Post by niklas1073 on Mar 28, 2023 10:32:45 GMT -6
Hello, I am a long time follower of this forum and finally got myself registered and reaching out for some support. Thanks for all the support so far by just ending up here very often finding answers. The thing is that I have replaced some gear in my vocal chain over the past year so there are some variables that might make it difficult for me to easily track the issue. I have started to get weird random distortions in my vocal chain. I have two separate chains before it hits my UAD 4-710 where I do the conversion before my apollo. The two chains are BAE1073-IGS LA ONE compressor, and the other one is another BAE1073-WES B76 compressor. The same noise occurs with both chains. The only thing the BAE’s share is the power supply. I have been using Telefunken cu29 tube mic, sounds great other wise, got it second hand, and havn’t had it for a long time, but since I got some other of the gear also replaced lately its hard for me to say did the problems come with the mic. But I have been tracking with another mic today shortly and did not find the the noises. I will keep tracking with that one to see if they stay away, as the problem is very random. could the problem be related to the cu29 or the tube? Does the sound sound familiar to anyone? I’ll attach a file here. Distorted vocal.mp3 (61.29 KB) cheers, niklas
Post by phdamage on Mar 28, 2023 11:03:54 GMT -6
Is there another mic you can try? I would just try swapping things out one at a time until the issue goes away. Sorry to be captain obvious
Post by tkaitkai on Mar 28, 2023 11:16:54 GMT -6
When you say distortion, are you referring to that weird artifact that happens right before the word “days,” or are you talking about the tone in general being kind of fuzzy/gritty/overdriven?
Hard to draw any conclusions from such a short clip, but I dealt with a similar issue a few years ago and it was a really frustrating experience getting it sorted out.
I would recommend process of elimination. To start, take as many variables out of the equation as possible. Go straight from the CU-29 to your Apollo, no Unison pres or FX enabled. Just the clean, stock mic pre with the gain set really low. If you still hear it, try the pad on your Apollo, or use an inline XLR pad.
Barring that, try a different mic, preferably something new so you know the condition isn’t a confounding variable. If the issue goes away, you know it’s something with the Tele/Apollo. Could be a tube going out, dirty capsule, or a bad component or connection somewhere in the mic circuit or PSU. It’s also worth a shot to swap tubes and try different mic cables (including the 7-pin tube mic cable) — inexpensive and doesn’t involve sending the mic off for repair.
On the other hand, if you go straight to the Apollo mic pre and DON’T hear it, you’ll have to insert your other gear in the chain piece by piece. Start with the 710, since it happens with both of your analog chains. If you reintroduce the 710 and the issue comes back, you know that’s the culprit. Try all four of the 710 preamps at low gain. Put one of your BAEs in the chain and try all four line inputs. If it happens with all inputs, it might be something wacky with the digital connection or clocking between your 710 and Apollo. Make sure you’re setting the 710 as the master clock in Console. Not sure which Apollo you’re using, but try different cables for the digital connection (whether that’s ADAT or AES/EBU). Try different BNC cables if applicable. And of course, try different cables for the line level connections, too.
If reintroducing the 710 doesn’t bring it back, then it’s probably something with your BAEs or compressors. Since it happens with both chains, I doubt it would be a failing component, but since both BAEs are fed off the same PSU, that might be the problem. It could also be a grounding issue or interference. Hard to say. I’m not too well-versed on troubleshooting that kind of stuff. In that scenario, maybe try running the BAEs off a UPS or maybe see if you can get a separate BAE PSU to test.
Now, going back to the first step, if you try a different mic direct into your Apollo, you might actually get the same issue. This happened to me. In my case, the solution ended up being astonishingly simple — it turns out the A/D on the Apollo MKI just sounds grungy and distorted to me, and the other converter I had at the time (Lynx Aurora MKI) wasn’t much better. Getting a Lavry completely solved it for me. No guarantees that this will be the case for you, but if none of the above fixes your problem, it might be worth testing a separate A/D to see if it goes away.
