Post by porkyman on Dec 2, 2015 17:36:17 GMT -6
Listening in the shop but they are good enough for location monitors. The top end will rival $5000 speakers for 1% of their cost. The top end has better resolution than my JBL tweeters have. On sale until tomorrow, get a pair. will do. thanks.
Post by Johnkenn on Dec 2, 2015 18:15:04 GMT -6
Damnit, Jim...you just spent $52 of my dollars...Ordered
Post by indiehouse on Dec 2, 2015 20:56:53 GMT -6
What's a decent amp for these things? I wonder if they'll be suitable for a home stereo setup?
Post by Deleted on Dec 3, 2015 2:20:52 GMT -6
The speakers have a spec'ed power handling of 40W RMS. The above mentioned Class-T tripath amp has something around 2x20W. Could work ok if you don't crank the volume knob too hard. Personally i prefer to have amps with more power than the speakers can handle so that the power supply does never get in trouble when the impedance drops in the speakers. Maybe an amp with something rated like minimum 2x60W RMS for a load of 4 Ohm. But that's only me. Sure you can run the speakers for your home stereo setup. ("6 Ohm" speakers could be 4 Ohm speakers ... they write 6 because customers often think that there is some kind of "impedance matching" with the amp needed, which is a urban myth, and often don't buy speakers that they think are not "compatible" with what the amp manufacturer labeled his amp outs and "wants" the amp to see there...) This said, i am the crazy guy who powers antique french speakers for 200 Euro used with a 5k amp... and i swear they sing and outperform many studio monitors. ;-)
Btw., the tripath based class-t amps i heard until now are quite impressive in their perfomance/price ratio and might be a good cost effective amplifier topology for these speakers..
Post by Deleted on Dec 3, 2015 2:58:20 GMT -6
Beware! These are not the same speakers, it must contain the "AIR" suffix. Only these have the tweeters you want to have. The cheaper ones supposedly have a far inferior i.e. crappy tweeter.....
Post by Johnkenn on Dec 7, 2015 13:27:07 GMT -6
@smallbutfine So, I can use the same Lexicon 212 just to hear what they sound like?
Post by ericn on Dec 7, 2015 14:27:15 GMT -6
@smallbutfine So, I can use the same Lexicon 212 just to hear what they sound like? Yes , but John to make it easy I'm going to suggest a speaker switch box!
Post by Guitar on Dec 7, 2015 15:14:01 GMT -6
@smallbutfine So, I can use the same Lexicon 212 just to hear what they sound like? Yes , but John to make it easy I'm going to suggest a speaker switch box! That's what I do. I started out with a chinese generic one, it gave me mostly trouble. I recycled it and got a used Niles HDS-6 for similar cheap money on eBay and it's been flawless ever since. Right now I've got 3 pairs of speakers on the same amp but it will soon climb to 4. I wonder if I'll ever do all 6.
Post by jcoutu1 on Dec 7, 2015 15:28:46 GMT -6
Speaker switch box. Man alive, this is a breakthrough. Didn't even think of these.
Post by ericn on Dec 7, 2015 15:47:05 GMT -6
Saw in Adcom in a pawn shop today if anybody wants me to go back and try to deal shoot me a pm!
Post by kcatthedog on Dec 7, 2015 15:55:57 GMT -6
nice do you recall which model ?
Post by ericn on Dec 7, 2015 16:21:44 GMT -6
nice do you recall which model ? It was the little one, like 1/2 space.
Post by kcatthedog on Dec 7, 2015 16:24:14 GMT -6
K I think that is sub 50 watts per side ?
Post by ericn on Dec 7, 2015 18:23:06 GMT -6
K I think that is sub 50 watts per side ? in Johns little room Ill bet he's never used more than 40!
Post by Deleted on Dec 8, 2015 14:43:43 GMT -6
Johnkenn the others already said it - sure. Check them out with the amp you are used to. The Lexicon 212 looks nice. It's a known re-branded amp, right? Have fun with it, if the small speakers doesn't sound good to you, at least they were *cheap*. Don't forget to tell this you wife, you *would* buy cheaper gear if it was always so good, but this is soooooo rare. (That's my strategy...)
Post by Johnkenn on Dec 8, 2015 16:40:25 GMT -6
Yep...hooked them up last night. Nice and flat top end. Might be really good for a different reference point.
Post by Johnkenn on Dec 8, 2015 16:40:33 GMT -6
Actually, I was hoping they would be a little worse than they are so I could really have a "boombox" type speaker to hear a mix on.
Post by tasteliketape on Dec 8, 2015 17:16:14 GMT -6
Coleman audio makes an la3a that nice
Post by ericn on Dec 8, 2015 18:59:18 GMT -6
That's line level for switching actives or amps not speaker level!
Post by Johnkenn on Dec 8, 2015 19:02:09 GMT -6
Yeah - someone point me to a decent cheap switcher if you wouldn't mind...One issue is that I'm using Straightwire going to my monitors...haven't seen any cheap ones that accepts the big fat end of that.
Post by ericn on Dec 8, 2015 19:56:22 GMT -6
Yeah - someone point me to a decent cheap switcher if you wouldn't mind...One issue is that I'm using Straightwire going to my monitors...haven't seen any cheap ones that accepts the big fat end of that. Adcom's will take decent size barewire or pins take a look on eBay, in the past I have built panels with 4 pin speakon's and a 4-12ga speaker patch cord. Best simple speaker switching, was out looking at car speakers and looking at all the stupid digitally controlled switchers and thinking how easy simple patch bays and panels would be!
Post by Johnkenn on Dec 8, 2015 20:34:09 GMT -6
I thought you were talking about the Adcom amp...
Post by Johnkenn on Dec 8, 2015 20:41:34 GMT -6
Post by ericn on Dec 8, 2015 22:10:43 GMT -6
If its bare wire or pins yes, if it's banana plugs or screw lugs no. I don't remember how your wire is terminated! But you will need 3 pairs of speaker wire 1 amp to switcher 2 switcher to Amphions 3 switcher to Jims faves, personally like JW I'm a kimber cable guy but it's a bitch to work with, so I'll say your best bet is generic 12ga. I used to buy cheap generic 12ga extension cords chop the ends and terminate ( probably just tin the ends at the switcher box and crimp on Or solder Spade lugs amp and speaker ends ) in my poor kids live rig.
Post by sean on Dec 9, 2015 8:29:48 GMT -6
