Post by Johnkenn on Jul 6, 2024 10:50:10 GMT -6
Anyone swear by these? It would be nice to have something that would allow the mic to sound the same regardless of where it is in the room…not that it’s a huge change or anything - it would just be nice to sit at the desk and sing occasionally without a bunch of reflections.
Post by Johnkenn on Jul 6, 2024 10:54:07 GMT -6
I should say - I don’t have any audible reflections or flutter - but I do think there are different resonances at different parts of the room…
So that’s my question really - will this cut down on resonances?
Post by Johnkenn on Jul 6, 2024 10:57:24 GMT -6
After reading a little bit…not sure they wouldn’t introduce more of a problem than they fix.
Post by andersmv on Jul 6, 2024 11:08:48 GMT -6
I’ve never done any scientific tests or anything remotely close, so all of this is just my subjective opinion based off of what I hear… Pretty much all of the vocal shields I’ve worked with have made vocals sound worse. Ya, you might get rid of a little bit of those room reflections, but the trade off is weird/phasey artifacts and at the worst end of the spectrum, a nasty and boxy tone.
I found this out early on when I was doing vocals in tiny bedrooms, I ended up just dumping the vocal shield completely becasue it sounded better without it when it came time to process the signal. I literally got better results using those cheap auralex foam panels to cover a section in a corner of a room and singing into the corner.
If you absolutely HAVE to have a small vocal shield and are against just slightly treating your room or using a larger panel, the smaller GIK VISO Booth is the only thing I’ve found that sounds good to me. I don’t know if it’s the absorptive material, the fact it’s a little bigger, the angle of the sides (more than likely a combination of all of those), but GIK figured out how to do one of those well. That would be my one and only recommendation.
If you want to actually have something that does the job right, and you’re a little flexible on suggestions, move up to one of the GIK PIB Portable Isolation Booths. They fold down and can be stored out of the way pretty easily if need be. I have two of them and cram them around a corner in my live room all the time, it makes as good a sounding vocal booth as any of the expensive rooms I’ve worked in.
Don’t bother with any of the other vocal shield things out there. It’s kind of the equivalent to taking a headache medication that just makes you shit your pants all the time. Did you really solve your problem?
Post by drumsound on Jul 6, 2024 11:35:31 GMT -6
I've tried a couple and even bought a cheap Primacoustic one from the pawn shop for like 35 bucks. I never like them with the mic right in them as they are 'designed.' I don't mind having it on a stand in front of the booth glass with the mic further back, but I think it's kinda placebo. I cut something recently and realied after the fact that I didn't have it in front of the glass, and the cardioid pattern was not having trouble doing its thing. ETA: I think BEHIND the singer is more important to think about then in front of them, more often. It’s kind of the equivalent to taking a headache medication that just makes you shit your pants all the time. Did you really solve your problem? This line is BRILLIANT!
mrcel0
Junior Member
Post by mrcel0 on Jul 6, 2024 11:40:56 GMT -6
Post by notneeson on Jul 6, 2024 11:57:48 GMT -6
Had a client get one out of desperation. Didn't help. Not exactly scientific.
Post by ericn on Jul 6, 2024 12:09:07 GMT -6
These things are so all about marketing rather than any real sonic benefit.
Post by Johnkenn on Jul 6, 2024 13:42:29 GMT -6
I’m on a “resonance” kick atm, so this I guess is more for cutting out flutter reflections. Apparently what I might need is a roof extension.
Post by thehightenor on Jul 6, 2024 14:00:48 GMT -6
I had an SE reflection thing ...
Messed with the pick-up pattern of the mic in a negative way.
Sold it. Experiment over.
Now I have a proper dedicated vocal booth/zone using a GIK portable isolation booth, sky trap and wall panels - works brilliantly.
Post by geoff738 on Jul 6, 2024 14:05:10 GMT -6
The alpaca thing that Audioscape are linked with looks interesting. Different approach. Much smaller. Never tried though.
But there’s alpacas!
Cheers, Geoff
Post by ericn on Jul 6, 2024 14:12:59 GMT -6
I’m on a “resonance” kick atm, so this I guess is more for cutting out flutter reflections. Apparently what I might need is a roof extension. I keep saying if people were Smart the other place would have been real estate slutz, it’s the room, it’s the room it’s always the room. Treatment only goes so far, nothing replaces actual space.
