Post by Johnkenn on Mar 16, 2017 16:19:38 GMT -6
How many of you guys prefer ldc's on acoustic guitars? Just wondering.
Post by Martin John Butler on Mar 16, 2017 16:37:01 GMT -6
I can be quite happy with the guitar sound the LDC gets me, but I use an SDC for acoustic guitars because I find they sit a little better in a mix. Also, I prefer not to have the same mic for vocals as acoustic guitar, so they don't push exactly the same frequencies. Maybe I'm being superstitious, but having two slightly different tones on a track works for me.
I'd be curious to know which mics were used on some of my favorite acoustic guitar tracks on some favorite records. What does Knopfler use, What did Tony Rice prefer, CSN&Y?
Jimmy Page used multiple mics, Lyle Lovette used a C24, (stereo C-12) on Road To Ensenada, Pete Townsend on Tommy? Hmm, this could get interesting..
Post by drsax on Mar 16, 2017 17:15:13 GMT -6
How many of you guys prefer ldc's on acoustic guitars? Just wondering. Stereo pair of LDC (Neumann TLM170's) here and it's the best Ac Gtr sounds I've achieved yet. Sounds like I'm in the room standing in front of the guitar.
Post by Johnkenn on Mar 16, 2017 17:33:28 GMT -6
How many of you guys prefer ldc's on acoustic guitars? Just wondering. Stereo pair of LDC (Neumann TLM170's) here and it's the best Ac Gtr sounds I've achieved yet. Sounds like I'm in the room standing in front of the guitar. That's definitely the goal
Post by ragan on Mar 16, 2017 17:35:38 GMT -6
I usually mic with an LDC and an SDC, lately it's the 67 at the neck body joint and the CM100 (omni-flat capsule) at about forehead height, pointing down, same plane of depth as the 67. Sometimes right in front of me, sometimes over my right shoulder.
Anyway, I use one or the other or both come mix time.
Post by Martin John Butler on Mar 16, 2017 17:59:42 GMT -6
Just beginning to research.. Knopfler's producer, Chuck Ainley says they use an SM 57 and a U67. I would've guessed a U67 myself, it doesn't get any bigger. The SM57 surprised me though.
Stephen Stills on "Suite Judy Blue Eyes"? U 67 again!
Post by ragan on Mar 16, 2017 18:04:12 GMT -6
Just beginning to research.. Knopfler's producer, Chuck Ainley says they use an SM 57 and a U67. I would've guessed a U67 myself, it doesn't get any bigger. The SM57 surprised me though. Stephen Stills on "Suite Judy Blue Eyes"? U 67 again! Don't be surprised! U67 and SM57 are some of the most popular guitar mics in history.
Post by jeremygillespie on Mar 16, 2017 20:56:24 GMT -6
I don't really have a go to setup for acoustic gtr. - so much depends on the application.
If it's more of a solo acoustic and vocal thing, it's a 67.
If it's a dense pop thing, an sm81 or 451 can really pop it through a clouded mix.
Flat picking is usually a km54.
I rarely will mic an acoustic stereo or with 2 mics. One time I did was for a Warren Haynes record I tracked - and got great results with a km84 at the body/neck joint and a Sony c37 behind the bridge. It didn't hurt that he is a total badass and could make a cardboard box sound fantastic. Also, we cut it all live and there was a mando player with a schoeps, a gtr/dobro/banjo player with a km54, and his vocal mic all going. The leakage was fantastic with those particular musicians and how they were arranged in the room.
Just wish I had mixed it...
Post by rocinante on Mar 16, 2017 21:17:57 GMT -6
I use an U87 often enough. Or with an oktava mk012 or just the Oktava. Sometimes an aa cm47. I plan on getting some more sdc's.
Post by Martin John Butler on Mar 16, 2017 21:18:45 GMT -6
Ragan said, "Don't be surprised! U67 and SM57 are some of the most popular guitar mics in history". I was surprised because I've always associated SM57's with miking guitar cabinets. I would've guessed they'd used a 67 and maybe a KM84.
