Post by mcirish on May 8, 2024 8:52:56 GMT -6
Warm in general is kind of a mixed bag, isn't it? I do have a WA412 and I swapped out the opamps. It's pretty great on snare and kick now. Their mics have been sort of hit or miss though. The thing that I question is that they are making clones, yet knowingly skimp on details that made the originals what they are. They scream "pro-sumer" to me and if your client really wants a U67, I'd rather spent the money on a BU67 from Ben (which I did). I've got four ribbons so far and I'm not sure this clone of a 44 is going to persuade me to buy another.
Post by bluesholyman on May 8, 2024 10:10:34 GMT -6
I was looking for a less expensive alternative to a C414 and listened to a comparison of the 414 to a WA14 anc the C214 - neither sounded as good. Warm Audio is not something I consider as a good alternative to the "real thing." Maybe its fine, but they don't seem to be close to the originals - obvious sonic differences - which baffles me. But maybe its the same plan AKG has with the C214, 314 vs 414 - but again, they don't sound the same - seems to be different diaphragms even in AKGs from the torch bearer.
Post by andersmv on May 8, 2024 10:21:22 GMT -6
I would be careful comparing this with their other mics, those circuits on the condensers and tube mic are a lot more complicated with more variables. A lot less things to consider with the 44 design specifically, I don't want to turn this into comparisons with all the other warm gear threads. I'm struggling to find anything (aside from the ribbon thickness) they really skimped or cut corners on with this one. They could have easily tried to hit the $500-$600 price point and done this cheaper, it doesn't look like Warm did that. Here's what I wrote on the purple site:
I've got a couple of thoughts after reading through here. Someone please correct me if I'm wrong, but doesn't AEA use neodymium magnets as well in their 44 series (might use them in all their mics)? I was pretty sure they did, but looking at their website and the manuals for the 44 series, I don't see anything confirming that. I think I'm right, so the Warm is using a similar magnet to the top clone of this design.
As far as price, I'm seeing a lot of comparisons to the AEA R84 and the Coles. The R84 is like $1200 new and the Coles 4038 are getting close to $1500 at this point. I think the Coles is priced too far out of the range to be a fair comparison, the R84 is definitely a contender (and I see they've lowered the price to almost $1000 today on the R84 . Smart move). There's definitely a lot of similarities between the 44 series and the R84, so sonically I think that's fair game for some comparisons. The Coles sounds nothing like a 44 type mic though, so I really don't see any point comparing them. Different enough to warrant having both and just liking one more than the other.
The Cloud 44 is another good consideration, but I don't think they make the passive one anymore, so you're stuck with the Active version that's $1500 now (which is the one you want anyway, it's great). I got to work with a pair of the Cloud 44's for years and although I like them a lot for certain things (best drum room mic I've found), I didn't like them as much on acoustic instruments and preferred the AEA's. That's definitely my opinion, but objectively I'll just say that it doesn't sound like the AEA R44 or any of the vintage 44's I've used. I would classify it as it's own sound. Not a bad thing by any means, but it's definitely not a 44 clone in my experience.
I don't have as much experience with the Stagers, they've all knocked my socks off in my limited uses. Again though, I havn't heard anything from them that made me think they can do the 44 thing. All original designs doing their own thing, and their larger ribbon models are $1500 and up (which takes them out of the "fair comparison" category in my opinion).
There really isn't any magical, unobtanium thing as far as doing a 44 clone. I think all the other mics that Warm clones are a much more complicated can of worms, but in this specific instance and design, I think there's potential to pull this off well. You need big honking magnets, a large ribbon and a good transformer. The body of the mic is icing on the cake, as the acoustics of the housing and cage definitely come into play. The one thing I'm seeing is the thicker ribbon material they're using, and I would bet that was an intentional decision. Less likely to get damaged in shipping, less likely to get damaged by the people buying it and less returns. This is probably going to be a lot of people's first ribbon purchase, you don't have to baby these things but you do have to be careful. I baby my gear and I've had to re-ribbon my AEA R88 twice in the last 10 years. The first time, I'm really not sure what happened. One side was just responding differently, the ribbon came loose a bit somehow. The second time, my dog saw a squirrel outside, freaked out and managed to knock it over on the Latch Lake stand. Leave it to that fur ball to have enough stupid to pull that off .
