Post by NoFilterChuck on Aug 13, 2017 22:14:16 GMT -6
Hey folks, I finally got some mixes to show. You may or may not know about my youtube channel, where I've been posting videos of the band I play with at this SDA service here in Brooklyn. The AV team records the service using a DANTE system with 40 tracks (Allen & Heath, and an X32 so we have headphone mixes) for the purpose of live streaming on the internet, and the organist usually captures it to Cubase so he can mix it. Usually, I'll just take his mix and sync it with the Zoom Q2n footage I capture of us playing. Anyway, he gave me the stems to a couple of the services along with screenshots of his mix settings, and I think I finally have something worth listening to! If they're cool, then they'll end up on the channel in the next couple weeks. here are the two that I mixed, and also here is one of the organist's mixes for reference. www.dropbox.com/s/eirieu6fjuns47s/KBT%2005-06-2017%20Chuck%20Mix.wav?dl=0www.dropbox.com/s/zo4daixfyffr9cr/KBT%208-5-2017%20Chuck%20Mix.wav?dl=0Fun fact, the only plugin I used on all of the tracks was MetricHalo ChannelStrip v3 :-) and the occasional X-Noise on the bass.
Post by svart on Aug 14, 2017 8:17:09 GMT -6
First link is 404.
Second link critique: A bit muddy, the kick and bass interact in a way that makes one or the other jump out too much at certain times. I think the wurly/rhodes needs to be more airy and spread in the mix. Seems like the main body of all the instruments fall down the middle and get congested. Toms need to be up in the mix or have more top end. Hats need a narrow cut somewhere in that clank region. Piano needs more top end as it gets lost in the mix a lot.
That's just my initial impressions. Overall things just get lost under the sax when I think they could all have more clarity without being overpowering.
Post by NoFilterChuck on Aug 14, 2017 10:01:51 GMT -6
Fixed the first link.
I'll listen for those things and see if I can fix 'em.
Post by brucerothwell on Aug 14, 2017 13:16:33 GMT -6
Bass is too muddy, and over powers the mix, even on the cheap lacking-low-end headphones here at work.
The organ could be stronger.
The drum components sound generally good, but that's just it... it doesn't sound like a kit. I would try to get more of a "room sound" going for the kit, and also bring the toms in a bit -- they are too wide for my taste.
Overall, the mix doesn't gel.
Post by NoFilterChuck on Aug 14, 2017 16:56:25 GMT -6
The drum components sound generally good, but that's just it... it doesn't sound like a kit. I would try to get more of a "room sound" going for the kit, and also bring the toms in a bit -- they are too wide for my taste. drums never have a room sound in Gospel tho. Not sure what genre you normally listen to, but just listen to the mix glen had in the youtube video.
Post by M57 on Aug 14, 2017 17:10:46 GMT -6
I think the mix sounded very good in the video. I particularly loved the soft sparkle of the cymbals. In fact, it's very close to what I consider to be the holy grail of overhead sound for contemporary jazz. It might be tempting to bring out the synth/organ ..and even more, the guitar - but honestly, I was not impressed (or confused) by some of the voicings they were playing at times. Where I would normally expect to hear cleaner altered/lydb7 substitutions or voicings in 4ths, etc. I heard mud. More politely - I thought the levels were well-considered. To be fair, getting a keyboard player and guitarist to comp changes together musically requires the best of players. Maybe the bottom end - both Kick and Bass could have been pushed a bit, but I'm writing this hours after listening to the video.
Post by NoFilterChuck on Aug 14, 2017 17:22:19 GMT -6
I just want to add, for those listening to the youtube vid, since the service is about 3 hours long, Glen set up his mix to sound like how it sounds in the video without any automation. That's what I'm trying to do as well. So, trying to set up all the tracks in a "set-it-and-forget-it" template, and we just drag in the recorded tracks, and press "bounce" for whatever section we want a bounce of, be it Offering or Special Music, or Praise&Worship, or whatever.
So, again, an Automation-less mix is the goal here.
Post by mrholmes on Aug 15, 2017 8:12:03 GMT -6
My taste on the mixes:
Mix one:
Get that Kick drum under control, sounds too boomy for my taste, cut with a sharp Q factor between 200-300 Hz. Lower the level smooth the transient... Overall the snare drum has no height, no room, for my taste the drums need a drum room and you may put an FX verb on the snare? I would could out some 100 Hz on the snare to free the space in the low end for low end instruments.
The whole thing does not sounds like tracked in a room I also would try the 7H reverb. I miss tons of ERs.
Overall listen to some Fourpaly records from the 80s that should be your reference.
Mix two sounds very harsh in the top end special on the HH tsss tsss...NG to my ears. I like the sanre way better than in mix one. Also the saxphone has some saturation thing going on that makes it hard to listen to??? The sax could be more 3D to my taste, use some delays to get some width and some reverb for depth.
