Compressor
Aug 23, 2023 17:03:28 GMT -6
via mobile
Post by ericn on Aug 23, 2023 17:03:28 GMT -6
Yeah my mistake and ouch! They were like $75 a pair !
Post by Deleted on Aug 23, 2023 17:07:00 GMT -6
In the recording I've done, I just don't find that lowering levels enough to not get overs has raised the noise floor enough to be a problem. Other analog elements like mic noise, preamp noise, etc. far overshadow the noise levels of 24 bit. I guess YMMV comes into play Who cares about noise floor? It's the direct sensitivity of the mic vs. volume that matters. Some mic's just sound amazing at higher SPL's and that's the absolute requisite of nuance & detail for a specific setup. Do you think these tap coils and 1176 FET's were just for fun? No, they were made to balance. God knows how many songs leveraged this to sort this issue out.
In a WOS type song with a less than ideal singer that you bury into a mix you might might not notice, in a decent mix it's the life or death of a track. I'm probably better than your average singer because I know how to pull away at loud bits off axis and use proximity to purpose but that doesn't mean I can't clip the shit out of a converter even set to -20dB. Here's the thing, if you have a half decent set of lungs chances are your volume can spike like nothing. Great for opera but not so much in a studio.. The only way to even balance that is to practice in a studio but even then there's no gurantee's. So, compressor obviously..
The idea that 24 bit etc. matters is a mixer thing, not a musicianship thing. 0dB is 0dB and breaching it causes distortion.. There's nothing more to it..
Post by drbill on Aug 23, 2023 17:17:49 GMT -6
Evidently Dan cares. I was addressing his thoughts on this when I asked him about problems with noise floor if he lowered his levels and he said : "Yes especially with stuff besides the mic and pre in the signal path or anything pushed for a sound to typical converters. I still gate and sometimes expand things." My experience is that I've never had a problem with noise floor that my mic / mic pre / compressor / EQ didn't create. It's never been lack of resolution or headroom of the conversion. (I suppose I shouldn't say "never", but at this point, I can't remember a time, so.....let's call it very rarely.) Clipping at -20? No worries. Then set your levels to -30. I mean come on, we've got a theoretical -144dB of noise floor. 10dB isn't going to matter at that point. And by all means, compress for the sound of it all. I do. We all do. I just don't see how we can blame lack of limiters for clipping our A/D. But that's my take. Honestly, if digital PPM's were designed to show full dynamic range, we'd all be recording in the top segment of the LED array. Instantly, we'd drop levels down. It's as much visual as anything. That and the hangover from analog tape. That's my $0.02.
Post by Deleted on Aug 23, 2023 18:21:37 GMT -6
Well, I do hope you're loving this convo as much as me.. Parroting IME doesn't lead to a learning exprience and debate is the necessity of learning, so.. I don't think you would have quoted me if you weren't at least curious. Y'know I respect and love ya in a platonic sort of way Bill so forgive my bluntness if it comes across that way.. I literally said a lot of mics repsond better at higher volume inputs, the sensitivity to pick up nuance etc. is critical. So lowering the preamp gain is going to achieve what exactly? In many cases even the preamp itself works better at higher volumes, don't get me wrong most clean's (generally IC) are aligned to line level at -18dB but transformer wound and tube? Hmm.. They were meant to be driven and you need a catch at the other end. That's literally the point of them, crank, flavour ohh yeah..
With stuff like the Shelford, SSL 4K I had etc. this was never an issue. For example the B series contained everything you needed to control even the most dynamic of singers etc., are you recording direct to interface or something? I've done it and was never happy with the results.
