Post by GreaterSociety on Nov 2, 2021 15:51:34 GMT -6
I'm putting a studio together and for various reasons, it's going to need to be a single room--33'x18.5'x10'. I really wanted to have separate control and live rooms, but it's not going to work out for me. So I'm interested in hearing from those of you who have or have worked in single room studios. What are some of the most effective techniques you've used to make the most of such spaces?
I'm particularly concerned about not being able to adequately judge what I'm recording because the sound of drums, for instance, or loud guitars, won't be isolated from my listening environment. Obviously, I'll need to wear headphones, but that seems like it's not the same as being able to listen through good monitors. So what strategies do you employ? Any other benefits of working in single room studios you care to share (to make me feel better about the fact that I won't be able to have separate live and control rooms)?
Post by jmoose on Nov 2, 2021 16:13:57 GMT -6
Don't have enough time for detail right now... I've been working out of single room studios for over a decade.
Did a record at the Phish Barn which is basically a single room... last studio I co-owned was a single room cabin on a mountaintop. Current home-based space is getting the final touches to be a workable one room situation. Have recorded in a number of others... song I just posted in the C37 thread was done in a single room studio.
Personally I love the communication. Its instant. No talkback mics... That whole vibe where the band or signer finishes a take and they see people on the other side of the glass having a conversation? But they aren't hearing any of it?
Getting sounds, esp drums can take some time. Basically need to record a bit, listen back, make adjustments. Rinse & repeat.
The real trick is getting the "control room" aspect right w/o screwing up the rest of the space... or more likely, the rest of the space screwing up your monitoring environment.
Post by gravesnumber9 on Nov 2, 2021 16:19:13 GMT -6
Watch the classic records (or whatever it’s called) mini-doc on The Band recording their brown album for inspiration.
Beyond that, focus on the positives! Pretty big room with pretty high ceilings. Not too bad.
Post by Tbone81 on Nov 2, 2021 17:53:15 GMT -6
Was gonna reply early but Jmoose covered most of it. I love one room studios. The line of sight, intimacy and direct communication with the artist/band is awesome. I also think its better to have one good sounding room than two mediocre to bad sounding rooms. Orientating your workstation/console/desk etc can be tricky and is obviously dependent on your room acoustics. I frequent this studio every so often (actually have three days booked there this month), check out their pics www.themaproomstudio.com It can be hard to see but their console is about 12' from the back wall, which is a several foot thick bass trap. And the sides are thick bass traps too. Sitting behind that desk gives you the same line of sight you'd have if you were doing live sound. If you can, I'd wall off one of the corners and make a small amp room/vocal booth. A small iso room big enough for two guitar cabs, or a bass cab, or a singer etc. That will make things way easier for you. Also, make sure to have plenty of gobos that can be moved or stacked to section off instruments. I used to record my loud metal band in a one room rehearsal studio, and with careful placement, and a few gobos there was very little bleed between bass/drums/guitar.
Post by gravesnumber9 on Nov 2, 2021 18:01:19 GMT -6
I just remembered I room I recorded in here in Austin that was a one room setup that I loved. Large space but one room. I can't remember the name.
Anyway, what I loved about it was that they built the "control room" section on a lifted up floor to kind of visually differentiate it and also to provide a better view of the band "below". I say "below" in quotes because it was only like 18 inches off the ground but it made a difference.
Now that I think about it, I remember the house engineer at Levon Helm's Barn giving me a tour of the space after meeting him randomly at CMJ. Similar setup but even more extreme if memory serves. I could be mixing this up with another space (I did a lot of recording in some pretty, umm, blurry years) but I seem to recall that Levon had his control area (again, not a room) pretty much like a loft overlooking the barn.
Anyway, you might not want to lose your precious ceiling space, but just something to think about that could be visually striking and add a cool vibe with some practicality as well.
Post by GreaterSociety on Nov 2, 2021 19:21:01 GMT -6
Thank you all for the inspiration and encouragement. One thing I’m thinking through is where to put the mixing desk and speakers. I hear common guidance is about a third from the wall, but that results in facing me away from the band. If I put the desk facing the other way so I’m looking at the band, it would result in me sitting pretty close to the back wall, is that going to be a problem?