No Automatin, doubt that it will work for every song, every song needs some special treatmeant. A Ballad is something diffrent from an up tempo song etc....
My 2 cents Cheers.
Post by jazznoise on Aug 16, 2017 5:24:11 GMT -6
The first one isn't bad for the style, I'd consider cutting around 5Khz in the overheads and taking out a little bit of the 180Hz in the kick. Is there supporting snare and tom mics? They could do with a little more body.
Something funny about the sax sits but maybe it's just it's the only thing getting that much reverb. There's some midrange interaction 700-900 between it and the keys, try soloing them and seeing if you can use something notching to get some better seperation.
Second mix: Low shelf on the bass around 150Hz and boost the fundamental of the kick, the sensation with that sort of slap thing is that the bass's fundamental implies more low end in the bass than it actually has. Same issue with the brass and keys, spot mics for snare and toms. There's some bright FM string sound on the right that's not doing anything for me. Not sure how you'll fix it, but it's not adding much musical to my ears.
Feel like a dick listing of that much but it's small stuff - 2dB changes here and there. Tell the keys player to sell his DX7 though.
Post by svart on Aug 16, 2017 8:46:33 GMT -6
I didn't know that the video wasn't one of the mixes in the links, so I didn't listen to it.
I think the video mix is much more like what I was imagining when I suggested my changes. It's much more clear and rich with the instruments being very distinct.
Post by NoFilterChuck on Aug 16, 2017 9:54:35 GMT -6
edit: released the mix video with Glen breaking down every channel in his cubase mix, so these files are no longer available.
Post by svart on Aug 16, 2017 9:56:53 GMT -6
just for fun, here are the stems for the 8/5/2017 mix. each mono file is about 38mb, so it's just the offering from the service, not the entire 3-hr service. www.dropbox.com/sh/8yzis6fgyeuxr2a/AAAJoTMdQ-8UnZgndAoVOX1Ua?dl=0 I'd be curious what you guys come up with, if anyone wants to take a crack at mixing it. I'm definitely looking at it as a learning experience!! Cool, I'll have a go at it.
Post by NoFilterChuck on Aug 16, 2017 9:57:53 GMT -6
I put glen's mix of that session in the post with the stems, fyi
Post by jeromemason on Aug 17, 2017 8:13:06 GMT -6
When I got started in this business I was 17, I'm 33 now, but back then I got hired a lot by local churches, choirs and concert venues to record and mix their big events and such. Your post kinda took me back in a nostalgic moment for a second there.
One thing that you might want to give some thought to is whether that's how it would sound sitting 10 rows back. It seems like everything is just slammed in my face and there's not a lot of dynamic movement. One way to create that with a recording like you have is with a basic hall that you would feed the each mic'd head/instrument into to get it having some depth, that'll let you pull back the faders on the spots/direct ins. Then, because the sax is carrying the melody I would feed that into the same room, and put a plate behind it, something like a 2.5s rolled up to about 400hz and slowly slide that up until the sax starts to feel like it's special. Doing all that will allow you to pull back some compression and the spot faders a bit.
Another thing I would do is if you can use a transient designer on his kick to bring out the sustain a bit it'll sound more natural. Those guys love to throw pillows and God knows what else in there, so using a TD will get those drums ringing a little which again will allow you to pull things back so your mix has more dynamic movement.
I normally don't do critiques, but it brought back a lot of nostalgia.
-Jerome
Post by NoFilterChuck on Aug 17, 2017 9:48:18 GMT -6
Post by jeromemason on Aug 17, 2017 14:20:03 GMT -6
Well, you can't expect everywhere to be Oceanway, but there's no rule book saying that you can't make it sound that way.
My point was to create yourself a realistic structure to pipe instruments into and then give the melody maker (horns) a little plate tucked back just to add another layer of depth.
Post by NoFilterChuck on Aug 17, 2017 22:05:46 GMT -6
Well, you can't expect everywhere to be Oceanway, but there's no rule book saying that you can't make it sound that way. I posted the stems in one of the earlier posts. I'm encouraging everyone who participated in this thread to take a crack at 'em. Let's see what kind of sounds everyone hears with their mix!
Post by NoFilterChuck on Aug 19, 2017 16:20:20 GMT -6
svart did ya get a chance to put a mix together?