Post by Johnkenn on Jul 6, 2024 14:22:46 GMT -6
I should probably sing outside my room...
Post by geoff738 on Jul 6, 2024 14:27:22 GMT -6
What about a denoiser plug?
Cheers, Geoff
Post by ericn on Jul 6, 2024 14:50:04 GMT -6
I should probably sing outside my room... Try it but you’re probably going to find what ever room works best still could use treatment & of course there is the inconvenience to the family !
Post by thehightenor on Jul 6, 2024 15:04:59 GMT -6
I’m on a “resonance” kick atm, so this I guess is more for cutting out flutter reflections. Apparently what I might need is a roof extension. I keep saying if people were Smart the other place would have been real estate slutz, it’s the room, it’s the room it’s always the room. Treatment only goes so far, nothing replaces actual space. +1 When you go into a truly pro studio (with professionally designed purpose built recording spaces) - it's amazing how big the space can be to record vocals and how far back you can stand from the mic .... and it sounds fantastic with no room coloration and a very musical tonal balance to the vocal. It's been pointed out many times by Bob Olhsson too.
Post by chessparov on Jul 6, 2024 16:18:45 GMT -6
FWIW I did buy Mark Williams' PVB sold/designed by RealTraps (thanks again Mark! ) IMHO... It does help on either VO or Singing up to a bit more than "conversational level". Gonna come in real handy for my Children's Book, I'll be narrating. But to be fair at/near full volume... I would have to trudge off to a "real" Pro Studio. * Even my Buddy's nice Project Studio can't contain it! I realize that panels ala Gik etc, behind the Singer do typically help. Chris *"Great Room" is on my bucket list.
Post by christophert on Jul 6, 2024 16:38:10 GMT -6
I have one that I (rarely) use above outside bass drum mic when a drummer has loud cymbals.
Post by chessparov on Jul 6, 2024 17:43:02 GMT -6
I must slyly add that a M88 for John's vocals... Should solve a degree of acoustical issues right there. In fact I'll be on a M88, in around 3 Hours. At a local Art Gallery. (Voice seems to be finally back to normal/after my Operation mid April)
Post by drumsound on Jul 6, 2024 18:18:45 GMT -6
I’m on a “resonance” kick atm, so this I guess is more for cutting out flutter reflections. Apparently what I might need is a roof extension. Do you have a cloud? Maybe sing under it, an hang something behind you. FWIW I did buy Mark Williams' PVB sold/designed by RealTraps (thanks again Mark! ) IMHO... It does help on either VO or Singing up to a bit more than "conversational level". Gonna come in real handy for my Children's Book, I'll be narrating. But to be fair at/near full volume... I would have to trudge off to a "real" Pro Studio. * Even my Buddy's nice Project Studio can't contain it! I realize that panels ala Gik etc, behind the Singer do typically help. Chris *"Great Room" is on my bucket list. Simply hanging a packing blanket behind you (or any singer) can help quite a bit.
Post by russellcreekps on Jul 6, 2024 18:29:26 GMT -6
Anyone swear by these? It would be nice to have something that would allow the mic to sound the same regardless of where it is in the room…not that it’s a huge change or anything - it would just be nice to sit at the desk and sing occasionally without a bunch of reflections. I don’t have need for them anymore, but when I did, the only one I thought sounded great was the Aston Halo. Had the eyeball and Se reflection filter pro before that…the Halo was the only one I felt sounded natural and didn’t seem to impart anything negative (that I noticed anyway).
Post by ab101 on Jul 6, 2024 19:08:03 GMT -6
I have this one and sometimes it really helps. realtraps.com/p_pvb.htm (The one that goes on a stand.) I think this might be the one Chris is referring to but I could be wrong.
Post by geoff738 on Jul 6, 2024 19:14:36 GMT -6
Alpaca
Just Fyi. No affiliation, never used it so can’t give an opinion. I just kinda like alpacas. But not that way. Cheers, Geoff
Post by chessparov on Jul 6, 2024 19:35:07 GMT -6
I have this one and sometimes it really helps. realtraps.com/p_pvb.htm (The one that goes on a stand.) I think this might be the one Chris is referring to but I could be wrong. [br Yep. Same one. I have some Claustrophobia so... Only use blankets on Cover tunes. Chris P.S. Tony's right but-somehow-couldn't resist.
Post by ml on Jul 6, 2024 19:44:49 GMT -6
Never used one, but I have seen pics of A-listers using them:
