Post by maq3396 on Mar 26, 2017 23:32:55 GMT -6
Looking for opinions please...
It almost hurts to write this as I am demonstrating how naive I am regarding certain parts of audio.
I have built/purchased a number of preamps, eq, compressors and mics over the last few years and have had a great time doing it.
Currently these run through an inexpensive Mackie mixer then to monitors (yes...usually live vocals)
When run into a DAW it is an older version of PT.
The audio interface I have, for me, has a non-intuitive interface and drivers are not available for Windows 10. THe computer is about to be upgraded.
I would like to be able to interface the analog gear with some of the plugins on a DAW and also have the opportunity to record.
I have read where possible but would still appreciate input from this group as the information out there is vast.
Is the best way to do this mic - analog - interface - daw OR mic - analog - mixer - interface - daw OR mic - mixer - analog via send - interface - daw
Or something else?
I am content to use the preamps that are already part of my system so these do not need to be part of the interface or mixer (although it seems both tend to have them) but am open to recommendations as to how the sequence should be set up and recommendations for interface/mixer or whatever is required. Ideally like to keep budget under $2000-2500 but also appreciate that you get what you pay for.
Please bear with me on this as this pursuit is a hobby and unfortunately I am not immersed in this world like many of the experts on this forum.
Thanks in advance Mac
Post by NoFilterChuck on Mar 27, 2017 1:17:02 GMT -6
$2k-$2500 is a pretty big budget to replace your existing interface. let us know what type of ports your new computer will have and we'll be able to tell you if you should go with a Motu Tbolt interface, or something USB-based. or maybe keep what you have and buy a light-pipe converter. lots of options..
Post by maq3396 on Mar 27, 2017 5:31:03 GMT -6
The budget is set at that level to possibly accommodate a mixer as well. Lower is better! The interface will have to go as it is not win 10 oriented.
Low latency is important so the new computer will have USB 3 and I suspect an addn-on Thunderbolt would be fairly easy to install.
Post by kcatthedog on Mar 27, 2017 5:36:34 GMT -6
How many signals max will you need to convert at one time , less than 8, less than 16, less than 24 ?
Post by Johnkenn on Mar 27, 2017 7:19:32 GMT -6
Post by svart on Mar 27, 2017 7:25:46 GMT -6
As much of an analog guy I am, I'd say you'd be best served with a good interface and a preamp patchbay first, then a summing mixer with inserts (going to another patchbay) for the mixdown stage. Once you get all this working, then decide if you really need a mixer later.
For me, since I'm doing this stuff semi-professionally, I've found that a mixer is great for me, but I use it mostly to work with stems and submixes for guitars, bass, vocals and effects. For drums I use separate channels and then sum through a bus.
Post by kcatthedog on Mar 27, 2017 9:22:08 GMT -6
btw there is a black face Apollo 16 on gearlslutz classified.
Post by maq3396 on Mar 27, 2017 11:50:12 GMT -6
Thanks for the rapid answers!
My inputs will likely be a Max of 4 microphones plus their individual preamp/eq/comp
Post by ChaseUTB on Mar 27, 2017 13:57:14 GMT -6
Thanks for the rapid answers! My inputs will likely be a Max of 4 microphones plus their individual preamp/eq/comp If the preamp Eq and Comp are analog HW and standalone 19" or 500 series this would be great for AD/DA .... www.sweetwater.com/store/detail/Element46?adpos=1o3&creative=55225946401&device=m&matchtype=&network=g&product_id=Element46&gclid=CLaGzby199ICFYk2gQodGOcNpQYou would then run your 4 mic chains into the analog line level inputs of this interface. You can plug in your speakers/ monitors ( pro audio term for speakers ) into the L R main out... Your recording chain would be this Mic-> preamp -> eq -> comp -> interface line level input Alternatively This would be better for using your HW for mixing and recording.. it has analog outputs on the interface to feed your HW eq and comps.... Plus you have more room to grow with this interface...$849 www.sweetwater.com/store/detail/828x?adpos=1o1&creative=55225946401&device=m&matchtype=&network=g&product_id=828x&gclid=CJ_RxoK399ICFdyCswod0zoLiQRecording Chain Mic-> preamp-> eq -> comp-> line level input Plug monitors into Main Out L R To mix with your HW eq and comps: ( without PatchBay or console/ mixing board) 1. you would have to unplug your preamp output from the eq line input. 2. you plugin the trs to xlr male cable or trs to trs balanced 1/4" ( depends on gear connectors ) from the line level Digital to analog output from the interface to plug into the eq's Xlr Female line level input... 3. If you want to use your compressor after the eq leave setup from the recording chain I posted above. ( eq outputs would still feed comp inputs ) 4. Setup DAW with correct outputs to send signal to mixing chain. 5. In pro Tools to use HW inserts ( hardware like a plugin ) your outputs have to return to the same inputs. For ex your eq and comp chain is input 5, follow the above steps and use line output 5 to send ( with cable ) audio to HW. 6. Under inserts tab when you click ( to insert a plugin ) you will see a section at the bottom called I/o select Insert 5 and then right click and rename that to the chain ex: 1073eq+1176 6. Likewise you could setup a return audio track in Pro Tools with line input 5 and record the Analog HW eq and compressed signal. This may be easier for you and you should not have a problem with audio recording not in time with the rest of the audio. If it sounds a little off it probably is, and you can zoom in and check the waveforms...
Post by b1 on Mar 28, 2017 6:20:33 GMT -6
Post by maq3396 on Mar 28, 2017 18:48:45 GMT -6
Great info! THanks
The MOTU looks great, particularly for the price,
The Apollo and RME look appealing as well but at more of a premium.
As does the Soundcraft.
If you pick up a board like the Soundcraft does one still need an interface or is that, more or less, built in?
Likewise, does a board, when added to an interface, add anything more than physical sliders and knobs?
Thanks again and sorry for the newbiness of this
Cheers Mac
Post by b1 on Mar 28, 2017 19:04:42 GMT -6
If you pick up a board like the Soundcraft does one still need an interface or is that, more or less, built in? Likewise, does a board, when added to an interface, add anything more than physical sliders and knobs? Thanks again and sorry for the newbiness of this Cheers Mac The Soundcraft Signature 22 MTK does 24 channels in & 22 out via discrete channels over USB... I explain it a little more in this thread: realgearonline.com/thread/6621/soundcraft-mtk-22EDIT: BTW, it's a Hybrid Console. You can use it as an interface in the Studio or as an analog standalone Live Mixer. You can send your VST/VSTi's out the mains during a live show, or route them for recording... or both.
Post by ericn on Mar 28, 2017 19:43:22 GMT -6
All in ones always look good, but in the long term you find that their compromises really weren't worth it in the long run. Start with a basic well thought out interface, then see what your real needs are.
Post by johneppstein on Mar 28, 2017 21:32:24 GMT -6
Looking for opinions please... It almost hurts to write this as I am demonstrating how naive I am regarding certain parts of audio. I have built/purchased a number of preamps, eq, compressors and mics over the last few years and have had a great time doing it. Currently these run through an inexpensive Mackie mixer then to monitors (yes...usually live vocals) When run into a DAW it is an older version of PT. The audio interface I have, for me, has a non-intuitive interface and drivers are not available for Windows 10. THe computer is about to be upgraded. I would like to be able to interface the analog gear with some of the plugins on a DAW and also have the opportunity to record. I have read where possible but would still appreciate input from this group as the information out there is vast. Is the best way to do this mic - analog - interface - daw OR mic - analog - mixer - interface - daw OR mic - mixer - analog via send - interface - daw Or something else? I am content to use the preamps that are already part of my system so these do not need to be part of the interface or mixer (although it seems both tend to have them) but am open to recommendations as to how the sequence should be set up and recommendations for interface/mixer or whatever is required. Ideally like to keep budget under $2000-2500 but also appreciate that you get what you pay for. Please bear with me on this as this pursuit is a hobby and unfortunately I am not immersed in this world like many of the experts on this forum. Thanks in advance Mac Well, one thing I can tell you right off the bat (and I may have more to say later) is this - you do NOT want a crappy Mackie mixer (and Mackie mixers are crappy by definition, I've owned too many of them) in your recording chain. In the musicians' tracking monitor chain, maybe. In your recording or control room monitor chain, no way.
Post by johneppstein on Mar 28, 2017 21:46:48 GMT -6
If you pick up a board like the Soundcraft does one still need an interface or is that, more or less, built in? Likewise, does a board, when added to an interface, add anything more than physical sliders and knobs? Thanks again and sorry for the newbiness of this Cheers Mac The Soundcraft Signature 22 MTK does 24 channels in & 22 out via discrete channels over USB... I explain it a little more in this thread: realgearonline.com/thread/6621/soundcraft-mtk-22EDIT: BTW, it's a Hybrid Console. You can use it as an interface in the Studio or as an analog standalone Live Mixer. You can send your VST/VSTi's out the mains during a live show, or route them for recording... or both. I would not accept the clocking rate limitations for my recording interface in this day and age. I also would not want an extra set of A/D-D/A conversion inserted in my analog chain. And after dealing with Soundcraft's "service" department for my DC2020 I wouldn't trust their service once the product is no longer current.
Post by johneppstein on Mar 28, 2017 21:53:32 GMT -6
If you pick up a board like the Soundcraft does one still need an interface or is that, more or less, built in? Likewise, does a board, when added to an interface, add anything more than physical sliders and knobs? Thanks again and sorry for the newbiness of this Cheers Mac The Soundcraft Signature 22 MTK does 24 channels in & 22 out via discrete channels over USB... I explain it a little more in this thread: realgearonline.com/thread/6621/soundcraft-mtk-22EDIT: BTW, it's a Hybrid Console. You can use it as an interface in the Studio or as an analog standalone Live Mixer. You can send your VST/VSTi's out the mains during a live show, or route them for recording... or both. If I'm not mistaken, their conversion limits you to 44.1/48 kHz sampling rate. That's a HUGE inconvenience these days when most plugins run best at 96. I would also not want my conversion to be married to my mixer. And I wouldn't want my audio always running through their converters, which it must if you're to apply VSTs through the board. Also, if you have quality outboard preamps and EQ would you REALLY want to be forced to run them through the analog stages of a prosumer level mixer? I wouldn't. You'd be sacrificing all the headroom advantage of your outboard gear. And despite all of Harman's hoopla about "famous Ghost preamps", I'd want to at least see schematics to see what kinda of circuitry they use. I am not at all convinced that the "ghost preamps" in their prosumer boards are the same circuit used in their top of the line consoles, no matter what the PR weasels claim. And IIRC the first Soundcraft Ghosts were actually prosumer/medium club consoles, not top of the line. And at any rate, they were reinforcement consoles, not recording desks.
Post by javamad on Mar 29, 2017 5:42:10 GMT -6
All in ones always look good, but in the long term you find that their compromises really weren't worth it in the long run. Start with a basic well thought out interface, then see what your real needs are. All in ones degrade at the rate of the fastest degrading component ... usually electronics and technical standards .. so if you get an interface with preamps .. no matter how good they are, when the sample rates and software move on (and they will, quite fast) you will be left with a box nobody wants... not even you! I have 2 x Apollo 8's .. but I'm not counting on using the 4 preamps in each one in 10 years time .. I work in IT and I have this assimilated :-) I currently need more channels of conversion I will be getting an Antelope Orion 32+(no preamps, just converters) ... but I would not buy the Antelope Goliath(converters and 16 pre's) without mentally writing off the 16 mic pre's in the next 5 years (or whatever the rate of change is with conversion) On the other hand, my RND Portico 5024 preamps and my Chandler Zener Limiter can be left in my will to my kids :-)
Post by b1 on Mar 29, 2017 6:45:22 GMT -6
Well, the OP could take his $2.5k budget and get nearly the same setup as the 22 MTK ($800), with an added benefit or two. Most people who have heard or used this new Soundcraft board have been impressed with the bang for buck. I've conversed with one of the engineers from the Signature project who says if he could have taken anything from that project, it would have been the 22 MTK, and I know what he means now. After I bought it, my Sweetwater Rep said he was impressed with it; which he didn't hear it before I bought it, but after I commented on it he gave it a whirl. I, as a user would absolutely buy it again if I needed to. Most owners love the quality and price to performance ratio and would buy it again... Yeah, I would have paid more, for more on this desk and 32 channels instead of 22/24, but it is what it is and delivers what it delivers from Harman's expertise. Soundcraft delivered on this board, IMO. Any great engineer could make music with it. Of the features that are there, nothing is lacking. These 16 Ghost Preamps are great. The Sapphire EQ is great (4 band with two sweepable mids). The DBX limiters are great. The dual engine Lexicon FX are great. The GB routing is great. All from previous SC Consoles, hence the "signature" name. This ain't a Mackie mixer. Nothing else out there delivers these features for 800 bucks... I've looked. If I do sound design, I use a 192k setup. To me, 24/48k is fine for everyday use. If you can't make competitive music on this desk, the desk is not what's holding you back. The 22 MTK is my everyday rig now. I can track all of the features on this console at 192k into another system and mix that in the box for vid or whatever, with a control surface. The sound is inspirational. There is nothing holding me back here. I've written, arranged, and rehearsed nearly 2 albums worth of material on this desk in the 10 months I've used the 22 MTK. I've put the last 2 albums on hold, because this desk's inspirational sound has made way for the new stuff. IMO, there are no "album filler" material in the bunch. ericn, you didn't give the OP any recommendations after you knocked an "all in one" rig. I'm confident the OP would be satisfied with the 22 MTK. I think he may find he rarely uses his outboard gear, but rather uses it because he has it. For a live setup, this is a no brainer. Haul all of the outboard gear around if you want to... I'm too old to deal with the mess. My 2 ton Fender Amp will stay put.