Post by svart on Aug 19, 2017 18:54:11 GMT -6
svart did ya get a chance to put a mix together? Gonna work on it tomorrow (Sunday) if that's cool
Post by Johnkenn on Aug 20, 2017 18:37:48 GMT -6
Hey folks, I finally got some mixes to show. You may or may not know about my youtube channel, where I've been posting videos of the band I play with at this SDA service here in Brooklyn. The AV team records the service using a DANTE system with 40 tracks (Allen & Heath, and an X32 so we have headphone mixes) for the purpose of live streaming on the internet, and the organist usually captures it to Cubase so he can mix it. Usually, I'll just take his mix and sync it with the Zoom Q2n footage I capture of us playing. Anyway, he gave me the stems to a couple of the services along with screenshots of his mix settings, and I think I finally have something worth listening to! If they're cool, then they'll end up on the channel in the next couple weeks. here are the two that I mixed, and also here is one of the organist's mixes for reference. www.dropbox.com/s/eirieu6fjuns47s/KBT%2005-06-2017%20Chuck%20Mix.wav?dl=0www.dropbox.com/s/zo4daixfyffr9cr/KBT%208-5-2017%20Chuck%20Mix.wav?dl=0Fun fact, the only plugin I used on all of the tracks was MetricHalo ChannelStrip v3 :-) and the occasional X-Noise on the bass. Awesome as usual. The first thing I notice is I want to hear a lot more bottom on the bass.
Post by svart on Aug 22, 2017 8:55:55 GMT -6
OK, here's mine. Took about an hour to bring in the tracks, do some minor EQing and leveling. I didn't do any editing or automation (it absolutely needs some though) other than pulling down the guitars in spots due to the hum of the guitar and the wild changes in it's level.. Otherwise, the raw tracks had some serious clipping happening in spots, while other tracks were ridiculously low in level.. However, the tones that were recorded were pretty good. www.theopiumdenproductions.com/RGO/ChuckMix2.mp3
Post by NoFilterChuck on Aug 23, 2017 11:37:19 GMT -6
no x-noise? your mix has some seriously loud buzzing happening. the bass track had a lot of buzz, if I remember. I had to x-noise it along with my sax channel.
Post by svart on Aug 23, 2017 14:08:43 GMT -6
no x-noise? your mix has some seriously loud buzzing happening. the bass track had a lot of buzz, if I remember. I had to x-noise it along with my sax channel. It was the guitar that had the serious buzzing. I just wanted to get a mix up, so no I didn't really do much editing and such.
Post by viciousbliss on Aug 23, 2017 16:02:09 GMT -6
The mix in the video is great. The two dropbox both have some noticeable issues. Not sure in technical terms how to address them all. I have a pretty good idea how I'd tackle it, so I may try mixing your files. Oh, and that Metric Halo Channel Strip has some pretty serious issues.
Andy from Cytomic said the following about it:
"The Metric Halo CS3 EQ does look like exactly the noise of a 32-bit float DF1 biquad, if green means around -60 to -70 dB then I'm very confident this is the cause. Regardless of if I'm exactly right or not you really do have to ask yourself if you want low frequency rumble added to your mix every time you do a high pass filter to remove low frequency rumble!"
I've done the tests myself and it does add low rumble after subtracting low rumble. Pro Tools' EQ3 or whatever it's called does the same thing. It could be problematic for you. There's gotta be an inexpensive channel strip that's just as good or better. Bx_Console is kinda pricey, but maybe you could try something from Hornet, Stillwell, or Sknote. Waves sells a lot of stuff for $29 these days too. Gear/Software definitely does matter, despite the mantra some people preach about only needing stock plugins. You really only used the Metric Halo and X-Noise? I'll 2nd the Seventh Heaven recommendation. The regular one is great and not expensive. Seventh Heaven for me is the only ITB reverb I'll use. Just kills anything else when I load up another reverb for comparison. The pro version is worthwhile, especially since they added the non-linear algos. You may also want to try a tape plugin, like Hornet Tape or McDsp Analog Channel. Waves NLS can also do a lot for making a mix cohesive. I'm also starting to take a liking to Sknote Disto. You could also try resampling the files to 88 or 96 in Audacity and mixing at a higher sample rate if you're mixing at 44/48. Audacity's SRC is among the best nowadays, just set it to the highest quality and use the dither.
Post by NoFilterChuck on Aug 23, 2017 22:52:53 GMT -6
Andy from Cytomic said the following about it: "The Metric Halo CS3 EQ does look like exactly the noise of a 32-bit float DF1 biquad, if green means around -60 to -70 dB then I'm very confident this is the cause. Regardless of if I'm exactly right or not you really do have to ask yourself if you want low frequency rumble added to your mix every time you do a high pass filter to remove low frequency rumble!" For everyone curious about this, Andy from Cytomic explains how to test for it here: www.gearslutz.com/board/ableton-live/126945-ableton-live-sound-quality-5.htmlI did the test with Logic's channel EQ and Test Oscillator plugin, and couldn't get anything to appear. So, maybe Logic's EQ is cool...
