Post by jin167 on Oct 30, 2016 1:26:15 GMT -6
About to pull the trigger on this bad boy. I'm so nervous.. wish me luck.
Post by timcampbell on Oct 30, 2016 4:33:20 GMT -6
Finally replacing my old Struers. Indirectly audio.
Post by kcatthedog on Oct 30, 2016 5:04:46 GMT -6
You got me, what the hell does that cool machine do ?
Post by timcampbell on Oct 30, 2016 5:19:44 GMT -6
Hahaha! It's a lapping machine for polishing capsule backplates to within 2 microns of absolute flatness. After using my old struers on about 2500 capsules it finaly bit the dust
Post by sean on Oct 30, 2016 7:28:54 GMT -6
Drums..lots of drums. Some to sell but a few to likely keep ('67 Acrolite, early 60's Champagne Sparkle Jazz Festival, 70's 6.5" Supraphonic)
Also, a Josephson e22s. Excited to finally try one.
Post by schmalzy on Oct 31, 2016 10:05:09 GMT -6
I finally got a mic stand I can trust. ...but even then it's kind of cheap. The bottom of the legs where the caster screws in isn't welded on straight so it sits wonky. I'm not planning to wheel it around a ton so it shouldn't be a real problem. Attachments:
Post by jin167 on Nov 1, 2016 5:32:15 GMT -6
Double needle VU + amorphous xformers.... on its way here to New Zealand and I think I'm the first person in this country to have one ha!
Post by gearshoot on Nov 4, 2016 16:57:39 GMT -6
Custom built Klontz Sum Difference and 2 parallel blenders in one unit. Super handy combo for the outboard gear.
Post by mikec on Nov 5, 2016 8:20:19 GMT -6
I was able to use a 15% off discount code on Front End Audio so I couldn't help myself and just received this Smart C1 LA that I will be running in the insert in my 2Bus Plus.
Post by wiz on Nov 5, 2016 15:18:22 GMT -6
Well, the SA4000 from STAM is on the way...
I also bought a STELLAR CM5 Microphone thats on the way...
Post by ragan on Nov 5, 2016 15:24:49 GMT -6
Well, the SA4000 from STAM is on the way... I also bought a STELLAR CM5 Microphone thats on the way... cheers Wiz Oh nice. A new CM-5 or one of the older ones? I heard Peter was redoing them and re-releasing them but haven't heard much since. I had a CM-5 for awhile. I regret selling it.
Post by wiz on Nov 5, 2016 15:35:07 GMT -6
Well, the SA4000 from STAM is on the way... I also bought a STELLAR CM5 Microphone thats on the way... cheers Wiz Oh nice. A new CM-5 or one of the older ones? I heard Peter was redoing them and re-releasing them but haven't heard much since. I had a CM-5 for awhile. I regret selling it. Old one... There was a split in the company, and one entity is getting rid of stock. As far as I know, the second half hasn't produced the updated models yet cheers Wiz
Post by ragan on Nov 5, 2016 15:54:43 GMT -6
Oh nice. A new CM-5 or one of the older ones? I heard Peter was redoing them and re-releasing them but haven't heard much since. I had a CM-5 for awhile. I regret selling it. Old one... There was a split in the company, and one entity is getting rid of stock. As far as I know, the second half hasn't produced the updated models yet cheers Wiz Gotcha. Explains why I hadn't heard anything about it. Let us know what you think. I found that to be a really solid mic.
Post by timcampbell on Nov 5, 2016 17:07:57 GMT -6
I literally got these in the last hour.
Post by jayson on Nov 6, 2016 7:12:30 GMT -6
Post by sean on Nov 6, 2016 9:01:11 GMT -6
Incoming!
Post by mulmany on Nov 6, 2016 9:55:48 GMT -6
You Sir have a drum fetish! :-)
Post by mulmany on Nov 6, 2016 10:10:52 GMT -6
Capi 51x rack, capi t-shirt
m-parts 990 and Sdc mod kits with k47 capsule
Collective cases 3 slot 500 series rack kit and psu filter.
JLM kraft work psu, Hammond power transformers.
72' of canare 8ch snake for patchbay wiring.
Post by c0rtland on Nov 6, 2016 14:37:16 GMT -6
Post by ragan on Nov 6, 2016 15:13:49 GMT -6
DAMN
Post by ChaseUTB on Nov 6, 2016 15:36:10 GMT -6
Post by sean on Nov 7, 2016 6:53:53 GMT -6
You Sir have a drum fetish! :-) It's a bit of an obsession but hey, it helps pay for expensive studio stuff. Hoping to turn that around and get a Upton 251 or a Flea 47...or a TG1 or real close to a Zener Limiter. Then do it all over again 100 times and slowly tick off the boxes of gear I want for the studio
Post by mulmany on Nov 7, 2016 8:13:36 GMT -6
You Sir have a drum fetish! :-) It's a bit of an obsession but hey, it helps pay for expensive studio stuff. Hoping to turn that around and get a Upton 251 or a Flea 47...or a TG1 or real close to a Zener Limiter. Then do it all over again 100 times and slowly tick off the boxes of gear I want for the studio So, are you restoring the kits then selling them on for a little profit? Or are you just flipping them?
Post by sean on Nov 7, 2016 8:51:40 GMT -6
It's a bit of an obsession but hey, it helps pay for expensive studio stuff. Hoping to turn that around and get a Upton 251 or a Flea 47...or a TG1 or real close to a Zener Limiter. Then do it all over again 100 times and slowly tick off the boxes of gear I want for the studio So, are you restoring the kits then selling them on for a little profit? Or are you just flipping them? I usually have to do some restoration, track down some parts, do some cleaning, occasionally a small repair. Sometimes it's a simple flip that just requires cleaning them up and making them look nice. I've also had good luck trading with studios and musicians. That doesn't mean I don't keep some things for myself though I have a Slingerland set at home, and a Ludwig kit at the studio, and about 10 snares. I've also been into flipping and trading gear...my dad used to restore vintage cars (now mostly motorcycles) so I spent a lot of time doing that with him as a kid and it rubbed off on me.
Post by EmRR on Nov 8, 2016 10:29:48 GMT -6
Proper box for my KM140's, pair of Rycote INV-3 shockmounts, pair of mic stand elbows to get that final angle adjustment made with awkward mic arrays.