Even when I have a pair of KM84's, I tend to use one, it's just so much easier than two, what with phase issues and then it gets tricky balancing levels. Maybe I'll try the LDC/SDC thing again, next time I'm tracking. I'm hoping to get to try the Soyuz 0-13 FET for just that purpose soon.
Every track I've ever posted here had the KM84 as the acoustic guitar mic, with maybe one exception.
Post by EmRR on Mar 17, 2017 7:28:52 GMT -6
Max's U67 clone is the first thing I've owned that I've really liked on acoustic, and it sounds consistently good there. I haven't liked Gefell UMT70S, AKG 414-ULS, Joly K47H unless they were the distant part of an array. I did really like a Lomo 19A19 I used at another studio. I usually go SDC omni close, and if there's stereo it's usually with distance in addition to mono close.
Post by jazznoise on Mar 17, 2017 8:41:01 GMT -6
If they're singing while playing, it's gotta be a dual diaphragm mic on Fig 8. just for the isolation. I'll put a regular cardioid on the vocal. It's sort of a compromise sonically, as I prefer omnis for mono guitar or else 2 cardioid SDC's at bridge and 12th fret. I'll compensate by trying to have a pair of nicely balanced room mics if it calls for it, close enough (delay to avoid comb filtering) just to fill out the picture and give some space.
Post by EmRR on Mar 17, 2017 8:54:18 GMT -6
If they're singing while playing, it's gotta be a dual diaphragm mic on Fig 8. just for the isolation. I'll put a regular cardioid on the vocal. I have found over many sessions that this approach demands additional vigilance, in that the artist will always move some, sit differently, reposition the chair, sit up higher, slump down lower, etc. If I don't check position for virtually every take, they will have moved and there will be at best no sonic continuity between takes, at worst some crazy phase interaction. Sounds good when it works.
Post by indiehouse on Mar 17, 2017 9:06:57 GMT -6
I've been tracking acoustic this week, MaxMod U67/KM84 -> Tabfunkenwerk V72s -> Zulu -> CAPI BT50 (litz wire & red dots) -> modded Ross Martin AD. Fantastic results. Tons of vibe. Ended up with mostly the MaxMod U67.
Post by Ward on Mar 17, 2017 9:16:27 GMT -6
Personally, I've never been displeased with a U87 (or U87 pair in Blumlein) centered at the neck/body join, just slightly above looking down. Running into a 1073 with a little EQ knocking out any low-mud woo sound at 250 to 350, and a touch of sparkle if necessary. Add some light 1176F compression, and done.
Post by ragan on Mar 17, 2017 9:19:20 GMT -6
Personally, I've never been displeased with a U87 (or U87 pair in Blumlein) centered at the neck/body join, just slightly above looking down. Running into a 1073 with a little EQ knocking out any low-mud woo sound at 250 to 350, and a touch of sparkle if necessary. And some light 1176F compression, and done. A classic. I use that position a lot too. Same everything except the 67 instead of 87.
Post by c0rtland on Mar 17, 2017 9:38:24 GMT -6
I like ldc on acoustics when the sound needs to be big. Sdc when it needs to be tight. That's generally how I approach ldc and sdc on anything.
Post by longscale on Mar 17, 2017 9:56:45 GMT -6
For the right song/artist/arrangement I really like what I get from a nice tube LDC on acoustic guitar. For solo guitar and voice - singer songwriter stuff I nearly always reach for a LDC for both. With a good room and a performer that can balance themselves well I like to use a single LDC. Otherwise I tend to use two LDCs each in figure 8; and I point the nulls where one normally would to get some isolation. I'm equally happy using the LDCs not in figure 8 however - I don't fret over the bleed if I'm getting the sound I want out of the mics.
I don't have access to something nice like a KM54 so I might change my mind on a LDC if I did.
