Post by bluesholyman on Aug 7, 2024 5:56:21 GMT -6
I am starting a hunt now, with the intent to begin a transition from completely ITB to a hybrid scenario beginning next year.
Wanted to get thoughts on what would be the first piece of [analog] outboard gear you would choose. Generally speaking, I would think some sort of stereo compressor or leveling amplifier, but then again, just not sure. I assume there are some "foundation" pieces that just make things more better good and again, I would think this is what I would want, but I could be wrong.
Don't worry about price/connectivity as all that can be figured out. Appreciate the suggestions, thoughts, etc.
Post by theshea on Aug 7, 2024 6:09:19 GMT -6
well if price ain‘t a problem i personally would start with a rupert neve design master buss transformer.
Post by svart on Aug 7, 2024 6:39:12 GMT -6
1176 of some type. A few of them live on my vocal and bass inputs.
Post by bluesholyman on Aug 7, 2024 6:48:01 GMT -6
well if price ain‘t a problem i personally would start with a rupert neve design master buss transformer. Well, price isn't a problem unless the letters RND are in the name, each letting adding $1K to the average price Assuming I could swing it, this would be a killer piece to have, based on the little I know.
Post by niklas1073 on Aug 7, 2024 6:57:21 GMT -6
Have you already built your tracking chain? That will impact your process plenty while still keeping your mixing itb until you find itb inadequate for your needs. I would start with hw on the a side of a/d and then build a solid mixbus (if a 2bus is essential to your process). This way you have front and rear covered which i think has most impact on the outcome. Then if still lacking wow going hybrid in between the front and rear end is easy. At this point also lackings have probably shown themselves.
Edit: and while starting to look at bus units, as i agree that stereo comp is esential, it’s much up to knowing what is the sound you are after. There’s plenty of “industry standards to go by”
Post by svart on Aug 7, 2024 7:03:14 GMT -6
Have you already built your tracking chain? That will impact your process plenty while still keeping your mixing itb until you find itb inadequate for your needs. Going mostly ITB has proven to me that I never needed the fancy hybrid setup I had. It was actually more of a distraction to me having all that gear. Now I just use a choice setup of hardware pieces on the way in and life is so much better.
Post by Dan on Aug 7, 2024 7:08:05 GMT -6
I’m itb now probably forever but what impressed me. Keep in mind there’s no money in this, no time saved in mixing, and every single piece of hardware is a recall issue because it might break or need maintenance even if it has switches
On a bus? Something with megaton of distortion (not a fan of distressor and fatso that much though) or a lot of sounds to mangle drums or stomp down background vocals or something to mix into. There is a lot of stuff but of not clones and still made Smart C2, Drawmer 1978, or something with tubes in it or a Kush Tweaker on an individual track to mess it up. Hey if you want squeaky metallic clean and can piss away money, you can still get Maselec.
For tracking? I’d get something useful and clean to solve problems on the way in. Not an 1176. It’s far too easy to crush something with it and ensure the vocals never come out of the speakers. If you do more than a couple vu off, this will happen but often a couple of vu is not enough. The blue stripe clones are distorted but also spitty and gross. These are a problem on a lot of big records and you can hear it. There are used Daking FET II and III for dirt cheap that make every flavor of 1176 sound like crap. I love them and would get some if I tracked really but guys paying for tracking in 2024 is unusual. Daking also have the new vca comps that try to emulate their behavior and the little labs ll2a with two knobs and a killer demo that uses ad633 analogue multipliers to make a linear vca to simulate behavior of optical compressors but more consistently. For something else classic and also “automatic” there are dbx 560 of course.
EQs: something with inductors that saturate and ring or something? Maybe a used cool channel strip of some sorts just to solve some problems on the way in like even the clean grace one or the daking mic pre eq with the weird trident eq. A real api 550 type of eq is very useful. Cut the box, boost some shelves, add a little sound. Surgical parametric can fix problems on the way in with guitars and drums and also lower latency than digital eqs in the artist’s monitoring mix if they are not monitoring digitally. If they are going digitally, there is no point in 2024 unless you want to take out the nasty before hitting other stuff on the way in.