Super long post, but I know how painful it was to deal with this, and I would never want anyone else to go through that.
Post by niklas1073 on Mar 28, 2023 15:29:57 GMT -6
Super thanks for the replies. I am swapping the mic first to a fet47 style and tracking with that some for a while to see if that repeats it. As it is very random it might take some time to reproduce it. I will for sure try the copperhead straight to the apollo. I use an apollo twin x. I actually might have another psu i can get hold of I can troubleshoot with in case it would be the bae psu.
I sent clips to telefunken too to hear their opinion, and they could not put the finger on it, they could hear the issue and said it could be the tube but more likely maybe the capsule. So I will try to dry that also in case it would have got moist.
I use the 4-710 pretty much as a centre where my 2 bae and two api’s take the remaining 4 channels. I have not heard this fuzzy distortion on any other tracks except the vocals lately. But then again, it might just blend in with instruments in a way it goes unnoticed.
I will continue the hunting with the advice you guys came with and get back when i get some results.
Post by tkaitkai on Mar 28, 2023 19:40:38 GMT -6
I will for sure try the copperhead straight to the apollo. I use an apollo twin x. Here’s an older thread from the UAD forums on the same issue: uadforum.com/community/index.php?threads/apollo-twin-mkii-distortion-issue-with-example.40451Hilariously, you can see some of my old posts back when I bought my Aurora in 2020 and THOUGHT I fixed the problem… only to come back a few months later basically admitting it was wishful thinking. The OP in that thread eventually upgraded to a rackmount Apollo X and still had the same problem. If you search around, there are numerous other threads about vocal distortion issues with the Twin. I’m not saying this is definitely the culprit in your situation, but it’s worth considering.
Post by niklas1073 on Mar 29, 2023 0:53:59 GMT -6
Ok, sounds interesting, I will definitely look into that. Too bad i dont have another interfaces lying around at the time, but surely I can borrow from somewhere if that seems to be the last unchecked box in the end. I am now on my way to the studio and will do a thorough systematic go thru.
Post by niklas1073 on Mar 29, 2023 3:07:51 GMT -6
UPDATE! Ok, so looks kinda good in the sense that I'd say that the expensive gear is ruled out . I plugged straight into apollo and was eventually able to reproduce the fuzzy distortion with both the copperhead and eventually with the AT4047, though the AT was maybe slightly more subtle but non the less, audible. The link to the UADforum was actually great as it kind of felt very similar though I didn't find any sound samples to compare with, the descriptions was darn close to what I feel. I will try reset of the unit and see if that makes any difference. Then there is ofcourse on thing that's been also circulating in my mind since it seems easies to reproduce with the word "down" in the vocal line ive noticed I have the easiest to reproduce the issue. Is it in my voice??? but it doesnt sound like anything ive heard before in that context. I dont have a vocal session coming up shortly that i could try to find out if its only me... and I am kind of trying to trace this down before the next session
Post by niklas1073 on Mar 29, 2023 3:58:58 GMT -6
UPDATE nr2! I did the quick hardware reset on the apollo twin x. Now I have tried a few lines and cannot seem to reproduce the same noise.. though I can still hear some vaque grittiness somewhere alse, it could be my voice or the sound of the twin, not a disturbing kind of thing, something i have probably not even noticed before I started to inspect the sound under magnifying glass due to the distortion. I will hook everything back up and start tracking normally and see how it goes. should show eventually if this was it or was I just lucky to get a few takes without the issue now.
And a super thanks to you tkaitkai, without your input I would still be hunting.. at least now I think I know where to dig in first if it comes back.
Post by niklas1073 on Mar 29, 2023 7:23:41 GMT -6
.... and sorry to say, it didn't solve it. seems less though than before, but still getting the distortion. I am positive though that it has to be in the apollo as all other options are pretty much ruled out. I've opened a ticket with UA so lets see what response there will be.