Post by Deleted on Aug 23, 2023 18:27:02 GMT -6
Evidently Dan cares. I was addressing his thoughts on this when I asked him about problems with noise floor if he lowered his levels and he said : "Yes especially with stuff besides the mic and pre in the signal path or anything pushed for a sound to typical converters. I still gate and sometimes expand things." My experience is that I've never had a problem with noise floor that my mic / mic pre / compressor / EQ didn't create. It's never been lack of resolution or headroom of the conversion. (I suppose I shouldn't say "never", but at this point, I can't remember a time, so.....let's call it very rarely.) Clipping at -20? No worries. Then set your levels to -30. I mean come on, we've got a theoretical -144dB of noise floor. 10dB isn't going to matter at that point. And by all means, compress for the sound of it all. I do. We all do. I just don't see how we can blame lack of limiters for clipping our A/D. But that's my take. Honestly, if digital PPM's were designed to show full dynamic range, we'd all be recording in the top segment of the LED array. Instantly, we'd drop levels down. It's as much visual as anything. That and the hangover from analog tape. That's my $0.02. -144 db is the thermal noise of a resistor at 1 khz at room temperature. Raise the frequency or temperature and it goes up. All of you cool sounding but hot running class a gear will have higher noise. Your recording path will have quite a bit of thermal noise starting from the mic itself. FET and diode compressors tend to have major noise issues. Now even good stereo converters tend to have real world noise specs beneath the fudged manufacturers' specs. Your average multichannel converter will be worse. You still want to hit it fairly hot to avoid audible noise later on. Snares, proximity effect, clean guitars, and singers can be very loud and a lot of gear sounds best hit hot. Something to avoid clipping with sharp transients like the Apogee Soft Limit is very useful.
Post by Deleted on Aug 23, 2023 18:29:16 GMT -6
very loud and a lot of gear sounds best hit hot. Nods hard.. Probably cause, y'know they were designed that way..
Post by Ward on Aug 23, 2023 19:09:33 GMT -6
In the recording I've done, I just don't find that lowering levels enough to not get overs has raised the noise floor enough to be a problem. Other analog elements like mic noise, preamp noise, etc. far overshadow the noise levels of 24 bit. I guess YMMV comes into play I've worked with some really dynamic musicians and singers who can surprise anyone with their ability to soundcheck at -32db and then belt out notes over zero! One can't always be prepared . . . Lord knows we try!
Post by drbill on Aug 23, 2023 19:53:21 GMT -6
In the recording I've done, I just don't find that lowering levels enough to not get overs has raised the noise floor enough to be a problem. Other analog elements like mic noise, preamp noise, etc. far overshadow the noise levels of 24 bit. I guess YMMV comes into play I've worked with some really dynamic musicians and singers who can surprise anyone with their ability to soundcheck at -32db and then belt out notes over zero! One can't always be prepared . . . Lord knows we try! One word..... -40dB.
Post by drbill on Aug 23, 2023 19:58:59 GMT -6
I don't disagree with you. I think we are having a mis-communication. PLEASE - drive your mic and preamp as hard as you like. If they have the headroom you will be happy. If not, you may get saturation you either like - or don't like. But in any of those circumstances, there were these things on consoles called faders. They were for lowering (or raising, but in this convo - lowering) the levels "to tape". Or in this case to our A/D. If your pre doesn't have an output trim, or if you don't like the sound if you turn it down, put something after it that can attenuate signal. Problem solved. I used to have to do that all the time with 512B's on drum overs. I was CONSTANTLY clipping the converters. I used an A Designs ATTY I believe to pull things down so that I NEVER - or at least very rarely - got overs. We've got the room far below the realm of hearing here. I'm a proponent of using it. I see no reason to clip signals either via hardware, a limiter, or in the A/D unless doing it for CREATIVE reason.
Post by drbill on Aug 23, 2023 20:06:25 GMT -6
Evidently Dan cares. I was addressing his thoughts on this when I asked him about problems with noise floor if he lowered his levels and he said : "Yes especially with stuff besides the mic and pre in the signal path or anything pushed for a sound to typical converters. I still gate and sometimes expand things." My experience is that I've never had a problem with noise floor that my mic / mic pre / compressor / EQ didn't create. It's never been lack of resolution or headroom of the conversion. (I suppose I shouldn't say "never", but at this point, I can't remember a time, so.....let's call it very rarely.) Clipping at -20? No worries. Then set your levels to -30. I mean come on, we've got a theoretical -144dB of noise floor. 10dB isn't going to matter at that point. And by all means, compress for the sound of it all. I do. We all do. I just don't see how we can blame lack of limiters for clipping our A/D. But that's my take. Honestly, if digital PPM's were designed to show full dynamic range, we'd all be recording in the top segment of the LED array. Instantly, we'd drop levels down. It's as much visual as anything. That and the hangover from analog tape. That's my $0.02. -144 db is the thermal noise of a resistor at 1 khz at room temperature. Raise the frequency or temperature and it goes up. All of you cool sounding but hot running class a gear will have higher noise. Your recording path will have quite a bit of thermal noise starting from the mic itself. FET and diode compressors tend to have major noise issues. Now even good stereo converters tend to have real world noise specs beneath the fudged manufacturers' specs. Your average multichannel converter will be worse. You still want to hit it fairly hot to avoid audible noise later on. Snares, proximity effect, clean guitars, and singers can be very loud and a lot of gear sounds best hit hot. Something to avoid clipping with sharp transients like the Apogee Soft Limit is very useful. I dunno. I just live in the real world. I grew up on tape, then tape and Dolby SR. Noise was a way of life. It was just a part of the sound. Most Tape sims hilariously have the option to add noise back in. LOL Today, even the worse converters run at 16bit "hot" as you describe have a noise floor far below that of the best tape machines running SR. I just never find noise floor an "issue" in digital real life that isn't created out in FRONT of the conversion itself by a piece or more likely multiple pieces of analog gear. Aren't most good mics at least 50dB below conversion noise levels. Then, add a mic preamp to that.... PS - so....what was this thread about again - oh yeah... Matt - FET all the way.