Post by gravesnumber9 on Nov 2, 2021 19:28:29 GMT -6
Out of my scope for sure. But I do know that these rules of thumb are just that... rules of thumb. Not straight "rules". More like starting points. If it were me a lot of it would depend on how many people I expect to track. If you expect to do full bands (even if they're overdubbing, you still want to let them stay set up if you've got the room) then that's one thing. If you don't, that's another. There are advantages and disadvantages to every setup. For example, let's say you decide you'd like to be facing the band so you set yourself up to be about 10 or 12 feet from the back wall. It's not ideal, but you get better visual connection with the performers and, if you have rear ported speakers, lots of room for the bass coming from the back to dissipate. On the other hand, I do a lot tracking of myself so I'd probably want to set up the other way around so that I can see my screen when I'm playing. On the other other hand, your room is big enough that you could still do that with any setup. My point is there are tons of variables. If you really want to get it right hire an expert to come in and help you. Otherwise (again just my advice, not an expert in acoustics) I would focus on layout for my clients and then just do my best on the basics of sound. Copious ceiling clouds. As much treatment on the back wall as you can handle and gobos galore. p.s. one more time for good measure... NOT AN EXPERT IN ACOUSTICS!!!
Post by the other mark williams on Nov 2, 2021 20:55:35 GMT -6
I'm with jmoose on this: embrace the positives of the situation as much as possible. There is a wonderful immediacy to recording right there with the band (unless you don't like the band, which quickly becomes a more complex issue altogether). It's an intimate experience when done right, an experience where the artist can feel you rooting for them. It requires more from you on an emotional level, but the dividends can be huge. You can really build personal relationships with the clients, and if you're good at that part, you can build loyal clients that way. You'll be in the creative trenches with them, after all. Design-wise, this is where a LEDE ("Live-End-Dead-End") approach can work well. Originally, LEDE design was intended for live rooms, but in this case, you make the dead end where your desk and monitoring is. With a space that size, I personally think constructing a vocal booth is of marginal benefit, unless you're tracking a lot of VO/podcasts or something. If you record a lot of bands, though, it can be of benefit to build small closet-sized iso booths for amps. And I agree with Tbone81 about gobos. Gobos are your friends.
Post by christophert on Nov 2, 2021 21:00:36 GMT -6
I operated a studio for about 6 years working this way. At first frightening, but then I learned to love it.
More immediacy and connection with the artists / really makes you be aware of mic placement / very enjoyable for the artists / you are on the headphone sends with everyone else / and I love the committal to process - no second guessing. One learns to be fearless - and really on your game. Did many awesome albums during that period.
The only negative is, it is a little exhausting being immersed in so much volume all day long....
Post by EmRR on Nov 3, 2021 6:18:12 GMT -6
My first 3-4 years were in one room. I had amp iso boxes in another room but always drums and people with me. No way to hear anything until playback, unless you wanted to deafen with headphones. Kinda like doing monitors from beside a stage, really.
Actually, I did Avett Bros Third Gleam in one of their personal studio one room areas, I was sitting less than 10 feet from them with an imac and external drive. Similar deal on Four Thieves Gone, but that was ADAT’s. That also had a number of other people just sitting around.
Post by drbill on Nov 3, 2021 9:49:13 GMT -6
I've worked that way for way over a decade - and I love the communication and creativity it brings. But there are a couple of things I've learned I never want to record in that type of situation again - a Brass section, and Drums. Those are both no go for me in that type of environment. I do love working that way though.
Post by Tbone81 on Nov 3, 2021 10:23:02 GMT -6
Thank you all for the inspiration and encouragement. One thing I’m thinking through is where to put the mixing desk and speakers. I hear common guidance is about a third from the wall, but that results in facing me away from the band. If I put the desk facing the other way so I’m looking at the band, it would result in me sitting pretty close to the back wall, is that going to be a problem? I would consider building some gobos and arraigning them similar to an ASC Attack Wall. Then I’d heavily treat the back wall. 2-3ft of floor to ceiling insulation (like roxul safe n sound) would make a killer bass trap and really help your monitoring. Maybe cover it with wood slats to retain a more natural sound. With your back about 12” from the back wall you’d still have quite a bit of space in the room for the band. And you’d be far enough away from the wall for a little diffusion if you need/want it.
