Post by plinker on Jun 26, 2022 19:15:35 GMT -6
It's been a slow death for me, but SonarID is now a giant POS.
Do I need to re-shoot my room, install something, click my heals three times and say "there's no place like home"??
I was patient as long as the plugin worked. But now....................
NOTE: I edited the title of this thread to reflect current conditions
Post by mcirish on Jun 27, 2022 8:59:25 GMT -6
Can you give more specifics? I had some troubles but now have it working completely fine again on Windows 11 with V2 drivers for me Lynx Aurora 16. There are so many variables that can cause issues. I'm glad to help if I can.
Post by Johnkenn on Jun 27, 2022 12:19:46 GMT -6
I used to be able to track with it on the master without worrying about it. Then after this update, audio started to get delayed. Finally figured out that the plug was defaulting to mixed adding latency. Tried to turn it to zero but it was still weird so I just defeated it. Just annoying.
Post by plinker on Jun 27, 2022 14:11:06 GMT -6
OK -- I'm on a Mac. I had to do a clean un-install (delete) using AppCleaner to remove old prefs and such and now it works in System-wide.
However, the plugin is not responsive in Logic, and doing nothing.
Post by Johnkenn on Jun 27, 2022 15:38:52 GMT -6
One reason I’m selling a kidney and buying a Trinnov
Post by stratboy on Jun 27, 2022 16:14:37 GMT -6
How much does an ST-2 Pro system go for (roughly)? IOW, what is one of JK’s kidneys worth?
Post by Johnkenn on Jun 27, 2022 16:41:22 GMT -6
How much does an ST-2 Pro system go for (roughly)? IOW, what is one of JK’s kidneys worth? It ain’t pretty. Around $4600 new. Without the mic.
Post by wiz on Jun 27, 2022 16:48:06 GMT -6
I tend to just not update with it…..and really leave it till I know it’s good
Post by sean on Jun 27, 2022 16:50:02 GMT -6
From what I understand even in "low latency" mode the latency with the Trinnov is too much to track with and you have to bypass it (which apparently is easy to do in their app). But maybe there's some sort of work around.
Post by stratboy on Jun 27, 2022 17:05:16 GMT -6
How much does an ST-2 Pro system go for (roughly)? IOW, what is one of JK’s kidneys worth? It ain’t pretty. Around $4600 new. Without the mic. Wow. That’s a lot of coin.
Post by RealNoob on Jun 27, 2022 19:15:20 GMT -6
I too had loved sonarworks on 2 previous sets of speakers. Right now, I much more prefer Genelecs with GLM. Seems like the new Sound ID isn't working as well and doesn't sound as good.
Post by plinker on Jun 28, 2022 9:57:46 GMT -6
With the previous version, the plugin worked but the system-wide didn't.
Now the system-wide works but the plugin doesn't.
Good times...
Post by mcirish on Jun 28, 2022 13:41:33 GMT -6
On PC, it was the exact opposite. The plugin always worked but the systemwide would stutter badly. One note, and this shouldn't be the cause, but... make sure systemwide is not running when you start the DAW.
Post by nicksteinborn on Jun 28, 2022 18:05:19 GMT -6
I’m getting close to just getting a hardware eq and approximating the curve from Sonarworks. Systemwide constantly glitches out and I hate not being able to monitor through the correction in UAD console. I have a channel strip with some of the eq to kind of monitor accurately, but I feel like just committing to hardware will make life that much easier.
Post by plinker on Jun 28, 2022 18:44:13 GMT -6
On PC, it was the exact opposite. The plugin always worked but the systemwide would stutter badly. One note, and this shouldn't be the cause, but... make sure systemwide is not running when you start the DAW. good idea. Thanks. i'll try that.
Post by mattbroiler on Jun 28, 2022 21:18:12 GMT -6
I just checked and you can download all the old versions of SoundID and Sonarworks from their website so no problem to roll back to a previous version if the new one is causing problems
Post by kcatthedog on Jun 29, 2022 2:17:12 GMT -6
I’m getting close to just getting a hardware eq and approximating the curve from Sonarworks. Systemwide constantly glitches out and I hate not being able to monitor through the correction in UAD console. I have a channel strip with some of the eq to kind of monitor accurately, but I feel like just committing to hardware will make life that much easier. You can use REW for a room analysis and for setting the eq points.
Post by abridge27 on Jun 30, 2022 16:10:22 GMT -6
The infamous "since the update..." Man, it's almost as if audio software companies purposely put micro-innovations above stability. Steinberg does this too. Why don't they all just released updates on beta only if they can't ensure many users won't lose the basic functions?!?
Post by spindrift on Jul 4, 2022 22:46:23 GMT -6
Same….latest version of SoundID on new Mac Studio and PT 2022. Total POS. Get it together Sonarworks!
Post by plinker on Jul 4, 2022 22:59:51 GMT -6
Oh -- and when the sytem-wide works, it's got a shelf-span of about 15 mins.
Then, it's the Sonarworks version of the blue screen of death -- i.e., it is hosed!
Post by drumsound on Jul 6, 2022 1:12:38 GMT -6
I was thinking about trying it, but now... no thanks.
Post by plinker on Sept 15, 2022 20:36:30 GMT -6
The latest release is working better than any before. - The Logic plugin works fine - The system wide is much more dependable. It takes a few hours of being in the background to crap-out. A software reboot fixes it.
So, I'm liking it again, but sleeping with one eye open.
Post by RealNoob on Sept 15, 2022 21:05:27 GMT -6
I was thinking about trying it, but now... no thanks. I’m on M1 and never have stability issues. I didn’t on the older machine either, honestly
Post by drumsound on Sept 16, 2022 0:07:18 GMT -6
I was thinking about trying it, but now... no thanks. I’m on M1 and never have stability issues. I didn’t on the older machine either, honestly Good to know. My new monitors are running off a Dayton Audio DSP system, so I'm now covered.
Post by Johnkenn on Sept 16, 2022 0:33:01 GMT -6
I’ve said it before, but SW was a revelation when I got it. Really improved my mixes. I’ve since gone to Trinnov as you can find on the board elsewhere. Reading this and I need to go back and forth again with Trinnov and SW. I’ve done it a couple of times and thought Trinnov won every time, but I really need to listen and see post what I think the differences are. Obviously, there are the obvious time domain and phase things…but I’m talking about “sonically.” And real world.