Post by Deleted on Aug 24, 2023 8:03:41 GMT -6
I don't disagree with you. I think we are having a mis-communication. PLEASE - drive your mic and preamp as hard as you like. If they have the headroom you will be happy. If not, you may get saturation you either like - or don't like. But in any of those circumstances, there were these things on consoles called faders. They were for lowering (or raising, but in this convo - lowering) the levels "to tape". Or in this case to our A/D. If your pre doesn't have an output trim, or if you don't like the sound if you turn it down, put something after it that can attenuate signal. Problem solved. I used to have to do that all the time with 512B's on drum overs. I was CONSTANTLY clipping the converters. I used an A Designs ATTY I believe to pull things down so that I NEVER - or at least very rarely - got overs. We've got the room far below the realm of hearing here. I'm a proponent of using it. I see no reason to clip signals either via hardware, a limiter, or in the A/D unless doing it for CREATIVE reason. I could have saved a few posts by simply stating there isn't really a wrong way to do it. I've found that singers react better to compression (although you could use a comp in the cue) and I use compressors as attenuators because most of them have an output pot. The issue with recording so low is the singer has to hear themselves and the background music in can's, I've struggled with some interfaces.. A dedicated high volume headphone amp would fix that but then we go upwards in price.
Ultimately I have no issues tracking with compression, there's benefits to me and I've yet to find a valid reason to change that. Sorry Matt for de-railing.. Umm yeah, I'd go FET as well.
Post by matt@IAA on Aug 24, 2023 8:36:50 GMT -6
No worries, seems like DBC is the clear winner 😁
Post by ericn on Aug 24, 2023 9:35:54 GMT -6
In the recording I've done, I just don't find that lowering levels enough to not get overs has raised the noise floor enough to be a problem. Other analog elements like mic noise, preamp noise, etc. far overshadow the noise levels of 24 bit. I guess YMMV comes into play I've worked with some really dynamic musicians and singers who can surprise anyone with their ability to soundcheck at -32db and then belt out notes over zero! One can't always be prepared . . . Lord knows we try! Yeah, but politicians are even worse, over the years I have done a ton of congressional debates, both FOH & live feeds in the truck there is always a guy who whispers during sound check and screams during broadcast. Once again Aphex Dominators made me look so good. In fact it was those limiters that got from FOH to the truck! I’m not disagreeing with Bill per say, in the studio if you have the time and are working with professionals, yeah you shouldn’t need limiters, but if you live in the world where you time is a luxury and talent level is a crapshoot linters even those on a Behringer Composer are a great house keeping tool.
Post by drbill on Aug 24, 2023 9:59:48 GMT -6
I'd just like to re-articulate that I am most decidedly NOT anti-compressors - or even limiters. I love em, buy tons of em, and use em all the time. My posts were in reference to the comments that you NEED a limiter in the circuit so that you don't overdrive your converters. And this is just not true. I prefer to track with a compressor on vocals too if possible. And there are certain circumstances like ericn mentions where they are critical as anything can happen. God knows I've been caught off guard more times than I can count, and that's one of the reasons I love consoles - you've got a fader at your fingertips. But I think in general what I see is that the vast majority of engineers cut too hot. And then end up invariably clipping their converters. As I mentioned, I think this is due a lot in part to how the LED arrays are laid out. Anyway, it's all good, and whatever gets you there gets you there. There are of course a lot of guys who believe in clipping their converters to get more level too - so there's that. And yeah matt @iaa - FET!!!!!