Post by ericn on Mar 29, 2017 7:42:15 GMT -6
Well, the OP could take his $2.5k budget and get nearly the same setup as the 22 MTK ($800), with an added benefit or two. Most people who have heard or used this new Soundcraft board have been impressed with the bang for buck. I've conversed with one of the engineers from the Signature project who says if he could have taken anything from that project, it would have been the 22 MTK, and I know what he means now. After I bought it, my Sweetwater Rep said he was impressed with it; which he didn't hear it before I bought it, but after I commented on it he gave it a whirl. I, as a user would absolutely buy it again if I needed to. Most owners love the quality and price to performance ratio and would buy it again... Yeah, I would have paid more, for more on this desk and 32 channels instead of 22/24, but it is what it is and delivers what it delivers from Harman's expertise. Soundcraft delivered on this board, IMO. Any great engineer could make music with it. Of the features that are there, nothing is lacking. These 16 Ghost Preamps are great. The Sapphire EQ is great (4 band with two sweepable mids). The DBX limiters are great. The dual engine Lexicon FX are great. The GB routing is great. All from previous SC Consoles, hence the "signature" name. This ain't a Mackie mixer. Nothing else out there delivers these features for 800 bucks... I've looked. If I do sound design, I use a 192k setup. To me, 24/48k is fine for everyday use. If you can't make competitive music on this desk, the desk is not what's holding you back. The 22 MTK is my everyday rig now. I can track all of the features on this console at 192k into another system and mix that in the box for vid or whatever, with a control surface. The sound is inspirational. There is nothing holding me back here. I've written, arranged, and rehearsed nearly 2 albums worth of material on this desk in the 10 months I've used the 22 MTK. I've put the last 2 albums on hold, because this desk's inspirational sound has made way for the new stuff. IMO, there are no "album filler" material in the bunch. ericn, you didn't give the OP any recommendations after you knocked an "all in one" rig. I'm confident the OP would be satisfied with the 22 MTK. I think he may find he rarely uses his outboard gear, but rather uses it because he has it. For a live setup, this is a no brainer. Haul all of the outboard gear around if you want to... I'm too old to deal with the mess. My 2 ton Fender Amp will stay put. Glad your happy, but I have seen to many go down this road before and find in the long run that these all in ones just don't live up to the hype. They are absolutely great for simple live use, but even then most will grab a digital board for recall and even more features. The hype, while not bad these new Soundcraft boards are nothing like a little delta or 200, funny how in the day nobody claimed the Price point Mackie killer Ghost's pres were anything special, and the pots don't feel anything like the Sapphyres I have used! Throw in the fact we are talking a Harman product, a company that has killed more decent products by lack of support than dead batteries, add in new owners well not a bet I'd make. As for not makeing a direct recommendation well here's a dirty little secret, these days they all pretty much will do the job, rather see him figure it out as he goes and he can also decide if he wants to jump into the deepend. You can make a decent sounding record these days with a cheap generic LDC and just about any interface so best to start simple learn the craft then move up. I haven't played with many interfaces lately since going RADAR except my little Audient and I don't recommend products I haven't used, I also don't recommend just because I like it unless I have used a bunch of the competing products, I find owner bias very dangerous.
Post by ericn on Mar 29, 2017 7:48:00 GMT -6
One other point a budget of $x is often better in the bank if you don't know what you want, till you know what you need. I know what I would do, but I'm not you! I have seen to many go broke in my gear pimp days spending their wad upfront and ending up with a great set up for someone else, not them. Better to start with the basics and figure it out from there.
