Post by Deleted on Aug 24, 2013 21:56:38 GMT -6
I posted to start a discussion on buss strategy and want to start a discussion about the Mix Buss as well.
I have seen discussion in the past about the practical theory of EQ before Comp and Comp before EQ, lots of opinions. So how do you process your mixbuss and why?
Personally, I have one stereo HW comp, the Daking FET III. I like the gel it gives and though it has a sound, it is not overwhelming. Typically I will run through this first and use the Softube Pultec to add a top or bottom bump as needed. I typically will only put EQ on before the comp to correct a problem, not to enhance... API to add bite or Waves Q10 for notching, etc.
So what do you do and why?
Cheers, rob
Post by cowboycoalminer on Aug 25, 2013 9:07:52 GMT -6
The mix buss to me is a very sacred thing. It's easy to screw up in a second what I've spent hours to sculpt in a mix so I take the minimalist approach really, never waiting till the print to fix anything. So with that I mix looking ahead knowing what my comp and eq is going to impart (used the same setup for years). Always comp first (HPF sidechain engaged) them some eq if needed (usually only subtractive except for the "air" freq). Boost there from time to time. Might de ess after that if needed. Sometimes I'll use the Ampex tape sim, depends on the tune. Always set my brickwall at -10 to -11 rms for cohesion between tracks.
My thoughts are we should be smiling with a mix before we get ready to look at the buss mix. So usually, putting things on the buss strip makes me frown instead of smile, then I'll quickly take it off.
My 2 cents. YMMV
Post by jcoutu1 on Aug 25, 2013 9:12:02 GMT -6
I prefer to mix into a buss comp, then sweeten with an eq last.
Post by unit7 on Aug 25, 2013 9:24:16 GMT -6
I'm a eq before comp guy, except on the mix bus, analog btw. Cartec EQPs last in chain to give the final touch, just like jcoutu. Can't really say why though
Post by cowboycoalminer on Aug 25, 2013 10:49:58 GMT -6
That Cartec stuff is the shit that killed Elvis.. On my list of purchases for sure.
Post by Deleted on Aug 25, 2013 18:11:38 GMT -6
Cowboy, do you find that addressing the buss later results in many adjustments?
Post by Martin John Butler on Aug 25, 2013 20:36:29 GMT -6
I'm still learning as I go. To date, I've been using the Slate VBC compressor, for glue and level setting, and vibe, if you will, then the UAD Ampex ATR 102, for harmonic content, usually on the 30 ips setting, sometimes the Richard Dodd setting with some tweaks if it's a rock song. Then to the Slate FG-X mastering compressor.
I've just switched to Logic X, so this may change. Currently, the FG-X doesn't work, because Logic X is 64 bits only. I haven't gotten into my Massive Passive plug at all yet, because I don't have the dsp power to run it in the 2 bus. and I don't enjoy making a stereo mix and then bouncing that to a new track, then mastering the new with EQ and a mastering compressor. I feel bouncing messes with something. I know I'll have to get over that, but I'm just not there yet.
I haven't quite wrapped my head around the whole mastering process in the sense that once you have a mix, you send it to the mastering bus,now it's ready for the final print, what do you print to? In the old days, a 2 track tape recorder, now, what, back into Logic, or bounce the mix as a Wav file? There must be a better way.
Post by cowboycoalminer on Aug 25, 2013 20:54:42 GMT -6
Cowboy, do you find that addressing the buss later results in many adjustments? No not really. I try to do the least I can to it. What I hear while mixing is what I want to hear for a final. Basically just want it louder and squeezed a tad to catch the peaks. I'm a firm believer that there's nothing I can do at the mastering stage to help a bad mix. It will just be a louder bad mix. I try to print at about 0 to plus 4 as well so I don't have to run a limiter so hot to get to level. I find that even the cleanest limiters impart something, and I usually don't like it.
Post by Deleted on Aug 25, 2013 23:40:33 GMT -6
anyone use the Serpent Audio SB4001's on their mix bus? what settings?
