Post by Johnkenn on Jul 15, 2024 10:37:22 GMT -6
than SD3? I bought that Illbert pack and then started playing around with the main kits in EZ3 again...Maybe I'm crazy - but some of these just sound waaaay more ready to go than a lot of the SDX expansions. Maybe I just really really like Michael Illbert's take on things - I noticed the new presets in EZ3 are all him too. But even the house drums sound great.
Post by kcatthedog on Jul 15, 2024 14:50:16 GMT -6
I like ez3 and sold SD 3. SD3 seemed very expensive, and more so if you add libraries.
Post by wiz on Jul 15, 2024 16:38:24 GMT -6
I am using ezd3 exclusively now. I sold off all my sdx for sd3.
John do this……edit or play in a groove into ezd3…..do it with really shit timing and velocity levels.
Then highlight it all and use the humanise function……then under the timing menu select normal….pushed…and laid back …and see hear what it does to the levels and timing of the notes.
It’s pretty amazing.
I can play in a part using my e kit badly. Then in a few clicks sort out 99% of the level issues……and get the timing spot on…..then easily lay back the verses…and push the chorus…it’s pretty amazing.
the only thing that is an issue is no way to get the individual elements of the kit out…other than bouncing one at a time
Cheers
Post by Johnkenn on Jul 15, 2024 19:27:33 GMT -6
I am using ezd3 exclusively now. I sold off all my sdx for sd3. John do this……edit or play in a groove into ezd3…..do it with really shit timing and velocity levels. Then highlight it all and use the humanise function……then under the timing menu select normal….pushed…and laid back …and see hear what it does to the levels and timing of the notes. It’s pretty amazing. I can play in a part using my e kit badly. Then in a few clicks sort out 99% of the level issues……and get the timing spot on…..then easily lay back the verses…and push the chorus…it’s pretty amazing. the only thing that is an issue is no way to get the individual elements of the kit out…other than bouncing one at a time Cheers Wiz Damn
Post by bobeschism on Jul 16, 2024 1:41:43 GMT -6
EZD has multi outs. What DAW are you using and where are you having an issue?
Edit: Wait...Luna?
Post by wiz on Jul 16, 2024 1:58:56 GMT -6
Edit: Wait...Luna?
Yes luna
Post by kcatthedog on Jul 16, 2024 4:34:18 GMT -6
What if you export as audiofile(s), can you get selerate files for each drum element?
Post by wiz on Jul 16, 2024 5:17:20 GMT -6
What if you export as audiofile(s), can you get selerate files for each drum element? Stems I suppose I could do It in logic
Post by kcatthedog on Jul 16, 2024 5:56:42 GMT -6
There’s a drop down in ez for exporting file(S), can you solo in the mixer, the part you want like kick or snare and just export that, is it for more processing ?
Post by bluesholyman on Jul 16, 2024 8:19:43 GMT -6
Post by kcatthedog on Jul 16, 2024 8:22:58 GMT -6
Ha ha ! ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by kcatthedog on Jul 16, 2024 10:10:26 GMT -6
Post by kcatthedog on Jul 16, 2024 10:18:38 GMT -6
ps: in mixer, there is a mixer button, centre left, if you click on it, you have drop downs for output: stereo or multi.
So, as long as you set up the outs, you could have separate stems in your mix.
Post by bobeschism on Jul 16, 2024 11:38:43 GMT -6
Here's my EZD3 multi outs in Reaper:
I do most of my writing and editing just with the standard stereo out, then when it's time to mix, open a track template that I've created of any of my fave kits and can individually process each track without the laborious process of bouncing each track individually. Plus I can tweak individual kit pieces should I need to.
Post by Johnkenn on Jul 16, 2024 12:01:42 GMT -6
It's not EZ3, it's Luna. Luna doesn't have the multi capability yet I don't think.
Post by the other mark williams on Jul 16, 2024 12:02:50 GMT -6
Edit: Wait...Luna?