Post by niklas1073 on Aug 7, 2024 7:08:13 GMT -6
Have you already built your tracking chain? That will impact your process plenty while still keeping your mixing itb until you find itb inadequate for your needs. Going mostly ITB has proven to me that I never needed the fancy hybrid setup I had. It was actually more of a distraction to me having all that gear. Now I just use a choice setup of hardware pieces on the way in and life is so much better. I have exactly the same experience. Kind of combining the best of both worlds. I would always recommend to lay down the big money on the front end. For me though the mixbus was a big thing. Not that i could not mimic that itb but it just have become a defining stage in my workflow. But otherwise i do enjoy the simplicity and lightness of having everything else itb.
Post by doubledog on Aug 7, 2024 7:27:03 GMT -6
my outboard is mostly for tracking, or for sound sculpting later, but when I do final mixes, it's all ITB. so I'd recommend a compressor. What kind depends on what you are going to use it for (I don't think you really said yet?). And if the answer is I don't know, then save your money until you do know. I bought outboard stuff and quickly sold it when I didn't really have a purpose for it. when I finally understood why I really needed a specific piece, then I've kept those.
Post by Dan on Aug 7, 2024 7:27:31 GMT -6
There is also no real difference between analog and digital processing other than weird distorted stuff that digital tries to emulate and always fails horribly at. Yes an 1176 is weirdly distorted and the 1176 emulations all suck. You’re just modifying a signal. Don’t use defective clones and emulations to be cool or because some producer told you to.
Post by bluesholyman on Aug 7, 2024 7:52:05 GMT -6
There is also no real difference between analog and digital processing other than weird distorted stuff that digital tries to emulate and always fails horribly at. This is an interesting observation and one I don't have sufficient experience to disagree with, but my limited experience is not letting me agree either. To me analog has a warmth and a pleasant lack of pristineness that digital doesn't have. Digital just seems too perfect, almost sterile and I don't think anyone ever could say that of analog. I guess this is, in part, my interest in an analog outboard piece of gear. I must ponder this further.
Post by kcatthedog on Aug 7, 2024 7:55:07 GMT -6
If your front end is addressed, I’d suggest a good ssl clone for the 2 buss.
Personally, I prefer ob over plugs there.
Post by notneeson on Aug 7, 2024 9:11:14 GMT -6
LTL silver bullet:
It’s a stereo pre, it has EQ built in, the mojo circuits can be driven hard enough reduce dynamics in a very musical way, almost like tape or a compressor, but obviously different.
Everyone should have one!
Post by doubledog on Aug 7, 2024 9:19:03 GMT -6
There is also no real difference between analog and digital processing other than weird distorted stuff that digital tries to emulate and always fails horribly at. This is an interesting observation and one I don't have sufficient experience to disagree with, but my limited experience is not letting me agree either. To me analog has a warmth and a pleasant lack of pristineness that digital doesn't have. Digital just seems too perfect, almost sterile and I don't think anyone ever could say that of analog. I guess this is, in part, my interest in an analog outboard piece of gear. I must ponder this further. if you think digital is sterile, then I don't think one or two pieces of outboard hardware are going to solve that. Probably need to understand more about what you are recording, your room, your recording rig, etc. What kind of sounds do you like? And what about digital do you find "sterile"? That can mean different things to everyone. I have many recordings that are all digital. I don't think they are sterile. Maybe a lot of other things wrong with them but I don't find them sterile because it's digital. That ship sailed years ago really. There are plenty of modern recordings that are all digital and sound great. So what are you expecting from outboard hardware? Distortion? Saturation? I mainly have my outboard for functionality, maybe a little bit of coloration (especially some of the preamp choices I have for drums and more).