Post by svart on Mar 29, 2023 7:55:28 GMT -6
Hello, I am a long time follower of this forum and finally got myself registered and reaching out for some support. Thanks for all the support so far by just ending up here very often finding answers. The thing is that I have replaced some gear in my vocal chain over the past year so there are some variables that might make it difficult for me to easily track the issue. I have started to get weird random distortions in my vocal chain. I have two separate chains before it hits my UAD 4-710 where I do the conversion before my apollo. The two chains are BAE1073-IGS LA ONE compressor, and the other one is another BAE1073-WES B76 compressor. The same noise occurs with both chains. The only thing the BAE’s share is the power supply. I have been using Telefunken cu29 tube mic, sounds great other wise, got it second hand, and havn’t had it for a long time, but since I got some other of the gear also replaced lately its hard for me to say did the problems come with the mic. But I have been tracking with another mic today shortly and did not find the the noises. I will keep tracking with that one to see if they stay away, as the problem is very random. could the problem be related to the cu29 or the tube? Does the sound sound familiar to anyone? I’ll attach a file here. View Attachmentcheers, niklas To tell the truth, I don't hear anything wrong with that clip. Perhaps give us a longer clip and point out the exact issue?
Post by niklas1073 on Mar 29, 2023 9:33:01 GMT -6
Yeah maybe it takes a few clips to realize the distortion, and when you hear its really obvious. Its during the word “days”. Might take a set of headphones to properly hear it. I have now taken the unit back for warranty service (well the warranty is exceeded by 4 days, so lets se what they respond).
Post by svart on Mar 29, 2023 9:38:49 GMT -6
Yeah maybe it takes a few clips to realize the distortion, and when you hear its really obvious. Its during the word “days”. Might take a set of headphones to properly hear it. I have now taken the unit back for warranty service (well the warranty is exceeded by 4 days, so lets se what they respond). I've listened to it on repeat a couple dozen times on headphones and I don't hear any distortion at all. "Days" sounds normal.
Post by christopher on Mar 29, 2023 10:22:57 GMT -6
I think maybe you have a little James Hetfield in your vocal style. If you don’t, then jitter can cause a same Hetfield-ing.. or what I refer to as jitter anyway-not sure it’s the technical term. Sometimes digital stuff can sort of lose time for a few samples and jump around trying to speed up/slow down to lock with the daw again. I’ve had that a lot with older computers and budget 1394 or USB ports. Usually though it’s accompanied with a squeaky glitch.. sometimes I have had issues where clocking sort of ‘varispeeds around’ for a second or two, causing me to go back and wonder if I heard it or not. Reaper will do this sometimes -since I have it set to try to play even with too many plugins, where other DAWs just won’t let you play at all. Is this maybe what you hear?
Post by Ward on Mar 29, 2023 10:29:28 GMT -6
Hello, I am a long time follower of this forum and finally got myself registered and reaching out for some support. Thanks for all the support so far by just ending up here very often finding answers. The thing is that I have replaced some gear in my vocal chain over the past year so there are some variables that might make it difficult for me to easily track the issue. I have started to get weird random distortions in my vocal chain. I have two separate chains before it hits my UAD 4-710 where I do the conversion before my apollo. The two chains are BAE1073-IGS LA ONE compressor, and the other one is another BAE1073-WES B76 compressor. The same noise occurs with both chains. The only thing the BAE’s share is the power supply. I have been using Telefunken cu29 tube mic, sounds great other wise, got it second hand, and havn’t had it for a long time, but since I got some other of the gear also replaced lately its hard for me to say did the problems come with the mic. But I have been tracking with another mic today shortly and did not find the the noises. I will keep tracking with that one to see if they stay away, as the problem is very random. could the problem be related to the cu29 or the tube? Does the sound sound familiar to anyone? I’ll attach a file here. View Attachmentcheers, niklas I also a CU29 and love it! the Copperhead is very different depending on tube in it, but then so is a U67. Try out different tubes.
