Post by Johnkenn on Mar 10, 2024 18:54:00 GMT -6
So John, you’re running the current subscription PT Studio? I’m still rocking pre-subscription 11: but I might get in on the long-overdue upgrade/update if what you say is true, that delay comp on insert is actually functioning. *like you, I believe, I was getting the mindboggling EARLY return when manually inputting delay comp times, leading me to either print and nudge, or abandon inserts: just going to hardware, summing, and printing the two track return. Thanks for keeping us apprised of how this is going. Still seems scandalous that it’s so challenging. Cheers- P I mentioned to Drew at UA that I thought it had been fixed…but he claimed they’ve never officially supported it and sometimes it works sometimes not. That actually sounds more likely to me, so that’s why I’ve kept futzing about with Carbon to see if I could find workarounds or whatever. Don’t remember if this is the thread I’ve kindve documented my experiences…but I’ve finally gotten the Carbon optical to send to my Trinnov, and then I can send digital out of the Trinnov to the Burl - and that works. But I WANT to be able to go out to the Trinnov then back in to the CARBON. But when I do that, I hear nothing but the original signal from the carbon prior to going out of the digital out. I want to MONITOR the digital IN. How in the hell you do that?
Post by ragan on Mar 20, 2024 22:04:15 GMT -6
I've continued having HW insert delay compensation work in PT. I almost can't believe it. It's just working. I don't have any delay values in the I/O settings. Been doing parallel drums, vocals, no phase issues, works across buffer settings...it's aligned.
Post by Johnkenn on Mar 20, 2024 22:50:09 GMT -6
I've continued having HW insert delay compensation work in PT. I almost can't believe it. It's just working. I don't have any delay values in the I/O settings. Been doing parallel drums, vocals, no phase issues, works across buffer settings...it's aligned. Same with me. I’m not sure I’ll ever update lol. When I first tried to set this up last month or whatever, it took me about thirty minutes to figure out it was already working…I just assumed there was zero chance of it, so I did the whole record the click thing and zooming and counting the samples…but alas, there were no samples to count! And that shit nulled.
Post by ragan on Mar 20, 2024 22:52:59 GMT -6
Yeah I used to calculate and enter it, but you'd have to have different values for different sample rates and buffers, and it didn't seem to always be phase coherent.
Post by drbill on Mar 21, 2024 9:17:29 GMT -6
Did you guys get this miracle with the latest update?
Post by ragan on Mar 21, 2024 9:27:58 GMT -6
It was some prior but very recent update. I think ~two updates ago.
Post by Johnkenn on Mar 21, 2024 12:18:05 GMT -6
I'm having issues with a piece of HW and I don't know whether it's the HW or screwy PT IO. It's a stereo comp and it's weird - one channel is compressing and the other sounds broken...but occasionally, it will just work. I assumed it was a broken comp. But when I deleted and redid all my bus I/O just to try and confirm nothing was screwy - it started working. Today I get in with the same song, back to not working. I deleted the IO and started over. Still has the problem. So I'm back to thinking it's an intermittent problem with the compressor and not the IO. But that tells you how much I trust PT. I need to open up another DAW and confirm I'm getting the same issues.
Post by drbill on Mar 21, 2024 12:50:18 GMT -6
I'm having issues with a piece of HW and I don't know whether it's the HW or screwy PT IO. It's a stereo comp and it's weird - one channel is compressing and the other sounds broken...but occasionally, it will just work. I assumed it was a broken comp. But when I deleted and redid all my bus I/O just to try and confirm nothing was screwy - it started working. Today I get in with the same song, back to not working. I deleted the IO and started over. Still has the problem. So I'm back to thinking it's an intermittent problem with the compressor and not the IO. But that tells you how much I trust PT. I need to open up another DAW and confirm I'm getting the same issues. Swap L and R in's and out's. You'll know instantly if it's the comp or a routing / wiring issue.
Post by Johnkenn on Mar 21, 2024 13:23:38 GMT -6
I'm having issues with a piece of HW and I don't know whether it's the HW or screwy PT IO. It's a stereo comp and it's weird - one channel is compressing and the other sounds broken...but occasionally, it will just work. I assumed it was a broken comp. But when I deleted and redid all my bus I/O just to try and confirm nothing was screwy - it started working. Today I get in with the same song, back to not working. I deleted the IO and started over. Still has the problem. So I'm back to thinking it's an intermittent problem with the compressor and not the IO. But that tells you how much I trust PT. I need to open up another DAW and confirm I'm getting the same issues. Swap L and R in's and out's. You'll know instantly if it's the comp or a routing / wiring issue. Well, there's a patchbay involved...but I've literally checked and confirmed connections at least 6 times. Tried it in another DAW...same thing. switched the Left IN to the Right IN and the issue is happening to both signals only on the right side. So, I do think it's the HW.
Post by basspro on Mar 21, 2024 14:01:06 GMT -6
Wow, this is huge news for me! I've avoided hardware inserts with PT and Apollo for years due to the hassle. But if it's legitimately working, I'm ready to jump in! I've added lots of outboard in the last year or so, so it would amazing to have the opportunity to use it all on mixes.