Post by christopher on Nov 3, 2021 10:40:11 GMT -6
Glad to see so many also enjoy the open room. I’ve been using a large space they setup facing the corner, which seemed sort of weird at first. The large space allows the sound to travel, monitors are aimed so there’s no direct rear wall reflection, it sounds great, like maybe 8 out of 10? That’s with $500 monitors. Since it’s the corner, just turn your head and there’s the band. They also setup a little table extension, so it’s like a sideways U in the corner. That way can turn around, stand or sit at that table and watch, or wheel the mixing chair over and take notes while facing the artist. Feels kind of natural. You’d want to be sure to have cans with excellent isolation for ear protection, 770 aren’t bad. If there is a noise canceling option out there, might be ideal.
I do think you can also decide to view it as a giant control room that can do tracking, and not a tracking room that can also do mixing. I’ve had drums in a control room before, when I was chasing a certain tone that the vocal booth was too boxy for.., it was fun. There was plenty of room. Made me realize the control room shouldn’t sacrifice to give the artist more room, they can make do
Post by Omicron9 on Nov 3, 2021 10:50:39 GMT -6
Greetings.
First all, +1 on the preceding posts re: acoustic treatment and related things.
I've built two one-room studios and currently work out of the 2nd one. One thing that is really key for me: a machine room. I track classical solo and chamber-sized groups; all acoustic. So there can't be any DAW noise (fans mostly). Both studios have small storage closets. I've repurposed those as machine rooms; in other words, I have a large rack with all the gear including the DAW. I run snakes out into the live room and have long USB extension cables and VGA cables (both with repeaters; works great) that also run out to the live room. That way I have a computer video monitor, keyboard, mouse, etc. Mics connect with snakes. The headphone amps are in the closet and one of the snakes feeds headphones. I don't do any mixing here; it's all just tracking so I don't have a board nor big monitors.
I have a solid-core door on the "machine room." And lots of weather sealing around it. It's a nice tight fit and keeps everything quiet.
This setup works perfectly for me. And no extraneous DAW noise!
Just a thought if you're doing quiet live mic'ing. Good luck with your build and please post some pics in the Studio Build subforum!
Regards, -09
Post by drbill on Nov 3, 2021 13:07:52 GMT -6
Yes, YES, YESSSSS!!!!! ^^^^^^^^^^^^^^^^^^
Would not consider a one room setup again without a machine room.
Post by the other mark williams on Nov 3, 2021 14:54:17 GMT -6
Greetings. First all, +1 on the preceding posts re: acoustic treatment and related things. I've built two one-room studios and currently work out of the 2nd one. One thing that is really key for me: a machine room. I track classical solo and chamber-sized groups; all acoustic. So there can't be any DAW noise (fans mostly). Both studios have small storage closets. I've repurposed those as machine rooms; in other words, I have a large rack with all the gear including the DAW. I run snakes out into the live room and have long USB extension cables and VGA cables (both with repeaters; works great) that also run out to the live room. That way I have a computer video monitor, keyboard, mouse, etc. Mics connect with snakes. The headphone amps are in the closet and one of the snakes feeds headphones. I don't do any mixing here; it's all just tracking so I don't have a board nor big monitors. I have a solid-core door on the "machine room." And lots of weather sealing around it. It's a nice tight fit and keeps everything quiet. This setup works perfectly for me. And no extraneous DAW noise! Just a thought if you're doing quiet live mic'ing. Good luck with your build and please post some pics in the Studio Build subforum! Regards, -09 How big are your closet machine rooms, 09? Any air circulation there? How hot does it get inside the closet?
Post by javamad on Nov 4, 2021 3:45:45 GMT -6
I have a single room studio with a small back room that doubles as kitchen/storage and ad hoc vocal/iso booth.
I only use it for vocals if I need absolute silence or the artist prefers to be alone. It was easy enough to run a cable or two through the wall.
I have a 2020 iMac that does ocasionally have the fans come on but since I upgraded from a mid 2012 MBP that had fans running all the time I am very happy with the studio noise floor right now :-)
I decided to go single room as the total space I have is 8m x 5.5m and while I could have made a control room and live room … both would have been pretty small.
I like being in the room with the artists
On the way in I don’t EQ because I can’t get isolation enough to make decisions. I have certainly had to learn good mic placement so that when we do a test recording and play it back its pretty much what we are looking for.
