Post by joseph on Aug 31, 2015 19:33:16 GMT -6
Big assumption that you'll get proper mastering from a truly full service facility that digs into spectral editing. Usually doesn't happen. If you haven't fixed those problems before sending it to them, you usually hear about it as feedback. Assuming you have honest dialog with a regular mastering engineer. I rarely see bus compression reveal sub-sonic problems, but then I don't use it very heavily, barely a touch. You aren't gonna convince me that a 40Hz hpf on toms will "separate the body and cohesion in the midrange. And you have to resort to more compression". I'm struggling with the idea of getting rid of subsonic junk on the kick, but NOT on anything else. You can open up lots of different ribbon mics to still air in a quiet room, and see all kinds of junk at pretty good level down into single digit Hz. Put any sort of movement in front of it, and said junk goes way up. A lot of it you never hear, but it's happy to mess with your dynamics processing and eat your amplifier power, problems that get bigger the more compression one applies. Well of course, automate the truly egregious plosives that eat up to 250Hz or so. What about the ones under 50Hz your studio and home speakers don't reproduce, but a sub in a club will? Assuming again, that you have any say in the matter. I mean, HELL YES let's all make unwaveringly professional recordings WITH professional studio musicians in ASTONISHING sounding rooms, spending PLENTY OF TIME ferreting out every gremlin of mic placement and type, then we won't have to use all these fix-it tools. I'm all for it. It's usually not reality. I don't ignore the practicalities you describe, but try to deal with them in other ways. First, high-passing floor tom at 40hz is way different than overheads or even snare from 100-1000hz, obviously. I'm not an absolutist, so don't put words in my mouth. If you like to hpf everything but kick at 50hz, fine by me. I prefer gentle shelving because like I said I tend not to like the resonance bump most filters have reaching into the mids and the loss of depth with more aggressive hpf. With vocals or guitars, the unnaturalness of aggressive hpf is pretty easy to detect. Usually if I've done things right, I'm adding lows with electric guitars, not taking them away. This is something I try to apply from Joe Barresi. My monitors translate pretty well down to ~40hz. An SSL or 2254 style compressor without any sidechain engaged, and the limiter on cheap computer speakers will quickly reveal if your bass info is blown out. Beyond that, I do what I can with headphones and analyzer. Rest I leave to mastering engineer. As jazznoise said, always using good shock mounts makes a big difference! I don't close mike within an inch of a tom skin or a singer's mouth. This creates more depth so you need less eq and compression and it helps with proximity build up. Same deal with mud and using expander on room mics where necessary. I avoid the sources of build up if I can and try to use quality mikes that I am familiar with and can predict well (top choices being KM84, E22s, M88, RE20), or again pulled back far enough from the source (like M201 on snare). Yes, a good mastering experience will have some feedback, involve trust, and I don't expect to nail everything every time. That's how mastering engineers earn their reps, not by being aloof. These days, everything is portable, good rooms are cheaper. There's not much excuse for compromise on an important production. About the other issue, I think it's better to give tips to musicians to control their dynamics better and listen to each other. Rather than try to repair poor technique, because it never sounds as good. Bass players without touch and drummers especially, but same thing with singers and mic technique.
Post by joseph on Aug 31, 2015 20:29:58 GMT -6
low level, ultra low freq grunge is a part of life in recorded music, it comes from and happens for a lot of different reasons, the more time your speakers spend trying to reproduce that useless shit, the less time they're spending accurately representing the good stuff, it's really just common sense, and every serious AE in the world totally gets the importance of proper filtering, including Steve Albini. Bruce Swedien stuck with the Harrison 32 console for the entire 2nd half of his career based on the fact that he loved! and couldn't go on without the 32's filtering sections. What can I say? I agree. One more bit, and I'll leave the topic alone... I use eq and high-pass filtering only when I need to, and avoid them wherever possible, particularly the latter. Low-pass is different because I feel groups and drums tend to work well built on foundation from the ground up, not the top down. Digital recording at high sample rates can really benefit from LPF and more serious shelf cuts that go down more gently or musically into the audible range, like with cymbals or condensers on guitar amps or synthesis or to counteract a bell boost. The resonance tends to sounds better to me and doesn't affect the midrange like a hpf often does. But I like rhythm guitars to have body and drums built from the FOK, room mics or overheads. Like Svart said, I try to focus more on mic selection, placement and shock mounting. I use aggressive filtering only as a last resort when I fucked something up. I don't boost highs as a matter of course either, as it pulls on the midrange, and with condensers there are usually plenty highs without tape in the cymbals and vocals. Rest and any full mix sweetening I'd rather trust to mastering engineer with experience about what matters, and full range system.