Yes luna Does Luna not support multi-out instruments?? I always hear about the lack of hardware inserts or an I/O plugin for outboard, but I've never heard about a lack of multi-out instruments. That would be nearly as big a problem to me (personally) as the lack of hardware inserts.
I love hearing how you're using EZD3, Wiz! Very cool stuff.
Post by bobeschism on Jul 16, 2024 12:31:40 GMT -6
It's not EZ3, it's Luna. Luna doesn't have the multi capability yet I don't think. That's right. When Wiz first mentioned he had to bounce the tracks individually I figured it was Luna. No multi-outs and lack of I/O for hardware makes it a hard no even out of curiosity. I can't get my head around how a DAW in 2024 doesn't have those features implemented.
Anyway, completely with you on Illbert. His Signature EZX packs are great.
Post by russellcreekps on Jul 16, 2024 19:21:02 GMT -6
So I think I’m sold on EZD3 just because of the new Singer Songwriter EZX expansion…sounds soooo good! Wondering, does anyone else have it installed on an external SSD, and if so, does it perform well? I don’t have enough room left on my main drive.
Post by Johnkenn on Jul 16, 2024 19:23:58 GMT -6
So I think I’m sold on EZD3 just because of the new Singer Songwriter EZX expansion…sounds soooo good! Wondering, does anyone else have it installed on an external SSD, and if so, does it perform well? I don’t have enough room left on my main drive. I have all my samples on an SSD. It should work better than a normal HD for sure.
Post by wiz on Jul 16, 2024 19:27:49 GMT -6
So I think I’m sold on EZD3 just because of the new Singer Songwriter EZX expansion…sounds soooo good! Wondering, does anyone else have it installed on an external SSD, and if so, does it perform well? I don’t have enough room left on my main drive. I have all my samples on an SSD. It should work better than a normal HD for sure. Me too... on a Samsung T5 I really like the singer songwriter ezx cheers Wiz
Post by the other mark williams on Jul 16, 2024 19:28:58 GMT -6
All of the samples in both SD3 and EZD3 are loaded into RAM when you pull up a kit. So the only advantage in putting them on an SSD vs a HDD is that they will load faster when you first pull it up (or open a session). Once a kit is loaded into RAM, it doesn’t matter what kind of drive they were stored on. They don’t stream from disk.
Post by russellcreekps on Jul 16, 2024 19:30:26 GMT -6
I have all my samples on an SSD. It should work better than a normal HD for sure. Me too... on a Samsung T5 I really like the singer songwriter ezx cheers Wiz Thank you both! Just to clarify though, these are external drives correct? I.e. I have an SSD in my Mac as well. My external SSD is connected via usb-c I think?
Post by russellcreekps on Jul 16, 2024 19:31:16 GMT -6
All of the samples in both SD3 and EZD3 are loaded into RAM when you pull up a kit. So the only advantage in putting them on an SSD vs a HDD is that they will load faster when you first pull it up (or open a session). Once a kit is loaded into RAM, it doesn’t matter what kind of drive they were stored on. They don’t stream from disk. Ah okay, didn’t know that…cool beans! Thx
Post by Johnkenn on Jul 16, 2024 19:55:26 GMT -6
All of the samples in both SD3 and EZD3 are loaded into RAM when you pull up a kit. So the only advantage in putting them on an SSD vs a HDD is that they will load faster when you first pull it up (or open a session). Once a kit is loaded into RAM, it doesn’t matter what kind of drive they were stored on. They don’t stream from disk. Ah…that’s true. I just saw my samples loading fast as hell and assumed.
Post by wiz on Jul 16, 2024 20:00:04 GMT -6
Me too... on a Samsung T5 I really like the singer songwriter ezx cheers Wiz Thank you both! Just to clarify though, these are external drives correct? I.e. I have an SSD in my Mac as well. My external SSD is connected via usb-c I think? yes external
