Post by Johnkenn on Aug 14, 2024 13:20:06 GMT -6
Is there anything you can do? Or is it just the way the room is gonna be? Deres has made it a little easier to spot really bad notchable resonances. Lately - for better or worse - I've been starting vocal tracks and just adding several instances of Deres and pulling out the worst offending spikes. Actually nice, because you can notch out a freq, but you don't have to notch it at 100%...I've noticed sometimes, taking those frequencies totally out can leave things kinda dull. But using Deres like this has made a very positive difference for my mixing.
But - is there any way to knock these out at the source? Or are you just a hostage to the room?
Post by Johnkenn on Aug 14, 2024 13:51:35 GMT -6
OK - put the mic facing the 6" thick baffle about a foot away...and that seems to have knocked out a good bit of them. I've always tried to get in the center of the room...but alas...not good.
Post by spindrift on Aug 14, 2024 14:08:41 GMT -6
On a vocal I’m often using a bit of Soothe 2 as well as some surgical notching with ProQ3. I haven’t heard of the Deres plug. A lot like Soothe 2?
Post by Dan on Aug 14, 2024 14:13:20 GMT -6
Soothe. Arbiter. EQ out the scratch
Post by Pueblo Audio on Aug 14, 2024 14:33:01 GMT -6
Is there anything you can do? Or is it just the way the room is gonna be? Deres has made it a little easier to spot really bad notchable resonances. Lately - for better or worse - I've been starting vocal tracks and just adding several instances of Deres and pulling out the worst offending spikes. Actually nice, because you can notch out a freq, but you don't have to notch it at 100%...I've noticed sometimes, taking those frequencies totally out can leave things kinda dull. But using Deres like this has made a very positive difference for my mixing. But - is there any way to knock these out at the source? Or are you just a hostage to the room? Considering how many wonderful vocals have been recorded without any “instances” of anything, let’s not (at first) try to solve this artificially with plug ins. Is it every vocalist? If so then if you go in the tracking room do you hear the blemishes acoustically in the room? If not then it might be the choice of mic/placement or possibly other underperforming , non-real gear in the signal path. But If you do hear it in the room, then attack those acoustics. Much better return on investment.
Post by damoongo on Aug 14, 2024 14:41:24 GMT -6
Is there anything you can do? Or is it just the way the room is gonna be? Deres has made it a little easier to spot really bad notchable resonances. Lately - for better or worse - I've been starting vocal tracks and just adding several instances of Deres and pulling out the worst offending spikes. Actually nice, because you can notch out a freq, but you don't have to notch it at 100%...I've noticed sometimes, taking those frequencies totally out can leave things kinda dull. But using Deres like this has made a very positive difference for my mixing. But - is there any way to knock these out at the source? Or are you just a hostage to the room? Considering how many wonderful vocals have been recorded without any “instances” of anything, let’s not (at first) try to solve this artificially with plug ins. Is it every vocalist? If so then if you go in the tracking room do you hear the blemishes acoustically in the room? If not then it might be the choice of mic/placement or possibly other underperforming , non-real gear in the signal path. But If you do hear it in the room, then attack those acoustics. Much better return on investment. Amen
Post by Mister Chase on Aug 14, 2024 16:16:50 GMT -6
I can't imagine eliminating these completely. I'm sure there is a lot that can be done before plugins but I deal with some amount of these pretty much all the time. It's in the vocal perhaps, or a certain resonance in the room(maybe it's already treated) the mic itself, the piano, the guitar. If everything to be done has been tried, then I like q10, the Tokyo Dawn De-Edger and Soothe. Or automate a band in Fabfilter. I had a recording I was mixing where only 3 times in the track a certain note was sung and 1729hz just showed up real narrow and annoying. Usually I'll find some of these on occassional sources and notch with q10 about 3-6db. I just want to reduce it. Rarely do I kill it because things start to sound weird if you do that. Just want to make it a part of the sound. I have found on certain sounds that reducing these a bit remove masking and you can really hear the instrument beautifully then.