Post by b1 on Mar 29, 2017 9:12:23 GMT -6
Yeah, I'm happy with it. You're contradicting yourself, ericn. Your advice is to get a basic interface and throw some money at making that work or try/buy competing products to find what you want... Buy a basic interface, just not this desk with more features... lol... nice. A lot of reverse hype in your posts.
Post by ericn on Mar 29, 2017 10:05:21 GMT -6
Yeah, I'm happy with it. You're contradicting yourself, ericn. Your advice is to get a basic interface and throw some money at making that work or try/buy competing products to find what you want... Buy a basic interface, just not this desk with more features... lol... nice. A lot of reverse hype in your posts. I'm saying start with the most basic set up, figure out what ones individual needs really are then grow. I also have to add John Eppstiens point about the danger of ending up with a mixer interface that is a victim of no longer being supported is also something I would fear. Honestly I would fear any Harman Semi Pro product that plugs into a computer, seen to many people burned ! I admit the feature list is attractive I can see it working for you but I have had to help way to many dig out of putting all their eggs in one basket before, I have had to win back clients who bought into Harman's interfaces before ( oh how the screwed the pooch with Lexicon) and that scares me big time ! I hate to say this but as much as I can't stand what. Behringer did as far as stealing others designs, in the last 10 years they have proven to be a much Better big company than Harman and seam to actually care about the customer ( god it hurts to say that)!
Post by b1 on Mar 29, 2017 10:52:26 GMT -6
If the OP is building his own gear, he's probably looking for more than a basic interface. I agree about gear generally moving up in quality from what it used to be. The 22 MTK doesn't disappoint. I was considering a modded Delta before I bought the 22 MTK. After using it for a while, I haven't given it a second thought. The Ghost Preamps are great everyday Pres. They sound good with everything I've thrown at them. Nothing holding you back from using outboard gear either... The Sapphire EQ is fantastic. Different designers did the Signature series. In my book, it's not your daddy's SC. It doesn't outperform everything on the planet, but it doesn't need to & doesn't hold me back either. I never went down the road of grabbing every hyped piece of gear out there. I adequately used what I had with any work-arounds needed. To me, it's about the sound, not the specs necessarily. The music has to work and the gear has to be decent, at the very least. I never got caught up in replacing gear because it was all the rage by consensus. Just make what you have work, as long as it SOUNDS good. This is definitely a winner Home/Project Studios. I'm not interested in producing for or pleasing anyone else, except listeners. I enjoy what I hear from it... But I could deliver a good competitive product to someone if I had to; no doubt. I appreciate Customer support on new software. I've never needed to ship any hardware out for service - doubt that I ever would do that anyway... If I can't fix it, I don't need it. If repairs are needed, it would get my modifications probably. Samsung has acquired Harman: news.harman.com/releases/samsung-electronics-to-acquire-harman-accelerating-growth-in-automotive-and-connected-technologiesIf Behringer has something that works, I'll use it, though I don't own any... I said it before: If it work, it works... be happy & use it. If it's frowned upon, but still works, don't let anybody around here know about it... lol
Post by maq3396 on Apr 5, 2017 19:51:27 GMT -6
Thanks for all the insight and comments...very useful! Having something that is supported and compatible long term is important so will likely go with an RME if I can find a good deal or one of the MOTUs (828x, 16A or 1248)
Cheers Mac
Post by Deleted on Apr 6, 2017 5:54:09 GMT -6
Just want to give another example for a setup that is going for console based work, that we use: Motu 24Ao + ADAT AD + monitoring DA The Motu feeds 24 console channels at an awesome pricepoint in very good quality. We use an older Mytek ADAT AD that is plugged into the Motu and a Ross Martin DAC that is also plugged into the Motu via SPDIF. The Motu goes into the PC via USB. Since you have quite a high budget to spent, you could think about that. The monitoring DAC was already there, one could easily get away to use 2 of the Motu outs instead, they have pretty good sound quality, and might add a dedicated DAC later, if needed. The high channel count for the console is what made this the go-to for our setup. The console was there, the task was to upgrade from single speed ADAT converters of older generation. Nowadays you can make great bargains with upper midclass consoles on the used market. Especially if you are able to service them by yourself. I got my console ridiculously cheap, it looked a bit wasted, but was perfectly fine with turning the pots and using the switches to make them work again (had been out of use a while) and cleaning the channelstrip modules. A small repair on the PSU, and voila, 30 modular channel desk for 200 Euros. Today there are a lot of good possibilities to make something good out of a budget like yours.
