Post by Johnkenn on Feb 10, 2023 12:19:48 GMT -6
How do you guys address this. I can usually duck it out with some dynamic compression…but this one seems to be baked in all around. I supplement with trigger. Gonna try to do some stuff with SD…but I still hear that damn ring and it’s bothering me. I track at the same place all the time and it’s the drummers studio…it’s been getting ringier and ringier over the years - I should just tell him to stop being so damn ringy lol. I really wish I could just replace kick and snare completely with ones I really dig…well honestly I don’t think I’ve ever tried that…but I would imagine you lose a lot of authenticity.
Post by Bat Lanyard on Feb 10, 2023 12:45:35 GMT -6
I think you're on Pro Tools HD?
Post by Johnkenn on Feb 10, 2023 12:46:04 GMT -6
I think you're on Pro Tools HD? Native.
Post by ragan on Feb 10, 2023 12:55:47 GMT -6
Try Softube Transient Shaper, pull down the Sustain on the snare mic/mics. Might still have ring in the OH/other mics, but I bet this would help.
Post by Bat Lanyard on Feb 10, 2023 12:58:34 GMT -6
Probably the only thing I took away longterm from watching Warren Huart's stuff is the trick Ken Sluiter demonstrated using tab to transient. The difference on Native is that I don't think Native has the "replace all instances of clip" with one you Cmd+Shift drag from the clips list.
1. Find a sample you like, for example, snare 2. Place a new track above a real snare track you want to augment or replace 3. Drag the sample to that track and cut it to the clipboard 4. Select the snare track, then also select the new track 5. Group them 6. Click in the new track which will put the cursor across both
With tab to transient on you should then be able to hit tab and it'll stop on a snare transient, then Cmd+V and it'll paste your sample in the new track. Takes time to go across an entire song but I do this nearly every time with live drums when I want to slightly enhance the sound or lower a ringy snare, etc.
With HD you can do the same above but create and use a consolidated clip and paste that instead. With the "replace all instances" option you can paste the slug clip across snare or kick (or whatever), copy the track as many times as you want and then drag different samples to replace the slugs in the tracks.
It's work but I think it sounds a million times more natural than Trigger2 which I used to use.
Post by jmoose on Feb 10, 2023 13:13:24 GMT -6
How do you guys address this. I can usually duck it out with some dynamic compression…but this one seems to be baked in all around. I supplement with trigger. Gonna try to do some stuff with SD…but I still hear that damn ring and it’s bothering me. Ok before anything else... is it the ring itself that's bugging you or is it the pitch of the ring? Lets say the song is in the key of A major... and the snare is pitched to C natural and that minor 3rd is just singing away..? Making everything else in the track sound out of tune? If that's the case take a swing with the old Tony Visconti / Mutt Lange trick & re-pitch with an Eventide. Like otto toon for drums. Move it up/down a few cents until its at a natural pitch for the key of the song. Tracking at the same place all the time? Next trip maybe ask the drummer to try a few different snares... takes 5-10 minutes... or at the very least toss a piece of moongel on the batter. That takes 7 seconds and can save hours later.
Post by seawell on Feb 10, 2023 13:17:39 GMT -6
Boz Transgressor is the tool I use the most for this. You may want to demo it if you haven’t yet: www.bozdigitallabs.com/product/transgressor-2/If the ring is really bad, sometimes you have to use a bit on the overheads and room mics too. It’s such a pain! Good luck!
Post by sean on Feb 10, 2023 13:27:42 GMT -6
I usually take Pro-Q 3 and with a Q of say 10 and sweep around until I find the frequency of the “ring” and cut it. Sometimes it’s 18dB. Usually taking out the fundamental of the ring cures it. S you’ll probably have to do the same with the overheads/room mics
Post by notneeson on Feb 10, 2023 13:37:10 GMT -6
I find that a notch filter can be too drastic in solo, but work in the mix. Also, you can use the notch to sweep but then broaden the Q.
Post by mcirish on Feb 10, 2023 13:44:38 GMT -6
I use dynamic EQ tuned to whatever pitch it's ringing at. I still want some ring. I hate that old 70's thud snare thing. I know it's popular but I'm not. :-)
Post by svart on Feb 10, 2023 13:48:32 GMT -6
Notch filter. Sweep till you find the worst spots and see if that helps enough..
Post by Ward on Feb 10, 2023 14:49:29 GMT -6
Can you post an example with a sample, please? Submit and isolated snare track/s and overheads?
Post by fellowshiphallsound on Feb 10, 2023 15:02:59 GMT -6
I usually take Pro-Q 3 and with a Q of say 10 and sweep around until I find the frequency of the “ring” and cut it. Sometimes it’s 18dB. Usually taking out the fundamental of the ring cures it. S you’ll probably have to do the same with the overheads/room mics Yup. This plus transient master are my go-to. I've got a drummer I track very often who refuses to dampen his snare ~ and thinks the ring is king. I do it so often I can almost fix it without listening at this point
Post by Johnkenn on Feb 10, 2023 15:07:33 GMT -6
I usually take Pro-Q 3 and with a Q of say 10 and sweep around until I find the frequency of the “ring” and cut it. Sometimes it’s 18dB. Usually taking out the fundamental of the ring cures it. S you’ll probably have to do the same with the overheads/room mics Usually what I do too...the snare is just super compressed already too... these are all great tips. I totally didn't think of a transient designer
Post by christopher on Feb 10, 2023 15:14:10 GMT -6
You probably do this already, but I divide the snare in my mind into something like attack, sustain (body), and snap. Usually mute everything except kick and snare, kind of an 80s way I guess.. The ring is usually in the sustain/body part of the sound.