Post by scumbum on Aug 31, 2015 20:42:02 GMT -6
So am I hearing things right ? Because a mono overhead and kick mic seem to sound much more punchy than a typical multi mic setup ... That's exactly what I've been hearing for 40+ years! It was even worse on tape because of gap-scatter. Each additional mike is also an insult to the drummer. I always set up so I have the choice of mono drums in addition to the usual 1980s approach. Well that confirms what I'm hearing then . I thought maybe I was fooling myself . I recorded a Mono overhead + Kick , drum track , and then compared it to many commercial CD's with multi miced drums.........after an hour or so of listening my conclusion was that the mono overhead sounded overall better , punchier , better transients .....but it was hard to believe because multi micing is so entrenched in recording today , I kept thinking it can't be true . I swear a Mono overhead placed by the drummers head and a kick mic sounds damn good .
Post by popmann on Aug 31, 2015 20:43:58 GMT -6
Whether we're discussing the sub or supersonic frequencies--it's almost always less about their absence as the side effects of the filters that remove them.
There's nothing usefull below 50 or above 22khz....AND it's usually compromising to the audio pass filter them out. I can show you an 88.2 and 44.1 that have differences as low as 4khz. Effect of the 22khz decimation filter. Same way I can show you a 75hz HPF on a mic causing ugly sibilance--but, no one thinks that some sub sonic rumble is the cure for sibilance.
"It's the filter, stupid."
At first, moving to software mixing, I was loving linear phase pass filters....as they don't have the SAME side effects as traditional designs....until I started noticing they simply traded them for a different set of side effects. So--if you NEED to pass filter, you really need to try both and see which is less compromising to the program material.
Obviously YMMV.
Post by EmRR on Aug 31, 2015 20:53:06 GMT -6
Here, I am opposite: I rarely see any need to touch a LPF. I don't like what they do to most sources at all, unless they are employed to fix an F-up or unfortunate bleed. I am generally more critical of high frequency problems than most I know, FWIW, YMMV, etc etc. I tend to gravitate towards preamps and processors with non-hyped or soft top end.
Some talent are like paranoid wild animals, and there is no directing them. The best direction is knowing to leave that type in their natural state, work around them, an employ documentary procedures, as if a no-kill safari. Sometimes a HPF is a savior when dealing with elephants around the jeep.
I gotta ask, do you track full bands live in the same room frequently, as I do? Everything from loud rock to bluegrass, with keeper vocals thrown in? HPF's get really useful in those cases, to get more specific.
I didn't intend to put words in your mouth, simply responding to that which sounded potentially absolutist through vagueness; a constant pitfall of printed conversation.
Post by EmRR on Aug 31, 2015 20:59:05 GMT -6
That's exactly what I've been hearing for 40+ years! Each additional mike is also an insult to the drummer. I always set up so I have the choice of mono drums in addition to the usual 1980s approach. I swear a Mono overhead placed by the drummers head and a kick mic sounds damn good . Yeah, and this is MOST true when the drummer has good technique. So many don't! I swear it seem like the reason multi-mic technique came in at times. So many cymbal bashers who touch the toms like it's a dainty china teacup they worry might shatter. "hey man, can you turn up my toms?"
Post by EmRR on Aug 31, 2015 21:01:16 GMT -6
I can show you a 75hz HPF on a mic causing ugly sibilance--but, no one thinks that some sub sonic rumble is the cure for sibilance. This I haven't experienced. Turning off LA-2A plugs can definitely be a cure for sibilance!
Post by EmRR on Aug 31, 2015 21:02:42 GMT -6
I mean, really. The best sounding work I ever do is a stereo pair on an entire band, spending the time to orchestrate and arrange the music for the stereo pair. Duh.