Post by wreck on Aug 26, 2013 8:50:04 GMT -6
Fairly recently I started the EQ and Comp on the Mixbuss at the outset of tracking and that, combined with more emphasis on the drum buss instead of individual drum channels has completely changed my mix flow and sound for the better. I don't have hardware, but use the IK Classic EQ into the Waves SSL Comp on the Mix Buss. The IK allows me to pull the lows to the center and raise the highs on the sides with its M/S options. I typically mix with just those due to processing power issues, then when I get close to the end, I throw on the Slate VTM and run that into FG-X. I use FG-X on the drum buss as well. That and IK Classic EQ are the only things I stick on the drum buss. Again, IK is just to center the kick and spread the OHs.
Post by svart on Aug 26, 2013 11:28:00 GMT -6
Compression first and then EQ *if needed*. Generally I find that if the mix is working, then I rarely need output EQ. If it's one of those situations where I didn't track the tracks and things aren't quite up to my standards to begin with, then I'll use output EQ to fix large problems with brightness and stuff.
Post by unit7 on Aug 26, 2013 12:26:39 GMT -6
I don't disagree with the opinion that the mix should sound as good as possible without additional eq. It's just that the Pultec style eq (Cartec here) on the buss sounds so d*rn good so I add quite a lot of it early in the mix session and boost less on the console (Ok I admit, I'm talking mostly treble here). If the album is fairly consistent, like most of the stuff I do, I usually fine tune on the first songs and eventually find a setting all over which becomes like a signature for the album. Perhaps not the purist way, but I like the result!
Post by jazznoise on Aug 26, 2013 15:00:59 GMT -6
My thoughts are we should be smiling with a mix before we get ready to look at the buss mix. So usually, putting things on the buss strip makes me frown instead of smile, then I'll quickly take it off. My 2 cents. YMMV Pretty much this. I might add a little compression (1-2dB) and some saturation. Mostly Variety Of Sound's Density MKIII and his Variable Broadcast Limiter for a little distortion or Tessle SE for a little LF saturation. EQ doesn't really get touched so much, though sometimes I'll EQ pre and post saturation to get the thickening happening where I want it.
Post by svart on Aug 26, 2013 15:15:39 GMT -6
I think I'll add more detail. I most definitely mix INTO a 2-bus compressor all the time. It's just whether or not I use EQ that is always in question. I've been finding that I'm using less and less EQ over the years anyway.
Post by Martin John Butler on Aug 26, 2013 17:48:58 GMT -6
Funny svart, I mix into the 2 bus also, and since I don't have the processing power, I don't use my Massive Passive EQ. Mixes are getting better without usng EQ in the 2 bus, why I don't know, but I do wish I had to firepower to have the option. I may start printing with the massive occasionally, just to use it and not the hit dsp power at mixdown time.
Post by masteroftracks on Aug 26, 2013 18:02:55 GMT -6
I've been having great luck lately with this chain on the 2bus-Slate VTM-Maag eEQ4(a little air band never hurt anyone i know)-Slate FG-X. Mixing into that from the start has given me results I am quite pleased with.
Post by cowboycoalminer on Aug 27, 2013 14:49:51 GMT -6
I was thinking very hard today about the topic of buss mix. Usually, I'm always an outboard kind of guy but the fact is, sometimes clean plug ins are just better on the buss, especially if the tune was tracked to storage and mixed with a lot of vibey units. Harmonic content dictates what we use I think.
Any other thoughts on this?
Post by Martin John Butler on Aug 28, 2013 15:40:39 GMT -6
cowboy, I was wondering if you could elaborate on the idea that "sometimes clean plug-ins are just better on the buss". When did you find it was better, any particular kind of production? Any particular song of yours.
Unfortunately, it takes me a long time to wrap my head around things that some folks here find easy, like making a stereo mix and then doing a new, and separate mastering project. I find I integrate things slowly, so I never got into bouncing a clean mix and then doing a "mastering" session. I just try to get the best sound I can, mix into the mastering tools, and that's it. I tend to leave the FG-X off for as long as I can, use the Slate VCB and UAD Ampex 102 to dress the mix in the style that suits the song. The Ampex is easy, as it creates a background the mix sits in front of, the VCB requires more thinking, but the presets are good, so you can scroll and go if you want. I find the UAD 30ips setting on the 102 is generally very good on everything, and the Richard Dodd preset good is a starting point for Rock songs, although it thins things out a bit, so you have to tweak it.
In theory, what's the difference between having a stereo bounce called the final mix, and then a separate mastering session, or just running that final mix through the same plugs you would master through anyway? It seems my way saves a bounce. Is mixing into the mastering plugs considered something that typically hides flaws in final mixes, or is it an advantage?
Call me superstitious, but any time I avoid a stage, I feel better about it. If I wanted to have the final, with mastering plugs mix to send to a real mastering suite, I could just run it as is, mp mastering plugs, call it "plain" final mix, no? I'm certain I'd like having a DAC and an ADC, like a Burl, but otherwise, I kind of like the way the plugs are so easy to try presets on. Given all the time in the world and a full suite of analogue toys, I think analogue would still win out. But in general, with time being such an important factor in today's productions, the ability to try 20 different presets on an Ampex plug trumps actually having the reel to reel in your studio, even if the tape sounds better one on one in a test situation.
Post by Deleted on Aug 31, 2013 9:18:59 GMT -6
Do any of you treat the master in a way as to see what it will sound like when converted to MP3 or other formats?
Post by Johnkenn on Aug 31, 2013 9:42:59 GMT -6
I will usually go outboard through the VC528's and record the 2 mix. Then on the master, I'll have VCC, and SPL Vitalizer using just the stereo spread to add a little width. I'll usually gain stage with the UAD Ampex using one of the mastering presets and adjusting to taste. 30ips .5 inch tape. Then maybe VBC...maybe...or Slate FG-x. I've been wondering whether the Slate is adding a little top end, so lately I've been going back and forth with FF Pro-L.
Post by Martin John Butler on Aug 31, 2013 10:46:08 GMT -6
The Slate FG-X does add some edge in the upper mids I think, especially when you push it. I try to keep it around 3/4 or less of the volume possible.
Post by James Lugo on Sept 13, 2013 19:42:30 GMT -6
I prefer to mix into a buss comp, then sweeten with an eq last. That’s pretty much what I like too, though the past year I’ve been doing the Breaur set up with a multi buss out from my SSL 6k and running an eq last on the Program insert. It’s been working out nice. I think it’s better then adding a lot of eq on all the individual channels, especially top end.
Post by lolo on Sept 13, 2013 19:50:41 GMT -6
I prefer to mix into a buss comp, then sweeten with an eq last. That’s pretty much what I like too, though the past year I’ve been doing the Breaur set up with a multi buss out from my SSL 6k and running an eq last on the Program insert. It’s been working out nice. I think it’s better then adding a lot of eq on all the individual channels, especially top end. Good to gave you here James
Post by Deleted on Sept 13, 2013 20:02:25 GMT -6
VCC (Trident usually) SSL Comp (waves) Mpx Master Tape (waves) Clariphonic
Once it starts sounding close I start putting some mastering stuff on it. Gclip and Sonnox Limiter.
I used to use an RJR Sick Sick Bus Comp with the Tonebuss, that was a cool rig too.
Post by jcoutu1 on Sept 13, 2013 20:58:44 GMT -6
VCC (Trident usually) SSL Comp (waves) Mpx Master Tape (waves) Clariphonic Once it starts sounding close I start putting some mastering stuff on it. Gclip and Sonnox Limiter. I used to use an RJR Sick Sick Bus Comp with the Tonebuss, that was a cool rig too. I've got an RJR sick sick sick. Nice little box.