Post by geoff738 on Aug 14, 2024 16:25:52 GMT -6
I wish Deres went a little lower. I will be working with a guy who has a fair bit of honk. I dunno if 1khz is low enough to catch it. Will probably try some combination of Deres, Arbiter and Neutron. They are all pretty new to me, but I think his voice will be a good test to see what these things are capable of/ are least intrusive.
Cheers, Geoff
Post by tonycamphd on Aug 14, 2024 16:36:22 GMT -6
I suggest, (example) take a room full of people, when a woman comes up to you and whispers in your ear you hear clear as day, lip smacking, mouth noises, loads of sibilance and proximity. When someone talks to you across the same room, you point your chin up and try to get your ears above everyone's head so the intelligible frequency range can get to your ears without being absorbed by people and atmosphere, treble and sibilance freq's don't travel well through objects and atmosphere, eating a mic or close micing an instrument is actually an unnatural listening experience, we mostly talk to people starting about 3 feet away, we listen to people play guitar from a decent distance, unless you are a close talker guitar player😂
So what i'm trying to say is, try backing off the mic and the sibs and trebs won't get to the mic so easily and freq's will naturally compress, vox and instruments, this way you shouldn't see resonances and spikes as much either, the only thing that can stop you from success with this is a noisy room IME
Post by geoff738 on Aug 14, 2024 16:42:16 GMT -6
On a vocal I’m often using a bit of Soothe 2 as well as some surgical notching with ProQ3. I haven’t heard of the Deres plug. A lot like Soothe 2? Well sorta. It only works from 1 to 8 khz and only subdues one frequency band, which you search out. But its also $10. cheers, Geoff
Post by the other mark williams on Aug 14, 2024 17:05:05 GMT -6
OK - put the mic facing the 6" thick baffle about a foot away...and that seems to have knocked out a good bit of them. I've always tried to get in the center of the room...but alas...not good. I would stay away from the center of the room when possible. John, having seen pics of your room, I’d be interested to hear how your voice capture changes if you set the mic up farther away from mix position - moved toward the back wall more, like around the 1/4 to 1/3 of the way into the room area. And singing out into the room, toward your desk.
Post by christopher on Aug 14, 2024 17:19:09 GMT -6
Yeah in any random room it can be good to walk around with the mic and wearing headphones and checking polarity, testing vocal, just to see what can be done. Try cardiod with null aimed at problems, knowing the top of the mic can get a good signal similar to side address. Fig 8 same thing if you can get the null aimed at the ugly stuff. Knowing the null of cardiod, you can try to back it against a wall if you want. I really like Omni on me since I can get up close and create a bigger S/N vs the room.
Post by wiz on Aug 14, 2024 17:52:41 GMT -6
My room has symetrical treatment... my mix position is around 38% into the room longwise.... it's where I track MY vocals.... essentially the mix position.. The other end of the room is where I track others....and I have tracked there over the years...both positions are around 38% in. Both have a cloud above them. Looking at your room Johnkenn I don't know what I would do....other than move around and test.... To be frank though....I don't hear anything bad in ANY vocal you have posted....I am always just (jealously) listening to your voice.... 8) cheers Wiz
Post by Johnkenn on Aug 14, 2024 18:05:56 GMT -6
On a vocal I’m often using a bit of Soothe 2 as well as some surgical notching with ProQ3. I haven’t heard of the Deres plug. A lot like Soothe 2? No - it's just a way to find offending resonances above 1Khz pretty easily and then a bunch of tools to do that. Man, Soothe and Reso just doesn't work well for me...or I don't know how to use them well. Sooth leaves some sort of fuzziness to me.