Post by tkaitkai on Mar 29, 2023 12:56:09 GMT -6
I definitely hear a little blip right at the beginning of "days" in that clip. I'm probably overly sensitive to this kind of thing because I almost lost my mind trying to troubleshoot it for 4 - 5 years.
Obviously, this clip alone isn't enough to make any definitive statements — it could very well be a mouth noise or the singer shuffling around or something. But if it's happening consistently and it's repeatable as OP states, that suggests it might be something else.
I don't want to immediately jump the gun and point fingers like, "It's the Apollo!!!!!!!!!" But I used to get subtle, artifact-y junk like this ALL the time when I was on my Aurora MKI + Apollo Twin setup. It's a shame, because this definitely doesn't happen to every Apollo user. And to be fair, there's still the chance it's a bad mic cable or interference or something.
OP, if you are able to, I would see if you can try out a high end converter, just for peace of mind. I would recommend something like a Prism Lyra, Apogee Symphony, Lynx Hilo, or maybe an Antelope Orion. If that doesn't fix it, you can return it and continue troubleshooting.
Post by svart on Mar 29, 2023 13:15:06 GMT -6
I definitely hear a little blip right at the beginning of "days" in that clip. I'm probably overly sensitive to this kind of thing because I almost lost my mind trying to troubleshoot it for 4 - 5 years. Obviously, this clip alone isn't enough to make any definitive statements — it could very well be a mouth noise or the singer shuffling around or something. But if it's happening consistently and it's repeatable as OP states, that suggests it might be something else. I don't want to immediately jump the gun and point fingers like, "It's the Apollo!!!!!!!!!" But I used to get subtle, artifact-y junk like this ALL the time when I was on my Aurora MKI + Apollo Twin setup. It's a shame, because this definitely doesn't happen to every Apollo user. And to be fair, there's still the chance it's a bad mic cable or interference or something. OP, if you are able to, I would see if you can try out a high end converter, just for peace of mind. I would recommend something like a Prism Lyra, Apogee Symphony, Lynx Hilo, or maybe an Antelope Orion. If that doesn't fix it, you can return it and continue troubleshooting. Are we talking about the warble on "days"? that's not distortion. That's just a singing issue.
Post by niklas1073 on Mar 29, 2023 13:32:40 GMT -6
I definitely hear a little blip right at the beginning of "days" in that clip. I'm probably overly sensitive to this kind of thing because I almost lost my mind trying to troubleshoot it for 4 - 5 years. Obviously, this clip alone isn't enough to make any definitive statements — it could very well be a mouth noise or the singer shuffling around or something. But if it's happening consistently and it's repeatable as OP states, that suggests it might be something else. I don't want to immediately jump the gun and point fingers like, "It's the Apollo!!!!!!!!!" But I used to get subtle, artifact-y junk like this ALL the time when I was on my Aurora MKI + Apollo Twin setup. It's a shame, because this definitely doesn't happen to every Apollo user. And to be fair, there's still the chance it's a bad mic cable or interference or something. OP, if you are able to, I would see if you can try out a high end converter, just for peace of mind. I would recommend something like a Prism Lyra, Apogee Symphony, Lynx Hilo, or maybe an Antelope Orion. If that doesn't fix it, you can return it and continue troubleshooting. I agree. I have a bunch of clips where Ive been able to replicate the sound, and though i for some time was convinced it was my voice, i came to the conclusion in the end it wasnt, since i got more samples to listen to. Sadly I do not have easy access to any of those converters. But my chain goes as following: mic, bae1073, either la2a or 1176, ua 4-710 which I also use as the converter and then to the apollo thru adat. The noise was present in all setup variations including mics straight into apollo as a stand alone unit. So I cannot figure where else the issue could be than inbthe apollo. At that stage all possible cable issues etc. are also bypassed.