Post by Dan on Aug 7, 2024 9:29:53 GMT -6
There is also no real difference between analog and digital processing other than weird distorted stuff that digital tries to emulate and always fails horribly at. This is an interesting observation and one I don't have sufficient experience to disagree with, but my limited experience is not letting me agree either. To me analog has a warmth and a pleasant lack of pristineness that digital doesn't have. Digital just seems too perfect, almost sterile and I don't think anyone ever could say that of analog. I guess this is, in part, my interest in an analog outboard piece of gear. I must ponder this further. They’re all just tools. Get analog tools that distort pleasantly then or have cool warm transformers. You can always get something like a fatso or silver bullet. You can get warm from a few hundred dollars (art vla, fmr pbc-6a, used 500 series) to decent rack mount stuff (the cleaned up nevey stuff is pretty warm while 1073 clowns are often metallic) to sky is the limit stuff. The digital stair step compressors and limiters that just act based on the pcm samples sound horrible. Beyond that digital is quite good. The spitty analog compressors like a blue strip 1176, Alesis 3630, distressor most of the time, yamaha 2020, dbx 160 outside of sweet spots, smart c2 misused on middle attack settings and no auto release, sound pretty horrible often. Just not as randomly horrible as an 1176 emulation like the CLA. So do a lot of the analog compressors over compressing like the black 1176, art vla, la2a, la4, dbx 160 often, etc. we could go on but there’s not really a lot of difference to my ears versus over compressing with a functional digital compressor doing the same thing like smash something with renaissance compressor, mdwdrc2, pro audio dsp dsm, molot ge, even oldtimer (free with pro tools. ME is ten bucks from it) and the new softube three pack of emulations even. Murky and gross and loses a ton of detail and high end. A lot of people don’t even know how to set their “classic” gear with small sweet spots that can do a couple of things. You can hear it really get in the way of powerful vocalists on a ton of old rock and classic metal records. They just get murkier the louder they should be getting so the screams are often masked by the guitars which might be quite small in the mix much of the time if not cleans. Or the vocals are too loud like on a lot of pop and country but then the color is more apparent. They’re over compressed. Of course right now with multiband limiters and far too long lookaheads on them (to scale the attack to clean up the distortion because the programmers cannot write something even as not very functional as the nasty old Waves ones. The cleaned up L1 25th anniversary edition can be set to be better than the multiband garbage too), the mix and fader moves are undone by events that happen in the future. On certain horrible pop diva records you can even hear the limiter pretty much ducking the vocal and making the reverb send louder than the vocal. And the kick might be twice as loud as the vocal and more forward in the mix from high passed bus comps and poor monitoring or wanting it to sound like a bad club or car. I’m not even talking about the awful distortion yet, just the mix levels. Now we have intentionally distorted limiters where running the mix through them makes it sound like Marshall mids with tweed murk and make the Oxford enhance / safe mode that sounds like a pedal seem pretty clean.
Post by Dan on Aug 7, 2024 9:43:44 GMT -6
This is an interesting observation and one I don't have sufficient experience to disagree with, but my limited experience is not letting me agree either. To me analog has a warmth and a pleasant lack of pristineness that digital doesn't have. Digital just seems too perfect, almost sterile and I don't think anyone ever could say that of analog. I guess this is, in part, my interest in an analog outboard piece of gear. I must ponder this further. if you think digital is sterile, then I don't think one or two pieces of outboard hardware are going to solve that. Probably need to understand more about what you are recording, your room, your recording rig, etc. What kind of sounds do you like? And what about digital do you find "sterile"? That can mean different things to everyone. I have many recordings that are all digital. I don't think they are sterile. Maybe a lot of other things wrong with them but I don't find them sterile because it's digital. That ship sailed years ago really. There are plenty of modern recordings that are all digital and sound great. So what are you expecting from outboard hardware? Distortion? Saturation? I mainly have my outboard for functionality, maybe a little bit of coloration (especially some of the preamp choices I have for drums and more). Vintage Warmer and Blockfish came out in the early 2000s. The drastic Decapitator and the subtler SDDR are over ten years old. MJUC brought the variably distorted compression around then too. Right now I’m impressed with the Softube British Class A for murk. It feels more analogue but less flexible than the American class a or the intentionally distorted ssl emulations from everyone with the incredibly dysfunctional dynamics. The SSL native channel strip compressor if you hit peak is one of the biggest pos ever. It’s not even distorted like other bad things like cla 76 or awful linear compressors like reacomp or metric halo mio. It’s just terribly ticky nonsense and letting the user defeat the “rms” smoothing (it cannot detect the true rms or make the fast attack work at all) is design defeating.