So first I try to make the attack way louder than the sustain. I want to hear just the stick. 12:1 or 20:1 ratio compression, attack 120ms/release 5-10ms.. and start backing down *attack* until it’s just the “smack”. I might end up around ~60ms or 100ms .. whatever you need. Then add EQ … bring lots of top end for snap, suck away 400 to get rid of boxy ring etc , boost 250 or low shelf kind of thing for punch. Most snares (and kicks) are already totally transformed from this and act more like a sample. Then boost really really loud (in the mix I mean) and start messing with other mics, overheads first super quiet.. is that enough? Or do I need to do more? Try a stereo room reverb on an aux and an expander on the snare first, .. if I switch to a gate that usually means more is needed.
More means= I’ll duplicate the snare track.. (I prefer that to a send) and focus the compression and EQ on the clone to be the sustain/body.. and blend it very quietly to fill in where I took too much away with the gate.
Reverbs etc help. If none of this works.. time to mess with samples and pitch shifters and automation hell
Post by Johnkenn on Feb 10, 2023 15:28:54 GMT -6
Left the dynamic eq on the fundamental and added a transient shaper...forgot I had the Xaudio DS-10 Drum shaper thing. Actually worked great. Thanks for the replies.
Post by eyebytwomuchgeer on Feb 10, 2023 15:49:53 GMT -6
Seeing as how the ring issue is a repeated thing and has been happening for a long time, I’d say the main thing to do is tune the snare better for future recordings. Or, as was mentioned previously, try to pitch shift the ring if possible.
As a drummer, I used to hate a ringy snare until I started to tune the ring to the key of the song. Now I love the ring. The snare sits better and doesn’t need as much eq to cut.
There is certainly a difference (at least to me) between a pleasing ring and and annoying cacophony of weird overtones. It takes some practice to get the snare to tune to a nice solid ringy pitch and still maintain some snare-iness. Once I get in that area, I usually use a small piece of gaff tape to tame some of the ring. It if I’m hearing a lot of weird zings and frequencies instead of a solid tone, it’s time to retune. A well-tuned ring sort of gets lost in the track once everything is piled on top.
Post by guitfiddler on Feb 10, 2023 21:16:16 GMT -6
The snare needs to work for the song! That’s what I’ve always done. Although, in the recording process and having someone else do your drums, swapping out different snares, as well as budget constraints, I can see there being issues with that process. If the drummer knows what you’re going for and how to tune a snare, and there is some good communication, it doesn’t have to be this way!!! 😆
That’s why I have a hundred snares!!!😆
Post by RealNoob on Feb 10, 2023 21:18:56 GMT -6
I usually take Pro-Q 3 and with a Q of say 10 and sweep around until I find the frequency of the “ring” and cut it. Sometimes it’s 18dB. Usually taking out the fundamental of the ring cures it. S you’ll probably have to do the same with the overheads/room mics just did this on a song. helps tremendously. I am also supplementing with samples.
Post by sean on Feb 10, 2023 21:26:27 GMT -6
I often forget about it but Waves “Torque” can be useful if the pitch of the drum/ring doesn’t work in the track
Post by ericn on Feb 10, 2023 21:32:45 GMT -6
The notch filter is the solution if it designed to be a true digital filter not an emulation of an analog filter and all the fun phase issues.
Post by Deleted on Feb 10, 2023 22:38:24 GMT -6
Sharp bell. I use MDWEQ, Oxford Eq, or Slick EQ GE Japanese mode. Sharp dynamic bell if they hit it only sometime in a weird way. I can recommend only Nova GE surgical mode and the Oxford Dynamic EQ
Post by smashlord on Feb 10, 2023 22:41:49 GMT -6
If you want to kill the ring, notching in the 270-600 range will usually help and/or a transient designer. That said, as some else suggested, you can embrace the ring and tune the snare to something within the key. Usually if the ring is in the key of the song, its not so annoying.
A few months back I received a track to mix (that I didn't record) where the snare was a ringy F and the key of the song was E major. As you can imagine, it was not the most pleasing ring. Pitching it down the 1/2 step made it significantly less brutal.
Post by Johnkenn on Feb 10, 2023 23:07:24 GMT -6
I wonder what auto tune would do to a snare? Lol I’ve literally never thought about trying it. I might have to go give it a try.
Post by Johnkenn on Feb 10, 2023 23:10:19 GMT -6
Btw - I very rarely have success with SD supplementing. I often find that there’s phase and timing issues and the juice isn’t worth the squeeze.