Post by joseph on Aug 31, 2015 21:38:50 GMT -6
I gotta ask, do you track full bands live in the same room frequently, as I do? Everything from loud rock to bluegrass, with keeper vocals thrown in? HPF's get really useful in those cases, to get more specific. I didn't intend to put words in your mouth, simply responding to that which sounded potentially absolutist through vagueness; a constant pitfall of printed conversation. Thanks for saying that. To clarify I usually use LPF that begins in the inaudible range or like a 2db 16khz shelf cut. With tape I wouldn't bother. All I do is track bands live in the same room if I can help it! That's how I worked on my mic placement and decided which mikes I like best. I guess you can say I leave most of the filtering to the microphones, which sounds way more natural to me. Live vocals I use Beyer M88, nothing better for cymbal bleed. RE20 if I can get away with it, but often not. Sometimes you just gotta overdub the vocals, though. I'm often amazed how little low end bleed there is with the right microphones vs how much crap with the wrong ones or poor placement. But I use small amps and thin cymbals. Forget about controlling bleed in most rooms if you don't. I always start with figuring out where the drums sound best in the room, and it's usually not the center of it. Then I'll add the other instruments and amps. E22S is the best microphone I've used for drums and pleasant rejection of things you don't want like too much cymbal wash and high-hat, capture of all you do. It is crazy good in almost any acoustic environment. KM84 for overhead, but I don't want to break it and E22 is slightly better for close miking, reverse being true for acoustic music. M160s can be useful because they are like laserbeams on amps near a drummer. Hey, of course I screw things up too, but usually I get the most important mikes right and lose what's not working or like I said use an expander keyed to snare if I want more room mic but it's getting muddy otherwise. I don't use a lot of mikes because I both prefer the sound and try to get each one just right in the time that I have, using the best mikes available. If a room sucks, I just avoid it, period. Thankfully, you can track anywhere with a laptop and 500 series. That's the big benefit these days. If the drummer plain sucks, then the drummer will suck no matter what you do. I will simply give up and refer elsewhere, not my type of service. I will talk to cymbal bashers though about how to favor their shells but not him them so hard they choke, and let them use my insured thin cymbals and 5as. Once I tell them about Grohl and Crover reigning it in, they tend to listen.
Post by joseph on Aug 31, 2015 21:43:41 GMT -6
I mean, really. The best sounding work I ever do is a stereo pair on an entire band, spending the time to orchestrate and arrange the music for the stereo pair. Duh. What pairs are your go-tos? I have yet to do this on anything but acoustic ensemble.
Post by EmRR on Aug 31, 2015 21:50:22 GMT -6
Samar MF65.
Post by popmann on Aug 31, 2015 21:56:39 GMT -6
It's not mutually exclusive to say they harm a signal AND use them because not using them harms the bigger picture more.
I'm simply saying that pass filters do more than filter out frequencies above or below. I'm not saying they aren't necessary at times....I'm not saying don't use them when they do more good than harm....but, to explain the above discrepancies where people feel it's a "myth" that there's nothing useful "down there", which is usually true--but, believe that because filtering out "down there" sounds worse than not. Or the constant belief that 44.1 is all we need because we don't hear over 22khz anyway....
And no--I never track bands where the instruments are all in one room. It's been a long time since I tracked bands at all.
Post by joseph on Aug 31, 2015 22:02:40 GMT -6
That's cool! Hope to check them out some day.
Post by tonycamphd on Aug 31, 2015 22:58:55 GMT -6
If i don't want any color from a filter, i use the fabfilter proQ2 in linear phase mode, i have an instance on every single channel in my templates(mac beast), i don't use them on low freq, sharper transient instruments(kick, funk bass etc) because the pre ringing artifacts, I use them to clean up the tracks as transparently as possible to save voltage and woofer waste, I can definitevly say that even in linear phase mode i hear the eq, not much at all, but it's definitely there. If i ever find an eq/filter that can pull off transparent in an absolutely transparent way, i'll be beyond stoked to have them. But for the most part, i honestly feel a good character HP filter is priceless, I'm a drummer 1st and foremost, in the past I've used a mono overhead, and a FOK mono mic ad nauseum and to good effect, I always HP both. I absolutely love the Glyn Johns technique, it's my go to, i've always used HP on every track. I love big open tuned drums mic'd minimally and with distance, and with my new personally built drum rig, i was lucky enough to get an endorsement with paiste, so I got to hand pick all of my cymbals at their headquarters in brea cali, they are a combo of giant beat, and 2002 thins with 15" hi hats and a 24" ride, big and thin, hit and out the way, awesome for recording. I'm now flirting with as close to a Bonham style sound as anyone i've ever heard with this setup, that is the Holy grail drum sound to me and i'm about there! and i will be using HP filters on every track when i lay it down for the first time(on our pal Levons project). HP filters are such an absolute must for me that I'm going to be putting HP/LP Harrison filters into all 38 of my input channel strips on my console, with hard bypass on both individually, i need to check out EmRR's findings, and talk to JW a bit about implementation, but it's going to happen.