Post by niklas1073 on Aug 7, 2024 10:36:34 GMT -6
There is also no real difference between analog and digital processing other than weird distorted stuff that digital tries to emulate and always fails horribly at. To me analog has a warmth and a pleasant lack of pristineness that digital doesn't have. Digital just seems too perfect, almost sterile and I don't think anyone ever could say that of analog. The terms warm vs. sterile are commonly used in discussions on analog vs. digital. But what do we really mean by that? I think it would be really good to define these attributes and understand what is really sonically happening when we experience these feelings, to be able to distinguish between preferred units and technologies. Dan is on spot with many arguments regarding distortion. As I see it the “warm” is made up of two things, EQ (usually a rolled off high end and low boost) and distortion (which acts as compression and thus usually at extremes contributes to the EQ’s effect). This does not equal analog nor tube nor a specific transistor. Many of these just happen to have one or more of these attributes in the physical nature depending of course on the circuit to what extent it is present. This doesn’t mean that you could not digitally achieve a similar result, which usually would be in a controlled context. What I believe is the magic (as I have figured it out in my head, no science here…) is the slight random and fluctuating outcome analog and especially tube equipment offers (we are talking very slightly here) that thru build ups, tracks interacting with each other creates a slight phase shifted, distorted soundscape, contributing to what we usually would call a 3D effect of sound. This is pleasant for the human ear. And I do believe this outcome is possible to achieve digitally likewise. As I have understood this randomness is coded into emulating plugs as well? Or I could be wrong. But all and all my point being. When we describe our preferences I think it’s important to try to understand what actually is happening there and not buy into the myth of commonly accepted facts of how a tube, analog or digital sounds. I have been so many times blown away by what lies behind a song, a track or a sound.
Post by drbill on Aug 7, 2024 10:58:11 GMT -6
LTL silver bullet: It’s a stereo pre, it has EQ built in, the mojo circuits can be driven hard enough reduce dynamics in a very musical way, almost like tape or a compressor, but obviously different. Everyone should have one! Agreed. And if you get the mk2, you can have a killer Locomotive Vari-Mu compressor or Buss compressor inside the mk2 as well. Or an LA76 soon....
Post by thirdeye on Aug 7, 2024 11:13:12 GMT -6
I am starting a hunt now, with the intent to begin a transition from completely ITB to a hybrid scenario beginning next year. Wanted to get thoughts on what would be the first piece of [analog] outboard gear you would choose. Generally speaking, I would think some sort of stereo compressor or leveling amplifier, but then again, just not sure. I assume there are some "foundation" pieces that just make things more better good and again, I would think this is what I would want, but I could be wrong. Don't worry about price/connectivity as all that can be figured out. Appreciate the suggestions, thoughts, etc. In my opinion, the 2 bus is priority. A good stereo bus compressor into a good stereo EQ printed through a nice stereo AD.
Post by drbill on Aug 7, 2024 11:20:14 GMT -6
The terms warm vs. sterile are commonly used in discussions on analog vs. digital. But what do we really mean by that? A sense of "alive-ness" is the best way I can describe it. It's hard to put into words. For those new to a hybrid workflow, it might even be hard to hear. But once you've lived there for awhile, it's very hard to go back to a fully ITB workflow - given of course that you have the means to sustain the hybrid workflow. Even when finalizing and printing my hybrid mixes, I am usually disappointed with the flatness or lifeless that invades the mix as its now no longer going through analog - but it's far less affected than a fully digital ITB mix for me. I could talk about this for hours, but those of us who work that way know what I'm talking about. Ultimately, sigh, everything ends up digital, but for me it's worth it to try to keep as much life and vibrancy in the music as possible for as long as possible. Even at the cost and effort of what a hybrid mix setup requires. It makes a tangible difference to some of us. I just mastered (kind of) a big score by a mentee of mine who has been getting some fairly high level films. He self mixed and mastered (ITB) this particular orchestral score, and asked me to lend a set of ears before it was released. He has been forced to be mixing himself and mastering ITB for a variety of reasons for the last 5 years or so. I listened. Instantly heard a technically good, but somewhat lifeless mix. I took it upon myself to do a super quicky "re-mastering" job where I really just added a touch of Silver Bullet, Miad EQ, & Bricasti (which BTW, he had already used ITB) and sent it back. He heard the subtle yet obvious - to us - differences, and his comment was that it was 1000 times better. I taught him how to listen and work in the studio 25 years ago as an intern, and he has become a very gifted and experienced composer. LOL. Obvious the 1000X's comment was hyperbole, but the difference was quite beneficial to the life of the music (orchestral with Appalachian overtones). Beneficial enough that the release was halted until I had time to "remaster" the entire score.
Post by chessparov on Aug 7, 2024 11:28:15 GMT -6
Along with SB... Audioscape and Coil are on my "Dream List". I_probably_wouldn't screw up my Tract with them. Too much.
Post by seawell on Aug 7, 2024 11:32:56 GMT -6
I would start with the 2 bus(compressor and/or EQ) since it's going to touch everything and then prioritize a great lead vocal compressor(I'd go Vari Mu) second. Those two are going to make the biggest difference in my experience. Hybrid is totally worth it and doesn't slow you down a bit because you're getting great tones faster/easier. Particularly with a 2 bus chain, once you dial in what you like it's pretty rare that would ever need to change so recall is a non-issue.
Post by bluesholyman on Aug 7, 2024 11:53:53 GMT -6
This is an interesting observation and one I don't have sufficient experience to disagree with, but my limited experience is not letting me agree either. To me analog has a warmth and a pleasant lack of pristineness that digital doesn't have. Digital just seems too perfect, almost sterile and I don't think anyone ever could say that of analog. I guess this is, in part, my interest in an analog outboard piece of gear. I must ponder this further. if you think digital is sterile, then I don't think one or two pieces of outboard hardware are going to solve that. Probably need to understand more about what you are recording, your room, your recording rig, etc. What kind of sounds do you like? And what about digital do you find "sterile"? That can mean different things to everyone. I have many recordings that are all digital. I don't think they are sterile. Maybe a lot of other things wrong with them but I don't find them sterile because it's digital. That ship sailed years ago really. There are plenty of modern recordings that are all digital and sound great. So what are you expecting from outboard hardware? Distortion? Saturation? I mainly have my outboard for functionality, maybe a little bit of coloration (especially some of the preamp choices I have for drums and more). Sterile might have been a poor choice of word. If I think about a ProTools Carbon, I don't think its sterile, but it is insanely clean, uncolored. My initial feeling around that was probably "sterile" for lack of a wider experience around a lot of good gear. To me analog has a warmth and a pleasant lack of pristineness that digital doesn't have. Digital just seems too perfect, almost sterile and I don't think anyone ever could say that of analog. The terms warm vs. sterile are commonly used in discussions on analog vs. digital. But what do we really mean by that? I think it would be really good to define these attributes and understand what is really sonically happening when we experience these feelings, to be able to distinguish between preferred units and technologies. Dan is on spot with many arguments regarding distortion. As I see it the “warm” is made up of two things, EQ (usually a rolled off high end and low boost) and distortion (which acts as compression and thus usually at extremes contributes to the EQ’s effect). This does not equal analog nor tube nor a specific transistor. Many of these just happen to have one or more of these attributes in the physical nature depending of course on the circuit to what extent it is present. This doesn’t mean that you could not digitally achieve a similar result, which usually would be in a controlled context. What I believe is the magic (as I have figured it out in my head, no science here…) is the slight random and fluctuating outcome analog and especially tube equipment offers (we are talking very slightly here) that thru build ups, tracks interacting with each other creates a slight phase shifted, distorted soundscape, contributing to what we usually would call a 3D effect of sound. This is pleasant for the human ear. And I do believe this outcome is possible to achieve digitally likewise. As I have understood this randomness is coded into emulating plugs as well? Or I could be wrong. But all and all my point being. When we describe our preferences I think it’s important to try to understand what actually is happening there and not buy into the myth of commonly accepted facts of how a tube, analog or digital sounds. I have been so many times blown away by what lies behind a song, a track or a sound. I remember listening to an older song on Apple music through my system and as an experiment, I pulled out an original pressing on vinyl of that same song. I don't remember the song but I think it was something Hendrix. While I can't sit here and say the Apple music version was sterile, what I heard, probably more accurately "felt" from the vinyl through the exact same system was remarkable, and the A/D converters being used in this case were hardly amazing.
Post by doubledog on Aug 7, 2024 11:59:15 GMT -6
I think all you've really proven is that Apple Music (and most streaming platforms) have the ability to ruin good music.
Post by Darren Boling on Aug 7, 2024 12:09:04 GMT -6
LTL silver bullet: It’s a stereo pre, it has EQ built in, the mojo circuits can be driven hard enough reduce dynamics in a very musical way, almost like tape or a compressor, but obviously different. Everyone should have one! Agreed. And if you get the mk2, you can have a killer Locomotive Vari-Mu compressor or Buss compressor inside the mk2 as well. Or an LA76 soon.... And a 3rd vote for the Silver Bullet. Works great in tracking and mixing, has eq, compression, meters you can see from across the room, solid without being complicated AND is customizable with different modules. Would be my first piece if I were starting over.
