Post by notneeson on May 13, 2022 12:15:13 GMT -6
I'm far from knowledgeable on the topic. I have noticed that when I send a mix to be mastered with fairly low levels it comes back quieter than mixes I sent that began with louder levels. This should not be, but it is. Mastered by whom?
Post by Martin John Butler on May 13, 2022 12:40:26 GMT -6
I'd rather not say. Two are well known major league mastering engineers, one was the Aria online mastering service.
Believe it or not, the Aria masters were closest to levels that matched what I was using as a benchmark.
Post by Dan on May 13, 2022 12:54:31 GMT -6
I'm far from knowledgeable on the topic. I have noticed that when I send a mix to be mastered with fairly low levels it comes back quieter than mixes I sent that began with louder levels. This should not be, but it is. Martin, they're judging if you want it slammed or not. Now most slammed masters come from slammed mixes. I mean beyond loudness war stuff. Totally SLAMMED. RMS of -5 or -6 or even higher from slamming faders into that limiter and however higher they push up the faders, the mix can't get louder, just more distorted with more intersample peaks because all those lookhead limiters have hold times hahahaha
Post by notneeson on May 13, 2022 14:12:45 GMT -6
I'm far from knowledgeable on the topic. I have noticed that when I send a mix to be mastered with fairly low levels it comes back quieter than mixes I sent that began with louder levels. This should not be, but it is. Martin, they're judging if you want it slammed or not. Now most slammed masters come from slammed mixes. I mean beyond loudness war stuff. Totally SLAMMED. RMS of -5 or -6 or even higher from slamming faders into that limiter and however higher they push up the faders, the mix can't get louder, just more distorted with more intersample peaks because all those lookhead limiters have hold times hahahaha Well, that’s somewhat what I was wondering: was a conversation had at all or was it just like, “here’s what you get.”
Post by Martin John Butler on May 13, 2022 17:23:43 GMT -6
Thanks Dan, I kind of suspected that. These days I compromise, I use a minimal amount of compression on the 2 bus, mainly from the UAD ATR-102 tape sim and Black Box plug which really adds a little sweet distortion, and a perhaps a pinch of "air". Once I have a mix where I like it, I'll put a compressor on and bring up the level, but never to where it's distorting. I'll let the mastering process do the rest.
Sooner or later I'll have to learn to side chain the master mix compressor so I don't affect the low end as much, or put on an EQ that leaves the low end alone.
Post by Dan on May 13, 2022 18:43:02 GMT -6
Thanks Dan, I kind of suspected that. These days I compromise, I use a minimal amount of compression on the 2 bus, mainly from the UAD ATR-102 tape sim and Black Box plug which really adds a little sweet distortion, and a perhaps a pinch of "air". Once I have a mix where I like it, I'll put a compressor on and bring up the level, but never to where it's distorting. I'll let the mastering process do the rest. Sooner or later I'll have to learn to side chain the master mix compressor so I don't affect the low end as much, or put on an EQ that leaves the low end alone. What are your references? What era? What masters? Waves L1 came out in 1992 and the limiter and clipper wars have been going on ever since.
Post by bossanova on May 13, 2022 21:22:12 GMT -6
Tears For Fears - Everybody Wants to Rule the World (original master) - 1985, -15 LUFS. Going back a bit, a good example of an 80s record tracked to tape that's more compressed than Aja, and not as open as the ADD and DDD Luther Vandross records, but still way more dynamic than most records from the 90s. Attachments:
Post by bossanova on May 13, 2022 21:36:30 GMT -6
Peter Gabriel - Shock The Monkey - 1982, -17.4 LUFS, 17.6 peak to loudness ratio. Glorious, crank-able rock with impact. Attachments:
Post by Martin John Butler on May 14, 2022 10:44:46 GMT -6
Thanks Dan, I kind of suspected that. These days I compromise, I use a minimal amount of compression on the 2 bus, mainly from the UAD ATR-102 tape sim and Black Box plug which really adds a little sweet distortion, and a perhaps a pinch of "air". Once I have a mix where I like it, I'll put a compressor on and bring up the level, but never to where it's distorting. I'll let the mastering process do the rest. Sooner or later I'll have to learn to side chain the master mix compressor so I don't affect the low end as much, or put on an EQ that leaves the low end alone. What are your references? What era? What masters? Waves L1 came out in 1992 and the limiter and clipper wars have been going on ever since. I use Ryan Adams' "Two" to compare volume, and Lyle Lovette's "Road to Ensenada" as well. For bass level and balance, my reference is Mark Knopfler's "Sailing to Philadelphia". I don't know their specs, but whatever I do has to be close to that.
