit, the bundle was really expensive 4+ years ago. This ( and waves SSL bus comp ) has been one of the main things holding me back from PT12, New UAD, 64bit..
Post by topshelfmg on Nov 23, 2016 1:04:44 GMT -6
The RTZ 9762 Dual Combo, based on Randge's recommendation, and man is it a nice preamp. My new personal favorite, as Randy said it would be. I know they still have the 500 series models available, but I think I scooped the last dual mono unit for a while. As soon as they pop up, give them a go. I also got an old Tube Tech LCA-2A that has had some slight mods done to it, which I love on BGVS, certain drum busses, and certain (typically more natural, slower, or acoustic sounding mixes), and even certain acoustic instruments with very subtle compression (guitar and cello is what I've tried so far). I think it's a great unit, and it's fast as all hell if I need it to be. On that note, I also picked up a Serpent Audio SB4001 in the last couple weeks I deciding on after posting on here, and that is awesome as well. Mix buss and drum buss for heavier or denser mix busses or drum busses, and Randy got great results on a piano of all things with it when I brought it over to his place. It had the boost side chain mode engaged, and a 2:1 ratio I believe. I've been gear binging as of late, haha.
Post by Guitar on Nov 23, 2016 8:39:34 GMT -6
I've been gear binging as of late, haha. I am afraid I am about to do the same with all these black friday deals popping up everywhere...
Post by mikec on Nov 23, 2016 10:34:14 GMT -6
I thought the features of the new Chameleon Labs 880 rack, 8 space lunchbox looked good, 8 spaces, rack ears and 4 blank panels included, on/off switch on the front, and 3 amps of power. Unfortunately after just a couple of weeks it is showing a LED fault with the -16V power. I guess now I see how good their tech support is. Maybe I should have stuck with a good standard like API. Anyone have any suggestions in case this one ends up not working out?
Post by BenjaminAshlin on Nov 23, 2016 13:41:03 GMT -6
I decided to try my luck with some Joly-esque (or Shannon-esque?) MXL sdc mods. I started with a sub-$80 pair of 991 mics, added a paper in oil cap between the capsule and FET, and replaced two ceramic 220n caps with larger 680n film caps in the audio path. Then I disassembled the capsules, carved a shorter and more rounded shape in the capsule housing, then reassembled the capsules. I intend to make blog post about it for other people to follow. This is basically the same thing OktavaMod will do for you but they are asking $300 per mic, which in my mind, means skip the whole thing and buy a better mic, like a Beyer MC930 or something. Used KM184, etc. I love doing stuff like this though so I had to take a shot at it. Also I just sold my KM184 so I needed something roughly similar to replace it. They sort of remind me of the Oktava MK 012 I used to own once upon a time. Pleasantly rounded tone, perhaps lacking that super clear detail of the more expensive mics like the Neumanns. Just a tiny bit less resolution. They almost sound "vintage" in a way. Sort of a distinct midrange character. They won't replace my favorite acoustic guitar microphones, might be a good option for too bright guitars, or guitars that need to sit in a big mix. I got some great drum sounds in XY over my kit. Cymbals are very clear but not hyped at all, even in a pretty bright room. It's too early to pass a grand judgement on these. But I can say stock, I found them almost unacceptable for use. After the mods, they are doing some worthwhile stuff. The mods open up the low end a lot, and drastically improve clarity. I guess most of all, it was a really fun, and cheap project. I guess I still am also on the market for a high end SDC pair. It's hard to move from Neumann to MXL, even when tricked out. Hi Monkeyxx, Interested to know what effect the capsule mod made when you did it. Did you get a chance to AB with a stock capsule?
Post by Guitar on Nov 23, 2016 15:49:34 GMT -6
Hi Monkeyxx, Interested to know what effect the capsule mod made when you did it. Did you get a chance to AB with a stock capsule? Yes I did an A/B comparison with different takes, unfortunately not the same take. But the effect is obvious enough to hear. The stock capsule just sounds a tiny bit closed in, and resonates very slightly at certain frequencies. Sort of like cupping your hands loosely around your ears or mouth. It sounds as if it's in the bottom of a small tube, which it is, almost 4 millimeters of material. The modified capsule sounds wide open and spacious, with very accurate off axis response to my ears. These mics have a very wide cardioid pattern so you can hear it pretty well. At first I was nervous going into this mod step. But then I thought, "hey these mics are worth less than $40 each" and I got brave and went for it. It really wasn't that bad. You just need to be careful not to contaminate the capsule while it's taken apart. I would absolutely recommend the capsule mod with these mics, makes a significant gain. My next step is to try the vent opening mods on either these or a second set of mics. I like this enough I think I'll probably do two more the same way to have more mics in my locker.
Post by BenjaminAshlin on Nov 23, 2016 19:01:36 GMT -6
Hi Monkeyxx, Interested to know what effect the capsule mod made when you did it. Did you get a chance to AB with a stock capsule? Yes I did an A/B comparison with different takes, unfortunately not the same take. But the effect is obvious enough to hear. The stock capsule just sounds a tiny bit closed in, and resonates very slightly at certain frequencies. Sort of like cupping your hands loosely around your ears or mouth. It sounds as if it's in the bottom of a small tube, which it is, almost 4 millimeters of material. The modified capsule sounds wide open and spacious, with very accurate off axis response to my ears. These mics have a very wide cardioid pattern so you can hear it pretty well. At first I was nervous going into this mod step. But then I thought, "hey these mics are worth less than $40 each" and I got brave and went for it. It really wasn't that bad. You just need to be careful not to contaminate the capsule while it's taken apart. I would absolutely recommend the capsule mod with these mics, makes a significant gain. My next step is to try the vent opening mods on either these or a second set of mics. I like this enough I think I'll probably do two more the same way to have more mics in my locker. Thanks, I have pulled one of those capsules apart. But made a mess of it trying to unscrew that washer thing with those 2 little holes in it. How tight did tighten it when you put it back together.
Post by Guitar on Nov 23, 2016 19:32:04 GMT -6
Thanks, I have pulled one of those capsules apart. But made a mess of it trying to unscrew that washer thing with those 2 little holes in it. How tight did tighten it when you put it back together. Well, that's up to you. Me, I like it pretty tight, so that's what I did. I hear that this affects the volume of the air space in the capsule and can affect the output.
Post by svart on Nov 25, 2016 22:44:36 GMT -6
A security system for the studio.
Post by terryrocks on Nov 26, 2016 1:38:33 GMT -6
Two capi bt50 kits. 👊
Post by Guitar on Nov 26, 2016 9:31:21 GMT -6
Went nuts on black friday, whoops -two MXL V250 mics for modding, same internal as SP-1, jimwilliams style mods. probably end up with K47 capsules. Possibly CK12. -CAD GXL2200 and GXL1200 for more mods. the 2200 will probably get an M7 capsule and a transformer and single FET amplifier. -two Apex 205 ribbons for mods. these are the ones I am most excited about! drbill and others have shown what they can do. I simply can't wait to get them set up. -Blackstar Studio 20H guitar amp head!!! This seems like the goldilocks amp I've been searching for, it's been some time now. Need amp OD. Tired of clean amps. Don't need full on shred. Don't need 100 watts in a home studio. Need to save a little physical space also. the fun for me starts on Tuesday, when these packages will have begun to trickle in
Post by ragan on Nov 26, 2016 12:15:22 GMT -6
WA-2a and a second WA76. Chilly outside but feeling pretty WARM in here....whah whah whah Attachments:
Post by Johnkenn on Nov 27, 2016 21:29:10 GMT -6