Bleed in this small space is an issue … especially when you have drums & violin in the same small space :-) … that one wss a challenge but we managed with a ton of gobos…
Post by Omicron9 on Nov 4, 2021 6:39:43 GMT -6
Greetings. First all, +1 on the preceding posts re: acoustic treatment and related things. I've built two one-room studios and currently work out of the 2nd one. One thing that is really key for me: a machine room. I track classical solo and chamber-sized groups; all acoustic. So there can't be any DAW noise (fans mostly). Both studios have small storage closets. I've repurposed those as machine rooms; in other words, I have a large rack with all the gear including the DAW. I run snakes out into the live room and have long USB extension cables and VGA cables (both with repeaters; works great) that also run out to the live room. That way I have a computer video monitor, keyboard, mouse, etc. Mics connect with snakes. The headphone amps are in the closet and one of the snakes feeds headphones. I don't do any mixing here; it's all just tracking so I don't have a board nor big monitors. I have a solid-core door on the "machine room." And lots of weather sealing around it. It's a nice tight fit and keeps everything quiet. This setup works perfectly for me. And no extraneous DAW noise! Just a thought if you're doing quiet live mic'ing. Good luck with your build and please post some pics in the Studio Build subforum! Regards, -09 How big are your closet machine rooms, 09? Any air circulation there? How hot does it get inside the closet? Hi, Mark.... Both are walk-in size. The current one is maybe 10' square. No air circulation, but it doesn't get hot in there. Warmer than the live room, yes; but never hot. If there was no air circulation/ventilation and it did get hot, I could open the door during breaks, but that's never been an issue. Regards, -09
Post by notneeson on Nov 4, 2021 15:26:34 GMT -6
My little local spot is a one room joint, although we do have an adjacent closet that we stick gobos and amps in and use as an iso booth (sorta, it's not totally isolated).
I agree that tracking drums this way is challenging.
Because this is my budget spot, people are always trying to cram in a lot of songs on a tracking day and it gets in the way of optimizing the drum sounds since you have to take time to stop, listen, and adjust— no tweaking on the fly like in a separate control room.
House drum kit helps since we kind of know what to expect. But I am so much happier tracking at the bigger rooms I have access to.
About the machine closet, we have a compromise— I bought a sort of whisper rack on craigslist and it has been sufficient for keeping fan nose etc. out of the capture. It does get hot in there though.
PS, I have also been doing a few projects at a lovely spot where the live room is upstairs from the control room and, well, that's weird in it's own way— working without sight lines.
Post by drbill on Nov 5, 2021 10:15:55 GMT -6
Greetings. First all, +1 on the preceding posts re: acoustic treatment and related things. I've built two one-room studios and currently work out of the 2nd one. One thing that is really key for me: a machine room. I track classical solo and chamber-sized groups; all acoustic. So there can't be any DAW noise (fans mostly). Both studios have small storage closets. I've repurposed those as machine rooms; in other words, I have a large rack with all the gear including the DAW. I run snakes out into the live room and have long USB extension cables and VGA cables (both with repeaters; works great) that also run out to the live room. That way I have a computer video monitor, keyboard, mouse, etc. Mics connect with snakes. The headphone amps are in the closet and one of the snakes feeds headphones. I don't do any mixing here; it's all just tracking so I don't have a board nor big monitors. I have a solid-core door on the "machine room." And lots of weather sealing around it. It's a nice tight fit and keeps everything quiet. This setup works perfectly for me. And no extraneous DAW noise! Just a thought if you're doing quiet live mic'ing. Good luck with your build and please post some pics in the Studio Build subforum! Regards, -09 How big are your closet machine rooms, 09? Any air circulation there? How hot does it get inside the closet? For me : 5' wide X 6' deep X 10' height No circulation naturally. And it gets unbelievably hot. I put a dedicated mini-split system in there, over spec'd, and it can barely keep up in the summer. (External wall, South / West facing). But worth every penny, and all the effort. Even in the winter with snow on the ground, the AC is on. The only gear in there is stuff with fans. (1) Power Mac tower w/ 4 internal SSD HD's, 4-6 external drives, 8 16 channel AVID interfaces (all of em loud, all of em hot), and a Grace m905 monitor controller box. (Located there for wiring convenience, not because it's loud or gets hot). Even in the winter with the ambient room temp in the upper 50's in the AM, that room will hit 90 and stuff (mostly the computer) will start acting sketchy by mid-afternoon with outside temps in the 30-40's if the mini-split is not on and set to 64 degrees. It easily hits 90 to mid 90's without AC. Even with studio being a comfortable 60-ish. It's mandatory for me.