Post by Dan on May 14, 2022 12:13:10 GMT -6
What are your references? What era? What masters? Waves L1 came out in 1992 and the limiter and clipper wars have been going on ever since. I use Ryan Adams' "Two" to compare volume, and Lyle Lovette's "Road to Ensenada" as well. For bass level and balance, my reference is Mark Knopfler's "Sailing to Philadelphia". I don't know their specs, but whatever I do has to be close to that. Those are limited and clipped. Waves L1 and clipped for the Lyle Lovett. Ryan Adams is crushed with something.
Post by OtisGreying on May 14, 2022 13:15:18 GMT -6
Even with a limiter doing 10Db of gain my mix is reading at -20, -21 LUFS.
Anything wrong with that? All my compression is working as intended and gain staging etc. just feel like adding 20 Db of gain on a limiter to get it up to proper level seems extreme but perhaps its a good thing to have so much headroom?
10db of gain reduction? Or, just adding 10db of gain (as in, makeup gain)? If it's the former (which I doubt), your mixes are likely very, very out of balance. 2-3db of limiting, and a peak value of -0.5, and my mixes live between -12LUFS (at the quietest end, usually for mellow genres) and -7LUFS (for stuff like metal). 10db of makeup gain, about 3 db of limiting on snare hits. My level is about -16 lufs right now. I realized my C1LA's makeup gain is at 0 and its doing about 4db of compression so I think if I had that makeup gain there It'd probably be pretty normal level, but I have limiting after the C1LA and dont want to crank gain into my other plug-ins in the chain atm.
My peak value is hitting -1 on my Waves dorrough meter. Is Peak value a measurement of how close you are to clipping converter or something to that effect?
Post by christopher on May 14, 2022 13:37:38 GMT -6
I think -20dB+ was probably common in the 80s? As the mastered versions only get them up to -17dB. I bet the un mastered mixes sounded incredible on full range
Post by christopher on May 14, 2022 13:43:29 GMT -6
One thing that might make a difference in mastering I’ve been thinking about, a 2 dB difference can sound pretty dramatic. So what if a certain EQ allows you boost the highs easier than another? If you can get an extra dB of high mids out of a certain EQ, might get you part of the way there. Same with compressors, if one is a little sweeter it might allow an extra dB. And then converters as well, maybe you can clip for another dB? Or maybe they are sweeter overall and allow you to EQ the highs hotter?
Post by Martin John Butler on May 14, 2022 14:57:20 GMT -6
I use Ryan Adams' "Two" to compare volume, and Lyle Lovette's "Road to Ensenada" as well. For bass level and balance, my reference is Mark Knopfler's "Sailing to Philadelphia". I don't know their specs, but whatever I do has to be close to that. Those are limited and clipped. Waves L1 and clipped for the Lyle Lovett. Ryan Adams is crushed with something. I can hear it on the Ryan Adams track for sure. I just like how it was mixed and arranged more than the mastering. It is kinda crunchy. Nathaniel Kunkel recorded the Lyle Lovett album with custom made Massenberg compression. It won album of the year. Whatever they did on that one is good enough for me. The Knopfler track is my go to when I need to compare bass level.
Post by bossanova on May 14, 2022 15:13:07 GMT -6
What are your references? What era? What masters? Waves L1 came out in 1992 and the limiter and clipper wars have been going on ever since. I use Ryan Adams' "Two" to compare volume, and Lyle Lovette's "Road to Ensenada" as well. For bass level and balance, my reference is Mark Knopfler's "Sailing to Philadelphia". I don't know their specs, but whatever I do has to be close to that. Road to Ensenada, -12.5 LUFS. About on par for a more thoughtfully/less slammed mastering in 1996, but still caught up in that post-95 limiter driven race. Two, -9.4 LUFS. Sounds like 2007. It's not "Flagpole Sitta" from 1997 in terms of the most crushed sections, but it doesn't even attempt to sneak in any contrast either. Tapping the ceiling from start to finish. Attachments:
Post by Martin John Butler on May 14, 2022 17:50:32 GMT -6
Thanks for that Bossanova! I figured the "Two" was just slammed up, I mainly like the arrangement, the L&R acoustics, and the tone of the piano taking a huge space, bass level, etc. I try to get some of that weight, but not as the expense of dynamics. It's a bit tricky. I also use Road to Ensenada as a guide to vocal tone. There's some sibilance there, but I like big upfront vocals and that track really does it for me.
Online I've begun listening to Chris Stapleton's "Starting Over" as a reference. That's the clarity and volume I hope for on youtube that I haven't been able to achieve on my meager home system when compared to the studio's firepower and engineering expertise on that track. I wonder what the level on that is.. hmm..