Post by ericn on Aug 24, 2023 10:16:32 GMT -6
I'd just like to re-articulate that my posts were in reference to the comments that you NEED a limiter in the circuit so that you don't overdrive your converters. And this is just not true. I prefer to track with a compressor on vocals too if possible. And there are certain circumstances like ericn mentions where they are critical as anything can happen. God knows I've been caught off guard more times than I can count, and that's one of the reasons I love consoles - you've got a fader at your fingertips. But I think in general what I see is that the vast majority of engineers cut too hot. And then end up invariably clipping their converters. As I mentioned, I think this is due a lot in part to how the LED arrays are laid out. Anyway, it's all good, and whatever gets you there gets you there. There are of course a lot of guys who believe in clipping their converters to get more level too - so there's that. And yeah matt@IAA - FET!!!!! Bill, you kind of inadvertently brought up a really good point and one that can be a total PITA if you’re tracking live with a mixture of pre’s. It’s not just about keeping an eye on those meter’s and “clip” lights, it’s about knowing them. I first learned this lesson at the other end, mixed racks of Amps, Crown’s idea of -3 dB before clip is different from Crest QSC and BGW! The same applies to pre’s and when you just have a “Clip” led you need to know what it means -3? -2? It’s really clipping? One of the most important lessons I learned live was to always take the time to just start soloing everything individually when you can to find the issue before it becomes a problem. Of course you also know at times I pick on you because in most cases you are right , about how you work, but the world of the internet takes it as gospel. I hate it when I’m sitting in the bar and Someone say’s “ but DRBill ( or Thrill or Ward …) said…” and they don’t realize their situation is completely different!
Post by drbill on Aug 24, 2023 11:12:09 GMT -6
ericn - what do you mean by "most cases"?? And come on, nobody has ever mentioned me at a bar.... PS - at this point, I think we have completely obliterated Matt's thread. LOL FET!!!!
Compressor
Aug 24, 2023 11:23:21 GMT -6
via mobile
Post by ericn on Aug 24, 2023 11:23:21 GMT -6
ericn - what do you mean by "most cases"?? And come on, nobody has ever mentioned me at a bar.... You would be surprised my friend, while I realize my place as a small market celebrity you JK, Ward amongst others have achieved a certain level of audio internet legends. The problem is your average fan who has found success with much of what you preach has never ever realized all methodologies should be taken with the unstated qualifiers of “ for me” and with “ my rig”. As someone who finds their niche more and more as general problem solver I do love you guys but damn if most of these guys understood rule #3 of audio is what works great in my situation may be the absolutely worst choice for you. Life would be so much easier.
Post by matt@IAA on Aug 24, 2023 11:30:47 GMT -6
This thread isn’t ruined it’s awesome 👏
Post by svart on Aug 24, 2023 12:24:30 GMT -6
very loud and a lot of gear sounds best hit hot. Nods hard.. Probably cause, y'know they were designed that way.. More like the small amounts of saturation that happen before full-on distortion. Human ears LOVE small amounts of distortion.
Post by svart on Aug 24, 2023 12:28:35 GMT -6
I've built a handful of 1176 compressors and have messed around with their guts a lot. I also built a pair of 2254/33609 from scratch and learned a whole lot about why I won't do that again..
Honestly I like both. They have their places.
I think the FET based compressors are just easier to build and tune. The diode bridge was somewhat finnicky about calibration. Could have just been Neve's implementation and my mods and changes to make it build-able though.