For me a C12 style mic - or U47 LDC on acoustic is magic. I use a Lucas CS1 and a CS4 and I'm super happy with the results. Big, lush, smooth. Sounds like the real thing in a room, only better with magic pixy dust sprinkled all over. Super simple to get results - put the mic up and go.
Post by c0rtland on Mar 17, 2017 11:17:44 GMT -6
I've been tracking acoustic this week, MaxMod U67/KM84 -> Tabfunkenwerk V72s -> Zulu -> CAPI BT50 (litz wire & red dots) -> modded Ross Martin AD. Fantastic results. Tons of vibe. Ended up with mostly the MaxMod U67. That Zulu looks larger than I would have expected.
Post by indiehouse on Mar 17, 2017 11:26:40 GMT -6
I've been tracking acoustic this week, MaxMod U67/KM84 -> Tabfunkenwerk V72s -> Zulu -> CAPI BT50 (litz wire & red dots) -> modded Ross Martin AD. Fantastic results. Tons of vibe. Ended up with mostly the MaxMod U67. That Zulu looks larger than I would have expected. ...and it sounds better than I expected.
Post by ragan on Mar 17, 2017 11:35:01 GMT -6
It's a tank.
Post by Vincent R. on Mar 17, 2017 17:27:28 GMT -6
I've been tracking acoustic this week, MaxMod U67/KM84 -> Tabfunkenwerk V72s -> Zulu -> CAPI BT50 (litz wire & red dots) -> modded Ross Martin AD. Fantastic results. Tons of vibe. Ended up with mostly the MaxMod U67. Ooh. I have and MK U67 and a Tab F V78M. This may be a combo I need to try.
Post by mrholmes on Mar 17, 2017 19:27:02 GMT -6
Believe it or not the first LDC which I love on my Morgan Dreadnought-Vancouver is the cheap Samson MTK 201....
Post by jazznoise on Mar 17, 2017 21:30:20 GMT -6
If they're singing while playing, it's gotta be a dual diaphragm mic on Fig 8. just for the isolation. I'll put a regular cardioid on the vocal. I have found over many sessions that this approach demands additional vigilance, in that the artist will always move some, sit differently, reposition the chair, sit up higher, slump down lower, etc. If I don't check position for virtually every take, they will have moved and there will be at best no sonic continuity between takes, at worst some crazy phase interaction. Sounds good when it works. It's a nightmare. Half the time I do this I'm in the room with them on headphones so I don't have particularly good realtime monitoring. Despite stressing the importance of positioning it can change, even if seems like they didn't move (sturdy mic stands are a must for this gig). They're probably not leaving the chair without a good, solid take so I emphasize just going for it and disclaim being able to edit it as I'm not in control of their bodies - I might get away with it, I might not. Had a girl do this with me for a song, 12 string guitar split into an amp with some octave and dist FX for a psuedo organ sound and then the 12 string mic'd and her singing. We overdubbed some electric guitars (I played and she instructed me on the parts) and she was delighted, really loved it. However her label saw her as a "folk" artist and were appalled and basically bit her head off. She came back and stripped off the guitars and wanted to redo the vocal in parts. However some of the vocal bleed was in the pitch shifter on the amp, which wasn't noticeable with the vocal track on, but became obvious without it. Anyway - couldn't do it without it being horribly noticeable and she was very annoyed. The lesson for some might be "always make sure you leave yourself as many options as possible", for me it was "When a label or any other unwarranted opinion is involved, delay sending the mixes as much as possible until the artist is confident enough in their decisions to withstand the inevitable, useless criticism they receive".
Post by ChaseUTB on Mar 17, 2017 23:14:08 GMT -6
Stereo pair of LDC (Neumann TLM170's) here and it's the best Ac Gtr sounds I've achieved yet. Sounds like I'm in the room standing in front of the guitar. That's definitely the goal Have you used the Upton on Gtr?