Post by bossanova on May 15, 2022 16:10:43 GMT -6
Here you go  It's actually a *huge* improvement from 15 years ago, or even (how did I get so old?) 25 years ago. Attachments:
Post by monkeyxx on May 15, 2022 16:13:37 GMT -6
Chris stapleton could sing a song about a Wendy's Cheeseburger and make it sound popular... in fact, he probably should. ;-D
Post by Martin John Butler on May 15, 2022 18:19:07 GMT -6
Big thanks Bossanova! That printout is interesting. I must admit I barely know anything about understanding track levels. That Stapleton track doesn't seem especially "loud", but online it's not any quieter than other videos.
How did they do that?
Post by bossanova on May 15, 2022 20:25:08 GMT -6
The big things I hear are that the bass and low mids have been very well controlled at the mix/recording level so that the energy is focused in the telephonic/articulation frequencies, which is making everything sound “louder” and clearer even with the wider, less compressed Peak ratios. To be honest it does sound quieter than other modern releases to me, but I consider that a good thing. (My personal taste in mastering stops somewhere around the early 90s, modern dynamic releases excepted.) It breathes more like Harvest era Neil Young without the same level of vintage coloration, but with that more modern (multiband?) low end and midrange sculpting.
Post by Martin John Butler on May 16, 2022 9:54:26 GMT -6
Appreciate your insights bossanova.
Post by Bob Olhsson on May 16, 2022 11:50:15 GMT -6
My experience has been that digital is the exact opposite of analog thinking. In analog, we were always trying for as high a level as we could get away with because noise was the enemy. In digital, it's always best to error on the low side and only bring it up at the end.
I bumbled into this when I was helping a friend with his new 001. His stuff recorded peaking to -20 sounded better than the stuff I was getting to master that had been mixed on an SSL. My conclusion was that the analog stages of most converters must be utter crap. You need look no further than at the analog section of pro tape machines to see the difference.
Post by OtisGreying on May 16, 2022 17:57:31 GMT -6
I use Ryan Adams' "Two" to compare volume, and Lyle Lovette's "Road to Ensenada" as well. For bass level and balance, my reference is Mark Knopfler's "Sailing to Philadelphia". I don't know their specs, but whatever I do has to be close to that. Road to Ensenada, -12.5 LUFS. About on par for a more thoughtfully/less slammed mastering in 1996, but still caught up in that post-95 limiter driven race. Two, -9.4 LUFS. Sounds like 2007. It's not "Flagpole Sitta" from 1997 in terms of the most crushed sections, but it doesn't even attempt to sneak in any contrast either. Tapping the ceiling from start to finish. Are these levels being pulled from any streaming services? That be interesting to see what the levels are on Spotify/YouTube since they are supposed to normalize to the same level but I’ve seen tests where people are mastering above the reccommended level and their masters are indeed coming out louder on those streaming services
Post by bossanova on May 16, 2022 20:42:59 GMT -6
My experience has been that digital is the exact opposite of analog thinking. In analog, we were always trying for as high a level as we could get away with because noise was the enemy. In digital, it's always best to error on the low side and only bring it up at the end. I bumbled into this when I was helping a friend with his new 001. His stuff recorded peaking to -20 sounded better than the stuff I was getting to master that had been mixed on an SSL. My conclusion was that the analog stages of most converters must be utter crap. You need look no further than at the analog section of pro tape machines to see the difference. I was waiting for you to weigh in Bob  My contributions are limited to what I've picked up from DIY analysis and mastering over the years, and absorbing what generous folks like you and Bob Katz have written about it. Knowing that the Digi 001 was very early in the interface game, have you found that recording at a higher level in digital world has gotten any better, or have you still of the opinion that -20, -12, etc, is the safer bet and just add gain ITB later?
Post by bossanova on May 16, 2022 20:49:12 GMT -6
Road to Ensenada, -12.5 LUFS. About on par for a more thoughtfully/less slammed mastering in 1996, but still caught up in that post-95 limiter driven race. Two, -9.4 LUFS. Sounds like 2007. It's not "Flagpole Sitta" from 1997 in terms of the most crushed sections, but it doesn't even attempt to sneak in any contrast either. Tapping the ceiling from start to finish. Are these levels being pulled from any streaming services? That be interesting to see what the levels are on Spotify/YouTube since they are supposed to normalize to the same level but I’ve seen tests where people are mastering above the reccommended level and their masters are indeed coming out louder on those streaming services They're all pulled from the original masterings where applicable. However, I did record/capture the stream of the Chris Stapleton song off of YouTube to compare from the album master that I used originally, and it was about 3.5 db *quieter*, but otherwise the same mastering, just level adjusted down.