Post by jazznoise on Sept 1, 2015 2:32:19 GMT -6
That's great, maybe the Harrison HP is the bomb diggity but I've never used one. I just don't like HPF'ing everything - it's fine as I said on snare, hat or toms where the panning out of these LF's might make your stereo image a little confused feeling. But I have to hear something before I cut - which I feel is sort of an ironic turn around. Usually when we disagree it's because you're using a more subjectivist perspective than I am. It's not punchy to carve everything out, it's carvey. It always sounds like a sonic jigsaw to me. Not to say you don't record well, but the guys in my area who do this a lot are basically not giving their clients the best product. Even the ones with very good setups. They could buy a Shure drum mic set and HPF it at home for a lot cheaper like the internet tells them 10 times a day, I think we should bring something more nuanced to the table.
LPF'ing as a mix tool is something I'll use on guitars when bands tell me they want the beer-commercial guitar sound. For modern metal it's also considered mandatory. I don't like it, but it's their music and not mine. I'll probably have to HPF the guitars too to glue the bass into the wall of chugga chugga. I'm not in general doing much but occasionally adding high end, but my setup doesn't really have any makes with a top end boost for that reason. I'd rather just focus on getting the midrange right.
This all said I really like the MS-20 style HPF, and I in general like running HPF's into distortion for cool effects. They're just not a subtle tool to me, they're something stylistically foisted on me by others, like when I work with metal bands, or they're a means for me to correct the errors of another engineer. Of course this is all just my experience. I'm not tracking drums for another month when I'm cutting them with my own band, I'll stick something up then.
Post by Guitar on Sept 1, 2015 7:46:11 GMT -6
My favorite filter for bass instruments lately is the UAD Little Labs VOG "Voice Of God." It's a resonant high pass filter, so you can get a lot of cut, along with a strong and narrow boost just where you want it, right above the low cut. This way you can clean up the low end a bit while still getting some power going at the right frequency. It's really easy to dial in as well.
But I'm also a low end lover and tend not to filter too much, unless there's excessive proximity effect or something like that. Usually I'm boosting stuff down there with Pultec shelves.
I use low pass filters all the time but more for synth music, since that's one of the major components of traditional subtractive synthesis, and electronic production in general. They don't come up quite as often for me in rock but I like a nice Pultec high shelf cut on the master bus sometimes, or a UAD Ampex tape machine doing more or less the same thing.
I side with those who tend not to get too tweaky with drum phase and track timing. As long as things are grossly in phase you can usually work from there and it sounds fine. I've also never had too many successes with tweaking these ad nauseum. It gets different but not necessarily better. I might gently high pass the overheads if the material calls for it, or heavily filter and gate the toms if the bleed is ugly. Sometimes a more cut up sound is better suited to a track than a natural one. I'm sure that genre is a factor there.
I like minimal drum miking but I always seem to need the close mics, especially the tom mics, to get everything where you can hear it properly. I would have a hard time just forgetting about the tom mics for most recordings, they just seem essential to me. Sometimes it's fun just to go punk rock though and put up one or two mics and just go for it. You lose a lot of control in mix balancing but that is such a cool sound. I like the idea of just committing to a sound, it makes for a simpler mix.
I guess my favorite place to get creative with trap set engineering is the overhead and room mic arrays. There are just so many variations on how to set those up, including using 3 or more overheads or however many room mics, or near the kit mics, underheads, whatever you call them. It's also really cool to cram mics right up in the middle of all the shells, you can capture the heart of the kit this way and get a lot of your sound from just that one mic.
The biggest lesson for me in the beginning was probably just to escape the idea that there's one right way to mic a kit. There are so many viable possibilities it's best not to be stuck in a box. You can get as creative as you need to, as minimal or maximal as you want.
I'm sure I don't have as much experience as a lot of you guys recording drums so I love reading these threads. I love drums.
Post by EmRR on Sept 1, 2015 8:18:28 GMT -6
Post by Bob Olhsson on Sept 1, 2015 8:29:08 GMT -6
FWIW all linear phase filters suffer from pre-echo. Another problem with high pass filters is they can increase peak level and distortion without creating any increase in perceived volume.
It's important to always ask and then listen for "What am I screwing up?" Listen to all filter and eq. settings in the context of a mix and never make judgements on a solo'd track.
Post by dandeurloo on Sept 1, 2015 8:31:16 GMT -6
In my kits I have fixed the problem thanks to EMRR for finding it!
Post by EmRR on Sept 1, 2015 9:06:17 GMT -6
Harrison Ford Filters, don't know if the boards have hit another run with in/out polarity fixed. Pay attention to it, as well if you are skipping the in/out buffer chips.
This is a zany thought.