Post by Deleted on Aug 24, 2023 12:41:14 GMT -6
-144 db is the thermal noise of a resistor at 1 khz at room temperature. Raise the frequency or temperature and it goes up. All of you cool sounding but hot running class a gear will have higher noise. Your recording path will have quite a bit of thermal noise starting from the mic itself. FET and diode compressors tend to have major noise issues. Now even good stereo converters tend to have real world noise specs beneath the fudged manufacturers' specs. Your average multichannel converter will be worse. You still want to hit it fairly hot to avoid audible noise later on. Snares, proximity effect, clean guitars, and singers can be very loud and a lot of gear sounds best hit hot. Something to avoid clipping with sharp transients like the Apogee Soft Limit is very useful. I dunno. I just live in the real world. I grew up on tape, then tape and Dolby SR. Noise was a way of life. It was just a part of the sound. Most Tape sims hilariously have the option to add noise back in. LOL Today, even the worse converters run at 16bit "hot" as you describe have a noise floor far below that of the best tape machines running SR. I just never find noise floor an "issue" in digital real life that isn't created out in FRONT of the conversion itself by a piece or more likely multiple pieces of analog gear. Aren't most good mics at least 50dB below conversion noise levels. Then, add a mic preamp to that.... PS - so....what was this thread about again - oh yeah... Matt - FET all the way. Bill, I love noise but prefer to keep it down to not sound like Led Zeppelin II and III. The tape hiss adds to flavor in tape sims and real decks but being audible during quiet passages can be a pita. Let’s say real world good converters are like -90 something db noise flows at 0 to +4 dbu. Average, lower than that. And not ideal measurements. Real world use cases. A diode clipper type limiter is insurance against weird shit and can also take some peaks off if you want. Mastering guys use clipping all the time because it’s not modulation, sharp transients are close to noise, and harmonics of close to noise are also close to noise. What do you think is in a brick wall limiter? Something other than a clipper? Those Apogee and Prism converters are ass savers. Then for the noise shit If you gainstage a wildly dynamic vocal conservatively to not clip, often you will often have to compress it 3 times: smack, limit, and level. The noise floor of the initial converter and analog gear will come into the picture here even if you use digital compressors with absurdly low 64-bit noise floors lower than the physical world if the initial gainstaging was very conservative or used some piece of shit multichannel converter loaded up. Try to maximize the level by getting it done going in and And most of your cool sounding JFET and diode bridge compressors are going to add noise. Modern ones maybe -80 something db noise floors and makeup amplifiers will add more after its been turned down. not to factory spec or vintage design diode stuff will add a lot more. Optos a little cleaner and stuff with tubes often a little noisier than fets. VCAs makeup by adjusting the dc voltage of the gain reduction so lower noise. They can have modern fet like noise at unity gain for the discrete ones, to ones equal to good converters at line level, to levels beneath most converters for the smart c2. Then for what I do, those vocal and drum busses are being smashed down further with something to have them be audible against noisy high gain guitars. The ones with two detectors for one vca or level dependent time constants for both attack and release (say certain VCA/digital/pwm compressors and faster optos hit just right) can save on noise and distortion, prevent a noise build up across gear and tracks, and you can maximize level right away going in!
Post by Deleted on Aug 24, 2023 12:54:25 GMT -6
I'd just like to re-articulate that I am most decidedly NOT anti-compressors - or even limiters. I love em, buy tons of em, and use em all the time. My posts were in reference to the comments that you NEED a limiter in the circuit so that you don't overdrive your converters. And this is just not true. I prefer to track with a compressor on vocals too if possible. And there are certain circumstances like ericn mentions where they are critical as anything can happen. God knows I've been caught off guard more times than I can count, and that's one of the reasons I love consoles - you've got a fader at your fingertips. But I think in general what I see is that the vast majority of engineers cut too hot. And then end up invariably clipping their converters. As I mentioned, I think this is due a lot in part to how the LED arrays are laid out. Anyway, it's all good, and whatever gets you there gets you there. There are of course a lot of guys who believe in clipping their converters to get more level too - so there's that. And yeah matt @iaa - FET!!!!! Bill, there’s more need for peak control than ever and there’s less peak control than ever in popular music.
Post by Ward on Aug 24, 2023 15:25:03 GMT -6
I've worked with some really dynamic musicians and singers who can surprise anyone with their ability to soundcheck at -32db and then belt out notes over zero! One can't always be prepared . . . Lord knows we try! One word..... -40dB. LMAO!!
Post by Ward on Aug 24, 2023 15:28:00 GMT -6
Post by Ward on Aug 24, 2023 15:36:15 GMT -6
SNIP I realize my place as a small market celebrity you JK, Ward amongst others have achieved a certain level of audio internet legends SNIP Legends, are we now? HAHA!! I've been called worse. We're definitely overly passionate about this extremely difficult profession. I guess we're legendary in our inanity.