Post by tkaitkai on Mar 29, 2023 14:04:35 GMT -6
Are we talking about the warble on "days"? that's not distortion. That's just a singing issue. No, there’s a very subtle noise/artifact that happens right at the beginning of “days,” just after the first consonant. It’s extremely subtle, and easy to miss for sure. It’s hard to describe but I definitely hear it.
Post by christopher on Mar 29, 2023 14:11:31 GMT -6
If it’s not the vocal pitch warble, I can sort of hear a subtle grind or scratch. Sounds like something like a beard rubbing on a mic grill or clothing touching the mic stand? It’s not noticeable at all but if that’s happening all the time in everything I could see it being frustrating. ADAT can be jittery and sometimes can produce those weird warbles.. just keep that in mind - sometimes it’s not always performance
Post by svart on Mar 29, 2023 14:19:10 GMT -6
Are we talking about the warble on "days"? that's not distortion. That's just a singing issue. No, there’s a very subtle noise/artifact that happens right at the beginning of “days,” just after the first consonant. It’s extremely subtle, and easy to miss for sure. It’s hard to describe but I definitely hear it. Well, ok, after listening to it about a hundred more times, I hear a little click type sound. It was very hard to notice because I was listening for *distortion*, not an artifact of some type. It doesn't sound at all like distortion to me. It sounds more like the tube ringing or capsule vibrating.
Post by niklas1073 on Mar 29, 2023 23:14:58 GMT -6
No, there’s a very subtle noise/artifact that happens right at the beginning of “days,” just after the first consonant. It’s extremely subtle, and easy to miss for sure. It’s hard to describe but I definitely hear it. Well, ok, after listening to it about a hundred more times, I hear a little click type sound. It was very hard to notice because I was listening for *distortion*, not an artifact of some type. It doesn't sound at all like distortion to me. It sounds more like the tube ringing or capsule vibrating. Yeah, the tube and capsule were one of the first suspects on the list, but they got ruled out in the end.
Post by niklas1073 on Mar 29, 2023 23:28:17 GMT -6
Since my apollo is now at checkup for a few weeks I was playing with an idea what do you guys think?
I have been meaning to upgrade to a rack version of apollo, x6 or 8. Mostly for the hw inserts. I am tracking thru hw pres and comps nowadays and I have hw vari mu comp in the mixbus. But my mixing is done otherwise itb and will remain that way. I also have an octo sat to run uad plugins. I have almost exclusively moved to uad plugins. All and all I like and feel comfy with the uad ecosystem. But for the interface I was thinking about maybe getting a motu ultralite mk5 for it’s I/O options and using the apollo for mixing at home and tracking on the run. Would it make a difference using the motu in my setup since I dont track thru unison and I convert in my 4-710d? Its 1/4 of the price of an apollo x6 and im not sure if the x6 will make a difference in this case?
Post by tkaitkai on Mar 30, 2023 8:01:11 GMT -6
Since my apollo is now at checkup for a few weeks I was playing with an idea what do you guys think? I have been meaning to upgrade to a rack version of apollo, x6 or 8. Mostly for the hw inserts. I am tracking thru hw pres and comps nowadays and I have hw vari mu comp in the mixbus. But my mixing is done otherwise itb and will remain that way. I also have an octo sat to run uad plugins. I have almost exclusively moved to uad plugins. All and all I like and feel comfy with the uad ecosystem. But for the interface I was thinking about maybe getting a motu ultralite mk5 for it’s I/O options and using the apollo for mixing at home and tracking on the run. Would it make a difference using the motu in my setup since I dont track thru unison and I convert in my 4-710d? Its 1/4 of the price of an apollo x6 and im not sure if the x6 will make a difference in this case? The conversion on the MOTU is likely just as good as the Apollo. A bunch of former Apollo users here swear by them.
