Post by nick8801 on Dec 1, 2016 14:02:18 GMT -6
Post by kilroyrock on Dec 1, 2016 14:40:38 GMT -6
rjr
New Member
Post by rjr on Dec 1, 2016 18:34:07 GMT -6
Of all the options to add to an 1176...a +6 metering option??? Really? I think an internal SC Filter would be a better use for that extra button.
Edit: I just looked at it again. Is there not a bypass function? No labeling on the attack knob, and no buttons for it either.
Post by kilroyrock on Dec 2, 2016 6:33:35 GMT -6
You bypass by half pressing a button so that they all pop out. Then it's on and in bypass. That's the same as my WA76. It's true, it doesn't say "fast" and "slow" but neither does the original, only the WA76 does. I am a fan of that jewel led though. I think that's probably the coolest "feature". and it costs about 6 cents. Everything else is standard and probably sounds just fine. You're just buying a behringer compressor, if you're okay with that
Post by Ward on Dec 2, 2016 7:30:54 GMT -6
You're just buying a behringer compressor, if you're okay with that Infraction alert!! This guy just used the "B word".
Post by guitfiddler on Dec 2, 2016 7:50:38 GMT -6
Marketing can be a beautiful thing for one's wallet.
Post by ericn on Dec 2, 2016 8:30:42 GMT -6
You're just buying a behringer compressor, if you're okay with that Infraction alert!! This guy just used the "B word". I have used that word mostly in vane, at least a 100 times! Like it or not they are getting as big as Harmon, I mean Samsung ( when will we see a Midas sound system in a Kia) ! Behringer! Behringer! Behringer! may you be cursed by a Compsser on the Stereo bus that only responds to the left channel BTW that's all composer, & part of why they were so fing cheap!
Post by Ward on Dec 2, 2016 8:56:43 GMT -6
A pox upon thy house, Nelson!!
Post by ericn on Dec 2, 2016 9:14:44 GMT -6
A pox upon thy house, Nelson!! Been there done that ! In fact a rack of Uhli's worst survived better than the house, we called that pox Ike!😪