As I already said, it's easy enough to send one of these in to be re-ribboned. Pitman Microphones (formerly ENAK) charges $185 to do a re-ribbon, so if you're concerned about the thicker ribbon stock from Warm, that's an easy solution. I would be curious to see what Warm is tensioning these at from the factory, I know AEA does theirs pretty low. At some point, it would be great to have a pair of the WA-44's and send one off to be re-ribboned and hear the difference.
They got the ribbon size right at least, magnets look like they're right, the transformer is right, they can do it at $1k because they're making a lot at once and they're not hand made like the AEA's, it make sense. In this specific instance, I really doubt they've cut any corners. There just isn't much to these old RCA ribbon mics, it looks like Warm understood the assignment, did their homework and have probably made a really good mic. I'm looking forward to trying them at some point.
Post by chessparov on May 8, 2024 10:30:38 GMT -6
Sontronics Sigma 2 is another very cool Vintage-ish vocal mic. IMHO between an AEA 44 and 4038 in tone. Cloud 44a on "Flat" was best on my Tenor. Switched "bright" better on Baritone. I love switches! (Like my BU67 and U195) Ketchup with you guys on this Thread. Before bed. Chris
Post by EmRR on May 8, 2024 10:55:38 GMT -6
Someone well in the know mentioned that 44’s and 77’s don’t sound great positioned fully horizontal (typical OH), they always leave them at some angle for better results. Probably more to cut down on direct reflections from the ceiling since it's a figure 8 mic (especially if you have low ceilings). Nope. These folk have engineered at plenty of nice places for 50 years. It's the effect on the ribbon at that angle. I'd like to see the Warm next to an RCA, see how accurate it really is. I approve of the black/silver versus the turkey shit brown (cough, Umber) of the later RCA. Need to lose the Phillips head screws in favor of slotted types. Didn't use no freakin' Phillips head in the USA back then. Horrors if they're metric.....
Post by chessparov on May 8, 2024 12:24:17 GMT -6
US Yanks have a foot fetish.
Post by notneeson on May 8, 2024 15:00:32 GMT -6
Probably more to cut down on direct reflections from the ceiling since it's a figure 8 mic (especially if you have low ceilings). Nope. These folk have engineered at plenty of nice places for 50 years. It's the effect on the ribbon at that angle. I'd like to see the Warm next to an RCA, see how accurate it really is. I approve of the black/silver versus the turkey shit brown (cough, Umber) of the later RCA. Need to lose the Phillips head screws in favor of slotted types. Didn't use no freakin' Phillips head in the USA back then. Horrors if they're metric..... Tilting that mic would tend to reduce the thunderous low end response?
Post by hadaja on May 8, 2024 15:15:43 GMT -6
My Stager Sr1A is a massive mic. That thing has even more low end the RCA44bx which I didnt think possible. It sounds closer to the RCA then the Cloud 44a. If you get the opportunity to try out that particular stager model you should really try it.
Post by Ward on May 8, 2024 16:01:35 GMT -6
Anyone have any news on a Warm 4038 yet? Seems an inevitability
Post by EmRR on May 8, 2024 17:19:21 GMT -6
I punched vocals done with a 44-B....with a Fathead II (stock).....couldn't tell....YMMV.....hahahahahahaha
Post by paulcheeba on May 8, 2024 18:54:37 GMT -6
Warm are awful. Totally the new Behringer. Seeing all the repairs on instagram and Facebook is so funny.
