Post by LesC on Jun 11, 2015 20:44:41 GMT -6
Thank you for the detailed info, I'm sure it will be useful for others reading this thread. My UFX can certainly handle SPDIF levels and impedance on the AES ins and outs. But I was asking about the connectors on your box itself. I think AES connectors are seen as more professional than coax SPDIF, in the same way that XLR connectors are see as more professional than TRS. If for no reason other than marketing purposes, you might want to consider offering both in future products. I see. Since there is no functional difference between AES and SPDIF, I chose the one that also allows me easy connection to a lot of audiophile products as well, CD players and such. This greatly expands my possible product reach beyond the pro-audio market. I figured people would adapt the units as they need, while I keep costs down and space to a minimum by using the smaller RCA connector. I understand some folks might be turned off because of this, but there is no technical reason for them to think they are unsupported, as the adapters are extremely simple. In the future I might offer AES in XLR format if things work out with this product. I agree with you, there is no technical reason for both. But most of the ostensibly "high end" convertors tend to have at least AES, coax SPDIF, optical SPDIF, and work clock in/out for marketing purposes as well as convenience. They also usually have XLR connectors for analog, or both XLR and TRS. Examples would be the Ross Martin Superbeast, Burl B2 ADC, Lynx Hilo, Antelope Pure2, Metric Halo ULN-2, Apogee Symphony 2x6, and I'm sure lots that I'm not remembering.
Post by jcoutu1 on Jun 13, 2015 12:07:47 GMT -6
Post by Martin John Butler on Jun 13, 2015 12:11:16 GMT -6
Will do this tomorrow, was bumper to bumper the last two days.
Post by Johnkenn on Jun 13, 2015 13:08:17 GMT -6
Just know Jcoutu is wating on you...
Post by Martin John Butler on Jun 15, 2015 11:14:02 GMT -6
Just plugged it in, it looks like it's working. I set my Apollo to spidif in.I'll track a little acoustic guitar and vocal later, or tomorrow. Listening with just the new clock, it's much more transparent. I borrowed a BLA Microclock for a week 2 years ago. The Microclock was excellent, and there was no doubt it helped with the Apollo, it was absolutely cleaner and clearer.
The clock on the svartbox is similar, way more transparent than the Apollo's clock, and I feel there's a little more life and sparkle with the svartbox compared to the Microclock, if memory serves.
Post by Johnkenn on Jun 15, 2015 11:39:28 GMT -6
Sorry I didn't hit you back Martin. Here's the way to hook it up - but I'm sure you've got it going.
DA Connect spdif cable from Apollo (out) to SB. Facing the back of the SB, should be on your left. Make sure your audio cables that connect to your monitors are coming out of the SB analog outs. Change the Apollo clock to Spdif.
AD Connect the spdif cable from SB spdif out to Apollo spdif In Make sure to use an outboard pre to test. This way you're using the SB AD. Run that pre and whatever else into the analog in of the SB. In Console, you will now see the input coming into the Spdif channel.
Post by Martin John Butler on Jun 15, 2015 21:27:53 GMT -6
Got it running earlier today John, thanks. I'll do a quick recording with the SB, and then without, just as a general comparison. I'd like to do more extensive testing, like a complete remix, but just can't spare the time right now. My sister's terminally ill and I've been focusing on that for a while now.
I like what I've heard so far, the new clock is more transparent, much like the BLA micro clock was, but more life and sparkle. I did notice what seemed like a little reticence in the low end, but I think it's just plain ol' more accurate.
* I think when I hit 2,000 posts I'll need an honorary title or a nickname under my icon. Could be, "Wears Black, like Johnny" But I'll leave it up to you, perhaps you' guys will think of something better.
Post by Guitar on Jun 15, 2015 21:37:01 GMT -6
MJB what is your main DAC and ADC you are comparing with?
Post by Martin John Butler on Jun 15, 2015 22:24:21 GMT -6
The UAD Apollo, monkeyxx.
UAD has just upgraded the Apollo line with many new mods, chips and new converters. The Apollo was already close for my uses, but the converters were the achilles heel. With new converters, the new Apollo might be all I'll need for my purposes. I'll get the new model eventually, and then I can compare the SvartBox files to the new Apollo, Then I'll know for sure if I need a separate converter or not.
Post by NoFilterChuck on Jun 15, 2015 23:08:04 GMT -6
The UAD Apollo, monkeyxx. UAD has just upgraded the Apollo line with many new mods, chips and new converters. The Apollo was already close for my uses, but the converters were the achilles heel. With new converters, the new Apollo might be all I'll need for my purposes. I'll get the new model eventually, and then I can compare the SvartBox files to the new Apollo, Then I'll know for sure if I need a separate converter or not. *shouts over laundromat rumble and window AC units* Based on your space, new converters are the last thing you need :-P
Post by Guitar on Jun 16, 2015 12:14:43 GMT -6
The UAD Apollo, monkeyxx. UAD has just upgraded the Apollo line with many new mods, chips and new converters. The Apollo was already close for my uses, but the converters were the achilles heel. With new converters, the new Apollo might be all I'll need for my purposes. I'll get the new model eventually, and then I can compare the SvartBox files to the new Apollo, Then I'll know for sure if I need a separate converter or not. I am very curious about the black Apollos for the reasons you've stated. Also as a consideration, I believe the Apollo 16 has "even better" technical specs on the DAC side than the 8 or 8P, like the conversion chips used. If you are going for the ultimate all in one interface, that might be worth thinking on. BLA mods are an interesting idea for version 1. But at that point it seems like, why not just upgrade to version 2, for possibly even less money lost. Personally, I think I will always rely on stereo DACs for monitoring. I just have my favorites. I think what I like would have to be an Orpheus or a Symphony or something at that level to get the DAC quality I'm used to in a rackmount full sized interface. I guess "Mastering quality" would be the goal. Simply buying a really good 2-channel DAC makes sense for me since Orpheus or whatever is clearly beyond my budget. Apollo is my go-to for tracking and mixing, and I don't feel like "mastering quality" is nearly as critical for multiple tracks. It's good enough. I am such a digital junkie.