I wonder if those who like LPF's while eschewing HPF's predominantly use condensers, and those who like HPF's while eschewing LPF's predominantly use dynamics/ribbons? As a big broad nasty generality, of course it's not that clear cut.
I don't use many condensers, they mostly sit in their boxes. Usually ribbons on guitar amps, OH's, room mics, vocals. My input path is virtually all pre-1970 tube and transistor too. Pre-filtered and shaped if you will, not much call for a LPF on much of anything, yet plenty going on well above 30K. Big emphasis on fundamental frequencies, ribbons working from resonant point at the bottom of the curve, more sensitivity and call for HPF's?
Feel free to ignore, thinking out loud. Could be a bad habit.
Post by jimwilliams on Sept 1, 2015 9:28:00 GMT -6
Acoustic drums are never in phase. They are seperated by a couple of feet so that never happens when you listen to them either. That is ok, it's a natural and an expected sound. Re-setting the timing so they all sound like they were played from the same 1" spot is very weird. Might be a good go if you are going for a drum machine sound.
Post by dandeurloo on Sept 1, 2015 10:07:43 GMT -6
Harrison Ford Filters, don't know if the boards have hit another run with in/out polarity fixed. Pay attention to it, as well if you are skipping the in/out buffer chips. This is a zany thought. I wonder if those who like LPF's while eschewing HPF's predominantly use condensers, and those who like HPF's while eschewing LPF's predominantly use dynamics/ribbons? As a big broad nasty generality, of course it's not that clear cut. I don't use many condensers, they mostly sit in their boxes. Usually ribbons on guitar amps, OH's, room mics, vocals. My input path is virtually all pre-1970 tube and transistor too. Pre-filtered and shaped if you will, not much call for a LPF on much of anything, yet plenty going on well above 30K. Big emphasis on fundamental frequencies, ribbons working from resonant point at the bottom of the curve, more sensitivity and call for HPF's? Feel free to ignore, thinking out loud. Could be a bad habit. I had the same thought earlier in the thread reading your comments. I have a pretty good understanding of what you are regularly using and most guys even with a good amount of gear are not set up like you. You have a very unique set of gear and that has to lead to different set of problems/solutions and processes from most everyone else who doesn't have such an vintage locker of gear. BTW, HPF are good. haha
Post by tonycamphd on Sept 1, 2015 10:25:26 GMT -6
Harrison Ford Filters, don't know if the boards have hit another run with in/out polarity fixed. Pay attention to it, as well if you are skipping the in/out buffer chips. This is a zany thought. I wonder if those who like LPF's while eschewing HPF's predominantly use condensers, and those who like HPF's while eschewing LPF's predominantly use dynamics/ribbons? As a big broad nasty generality, of course it's not that clear cut. I don't use many condensers, they mostly sit in their boxes. Usually ribbons on guitar amps, OH's, room mics, vocals. My input path is virtually all pre-1970 tube and transistor too. Pre-filtered and shaped if you will, not much call for a LPF on much of anything, yet plenty going on well above 30K. Big emphasis on fundamental frequencies, ribbons working from resonant point at the bottom of the curve, more sensitivity and call for HPF's? Feel free to ignore, thinking out loud. Could be a bad habit. I had the same thought earlier in the thread reading your comments. I have a pretty good understanding of what you are regularly using and most guys even with a good amount of gear are not set up like you. You have a very unique set of gear and that has to lead to different set of problems/solutions and processes from most everyone else who doesn't have such an vintage locker of gear. BTW, HPF are good. haha Yeah, i was checking out Doug's rig(EmRR), it's ridonkulous!!!
Post by EmRR on Sept 1, 2015 10:39:00 GMT -6
Right or wrong, this is where obsession gets you.
It's kinda hard to check out my rig, website is grossly out of date, and I took down the equipment list, deciding it's just an ego trip and a thieves shopping list. It's never served any purpose to put it out there.
Post by joseph on Sept 1, 2015 13:53:51 GMT -6
I'm a drummer 1st and foremost, in the past I've used a mono overhead, and a FOK mono mic ad nauseum and to good effect, I always HP both. I absolutely love the Glyn Johns technique, it's my go to, i've always used HP on every track. I love big open tuned drums mic'd minimally and with distance, and with my new personally built drum rig, i was lucky enough to get an endorsement with paiste, so I got to hand pick all of my cymbals at their headquarters in brea cali, they are a combo of giant beat, and 2002 thins with 15" hi hats and a 24" ride, big and thin, hit and out the way, awesome for recording. Well, I think with your kind of setup/technique it's hard to go wrong regardless. Highly recommend you check out the Paiste 602 20" thin crash, it is incredible.