A few more thoughts:
I don't mean to be a downer, but it's very possible that you might continue to get the same issue with your 710 (you might not, though, so take this with a grain of salt).
My old setup was very similar to yours — outboard mic pre/EQ/compressor, Lynx Aurora MKI doing the A/D conversion, then going ADAT to an Apollo Twin MKI. My vocals always sounded grungy/dirty with random blips and artifacts like the one you shared. Happened no matter which converter I chose. At one point, I tried a completely separate Focusrite interface and still had the same problem. It was incredibly frustrating.
After years of this, I finally said fuck it and bought a Lavry Blue A/D just to see what would happen, and no joke, the issue was instantaneously resolved the moment I hooked everything up. Crazy enough, the Lavry was still connected to the Apollo, and it sounded great.
I have since swapped the Apollo for an Apogee Element, and I have to admit, the Apogee converters sound almost 80 - 90% as good as the Lavry. Not QUITE as clear and detailed, but man, it's close.
For some strange reason, it seems like certain converters just don't play well with some recording chains. I hate that it's even a thing, and I will always be jealous of people who can just plug an MXL into a PreSonus and sound like money. If you can't demo out one of the converters I mentioned, see if you can try a Symphony Desktop. Same price range as the Apollo Twin X, and similar features, but you get some of Apogee's best conversion.
Lastly, there's still the possibility that it's not the converters at all. Just offering my experience. Hopefully you can figure this all out.
Post by niklas1073 on Mar 30, 2023 8:58:23 GMT -6
Thanks, you actually carry a valid point there. Very insightful, didn't think about it that way. The 710 probably carries same converters as apollo, so even though the apollo did these tricks also on its own the 710 might have same tendencies. As i dont have access to those interfaces, i might try out the motu for a few days, if it works great, ill keep it as i need anyway the expansion of i/o for mixbus hardware. Ill let you know how it all plays out after some more trial and when i get some feedback from the service.
Post by niklas1073 on Apr 1, 2023 4:15:30 GMT -6
I think the mystery is solved... I picked up a MOTU Ultralite mk5 for trial to try everything with another interface. As I power off all my other gear, run the copperhead straight into the motu's pre... I will still get the similar distortion on the same words like "days" and alike. However weird it sounds as the distortion cannot be heard in the room while I sing, I believe I have ruled out all other factors from the equation. So yeah, It has to be my pipes. I am very ok with that as long as my beloved gear is up and running. The reason I did not believe it would be my voice at first was partly because it sounded so electrical the fuzz, and because when when earlier this year tracked my sons single, I had a few similar fuzzez on his vocal track. I can only now believe it's because his voice is quite similar to mine, which it is, and he also has some grit to voice in the lower register. The fuzz was not as pronounced with the motu as it was with the apollo and esp. with my 1073 and 1176. I suppose it's because the 1073 pushes that mid some and the 1176 pronounces further that. The Motu pre's sound somewhat different to the apollo anyway, kind of dull and vailed maybe, and I think it hides that effect a little. But none the less I can pick it out from there and the locations are identical. Despite the fact that the MOTU didn't change a thing, and I honestly hate their DSP mixer and cue mix software, awkward and cheap feeling in every way, especially compared to UA Console, which I enjoy a lot. I consider keeping it. It is after all 1500 bucks cheaper than an apollo x6 which I was having in mind, offers me the routing i'm looking for in rack apollos, economically allowes me to also keep my apollo twin for mobile mixing and recording. Right now im routing my mixbus hw thru apollo twin 3/4 out and in thru 1/2, which offers me the possibility to monitor and print the mix bus thru outboard, but I cannot create insert with it. This worflow works great for me though it's a little cumbersom, as i am and will be mixing itb except for the last stage mixbus. But it would neat up the studio desk nicely and I could add more outboard pre's in the future to the motu ins as my 8 ADAT are now full.
