Post by Johnkenn on Jul 4, 2024 11:02:22 GMT -6
Post by geoff738 on Jul 4, 2024 11:06:16 GMT -6
Whats it do?
Cheers, Geoff
Post by bgrotto on Jul 4, 2024 11:10:22 GMT -6
*Deres, from WA
Post by Johnkenn on Jul 4, 2024 13:43:06 GMT -6
This has made my mixes better. Yes - it can be done with EQ…but this makes it so easy. I’ll use a couple on OHs, Acoustics, vocals…really cool. Yet another plug that educated me on problems I wasn’t identifying myself. Now I feel like I can here a track and immediately “hear” there’s resonances that are masking the sound
It also makes me wonder if ALL THESE YEARS - maybe I’ve been blaming what were room resonances on the mics I’ve used. Yeah - some are more predisposed than others…
Post by geoff738 on Jul 4, 2024 13:53:32 GMT -6
So its kinda like Soothe, but much more affordable?
Cheers, Geoff
Post by copperx on Jul 4, 2024 16:33:27 GMT -6
So its kinda like Soothe, but much more affordable? Cheers, Geoff I highly doubt they use the same algorithm.
Post by bossanova on Jul 4, 2024 21:36:24 GMT -6
John, you've successfully sold me the last two WA plugins. You should get a commission and TDR should compensate the lot of y'all for talking up Arbiter 😆
Post by Johnkenn on Jul 5, 2024 6:26:52 GMT -6
John, you've successfully sold me the last two WA plugins. You should get a commission and TDR should compensate the lot of y'all for talking up Arbiter 😆 Yeah. Unfortunately, I do not get any commission.
Post by bossanova on Jul 5, 2024 7:47:45 GMT -6
So its kinda like Soothe, but much more affordable? Cheers, Geoff I highly doubt they use the same algorithm. The whole thing is manual. The main benefits are workflow and resource usage plus an exciter and compensation control to make up for what's been taken out.
Post by copperx on Jul 5, 2024 8:29:32 GMT -6
I highly doubt they use the same algorithm. The whole thing is manual. The main benefits are workflow and resource usage plus an exciter and compensation control to make up for what's been taken out. I tried last night and it was more effective and sounded much better than Soothe on a problematic track. Also, less fiddly than using a regular EQ.
Post by geoff738 on Jul 5, 2024 11:19:31 GMT -6
Does this do anything Arbiter doesn’t?
Cheers, Geoff
Post by indiehouse on Jul 5, 2024 20:11:47 GMT -6
This has made my mixes better. Yes - it can be done with EQ…but this makes it so easy. I’ll use a couple on OHs, Acoustics, vocals…really cool. Yet another plug that educated me on problems I wasn’t identifying myself. Now I feel like I can here a track and immediately “hear” there’s resonances that are masking the sound It also makes me wonder if ALL THESE YEARS - maybe I’ve been blaming what were room resonances on the mics I’ve used. Yeah - some are more predisposed than others… Is this different/better than Vocal Shaper?
Post by Johnkenn on Jul 5, 2024 20:55:04 GMT -6
Yes. This is a sweep that helps identify resonances…you can do it with EQ, but this makes it really simple.
Post by indiehouse on Jul 6, 2024 4:31:11 GMT -6
Yes. This is a sweep that helps identify resonances…you can do it with EQ, but this makes it really simple. Thanks, might grab it! The reason I asked was because you seemed to think Vocal Shaper works a better, realgearonline.com/thread/17180/wa-production-vocal-shaper?page=1, but I’m not sure. Just wondering if it’s worth owning both?
Post by Johnkenn on Jul 6, 2024 7:32:01 GMT -6
Yes. This is a sweep that helps identify resonances…you can do it with EQ, but this makes it really simple. Thanks, might grab it! The reason I asked was because you seemed to think Vocal Shaper works a better, realgearonline.com/thread/17180/wa-production-vocal-shaper?page=1, but I’m not sure. Just wondering if it’s worth owning both? Because they do two different things really and I didn’t know the difference at the time. Deres is to get rid of the resonant frequency problems above 1khz. Vocal Shaper can “demud” resonant frequency below like 500hz. Deres obviously only does one resonance at a time - which I think stops me from overdoing things. Like with MTM Reso - I start hearing that “effected” sound like I do with too much Soothe. Just sounds computery. But 2-3 well placed Deres and it seems to really improve the sound.
Post by geoff738 on Jul 6, 2024 14:33:45 GMT -6
Well, for the price of aa pint I will probably pick this up. Although I am trying not to do what I did from Black Friday on with my plugin splurge that saw me buying multiple copies of similar plugs just because they were on sale. Do I need 439 vari-mu plugs? Do I need multiple resonance suppressors etc. We shall see how this goes seeing as everything seems to go on sale every couple of months now.
Cheers, Geoff
Post by ragan on Jul 7, 2024 2:22:11 GMT -6
I watched a couple of videos on this and I can’t figure out how it’s different from just using, say, Pro-Q3 to sweep for resonances. Except with DeRes you’re limited to one band?
Or, people have already noted you can just do it with EQ, but that DeRes is easier. I’m wondering how?
Post by ragan on Jul 7, 2024 2:23:58 GMT -6
Post by copperx on Jul 7, 2024 2:57:14 GMT -6
I watched a couple of videos on this and I can’t figure out how it’s different from just using, say, Pro-Q3 to sweep for resonances. Except with DeRes you’re limited to one band? Or, people have already noted you can just do it with EQ, but that DeRes is easier. I’m wondering how? Yes, it's nothing more than EQ. The "listen" feature is just a +24 dB bell boost with narrow bandwidth. Then, to suppress the resonance it becomes a cut. "Compensate" changes the shape of the bell slightly, and "excite" adds a pultec-like high shelf. The "octave" feature creates two more cuts in the next two octaves relative to the cut.
Post by Johnkenn on Jul 7, 2024 8:43:27 GMT -6
I watched a couple of videos on this and I can’t figure out how it’s different from just using, say, Pro-Q3 to sweep for resonances. Except with DeRes you’re limited to one band? Or, people have already noted you can just do it with EQ, but that DeRes is easier. I’m wondering how? Just easier imo.
Post by Johnkenn on Jul 7, 2024 10:21:14 GMT -6
Like he said…just makes it easier.
Post by geoff738 on Jul 7, 2024 10:57:15 GMT -6
Easier is good.
Cheers, Geoff
Post by Martin John Butler on Jul 7, 2024 12:00:27 GMT -6
I can do this with Logic's EQ. Maybe it's a pinch easier, but Sooth is a dynamic plug-in which is a different story because that is more like a real time multi-band compressor.
Post by Johnkenn on Jul 8, 2024 9:36:02 GMT -6
I can do this with Logic's EQ. Maybe it's a pinch easier, but Sooth is a dynamic plug-in which is a different story because that is more like a real time multi-band compressor. Anyone can do this with any eq. The point is that this does it quicker and more easily with less steps.
Post by geoff738 on Jul 8, 2024 15:49:42 GMT -6
Well went and ordered this via plugin boutique as I was probably at least as interested in the eq matching freebie.
Cheers, Geoff