Post by Johnkenn on Aug 14, 2024 18:07:33 GMT -6
Is there anything you can do? Or is it just the way the room is gonna be? Deres has made it a little easier to spot really bad notchable resonances. Lately - for better or worse - I've been starting vocal tracks and just adding several instances of Deres and pulling out the worst offending spikes. Actually nice, because you can notch out a freq, but you don't have to notch it at 100%...I've noticed sometimes, taking those frequencies totally out can leave things kinda dull. But using Deres like this has made a very positive difference for my mixing. But - is there any way to knock these out at the source? Or are you just a hostage to the room? Considering how many wonderful vocals have been recorded without any “instances” of anything, let’s not (at first) try to solve this artificially with plug ins. Is it every vocalist? If so then if you go in the tracking room do you hear the blemishes acoustically in the room? If not then it might be the choice of mic/placement or possibly other underperforming , non-real gear in the signal path. But If you do hear it in the room, then attack those acoustics. Much better return on investment. Thanks for the reply. I'm well aware that many vocals have been recorded without a plugin.
Post by Johnkenn on Aug 14, 2024 18:10:25 GMT -6
OK - let me just say this. This is not my first day recording. I understand that you can do more harm with a plugin than without one. So you can all assume that I know what I'm doing. OK. Now...resonances. Are they room dependent or both room and equipment?
Post by Johnkenn on Aug 14, 2024 18:12:07 GMT -6
OK - put the mic facing the 6" thick baffle about a foot away...and that seems to have knocked out a good bit of them. I've always tried to get in the center of the room...but alas...not good. I would stay away from the center of the room when possible. John, having seen pics of your room, I’d be interested to hear how your voice capture changes if you set the mic up farther away from mix position - moved toward the back wall more, like around the 1/4 to 1/3 of the way into the room area. And singing out into the room, toward your desk. Exactly the way I've done it for the 17 years I've been in this house. I actually just put the mic closer to one of the baffles and sang directly at it, perpendicular to the room, and it was mucn, much, much better.
Post by Johnkenn on Aug 14, 2024 18:14:46 GMT -6
My room has symetrical treatment... my mix position is around 38% into the room longwise.... it's where I track MY vocals.... essentially the mix position.. The other end of the room is where I track others....and I have tracked there over the years...both positions are around 38% in. Both have a cloud above them. Looking at your room Johnkenn I don't know what I would do....other than move around and test.... To be frank though....I don't hear anything bad in ANY vocal you have posted....I am always just (jealously) listening to your voice.... 8) cheers Wiz Thanks, man. There are definitely some spikey resonances. And it seems to be more when I sing. Maybe I sing with spiky resonances. lol. I've figured out I sing really loud I think...so I'm trying different headphone volumes than I'm used to. Turning it up a little more so I don't push as hard.
Post by Johnkenn on Aug 14, 2024 18:17:18 GMT -6
I suggest, (example) take a room full of people, when a woman comes up to you and whispers in your ear you hear clear as day, lip smacking, mouth noises, loads of sibilance and proximity. When someone talks to you across the same room, you point your chin up and try to get your ears above everyone's head so the intelligible frequency range can get to your ears without being absorbed by people and atmosphere, treble and sibilance freq's don't travel well through objects and atmosphere, eating a mic or close micing an instrument is actually an unnatural listening experience, we mostly talk to people starting about 3 feet away, we listen to people play guitar from a decent distance, unless you are a close talker guitar player😂 So what i'm trying to say is, try backing off the mic and the sibs and trebs won't get to the mic so easily and freq's will naturally compress, vox and instruments, this way you shouldn't see resonances and spikes as much either, the only thing that can stop you from success with this is a noisy room IME I usually sing a foot foot and a half away...but like all singers, I'm a sucker for proximity effect. But you look at all the old pics at Capitol and the mic's hanging down and the singers are like 5 feet away. I need to try that some...scoot back and raise the pre.
Post by Mister Chase on Aug 14, 2024 18:39:19 GMT -6
On a vocal I’m often using a bit of Soothe 2 as well as some surgical notching with ProQ3. I haven’t heard of the Deres plug. A lot like Soothe 2? No - it's just a way to find offending resonances above 1Khz pretty easily and then a bunch of tools to do that. Man, Soothe and Reso just doesn't work well for me...or I don't know how to use them well. Sooth leaves some sort of fuzziness to me. I max the oversampling and resolution and usually go 85% wet to help with Soothe.
Post by tonycamphd on Aug 14, 2024 19:12:21 GMT -6
I suggest, (example) take a room full of people, when a woman comes up to you and whispers in your ear you hear clear as day, lip smacking, mouth noises, loads of sibilance and proximity. When someone talks to you across the same room, you point your chin up and try to get your ears above everyone's head so the intelligible frequency range can get to your ears without being absorbed by people and atmosphere, treble and sibilance freq's don't travel well through objects and atmosphere, eating a mic or close micing an instrument is actually an unnatural listening experience, we mostly talk to people starting about 3 feet away, we listen to people play guitar from a decent distance, unless you are a close talker guitar player😂 So what i'm trying to say is, try backing off the mic and the sibs and trebs won't get to the mic so easily and freq's will naturally compress, vox and instruments, this way you shouldn't see resonances and spikes as much either, the only thing that can stop you from success with this is a noisy room IME I usually sing a foot foot and a half away...but like all singers, I'm a sucker for proximity effect. But you look at all the old pics at Capitol and the mic's hanging down and the singers are like 5 feet away. I need to try that some...scoot back and raise the pre. Do it and let us know JK, I'm a distance guy, I rarely record an acoustic guitar closer than 2' away, and i think you've heard some of the sounds i've gotten, not bad if i say so myself😆 (i do have a quiet space though)
Post by geoff738 on Aug 14, 2024 19:23:51 GMT -6
My understanding is that the headbasket design absolutely contributes to resonances or the lack thereof in a mic. Maybe some of the mic builders here can chime in.
Cheers, Geoff
Post by the other mark williams on Aug 14, 2024 21:01:13 GMT -6
My understanding is that the headbasket design absolutely contributes to resonances or the lack thereof in a mic. Maybe some of the mic builders here can chime in. Cheers, Geoff Very true, though not much headbasket resonance on John’s 017
Post by Dan on Aug 14, 2024 21:35:34 GMT -6
On a vocal I’m often using a bit of Soothe 2 as well as some surgical notching with ProQ3. I haven’t heard of the Deres plug. A lot like Soothe 2? No - it's just a way to find offending resonances above 1Khz pretty easily and then a bunch of tools to do that. Man, Soothe and Reso just doesn't work well for me...or I don't know how to use them well. Sooth leaves some sort of fuzziness to me. the soothe smokey haze never goes away. Try pro audio dsp dsm. Less haze, darker without being dull. Paul Frindle goodness
Post by drumsound on Aug 14, 2024 21:47:19 GMT -6
OK - let me just say this. This is not my first day recording. I understand that you can do more harm with a plugin than without one. So you can all assume that I know what I'm doing. OK. Now...resonances. Are they room dependent or both room and equipment? I think mics 'hear' the resonances differently than our ears do. So when we hear the playback all kinds of stuff that our brains automatically filter is there in Technicolor detail. Plus mics and the things they are plugged into have THEIR sound as well. My room has symetrical treatment... my mix position is around 38% into the room longwise.... it's where I track MY vocals.... essentially the mix position.. The other end of the room is where I track others....and I have tracked there over the years...both positions are around 38% in. Both have a cloud above them. Looking at your room Johnkenn I don't know what I would do....other than move around and test.... To be frank though....I don't hear anything bad in ANY vocal you have posted....I am always just (jealously) listening to your voice.... 8) cheers Wiz Thanks, man. There are definitely some spikey resonances. And it seems to be more when I sing. Maybe I sing with spiky resonances. lol. I've figured out I sing really loud I think...so I'm trying different headphone volumes than I'm used to. Turning it up a little more so I don't push as hard. I also think this is totally a thing. Our bodies are cavities. There is, of course, the mouth, but head shape, chest shape, etc that contribute to the noise that comes out of our faces. Which we don't ever actually hear, because we hear a big resonant heads as part of our voice that others (and microphones) do not. For some singers singing softly sounds beautiful but singing loudly does NOT (Ms Morrisette comes to mind). Other's the opposite. Some singers a lucky enough to be about to sings really dynamically without one part sounding bad. And, of course, some SONGS need to be sung one way or the other...