Post by Martin John Butler on Jun 16, 2015 12:22:26 GMT -6
I agree with you Monkeyxx, and I'd probably choose my own DAC's if budget permitted. I like the Burl, but haven't heard the White Sparrow yet, and I've heard there's some real magic there too. The Apollo 16 does have even better converters, though I dont really need the extra preamps, the 16 is over budget. Still, I'll have time to think on it as I save some money, if I can save any money.
Post by svart on Jun 16, 2015 12:28:47 GMT -6
Just be careful falling in love with marketing buzzwords. "New converters" and such give the impression of improvement, but it's rarely more than a lateral change in what would usually be considered objective descriptions once you get above a certain level. I think a lot of these devices already play in the area of "good enough", and it's really just shades of sonic opinions. Do you like more highs, or more lows? Do you like clinical sound, or smoothness? Etc.
Post by tonycamphd on Jun 16, 2015 12:44:06 GMT -6
Good enough? Nope, I have to have a certain level of focus, solidity, depth, height and width of image, with dynamics to match, it's not preference its mandatory, and MOST converter/clocking combo interfaces Ive listened to do not make the grade.
Post by Guitar on Jun 16, 2015 13:02:19 GMT -6
Good enough? Nope, I have to have a certain level of focus, solidity, depth, height and width of image, with dynamics to match, it's not preference its mandatory, and MOST converter/clocking combo interfaces Ive listened to do not make the grade. Haha I love it! I am coming from a dirty, noisy rock and roll upbringing so I'm used to a certain amount of filth. However, I truly aspire to a classical level of fidelity. This is a new interest of mine. I'd love to be able to buy some Schoeps, M49, Johny Hardy preamps, the best converters money can buy, and see what the heck I could accomplish with that. And what types of music I could branch into with a cleaner sound. As it stands, I've still got one bare foot in the mud puddle, the other is a polished black Italian boot stepping ahead. So I'm inching my way in that direction. I have to agree with Svart though, past a certain point of technical completeness, conversion is still ultimately a taste-test in the subjective realm. I do think it's a pretty critical concern though in the scheme of a production. I do not think it's arbitrary, since it has a sonic impact. I'm also a little worried that this obsession can take away from the creative impulse and lead to making less actual music.
Post by Martin John Butler on Jun 16, 2015 18:18:26 GMT -6
John, I'm trying to get some recording done, have spidif connections into and out of the Apollo inserted properly, and clock source changed, but don't see any input in my console settings.
I left a message with svart, hopefully he'll walk through it with me. If I have to, I can record something tomorrow, but it would be nice to be all set up and ready to go, this way I'm concentrating on recording, and not plugging in wires.
Post by kcatthedog on Jun 16, 2015 18:56:10 GMT -6
John, I'm trying to get some recording done, have spidif connections into and out of the Apollo inserted properly, and clock source changed, but don't see any input in my console settings. I left a message with svart, hopefully he'll walk through it with me. If I have to, I can record something tomorrow, but it would be nice to be all set up and ready to go, this way I'm concentrating on recording, and not plugging in wires. in console the input wil be on spdif.
Post by Johnkenn on Jun 16, 2015 19:01:59 GMT -6
That's correct - but they won't say Svartbox lol. There will say Spdif. If they're not showing up, go I the top of console - you have to select something to show the spdif channels.
Post by kcatthedog on Jun 16, 2015 19:26:54 GMT -6
That's correct - but they won't say Svartbox lol. There will say Spdif. If they're not showing up, go I the top of console - you have to select something to show the spdif channels. the spdif channels default to spdif but of course you can rename them
Post by Martin John Butler on Jun 16, 2015 20:16:19 GMT -6
I got it, I needed to change the input to channel 23/24 to see the spidif signal. Will try to track something tomorrow morning. Tip of the hat to our friend bannedchuck, he called me and walked me through the setup ! Gotta love that !
Post by tonycamphd on Jun 16, 2015 22:49:34 GMT -6
Chuck is the man! helps me out a ton, very smart, filter free, friendly NY kinda guy, whats not to like 8)
Post by NoFilterChuck on Jun 17, 2015 1:12:54 GMT -6
Chuck is the man! helps me out a ton, very smart, filter free, friendly NY kinda guy, whats not to like 8) it's cuz i'm actually from seattle originally lol I moved here (nyc) 10 years ago.
Post by Martin John Butler on Jun 17, 2015 7:19:00 GMT -6
I could almost live in Seattle, if only the weather was a little better. I have family there now, and love it when visiting. Gonna try some tracks this afternoon, to be continued..
Post by kcatthedog on Jun 17, 2015 8:45:46 GMT -6
less travel talk, dude, what about the svartbox ? 5 days and counting !!
Post by jcoutu1 on Jun 17, 2015 9:02:56 GMT -6
less travel talk, dude, what about the svartbox ? 5 days and counting !! Pfff... you're telling me!