Post by chessparov on May 8, 2024 19:25:40 GMT -6
Anyone have ant news on a Warm 4038 yet? Seems an inevitability If Plush ever approved... "It's the end of the world as we know it" (But I feel fine ) But it might sound great. To an ant. Chris
Post by chessparov on May 8, 2024 19:27:49 GMT -6
I punched vocals done with a 44-B....with a Fathead II (stock).....couldn't tell....YMMV.....hahahahahahaha I'll give TWO Fathead's for ONE 44 then.
Post by EmRR on May 9, 2024 11:55:57 GMT -6
Ya know what’s most likely to suffer over time? The quality of the chrome. Anyone here have any cheap chinese mic chrome that still looks clean? Unlikely.
Post by the other mark williams on May 9, 2024 11:58:59 GMT -6
Ya know what’s most likely to suffer over time? The quality of the chrome. Anyone here have any cheap chinese mic chrome that still looks clean? Unlikely. My Cascade Vin-Jet still looks clean. But...it's stored in its case like all the time and only brought out rarely, so not really fair.
Post by EmRR on May 9, 2024 12:37:36 GMT -6
Ya know what’s most likely to suffer over time? The quality of the chrome. Anyone here have any cheap chinese mic chrome that still looks clean? Unlikely. My Cascade Vin-Jet still looks clean. But...it's stored in its case like all the time and only brought out rarely, so not really fair. A first in my experience! Pretty much everything I have like that showed permanent effects from skin contaminants within 6 months. Or de-plating after a few years, from poor QC during plating. A too-common Chinese ribbon problem is de-plating around the magnet structure, which then blocks the ribbon path.
Post by jacobamerritt on May 9, 2024 13:28:19 GMT -6
My Cascade Vin-Jet still looks clean. But...it's stored in its case like all the time and only brought out rarely, so not really fair. A first in my experience! Pretty much everything I have like that showed permanent effects from skin contaminants within 6 months. Or de-plating after a few years, from poor QC during plating. A too-common Chinese ribbon problem is de-plating around the magnet structure, which then blocks the ribbon path. My Cascade Vin-Jet still looked brand new 15 years later... I did make sure to polish with microfiber every few months. Maybe they had good QC on materials or something
Post by ulriggribbons on May 9, 2024 13:50:51 GMT -6
A too-common Chinese ribbon problem is de-plating around the magnet structure, which then blocks the ribbon path. I have a stack of replacement magnets here for that very problem!
Post by hadaja on May 9, 2024 16:01:54 GMT -6
Ya know what’s most likely to suffer over time? The quality of the chrome. Anyone here have any cheap chinese mic chrome that still looks clean? Unlikely. I can see it now - grab my Warm Audio WA-44 hardly used with natural PATINA or Grab my Warm Audio Wa-44 which has been relic'ed ! But i wont be able to help myself and I will end getting a WA44 just to see what its like as i just love ribbon mics. But bear in mind I will make some adjustments to it.
Post by drbill on May 10, 2024 22:21:26 GMT -6
Post by chessparov on May 10, 2024 22:32:32 GMT -6
I'm still waiting for the keychain USB Ribbon mic... From Neumann.
Post by kcatthedog on May 12, 2024 13:16:56 GMT -6
Post by chessparov on May 12, 2024 14:27:42 GMT -6
Thanks for the post. But IMHO... Mic sounds a bit "too Modern" tonally, to be mistaken for a "real" 44. Minus the HUGE low end for one thing/maybe they Processed it out? Chris
Post by kcatthedog on May 12, 2024 14:53:54 GMT -6
No dog in this race: just posting clips!
Post by chessparov on May 12, 2024 15:48:16 GMT -6
I'm probably the fussiest on 44 Styles. It was my "First Love"! Also I try to factor in the "size" of the Room". IMHO to have the AEA or OG 44 shine at it's best... Best to get an exceptional sounding/large Room. More pragmatic for me if/when I get a 44 Style... With the Cloud Active. It sounded very well suited for Medium to Small Rooms. Chris