Post by Ward on Nov 6, 2021 16:10:18 GMT -6
Considering the size of the space, you have enough room for an ideal control room (23'L 17'W and 10'H) And have a decent booth and machine room, side by side. A short consult with Jeff Hedback would help you plenty! Also, Johnkenn, should we have this thread in the 'Studio Build' section? Just a suggestion as it's an awesome sub-forum and a great resrouce for all these ideas and discussions.
Post by Guitar on Nov 8, 2021 13:26:23 GMT -6
Nearly everything I've ever done has been in one room. You'll get the hang of it. Bleed between instruments seems to be the big deal, and using gobos and similar things to keep some separation.
If you get a super loud guitar based band that can be somewhat of a problem. I was reading some techniques I'd like to try. You can line the guitar players up in a line beside the drummer, and have the figure 8 mics on the drum kit, the null pointing at the guitar/bass amps. Something I never got to try but would like to. Obviously gobos will help, and maybe at least some amount of respect you can establish to get people to be reasonable with their amplifier volume. I know there are some prima donnas out there though, hard to record.
You can also consider something like direct amp head outputs to DI / Load boxes, to keep the amps out of the room, no speaker sound. If people are happy enough to play in headphones.
But a reasonable group, with reasonable separation, will sound brilliant when recorded together this way. It's a beautiful sound, like some classic records. Of course, the build-a-song overdub method will work just as well.
Just do your homework with drum mics, etc, so you can be reasonably sure of your capture.
And you'll want to record with exclusively solid state drives. A Hard Disk Drive (spinner) will have data dropuouts from loud enough volumes and ruin your session. This happened to me once, and basically I lost the opportunity to record the band, that never came again.
Post by notneeson on Nov 8, 2021 13:46:36 GMT -6
Nearly everything I've ever done has been in one room. You'll get the hang of it. Bleed between instruments seems to be the big deal, and using gobos and similar things to keep some separation. If you get a super loud guitar based band that can be somewhat of a problem. I was reading some techniques I'd like to try. You can line the guitar players up in a line beside the drummer, and have the figure 8 mics on the drum kit, the null pointing at the guitar/bass amps. Something I never got to try but would like to. Obviously gobos will help, and maybe at least some amount of respect you can establish to get people to be reasonable with their amplifier volume. I know there are some prima donnas out there though, hard to record. You can also consider something like direct amp head outputs to DI / Load boxes, to keep the amps out of the room, no speaker sound. If people are happy enough to play in headphones. But a reasonable group, with reasonable separation, will sound brilliant when recorded together this way. It's a beautiful sound, like some classic records. Of course, the build-a-song overdub method will work just as well. Just do your homework with drum mics, etc, so you can be reasonably sure of your capture. And you'll want to record with exclusively solid state drives. A Hard Disk Drive (spinner) will have data dropuouts from loud enough volumes and ruin your session. This happened to me once, and basically I lost the opportunity to record the band, that never came again. In particular the bass amp placement/bleed amount can be extremely critical since you will likely have the most phase interaction there. Some folks like to keep the bass rig very close to the drums for this reason, but that potentially comes with other challenges. Add to which, you will need to take time to quiet the room and listen to the phase interactions between the bass and drum mics really critically since you're going to be living with them. Same can be true of guitar, it's just that low end is the hardest to trap with just gobos etc. it will bleed into everything. Most of the time I just take a DI and we either reamp later or use a Sim as needed. Once in a while this pisses off the bass player, but mostly they're a chill bunch.
Post by EmRR on Nov 8, 2021 16:15:03 GMT -6
Plenty of rooms get overwhelmed with volume, and everything becomes bleed. That seems to define possibilities more than anything else.
Post by drbill on Nov 8, 2021 18:46:22 GMT -6
Plenty of rooms get overwhelmed with volume, and everything becomes bleed. That seems to define possibilities more than anything else. Yup. ^^^^^^^^^^^^^^^ Loud band, huge room - workable. Loud band, too small a room - makes for a horrible mess. I've even had a 25 person black gospel choir of pro (LOUD) singers overwhelm a decent sized room before that was OK for moderate volume bands. They were pretty much as loud as a band....  . And the reflections were not good. The room dictates how loud things can be - not the other way around. And really, being realistic about the room, and deciding what you will and what you will not record is the secret to one-room studios.
