Post by category5 on Jul 22, 2014 7:13:15 GMT -6
For those of you building this project just wanted to let up guys know that not only are Chunger and Matador's PSUs coming along handily but they also have U47 shock mounts about to get on the boat with some other components. Could be 6 weeks before they get here, but I promise they'll be way cheaper than what's avaiable now.
Post by kcatthedog on Jul 27, 2014 21:26:27 GMT -6
that's the way you do it, u47s for nuthin and your chicks for free ! my thiersch cap shows up tomorrow ! Attachment Deleted
MK-U47
Jul 27, 2014 21:48:53 GMT -6
Post by Johnkenn on Jul 27, 2014 21:48:53 GMT -6
Damn...
MK-U47
Jul 27, 2014 22:52:34 GMT -6
Post by tonycamphd on Jul 27, 2014 22:52:34 GMT -6
nice kcatthedog ! max has a bunch more in stock again, though it pains me, i'm gonna let this batch pass, i've spent way to much $ this month...
MK-U47
Jul 28, 2014 7:29:59 GMT -6
via mobile
Post by category5 on Jul 28, 2014 7:29:59 GMT -6
nice kcatthedog ! max has a bunch more in stock again, though it pains me, i'm gonna let this batch pass, i've spent way to much $ this month... This second batch might be it for a while you know. Awesome job Kcat. I don't think the RODE classic will be missed.
MK-U47
Jul 28, 2014 8:10:21 GMT -6
Post by Martin John Butler on Jul 28, 2014 8:10:21 GMT -6
SInce I can't afford any part of this build, I'll sit back and enjoy the show. I can't wait to hear how these sound. That looks fantastic kcat.
Post by kcatthedog on Jul 29, 2014 18:30:46 GMT -6
MK-U47
Jul 30, 2014 8:17:54 GMT -6
Post by Martin John Butler on Jul 30, 2014 8:17:54 GMT -6
What transformer is in it, I've forgotten.
MK-U47
Jul 30, 2014 8:46:24 GMT -6
Post by kidvybes on Jul 30, 2014 8:46:24 GMT -6
What transformer is in it, I've forgotten. ...Max's ioaudio BV8 custom tranny: "Full size, full stack Bv.08 transformer wound to original specs including 4 seperated chambers per bobbin." Attachments:
MK-U47
Jul 30, 2014 9:31:00 GMT -6
Post by tonycamphd on Jul 30, 2014 9:31:00 GMT -6
i have one of his early BV8 tranny's, i believe he used the NOS laminate material from neumann for them.?.?..
MK-U47
Jul 30, 2014 9:57:06 GMT -6
via mobile
Post by ericn on Jul 30, 2014 9:57:06 GMT -6
i have one of his early BV8 tranny's, i believe he used the NOS laminate material from neumann for them.?.?.. I do believe that was for the first run.
MK-U47
Jul 30, 2014 10:38:06 GMT -6
Post by Martin John Butler on Jul 30, 2014 10:38:06 GMT -6
Cool.
Anyone know how it sounds when compared to Oliver Archut's BV8 design?
MK-U47
Jul 30, 2014 18:03:56 GMT -6
Post by kidvybes on Jul 30, 2014 18:03:56 GMT -6
Cool. Anyone know how it sounds when compared to Oliver Archut's BV8 design? ...yeah, well that's kinda a loaded question, particularly when you consider AMI offers more than a few variations (BV8R, BV8N, BV8LP, T47, new "Classic Series" BV8, etc)...all variations on a theme (comments I hear often refer to the larger versions delivering more low end response)...no losers in the bunch, I would expect... ...IMHO, they are all very good options, limited only by personal preference...
MK-U47
Jul 30, 2014 19:11:54 GMT -6
Post by kcatthedog on Jul 30, 2014 19:11:54 GMT -6
"feels good, like I knew that it would !!" I had to use Max's plastic bolt for the cap mount cut off about 1 ct and used one spacer, took top off to insert bolt and to tighten it btw if you get thiersch cap , they have the back marked on them and wiring is simple front to front, side to side and back to back now where is that diy psu ?? Attachment DeletedAttachment DeletedAttachment DeletedAttachment Deleted
MK-U47
Jul 30, 2014 20:12:02 GMT -6
Post by tonycamphd on Jul 30, 2014 20:12:02 GMT -6
"feels good, like I knew that it would !!" I had to use Max's plastic bolt for the cap mount cut off about 1 ct and used one spacer, took top off to insert bolt and to tighten it btw if you get thiersch cap , they have the back marked on them and wiring is simple front to front, side to side and back to back now where is that diy psu ?? where is the front/back marking on the blueline? also, i have a psu here, send it to me, and i'll make sure that badboy works nice!!
Post by kcatthedog on Jul 30, 2014 20:22:38 GMT -6
Its on the outside edge in black hand written script by Herr Thiersch. So, easy to see before install or remove cap from mount ! or send your psu here so I can develop a deeper personal appreciation for your diy skills !
Post by tonycamphd on Jul 30, 2014 20:41:07 GMT -6
well played sir 8)
Post by kcatthedog on Aug 12, 2014 16:55:40 GMT -6
if u r sittin on the fence about this ?
get ready to jump !!
there are about 14 kits left but now MAX has some Thiersch Blue caps as well, so you can order the complete kit (no cable and psu) from Max directly for 1199 euros
it is difficult to get the caps independently
ok I done my good deed !
MK-U47
Aug 12, 2014 17:17:51 GMT -6
Post by tonycamphd on Aug 12, 2014 17:17:51 GMT -6
if u r sittin on the fence about this ? get ready to jump !! there are about 14 kits left but now MAX has some Thiersch Blue caps as well, so you can order the complete kit (no cable and psu) from Max directly for 1199 euros it is difficult to get the caps independently ok I done my good deed ! can you link to the offering of the capsule?
Post by kcatthedog on Aug 12, 2014 17:47:47 GMT -6
Post by winetree on Aug 12, 2014 20:29:58 GMT -6
Here's some of my 47 builds, except the center one. Can't seem to post a picture so here's a link. 47s Reply 1270
MK-U47
Aug 12, 2014 21:11:39 GMT -6
Post by mulmany on Aug 12, 2014 21:11:39 GMT -6
That is a lot of 47's!
Post by kidvybes on Aug 12, 2014 21:52:09 GMT -6
Here's some of my 47 builds, except the center one. ...showoff!...geez, you even numbered them, in case someone couldn't count? BTW, is that big-badge old-timer your's too?...(how do the MK-47s compare?) Attachments:
Post by winetree on Aug 12, 2014 23:50:47 GMT -6
The numbers were there to match the mics to the power supplies during the builds. I just badged all the mics and the numbers are gone. I know it's frowned on, with Neumann N.O.S. purple badges.
Yes, I bought it in 1980. Serial number 3X, could be the lowest number in existence. The plastic nut that holds the binder connector in the orginal power supply broke, so I removed the connector. Looking for another one (Neumann doesn't have one). When I get it together I'll do a comparsion.
MK-U47
Aug 13, 2014 8:07:54 GMT -6
Post by Martin John Butler on Aug 13, 2014 8:07:54 GMT -6
That's amazing kidvybes. I wish I was nearby so I could have a listen to those mics !
